KTM 350 EXC-F Six Days 2012
  • #46
    От: KTM 350 EXC-F Six Days 2012
    Съжалявам, че е на английски, но ще изнудя Тануцо да го преведе.
    2012 KTM 350 XC-F Six Days
    Not available in the US
    The 350 EXC-F is "ready to race " for the world's largest enduro competition, the "International Six Days Enduro". Six days in succession, over a thousand offroad kilometres, 40 hours in the saddle - a gruelling test, not only for the rider. A whole package of high-quality special options makes the 350 EXC-F fit for this ruthless contest, in which more than half the starters bank on KTM every year. 350 EXC-F Six Days - the genuine article with the orange powder-coated frame of the KTM Factory Team.
    ENGINE
    The new 350 EXC-F's compact, state-of-the-art four-stroke engine excels with an extremely wide usable rev range and the performance of an engine with much greater displacement. A laterally positioned balancer shaft, which acts as the drive for both timing chain and water pump, eliminates the vibration typical of this model type.
    VALVE TRAIN
    In the cylinder head with two overhead camshafts, four titanium valves are actuated by extremely lightweight, carbon-coated cam levers. This elaborate valve train, the ultra-light pistons and the new 350 EXC-F's extremely short-stroke engine facilitate speeds of up to 13,000 1/min.
    BALANCER SHAFT
    The balancer shaft with Wolfram weights not only eliminates vibration, but also acts as an intermediate shaft for the valve train and as the drive for the water pump. This intelligent multi-functionality makes a key contribution to the compactness and low weight of the new 350 EXC-F's engine.
    CRANKSHAFT
    When designing the crankshaft on the new 350 EXC-F, KTM engineers focussed on a reduction in the reciprocating weight and fine adjustment of the rotating masses. In this way, they managed to combine minimum vibration with an outstanding free-revving nature and optimum traction.
    LUBRICATION SYSTEM
    The new 350 EXC-F's engine is equipped with two oil pumps. A pressure pump lubricates the engine and clutch and cools the ignition, while a suction pump draws oil from the crankcase, using it to lubricate the transmission. At the same time, negative pressure arises in the casing, which provides an additional boost to engine power.
    EMS
    The Keihin engine management system with electronic fuel injection ensures spontaneous responsiveness and maximum performance from the engine. Various engine characteristics can be activated with an optional map select switch.
    CLUTCH
    The 350 EXC-F's newly developed clutch, with a robust steel cage and transmission-friendly back-damping, makes use of a spring washer for the first time instead of the customary conical springs, hence substantially reducing the operating force. The hydraulic actuation mechanism from Brembo® facilitates sensitive modulation of the clutch.
    TRANSMISSION
    The six-gear transmission on the new 350 EXC-F has been designed especially to match the characteristics of the 350cc engine and meet the demands of enduro sport, excelling with its precise and easy shifting.
    SILENCER
    The new 350 EXC-F's silencer featuring a special Six Days coating, reduces noise levels to the stricter standards of the future with its large volume.
    ELECTRIC STARTER
    The new 350 EXC-F is equipped with both a kickstarter and an electric starter. The drive for the electric starter is integrated into the generator cover instead of the engine case, so the bike can be converted into a pure kickstarter simply by replacing the generator cover.
    BODYWORK
    The new 350 EXC-F's bodywork with the very slim seat and spoiler lines, plus excellent contact points, perfects the bike's ergonomics, making handling even simpler and more precise. The long rear fender protects the rider very effectively from swirled up stones.
    FRAME
    The new 350 EXC-F's lightweight frame made from high-quality chrome-molybdenum steel is distinguished by an extremely high level of lateral stiffness. It is also excellent at absorbing jolts introduced by the suspension system, whereby the playful handling and comfort of the 350 EXC-F have been further optimised.
    SWINGARM, PDS
    The new 350 EXC-F's lightweight cast aluminium swingarm accommodates the WP shock absorber almost centrally, in order to load the swing arms more evenly. The PDS shock absorber with adjustable rebound and high/low-speed compression damping works with high progression, in spite of the direct linking.
    TELESCOPIC FORK
    The new 350 EXC-F is equipped with the latest WP upside-down fork with wide adjustment ranges. The sensitive responsiveness and outstanding damping of the open-cartridge fork with 48 mm outer tubes are a perfect complement for the 350 EXC-F's playful handling and precision.
    WHEELS
    Practically unbeatable in terms of weight and stability, the new wheels have CNC-machined hubs, new black-anodised rims from Giant, black zinc/nickel-coated spokes and ultra-light aluminium nipples. They reduce the unsprung and gyroscopic masses, hence boosting the playful handling of the new 350 EXC-F.
    SIX DAYS EQUIPMENT
    • Map select switch on the handlebars for selecting different engine management mappings
    • Camel SXS seat for improved long-distance comfort
    • Engine guard made of high-strength plastic for protecting engine case and frame down tubes
    • Radiator fan for optimising temperature control under extreme loads
    • CNC-machined, orange-anodised triple clamps for high-precision clamping of the fork tubes in favour of optimum sliding of the telescopic fork
    • Knock-out wheel spindle for easier removal of the front wheel
    • Full brake disc at the rear for improved heat resistance and therefore reduced pad wear
    • Rear brake disc protector for protecting the brake disc from mechanical damage
    • Quick-change brake pad securing bolts at the rear for quicker changing of brake pads without tools
    • Aluminium rear sprocket with riveted-on steel ring gear for a combination of reduced weight and increased durability
    • Wheels with black-anodised, extremely robust Giant rims and spokes with a high-quality, black tin-nickel coating
    • The same design as the KTM factory bikes thanks to Six Days graphics, orange powder-coated frame, orange anodised triple clamps, orange anodised handlebars and anthracite anodised silencer
    • #47
      Лесно ще ме изнудиш, но ще имам време утре вечер или събота вечерта и ще го преведа
      Per aspera ad astra.
      • #48
        Да улесня колегата, доколкото успях.
        Не се предлага за САЩ
        350 EXC-F е "готов да се състезава" за най-голямото ендуро състезание в света, "международното шестдневно Ендуро". Шест поредни дни, над хиляда километра офроуд, 40 часа на седалката - изтощителен тест не само за водача. Целия пакет от висококачествени специални опции прави 350 EXC-F годен за този безмилостен конкурс, в който повече от половината от участващите са на KTM всяка година. 350 EXC-F Six Days - истински артикул с оранжево прахово покрита рамка на KTM Factory Team.
        ДВИГАТЕЛ
        Новият 350 EXC-F е компактен, състоянието на най-съвременният четири-тактов двигател се отличава с изключително широк използваем оборотен диапазон и изпълнение на двигател с много по-голяма денивелация. Странично разположен балансиращ вал, към чиято верига е зацепена и водната помпа, елиминира вибрациите, характерни за този модел тип.
        КЛАПАНИ
        В главата на цилиндъра с два горноразположени разпределителни вала, четири титанови клапани се задействат от изключително леки, покрити с въглерод лостове. С тази сложна клапанна систена ,ултра-леки бутала и изключително къс ход новия 350 EXC-F двигател лесно вдига до 13000 об/мин.
        БАЛАНСИРАЩ ВАЛ
        Лек балансиращ вал с Wolfram не само елиминира вибрациите, но също така действа като междинен вал към разпределителния вал и за задвижване на водната помпа. Тази интелигентна функционалност прави ключов принос за компактност и ниско тегло на новия 350 EXC-F двигател.
        КОЛЯНОВ ВАЛ
        При проектирането на коляновия вал на новия 350 EXC-F, KTM инженерите са фокусирали върху намаляване на буталното тегло и фина настройка на въртящите се маси. По този начин, те са успели да комбинират минимум вибрации с изключително свободно форсиране и оптимално сцепление.
        МАЗИТЕЛНА СИСТЕМА
        Новият 350 EXC-F двигател е оборудван с две маслени помпи. Помпата за налягане смазва двигателя и съединителя и охлажда запалителната система, докато всмукателна помпа извлича масло от картера и го използва за смазване на трансмисията. В същото време възниква, отрицателно налягане в корпуса, което осигурява допълнителен тласък с мощността на двигателя.
        EMS
        Система Keihin за управление на двигателя с електронно впръскване на горивото осигурява спонтанна реакция и максимална производителност от двигателя. Различни режими на двигателя могат да бъдат активирани с карта . ОПЦИЯ.
        СЪЕДИНИТЕЛ
        350 EXC-F е с новоразработен съединител, със здрава стоманена клетка и плавно предаване на движението. Хидравличен механизъм за задействане от Brembo ® улеснява чувствително модулация на съединителя.
        ПРЕДАВАНЕ
        Шест-степенна трансмисия на новия 350 EXC-F е проектирана специално да съответства на характеристиките на 350cc двигател и отговаря на изискванията на ендуро спорта, превъзхожда с прецизното и лесно превключване.
        ЗАГЛУШИТЕЛ
        Новият 350 EXC-F заглушител със специална Six Days обшивка, намалява нивата на шума при по-строгите стандарти на бъдещето с големия си обем.
        ЕЛЕКТРИЧЕСКИ СТАРТЕР
        Новият 350 EXC-F е снабден с кикстартер и електрически стартер. Електрическият стартер е интегриран в капака на генератора, вместо в кутията на двигателя, така че лесно може да се използва кикстартера като се махне капака на генератора.
        КАРОСЕРИЯ
        Новата 350 EXC-F каросерия с много тънка седалка, плюс отлични точки за контакт. Усъвършенства ергономичността на мотоциклета, улеснява ездата. Дългата задна броня предпазва ездача много ефективно от камъни.
        РАМКА
        Новата 350 EXC-F лека рамка е направена от висококачествена хром-молибден стомана. Отличава се с изключително висока степен на твърдост при странично натоварване. Също така отлично абсорбира сътресенията, внасяни от окачването, което осигурява комфорта на 350 EXC-F.
        Люлеещо рамо, PDS
        Новият 350 EXC-F лек шарнир от лят алуминий побира WP амортисьор почти централно, за да движи люлката по-равномерно. PDS амортисьор с регулируемо отскачане и висока / ниска скорост на компресия са произведени с висока прогресия, независимо от директно свързване.
        ТЕЛЕСКОПИЧНА ВИЛКА
        Новият 350 EXC-F е оборудван с най-новите WP с обърнати надолу стержъни с широк диапазони на работа. 48 милиметровата вилка е идеалното допълнение за игриво боравене с 350 EXC-F и прецизност.
        КОЛЕЛА
        Практически ненадминат по отношение на тегло и стабилност, нови джанти, CNC-хъбове, нови черно-анодирани джанти от титан, черен цинк / никел покрити спици и ултра-леки алуминиеви нипли. Те олекотяват окачването и жироскопичните маси.
        ”SIX DAYS” ОБОРУДВАНЕ
        Превключвател на кормилото за избиране на различни за режими за управление на двигателя .
        Camel SXS седалка за подобряване на комфорта на дълги разстояния .
        Гардове, направени от пластмаса с висока якост за защита на двигателя и рамата отдолу.
        Вентилатор на радиатора за оптимизиране на контрола на температурата при екстремни натоварвания.
        CNC , оранжево-анодирани тройни скоби за висока точност за оптимално захващане и регулиране на телескопична вилка
        Knock-Out ос за по-лесно отстраняване на предното колело.
        Цял спирачния диск в задната част за по-добра устойчивост на топлина и следователно намалява износването накладките.
        Задна защита на спирачния диск от механични повреди.
        Болтове в задната част за по-бърза смяна на накладки, без инструменти.
        Алуминиев пиньон със занитен стоманен пръстен за намалено тегло и повишена издръжливост
        Колела черено анодирани, изключително здрави титаниеви джанти и спици с високо качество, с черно калаено- никелово покритие.
        В същия дизайн като фабричните KTM мотори благодарение на Six Days графики, оранжево прахово покрита рамка, оранжево анодирани тройни скоби, оранжево анодирано кормило и антрацитно анодиран заглушител.
        Диян Димитров
        • #49
          Ще помоля някой колега който има такива повдигачи за КТМ, да бъде така любезен и да ми даде следните размери.
          Последно редактирано от Chinela; 03-11-11, 20:49.
          • #50
            Първоначално публикуван от Chinela Преглед на мнение
            Да беше по близко да ти ги подаря останаха ми от Берга.Утре ще ги премеря и ще ти дам размерите.даже и болтове имам не са като нормалните с по плитка глава са.
            Живейте и вярвайте в това в което не вярвате. Обичам природата и нейните красоти.
            0887 543 312 ,Land Rover Discovery 300 Tdi, КЛИМАУТО АВТО КЛИМАТИЦИ И ДИАГНОСТИКА.
            • #51
              Хайде и аз чакам, че също се каня от 1 година са си правя такива
              • #52
                Станахме 3ма, въпреки че и по горния трипътник може да се измерят размерите. И аз искам да сменя мойте с такива. Този модел и той не е лош:
                В единия отвор влиза оригиналния къс болт и се притяга към трипътника, а през другия отвор минава болта който притяга държачите на кормилото.
                Иван Маринов
                Suzuki RMX 250 '92 - sold / Yamaha XTZ 750 Super Tenere '91 - sold / KTM EXC 250 2t '06 - sold
                ЕНДУРО ВАРНА
                • #53
                  Ванка виж как е при мен.
                  МОТОРА ТРЯБВА ТИ ДА ГО КАРАШ А НЕ ТОЙ ТЕБ 0888984256
                  • #54
                    Да, погледнах го, даже се чудех дали не е бил с такива държачи твоя мотор.
                    Ама ние сме си за другата тема с цвайките.
                    Иван Маринов
                    ЕНДУРО ВАРНА
                    • #55
                      Прелестен... Честит да е
                      • #56
                        Ето ги и новите заглушители от MIVV показани на фиерата в Милано.За нашият "сикс дейс" е моделът Stronger,който е издръжлив при екстремно ендуро,произведен от титан и карбон с цена от 740 евро.С най-модерните шумозаглушителни системи,моделът е лицензиран и за движение в градски условия,покривайки всички европейски нормативи.
                        Инфо: Motoblog.it
                        Beta 450 RR-Factory
                        0039 3206052599
                        • #57
                          Целия комплект ли е 740€ или само задното гърне. Ако е фул - цената е добра.
                          Mitsubishi L200 DobbleCab
                          KTM XC 450 RW 2009
                          KTM 350 SX 2011
                          • #58
                            Този разход, за този мотор, е напълно безсмислен!
                            Сток ауспуха е "откраднат" от Акрапович, отпушваш го и вола.
                            И на двете си хонди съм купувал ауспуси от щатите, но тук случаят е друг.
                            Въпреки всичко, засега палмата на първенството за най-добър ауспух за ТОЗИ мотор, е на FMF.
                            FMF-a е дал най-добри показатели, дори по-добри от Акрапович, поне така казват "злите езици".
                            • #59
                              Абе ауспуха да ни е проблема, особено в тия камънаци дето караме и мятаме като за световно.
                              Пък и нали знаеш че разликата между акрапович и фмф може и про да не я усети.
                              А и на списания вяра да нямаш. От 2 седмици чета разни ревюта за фотоапарати и на всеки сайт различно пишат. На единия самсунга на другия канона на третия фуджито, върви че вярвай. Не го ли хванеш и разцъкаш всичко друго е вятър работа.
                              • #60
                                Ауспуха е суета. Съвременните крос и ендуро машини излизат с много добри оригинални ауспуси, които след леко отпушване имат и глас и вървеж.
                                А за някакви дребни разлики от показателите по кривата не ми се коментира.
                                Като че ли най-големият им проблем остава силното нагряване дори и добре отпушен, докато един тунингов отдава много по-малко топлина.
                                Обаче си е друго да си погледнеш мотора с тунинг гърне, някакси гали окото. Просто изкушение.
