Удължаване на амортисьори на Гранд WJ
    От: Удължаване на амортисьори на Гранд WJ
    Да добавя малко допълнително инфо, което дават IronRock
    относно удължаването на bumpstop-овете в подкрепа на това, което казва Пламен (kinex)
    На мен ми звучи много логично и лесно за определяне:
    "Extend your bump stops with our custom length bump stop spacers (price is per pair).
    We recommend extending your OEM bump stops because simply put,
    they are the best bump stops available short of expensive pneumatic or hydraulic units that require lots of custom fabrication to install.
    The OEM bump stops are very progressive meaning they are very soft at initial contact,
    but get progressively firmer to stop even the hardest of hits without brutal, part breaking, metal to metal contact.
    The best part is they are designed to be used without even knowing it from the driver's seat.
    If you choose a custom "non-stock" length, please allow 5-10 business days to ship.
    How to choose the length:
    Actual lift height:
    It is very important that you do not use the manufacturers advertised lift height for any calculations.
    Always use a hub to fender measurement with the vehicle loaded they way it is typically used.
    If you usually carry tools and spare parts, have them in the vehicle when you measure.
    Also fuel weighs about 8lbs per gallon so measure with a full tank for bump stop purposes.
    Hub to fender measurment is measured from the center of the tire/wheel vertically to the bottom of the fender or fender flare.
    Measure on flat ground and measure all 4 corners because they always vary from side to side.
    Average the left and right measurements, but keep the front and rear measurments separate.
    Hub to fender measurements on a stock WJ Grand Cherokee are about 18.2" rear and 18" front.
    OEM distance to the start of the bump stop is roughly 1.5"
    What is your goal?
    OEM uptravel:
    If you just want OEM suspension uptravel then extend your bump stops by your actual lift height
    (see hub to fender measurement procedure above).
    Extra uptravel:
    If you want a little bit of extra uptravel then extend your bump stops by a little less than your lift height.
    For example for a 4" actual lift height extend the bump stops 3.5", or whatever you think is best for you.
    We think 1/2" additional uptravel is great for general use.
    Maximum tire clearance:
    If you are looking for maximum tire clearance then use an RTI ramp, trail obstacle, or other method to cycle the suspension.
    You must have your lift kit and tire combination in place to use this method.
    Simply cycle your suspension to the maximum travel you want to allow (remember to cycle your steering lock to lock).
    Then measure from the middle of your bump stop to the bump stop pad. This is the amount to drop your bump stops.
    Remember to consider the worst case scenario. For example, going downhill will push harder on the front bump stops,
    or as one tire droops more the other tire stuffs more even after contact with the bump stop (because of the location of the bump stops).
    So you may want to add 1/2" or more to your measurement, or be sure you measure using worst case scenario.
    We do not recommend extending bump stops more than your actual lift height (see hub to fender measurement procedure above).
    линк към оригиналната страница
    Jeep Grand Cherokee * WJ * 4.7 V8 * Quadra Drive II *
    2" lift (Bilstein 5100 & IronRocks springs), General Grabber AT3 31"
      На мен лично много ми помогна темата. Благодаря на всички участници. Според Вас при 2" лифт трябва ли да се увеличават и биалетките отпред и отзад и ако да с колко?
        Според мен, да. Определено.
        С лифта и стоковите много смешно се "разкрачваше" в планината :-)
        Не съм "обследвал" с колко. Просто поръчах пак от ironrock offroad с дължина за съответния лифт:
        https://www.ironrockoffroad.com/product/wj-front-sway-bar-links.html
        https://www.ironrockoffroad.com/prod...bar-links.html
        За съжаление, пропуснах момента с меренето, да видя с колко са удължени....
        Допускам обаче, че истинското подобрение идва със замяна и на стабилизиращата щанга.
        https://www.ironrockoffroad.com/prod...bar-addco.html
          Бъмп стопове от този сайт ли си поръчал? Могат ли да се направят от нещо друго и да си ги монтирам сам? И за замяната на задната стабилизираща щанга, какво подобрение се усеща ( на пътя и извън него), защото мн ги препоръчват по американските форуми?
            Ето ти тема.
              Първоначално публикуван от lordoff Преглед на мнение
              Трябва да усилиш горните уши на биалетките към купето защото ще ги откъсне.
              Дебелата задна щанга е измислена от Eibach за да работи с техните пружини. Които са минус 30мм и са много по-меки от заводските. Имам ги налични.
              Идеята е била да се направи окачване за Гранд Чероки за писта и са я постигнали.
              В крайна сметка без значение с какви пружини и амортисьори е комбинирана щангата, по дупките, задницата бие кикове като Порше. Направо чупи врат.
              По-доброто решение, според мен, за нашите пътища и офроуд е Koni SPX. Става меко и стабилно както е в заводски вид.
                Хм, това за Koni SPX e добра идея, благодаря! :-) Тези, моите Bilstein, макар и с lifetime гаранция, все някога ще предат четата. (За протокола, вече строших едни предни :-) )
                Лошото е, че аз (например) като лаик, нямам идея за съответния лифт с каква дължина да поръчам... Инак за стокови си имат таблица в сайта.
                  Така се удължават амортисьори. Колкото удължаваш - толкова подлагаш на бъмпстопа.
                  На какъв език да ти го напиша че да го разбереш.
                  [ATTACH=CONFIG]960082[/ATTACH]
                  Колега, може ли да споделиш от къде бих могъл да се сдобия с тези удължения ?
                  Благодаря предварително !
                    Няма да ти отговори, колегата не влиза вече във форума
                    "Ob Arm, ob Reich, im Tode gleich“
                    Русофилия: Тежка, наследствена незаразна болест, която не се лекува и от която за съжаление не се умира. Същата е дефиницията и за шизофрения.
                      Първоначално публикуван от Dilyan Zagorchev Преглед на мнение
                      Жалко...
                      Благодаря все пак 🙂
                      • Dilyan Zagorchev
                        Dilyan Zagorchev коментира
                        Потърси го у фейса Пламен Kinex
                      Благодаря, така и ще направя.
