От: Поръчка на добавка за диференциал
Добавките са поръчани. Сега чакаме. Алекс, взел съм те в предвид.
| Front Axle | ||||
| Dana 30 (186FBI)The Front Beam Iron (FBI) axle consists of a cast iron differential housing with axle shaft tubes extending from either side. The tubes are pressed into the differential housing and welded. The axles are semi-floating supported by the hub bearings. The axle shafts are retained by nuts at the hub bearings. | 2.5 pts. (40 +/- 1 oz)Bolt torque: Fill Plug: 25 Ft. Lbs. Cover Bolts: 30 Ft. Lbs. Axle Ratio: 3.55, 3.73 Axle shaft: 27-spline, 1.16-inch thick |
1999: Thermally stable SAE 80W-90 gear lube Mopar® P/N 048744681999-2004: SAE 75W-140 Synthetic Mopar® P/N 04874469 NOTE: Trac-lok and Vari-lok equipped axles require 2.5 ounces of Limited Slip Additive be added to the lubricant. Trac-lok for the front axle is available only with (and included with) all QuadraDrive systems |
(not listed, 30k recommended) | 12,000 mi. |
| Rear Axle | ||||
| Dana 35C (198RBI)The Rear Beam Iron axle has a cast iron differential housing with axle shaft tubes extending from either side. The tubes are pressed into differential housing and welded. The axles are semi-floating supported by the axle shaft and bearings. The axle shafts are retained by bearing retainer plates on the axles which are bolted to flanges at the outboard end of the axle tubes. | 3.75 pts. (60 +/-1 oz)Bolt torque: Fill Plug: 25 Ft. Lbs. Cover Bolts: 30 Ft. Lbs. Axle Ratio: 3.55, 3.73 Axle shaft: 27-spline, 1.16-inch thick |
Thermally stable SAE 80W-90 gear lube Mopar® P/N 04874468For heavy-duty or trailer tow use: SAE 75W-140 synthetic Mopar® P/N 04874469 NOTE: Trac-lok and Vari-lok equipped axles require 4 ounces of Limited Slip Additive be added to the lubricant. |
| Dana 44 (226RBA)The Rear Beam Aluminum axle housing has a cast aluminum center differential housing with axle shaft tubes extending from either side. The tubes are pressed into the differential housing. The axles are semi-floating supported by the axle shaft and bearings. | 4.75 pts. (76 +/- 1 oz)Bolt torque: Fill Plug: 25 Ft. Lbs. Cover Bolts: 30 Ft. Lbs. Axle Ratio: 3.55, 3.73 Axle shaft: 30-spline, 1.31" thick |
поръчал съм една допълнителна, но нека да дойдат и да видим какво ще стане...
