Избор на фенер за ежедневно носене.
  • От: Избор на фенер за ежедневно носене.
    Ако трябва да се носи само 1 светлина винаги избирам да е челник.
    Челника се ползва и в ръката но фенера не може на главата - освен ако не го налапаш ама мен ми се повдига от големи неща
    VW Golf VI variant
      Аз нося това всеки ден.
      0885600006 - Чичо Коце
        За няма и десет долара спорът фенер или челник е решен от китайците:
        https://www.aliexpress.com/item/LED-Headlight-And-Flashlight-Double-Function-Cree-T6-Waterproof-2000LM-rechargeable-18650-Headlamps-3-Modes-Zoomable/32610837979.html?spm=2114.01010208.3.156.FSEVt7&s=p&ws_ab_test=searchweb0_0,searchweb201602_5_10000560_10000606_10000561_10000073_10000074_10000608_10000709_10000660_10000704_10000703_10000175_10000509_10000507_10000505_10000558_10136_10000068_10000552_10000369_10000063_10000365_10000367_10099_10000663_10000665_10096_10000669_10000569_10000097_10000094_10000337_10000723_10000090_10000147_10000091_10000726_10000144_10000339_10000729_10000150_10000679_10084_10000678_10083_10000676_10080_10000153_10000673_10082_10081_10110_10111_10112_10113_10000535_10114_10000534_10000089_10000086_10000710_10000083_10000349_10000690_10000135_10000716_10000080_10000693_10078_10000717_10079_10077_10000688_10073_10000684_10000140_10070_10122_10123_10126_10124_10000546_10065_10068_10000746_10000782_10000743_10000132_10000033_10000786_10000030_10000026_10000126_10000023_10000129_433_10000123_10000696_10060_10062_10000699_10056_10055_10054_10000632_302_10059_10000738_10000120_10000774_10000734_10000020_10000778_10000013_10000117_10103_10102_10000016_10000114_10000111_10052_10053_10107_10050_10106_10051_10000621_10000384_10000763_10000629_10000766_10000101_10000100_10000576_10000770_10000579_10000104_10000045_10000578_10000375_10000108_10000377_10000758_10037_10000612_10000390_10000613_10032_10000042_10000750_10000592_10000754_10000594_10000039_10000587_10000036_10000389_10000187,searchweb201603_15,afswitch_1,ppcSwitch_5,single_sort_0_default&btsid=fe5524ba-b617-4c14-bcdc-a46da4eb2703&algo_expid=4b15c374-9ce6-4bca-b78d-a93f74e2b93d-19&algo_pvid=4b15c374-9ce6-4bca-b78d-a93f74e2b93d
          Първоначално публикуван от sl.daskalov Преглед на мнение
          Ако ми трябва да си светя в краката челника върши работа. За по далечно, по широко и по точно (прецизно) осветяване си трябва фенер. Да не говорим как бих търчал из гори и поля с опасана с ластици тиква когато заради потта и мръсотията дори собственната ми коса се явява дразнител! Да не говорим и че не бих искал да имам светещ маркер на главата който автоматически я превръща в мишена! Пък как се прибира челник с всичките му висящи ластици в джоб, в който има още няколко неща и как се вади бързо при нужда без да измъкнеш омотано в ластиците още нещо, което да падне и да загубиш из тревата! Абе мани, имал съм и челници, и все се каня да си купя пак, но фенера си е фенер и не го заменя ни челник, а за телефон пък изобщо да не говориме че е глупост голяма!
          Ебре! 40км. съм тичал с челник и да ти кажа не го мислиш ама грам. Не го усещаш, въпреки че си целия потен. Явно не си тичал достатъчно, за да е ясно че тичане и държане на фенер са леко несъвместими неща. Последният път бягах така и беше голям проблем.
          Lupine и Silva, за да не бъда празнословен, са челници които са направени конкретно за това.
          Отделно, че не виждам смисъл от уред, който свети по 1203109289048 Lm. Ако си на лодка сигурно има смисъл, но дали има повече от 2 човека дето да са на лодка ED.
            Първоначално публикуван от Savov Преглед на мнение
            https://www.aliexpress.com/item/LED-...d-a93f74e2b93d
            ...и нито фенера нито челника стават за нещо.
              Спарки, моят Макита стана голям звяр. Скоро ще дам инфо и снимки в темата.
                Първоначално публикуван от Вико Преглед на мнение
                Това че ти не виждаш не значи че други не виждат. Отделно дето тия с повечето лумени като ги пуснаш на по-малко обикновено са по-ефективни от нисколуменните им събратя за върху тиква. Понякога ти трябва и да метне надалече, а това с малко лумени не става. За светене в краката безспорно и 200 лумена са предостатъчни, ама фенера ми ще ги дава примерно 15 часа, а нормален челник примерно 2.
                  Прав си. Колкото повече, толкова повече, уж...
                  Колко грама тежи фенера за глава?
                    Ако въпроса е към мен - фенера ми тежи 120 грама без батерията. Горе дадох линкче. Не става за глава, но става за EDC в чанта или на колан.
                    EDC-то на жена ми тежи малко по-малко, а нейното наистина е EDC, щото постоянно и е в чантата, която постоянно мъкне. Заема и по-малко място от челник + ремъците му, зарежда се през USB, по спомен е 900 лумена. Като размер е нещо като средностатистическа пура.
                      Тези 900 лумена до къде ще метнат. Питам, защото имам един германски китаец със стар модел диод с 225, но на 300 метра те прихващам. Чудно ми е, защото рекламират много лумени, а де факто фенера свети на 30-40 метра.
                        До къде ще метнат зависи както от лумените, така и от оптиката. Стария ми фенер с тесен сноп, при поизхабена батерия (тоест около 500-600 към момента на гледане), съвсем уверено хвърля на над 500, мерено по карта, без много да се старая да ми свикват очите. Мерено на Синеморец, светейки от "средния" южен нос до северния плаж, светейки към чадърите на плажа - различаваха се и чадърите, и други подробности.
                        От тая точка светех:
                        Виждаше се поне до тук:
                        Новия ми в режим 1600 лумена мята поне на 300 (като казвам мята, разбирам да виждам уверено пердетата зад прозорците на осветен от разстояние блок например), но лъча му е сигурно 5 пъти по-широк, а допълнителен бонус е топлата цветна температура - 4000К.
                          Колегата оня ден си взе челник,и още първата вечер го перна на челото,след два часа като го свали на челото му остана едно голямо Н ,пукнах го от бъзик,това H на латиница ли е или на кирилица,демек Х*Й , или да не забравя каква марка кола да търси на паркинга Honda ,каза че и на сутринта си е личало.
                          Анатолий Пейчинов o8875о9815
                          https://dvrbg.com/
                            От главата ще да е, не от челника.
                              То всичко ни е от главата.
                                Мисля имаше едни Zebralight дето ставаха и за фенер и за челник. За EDC ползвам фенера на телефoна. Достатъчен е за моите нужди. За друго, в зависимост от лучая, ползвам това http://www.ledlenserusa.com/p14-2-356.html#start=19 или това https://www.petzl.com/INT/en/Sport/A...O#.WL6BhDuGM2w
