Телоподаващ апарат Einhell
  • От: Телоподаващ апарат Einhell
    Еми, дай пример за по-добра цена.
      Инверторно телеподавващо с цена около 1000лв.с ДДС може да се намери навсякъде...
      А aig доколкото си спомням рекламираше цена около 500-600 кинта!
        Къде конкретно. И с какви параметри?
          Ако плащането на данъци не е въпрос на патриотичен дълг.......
          Цената е 720 лева.
          А специално за тебе в цената ще ти влезе и редуцир вентил.
          Очаквам поръчка!
          АИГ-Заваряване ООД
          Заваръчни апарати "DEL"
          http://www.aigwelding.com
          0889 522 036
            Как ви изглежда миг със следните показатели:
            Introducing the new Wolf 140 Turbo Fan cooled Combination Gas/No Gas MIG Welder. With so many features, this smooth DC output welder offers both gas and no gas MIG welding, and is easily interchangeable between the two. With simple polarity changing (requiring no tools), makes this welder such a simple and quick way to convert this high performance MIG Welder! Supplied with all the accessories needed to start gas or no gas welding MIG welding, this new MIG welder with its non live torch is a pleasure to use.
            Incorporating 6 selectable power output settings, you can select the best setting for the job in hand, whilst the welding current range can be set from 30 amps to 135 amps. With fully variable wire speed control, you can adjust the wire speed to suit precisely the job in hand.. You’ll not fail to be impressed with the performance of this machine. If you’ve never had a DC output welder, you’ve never experienced just how straight forward obtaining good welding results can be. The inbuilt turbo fan cooling cool allows for extended welding duty cycles and with the transformer thermal overload protection circuitry.
            Technical Specification:
            • Turbo fan cooled
            • 30 amps-135 amps welding current range
            • 6 selectable power settings
            • Smooth DC output current
            • Non live torch
            • Weight: 32Kg
            • Fully portable
            • Operates from a 230V single phase supply
            GET ALL OF THIS
            • 1 x Mini spool of flux cored MIG wire
            • 1 x Mini spool of 0.8mm mild steel copper coated MIG wire
            • Spare MIG tips
            • 1 x spare torch shroud
            • 1 x 0.6mm / 0.8mm wire drive roller
            • 1 x Gas cylinder of CO2 gas
            • 1 x mini gas regulator
            • 1 x chipping hammer/wire brush
            • 1 x hand held face shield
            Това нещо се продава в ибей за 150GBР и би трябвало да може да пристигне в София за още 40.
            99,99999% е китайско.
              Това страшно много прилича на айнхел.
              Чист трансформатор.
              След като си го купиш, и се позабавляваш малко с него, ела да го дооправиме за да заработи читаво.
              Ще си поредния доволен клиент, макар и минал по трудния път.
              АИГ-Заваряване ООД
              0889 522 036
                Първоначално публикуван от aig Преглед на мнение
                Цената е 720 лева.
                Очаквам поръчка!
                Ще изчакам известно време, когато за 1000лв.ще могат да се купят две !!
                  Ще има да почакаш. Цените на всичко читаво китайско много скоро ще тръгнат нагоре, още от завода.
                    Добре, Ела и си купи 2 за 1000 лева !!!
                    Или гроздето е кисело май!?
                    АИГ-Заваряване ООД
                    0889 522 036
                      Колега aig дай малко снимки на машината
                      хах писали сме едновремено за 500лв го отнасям веднага но 720 са ми над бюджета освен ако не е напълно окомплектовано
                      с редуцил вентил и бутилка макар и малка
                      да мога само да си заредя газ и да почвам да бачкам
                      Последно редактирано от joromainata; 29-07-11, 08:31.
                        Тема: Телоподаващо за около 500 лв.възможно ли е ?
                        Ако почакате една седмица още, ще мога да ви предложа за тези пари инверторна машина.
                        Това беше обещано като оферта!
                          Там се говори за трансформатори!
                          Обещзно беше в отговор на това:
                          Купих от Англия ,чисто ново Кобел-200 ,за 260лири,фирмата която го докара взе 0.80-пи на килограм до София.Много съм доволен и работя вече около една година с него.
                          260 + 35*0.8 = 288 лири, с транспорта. Което по днешен курс е 640лв. Никъде не видях 500. И е 15% на 190А Ето:
                          От тук нататък всеки си преценява за себе си. Читаво истинско българско 200А трансформаторно телоподаващо тежи към 50 кила. Това горе - 35. Трансформатора иска метал в него.
                            Дори и така да е ... НО между 640лв. и 1000лв. има доста голяма разлика ! Не искам да бъда разбран неправилно или да си мислите че се заяждам ,но има една поговорка :"Казана дума-Хвърлен камък".
                              Разликата между 640 и 720 е 80лв!
                              А то иначе и между машините има мноооого голяма разлика...
                              Останалото не е моя работа. Не ги продавам аз. Просто трябва да сме коректни.
                              А по 500лв вървят примерно 200А електрожени. Няма как да сложиш телоподаващо+контролер+захранване за него + клапан + управлението му + шланг на евробукса, и цената пак да си остане 500лв. Тук само шланга ще ти продадат на половината от 500-те лв.
                              Както и да е. Надявам се изяснихме кое-що.
                                ДА! Само дето забравихме да сложим в сметката и ДДС-то на 720-те лв.
