Реалните цени на ЛР в Европа и доставката до БГ
    До: Какви са реалните цени на Ленд Ровър в Европа
    Диско 1 200ТДи, цена 1600 лири
    K reg, 200tdi 3dr. mileage is on about 135k, but i know that when i bought it 2 yrs ago it had been fitted with a much lower mileage engine, however, i have no proof of this, apart from how it drives..... the gearbox had also been replaced aswell.
    Tax & mot'd until Dec 09.
    The truck is fitted with what i believe is a 2 inch britpart lift kit, along with re-location cones front and rear, and procomp shocks, it's polybushed apart from the shocks.
    Tubular winch bumper, (no winch) tubular rear bumper with recovery points, front steering guard, and rock sliders.
    8 spoke weller wheels, with 235 85 16 Insa Turbo Sahara rubber, quite worn, and quite cut up, but not illegal by any means.
    The rear seats have been thrown away, and the rear of the truck has been boxed in to provide a flat load area, with storage for waffle boards, spare wheel, and hi-lift, (waffles and hi-lift not included in the sale) it also has four flip up lids on the sides for storage of all those goodies we need when we go offroad, spare fluids, strops/winching gear etc......
    The cooling system is fitted with two electric fans, the original fan has been removed, the 2 fans are controled by an X switch, with 2 temp settings, the fans can also be over-riden or switched off from inside the truck for wading purposes.
    A Safari snorkel and extended breathers have allowed several deep water crossing to have been made, as such, the carpets have been trimmed right back so that if (or when) water comes in the heater vents drying it out again isn't too much of an issue.
    A Midland CB is also installed.
    This vehicle has been 100%reliable in the 2 yrs plus that i've had it, i have changed the oil regularly and have replaced wheel bearing when needed, etc, almost every panel has some sort of damage, as you can see the arches have been cut out, and Roccia ABS arches added. oh, and the black bonnet chequer plate.
    This is not a shiney 4x4, it's most definately an offroader, and as such has and does perform extremely well.
    Any questions ...please ask!!
    Would like 1600 for it as is, will be going on ebay with a buy it now slightly above that in a few days.....
    I'm in Mid Dorset...
    Последно редактирано от Lazar; 25-11-08, 13:48. Причина: снимки с изтекъл срок на годност
      В колко часа е самолета за ЛОНДОН
      Последно редактирано от Lazar; 17-10-08, 08:26. Причина: цензурчица
        Има, имаааа, ама търсене му е майката, а бащата е пътуване до там - вижте: http://www.marktplaats.nl/
        Ето пример:
        Land Rover Defender 2.0 TDS 110 Commercial (bj 1991)
        Meer foto's
        Kilometerstand: 162.834 km
        Carrosserie: Terreinwagen (5 deurs)
        Brandstof: Diesel
        Bouwjaar: 1991
        Transmissie: Handgeschakeld (5 versnellingen)
        Kleur: Groen
        Aantal cilinders: 4
        Vermogen: 63 kW (86 PK)
        Meer foto's
        Prijs:
        Land Rover Defender 90 Turbo Diesel
        Advertentienr.:200943402 Terug | Auto's
        > Land Rover
        Home Vorige | Volgende
        Grotere afbeelding
        Prijs:Land Rover 90 Hardtop
        Advertentienr.:191562663 Terug | Auto's
        > Land Rover
        Meer foto's
        Prijs:Datum:05-09-08 08:57 Gezien:1005 keer Pokerkampioenvannederland.nl
        Deze auto kopen?
        Contact informatie
        Naam: Woonplaats: Hoofddorp, Noord-Holland Bekijk alle advertenties van adverteerder
        Beschrijving Kaart Verzekering
        Model: Defender Bouwjaar: tot en met 1994 Brandstof: Diesel Kilometerstand: boven 150.000 km
        Последно редактирано от ivied; 17-10-08, 09:13. Причина: снимки
          Ето и за Диското:
          Discovery 2.5 tdi '96 7 pers. apk veel nieuw 2 schuifdaken
          Advertentienr.:200598166 Terug | Auto's
          > Land Rover
          Meer foto's
          Prijs:
            Първоначално публикуван от Lazar Преглед на мнение
            Дифендър 90, 200Тди, 1991г
            цена 1600лири
            1991 'G' reg lr90. 200 TDi 99,500 miles have had no problems with engine/ gearboxLoads of extras. Have dog cage and has towbar.5 BFG MT's that have only done 200-300 miles (spare has done 0miles)couple of bits need doing such as cracked windscreen on passenger side and the rear drum pads need changing but other than that its fine.asking 1600 to get her sold.
            Мда, тоя е малко поочукан
            колко ще излезе тази с докарването /ако предлагаш такава услуга/?
              Ааа, не! Не се занимавам с търговия на автомобили! Офертите са дадени само за пример, колко са "скъпи" ЛР в Англия.
              Иначе, за себе си лично, бих внесъл едно Диско като онова червеното, НО за части.
                От личен опит с мойта Тойота мога да ти кажа приблизително 1500лв излизат разходите по докарването ако сам отидеш. +/- 200лв защото билетите за самолет и ферибот варират според сезона.
                Там трябва английски за да се оправят документи застраховки и т.н. - има тема за внос на коли от UK. Поне 4 дни трябва да отделиш за операцията и то ако отваш директно да купиш определена кола а не да обикаляш и търсиш.
                Поразпитай за автовози. Targa може да ти помогне ако също е търсил такива оферти.
                [COLOR=blue][COLOR=#000000][FONT=Times New Roman][FONT=Arial Black]When you see DEATH staring in your eyes and you feel her cold breath on your face, don’t slam on the brakes – make a sharp turn…[/FONT] [/FONT][/COLOR]
                [/COLOR]
                  ....за Автовози...е сложна работата / лично мнение /.
                  Иначе, колегата е прав...
                  Забравил е да ти спомене, че има и печалба / труд и риск / ...около 1000лв.
                  Това е всичко ....
                  Недей да взимаш нещо евтино!!! Има защо да е на тази " изгодна " цена!!
                  Купувай , кола със застрахомвка, МОТ и Роуд такс!!! В експлоатация...
                  Хубаво е да има сервизна книжка...и да е с гаранция!!
                  Разликата е ...около 1000 паунда!!! Струва си от всякъде!!!
                  Ти нали за теб ще си вземаш .., не за продажба!!!!
                  СИЛНИТЕ КРАДАТ ОТ ЧУЖДИ ДЪРЖАВИ, СЛАБИТЕ - ОТ СВОЯТ НАРОД !
                    .... не сериозни оферти под 2 500-2800 паунда недей да гледаш въобще!!
                    Тук в БГ има доста " изгодни оферти " около 7-8 хиляди лв.!!!
                    ...като извадиш 2500 лв...разходи по докарване
                    .....остават 1700 - 1900 паунда за колата и застраховката !!!
                    Изводите си направи ти....Какво ще очакваш за тези пари..и до кога..
                      аз не си правя сметка да го докарам лично... с джип за тия пари ще е приключение да прекосиш цяла Европа... но ако се купи за 1600 лири и 2000-2500лв за докарване... мисля, че в София за 7000лв не може да се вземе ЛР в движение...
                      това, че е очукан и има ръжда, не ме притеснява... лично ще се постарая да се доочука като пристигне
                      за каране по черни пътища десният волан не ме притеснява... само да свикна да сменям скоростите с лява ръка...
                        LR DEFENDER COUNTY WAGON TDI - 12 seats!!!
                        1992год на производство
                        4х4
                        сервизна книжка
                        това ми пратиха преди малко от Англия мои хора...
                        Цената до БГ е 10 000 лв. / ако има мот и застраховка / иначе + 500лв
                        Това е примерно предложение , което още не съм огледал и обмислил с подробности...нито съм говорил със собствениците на колата...за повече инфо.
                          Синия Дифендър е с МОТ, пътна такса, застраховка и сервизна книжка. Червеното Диско и то, цената му вече е 1300лири.
                          Изобщо такива без МОТ и т.н. не се гледат изобщо.
                          П.П.
                          За който не знае, МОТ е английския технически преглед (Ministry of Transport test)
                          Последно редактирано от Lazar; 17-10-08, 18:27.
                            Първоначално публикуван от pe4en Преглед на мнение
                            4х4
                            сервизна книжка
                            А, ей за това става въпрос!
                            Хайде кажи сега, ама честно!
                            - Колко струва там това нещо, щото като гледам как е го е подгонила ръждата и е пребоядисван с баданарката, аз не му давам повече от 1000лири.
                            - Защо "ако има мот и застраховка"? Че той ако няма, може да го изнесеш само за рез.части. А това е още едно потвърждение за това, че е с много ниска цена.
                            - И хоп - изведнъж тук идва за 10000лв. Минус 2500лв доставката, минус 1000лв печалба за търговеца и остават 6500лв. Това са към 2600лири. При това без мот....нещо не ми се връзва. Или май печалбата за търговеца е мааалко повече?
                            Последно редактирано от Lazar; 18-10-08, 09:28.
                              Преди няколко дена тая бялата 110-ка беше на 1300 паунда - поне на толкова я видях 2 часа преди края на търга. Интересна цена с доставката до България се връзва.
                              идеите са навсякъде и даже не ги заключват
                                Цената на колата наистина е 2600 паунда!!
                                Ти виждаш годината..
                                Виждаш , че е дълга база...
                                Виж му отватре салона...
                                Виж че има сервизни документи...
                                Това има като оферта ...аз трябва да преценявам, дали да пращам човека ..да оправи документите , и да я докара през цяла Европа..
                                Трудно се намира този модел след 90 година за по малко пари на тези реални мили...
                                Ако няма мот , ..ще се мине на такъв срещу 80 паунда , и после щесе плати застраховка и роуд такс ...ето ти 500 лв.
                                Колата се ползвала посладн по полето..., в момента е прегледана и сервизирана от оторизиран сервиз, има HPI сертификат , че е със перфектно досие и не е крадена , с глоби и запори..
                                Аз от този сервиз имам гаранция за нея!! Тя сигурно вдига цената / прегледа също струва пари там /
                                Най-много потребители онлайн 137,813 в 23:47 на Днес.
