CRF mania (само за пристрастени)
Това е залепена тема.
  • До: CRF mania (само за пристрастени)
    Първоначално публикуван от Петър Манолев Преглед на мнение
    "The Honda CRF250R is the ultimate 250cc, four-stroke, motocross bike. And for 2005, our engineers upgraded it everywhere, increasing power and suspension — while making it even lighter! "
    General information
    Model: Honda CRF 250 R
    Year: 2005
    Category: Cross / motocross
    Rating: 74.2 out of 100. Show full rating and compare with other bikes
    Engine and transmission
    Displacement: 249.00 ccm (15.19 cubic inches)
    Engine type: Single cylinder
    Stroke: 4
    Compression: 12.5:1
    Bore x stroke: 78.0 x 52.2 mm (3.1 x 2.1 inches)
    Fuel system: Carburettor. Keihin 37mm flat-slide with throttle position sensor (TPS)
    Cooling system: Liquid
    Gearbox: 5-speed
    Transmission type
    final drive: Chain
    Ignition: CD with electronic advance
    Physical measures
    Dry weight: 92.5 kg (204.0 pounds)
    Seat height: 965 mm (38.0 inches) If adjustable, lowest setting.
    Wheelbase: 1,478 mm (58.2 inches)
    Ground clearance: 361 mm (14.2 inches)
    Chassis and dimensions
    Rake (fork angle): 27.5°
    Trail: 123 mm (4.8 inches)
    Front suspension: 47mm inverted Showa cartridge fork with 16-position rebound- and 16-position compression-damping adjustability
    Front suspension travel: 315 mm (12.4 inches)
    Rear suspension: Pro-Link Showa single shock with spring-preload, 17-position rebound-damping adjustability, and compression-damping adjustment separated into low speed (13 positions) and high-speed (3.5 turns
    Rear suspension travel: 315 mm (12.4 inches)
    Front tyre dimensions: 80/70-21
    Rear tyre dimensions: 100/90-19
    Front brakes: Single disc. 2-piston calipers
    Front brakes diameter: 240 mm (9.4 inches)
    Rear brakes: Single disc
    Rear brakes diameter: 240 mm (9.4 inches)
    Speed and acceleration
    Other specifications
    Fuel capacity: 7.57 litres (2.00 gallons)
    Color options: Red
    Comments: Model ID: CRF250R
    Само заради това - "Dry weight: 92.5 kg (204.0 pounds)" бих предпочел това пред ендурото! 43 коня, 92 кила...Добре е, нали?
    Интересуваме дали клапаните са толкова калпави както при 450-ките. Понеже слабото място на 450 е клапаните дали и 250-ките имат този проблем?
      Първоначално публикуван от Georgi Vasilev Преглед на мнение
      Кой модел R или Х...и коя година. В първите години има малък проблем с R моделите но на по късен етап от 2005 насам откакто се произвежда и Х модела, този проблем е минало. Има случай и то не малко когато в щатите е карано с Х по 10 000 мили без проблем, тоест 16 000км.
      Със самия проблем според мен малко се спекулира и преекспонира така, че извода си е твой.
      Няма да получиш еднозначен отговор никога.
        Първоначално публикуван от Chinela Преглед на мнение
        Благодаря за бързия отговор. Аз лично се интересувам от R-модела и по точно след коя година проблема с клапаните отпада( до колкото може да отпадне за спортен мотор), ако някои има познания по вапроса да сподели.
          2005
            Проблемът с клапаните не отпада, понеже при всички положения трябва да са ти сменени ако не е почти нов мотора.
            Какво ти пука че си взимаш примерно 2006та мотор с вече новите клапани, при положение че вече са на 2 сезона. Ако не е нов мотора, клапаните са за преглед/смяна.
            Издъних се на Тюринг теста
              Пичове, всичко е точно. Машините са си идеални. Проблемът е, че много от хората, които си купуват изцеден 4т, та даже и 2т, не знаят какво си купуват, не знаят какво да очакват и най-лошото не знаят как да го обслужват. После идва един момент, в който с учудване разбират, че трябва 4 цифрена сума за обслужване(това да смениш клапани на 4т крос не е ремонт, това е козметика).
              Това е пичове. Моторите са перфектни. За това което дават тея машини даже са си много, ама МНОГО здрави, бъдете сигурни
              Всяка жаба трябва да си знае гьола
              Последно редактирано от iva_kx; 24-03-08, 17:55.
                Първоначално публикуван от Жоро XR 600 Преглед на мнение
                Много съм съгласен с теб Жоро, на тези обороти такова двигателченце и такава сила няма как да е друго яче, материалите на земята засега са тези.
                И в кръга на шегата, какъв е извода .... ами карайте 2Т
                  ..проблема с клапаните не може така да отпадне ..щото и новите модели ..пак са с клапани..може да отпадне..когато няма клапани..т.е..дето вика краси-карайте си 2 тетата
                    С моите скромни познания да споделя обаче, че поне клапаните на ЦРФ са много по ефтини от тези на Ямаха...
                    Bling bling, money ain't a thing :)
                      Аз нали сега с тях се боря точно: ето за стоманените как седи положението:
                      или
                      Иначе в хонда целия комплект - всумактелни и изпускателни , заедно с пружини, водачи, гумички и т.н. са към 600 лв. но са титаниеви. В оригиналната книжка си описват как се стърже главата ако са изстрадали леглата, иначе нова е 1070 лв.
                        не че не я знам тази информация за цените ама направо е плашещо цялото нещо, да не говорим че след това трябва да отиде на майстор, още време нерви и пари, не не мерси, ще си карам 2Т-то колкото и да ми се иска да имам 4Т мотор
                          Мда, колега продават направо преработени глави, http://www.ronhamp.com/default.aspx . Доколкото съм чел, тези господа поставят летвата. Успех!
                            Клапаните на ямахата са по-скъпи и са пет на брой вместо четири, което оскъпява подмяната допълнително.
                            За сметка на това са по-леки, поради което се износват много по-бавно. Което пък определя много по-редки смени. Номерът е да не се падне на теб да ги сменяш. Някой нещо спомена ли за "купи си го нов и го шитни на края на сезона" ?
                              В ранните години на новия век Хонда обявявява:
                              "До всички съзтезателни отбори по мотокрос и заможни любители. Гениалният японски прозиводител представя начина да разцепвате всички ваши неориентирани конкуренти:" та-дааа CRF 450 R
                              - Брей , брей , красавец, много върви....ще вземем 3...5 , за нас 10
                              Междувременно във фабриката:
                              - Инж. Късами Пишонака, отново прегледахме документацията, новият мотор дава страхотни показатели, продажбите вървят. Има само един проблем: г-н Якошиба Клапанага явно е препил със саке и е оплескал сметките за сплавите на клапаните. При натоварване от 80 часа те се набиват в главата и явно трябва да се подменят. Какво ще наредите?
                              - Хм. Колко съм сърдит. Какъв срам за нашата компания. Сега ще се обадя лично на г-н Хонда. Клапанага да си приготвя меча...
                              пиб пиб пиб муши - муши . дъра-бъра на японски...
                              - Да г-н Хонда, слушам. - Да се яви г-н Клапанага веднага при мен...
                              - Г-н Клапанага, по нареждане на всевишния г-н Хонда ви награждавам за изключителната дълновидност и принос за постигането на безпрецедентни по размер приходи от продажби на части за поддръжка с нов пост като главен инжинер на отдела за съединители и с ордена "Дагодуха Купувача" 1-ва степен. Ако продължавате да показвате такива резултати, скоро можете да се издигнете до шеф на направлението за разработки на мотокрос машини.... Сипете си още, преди да се върнете на работа.
                                Първоначално публикуван от iassen Преглед на мнение
                                ..... При натоварване от 80 часа те се набиват в главата и явно трябва да се подменят. .......
                                Имам само един въпрос, клапаните който си свалил в момента титаниеви ли бяха.. и ако....то както вече ти писах, за 5 годишен мотор по 16моточаса на година е добре...нали..
