Първи проблем с Renegade 800X
  • #46
    От: Първи проблем с Renegade 800X
    Първоначално публикуван от raa Преглед на мнение
    renegade fault codes..
    P1565 Cruise Servo Pos Sensor
    За да сме по полезни ето всичките кодове за грешки:
    P0001 Fuel Volume RegCtrl Circ/Open
    P0002 Fuel Volume RegCtrl Circ Range/Perf
    P0003 Fuel Volume RegCtrl Circ Low
    P0004 Fuel Volume RegCtrl Circ High
    P0005 Fuel ShutoffValve A Ctrl Circ/Open
    P0006 Fuel ShutoffValve A Ctrl Circ Low
    P0007 Fuel ShutoffValve A Ctrl Circ High
    P0008 Engine Pos SysPerf Bank1
    P0009 Engine Pos SysPerf Bank2
    P0010 A Camshaft PosActuator Circ (bank)
    P0011 A Camshaft PosTiming-Over-Advanced (bank)
    P0012 A Camshaft PosTiming-Over-Retarded (bank)
    P0013 B Camshaft PosActuator Circ (bank
    P0014 B Camshaft PosTiming-Over-Advanced (bank)
    P0015 B Camshaft PosTiming-Over-Retarded (bank)
    P0016 CrankPos-Camshaft Pos Correlation Bank1 Sensor A
    P0017 Crank Pos-CamshaftPos Correlation Bank1 Sensor B
    P0018 CrankPos-Camshaft Pos Correlation Bank2 Sensor A
    P0019 CrankPos-Camshaft Pos Correlation Bank2 Sensor B
    P0020 A Camshaft PosActuator Circ (bank2)
    P0021 A Camshaft PosTiming-Over-Advanced (bank2)
    P0022 A Camshaft PosTiming-Over-Retarded (bank2)
    P0023 B Camshaft PosActuator Circ (bank2)
    P0024 B Camshaft PosTiming-Over-Advanced (bank2)
    P0025 B Camshaft PosTiming-Over-Retarded (bank2)
    P0026 Intake ValveCtrl Solenoid Circ Range/Perf Bank1
    P0027 Exhaust ValveCtrl Solenoid Circ Range/Perf Bank1
    P0028 Intake ValveCtrl Solenoid Circ Range/Perf Bank2
    P0029 Exhaust ValveCtrl Solenoid Circ Range/Perf Bank2
    P0030 HO2S HeaterCtrl Circ (bank1, Sensor
    P0031 HO2S HeaterCtrl Circ Lo (bank1, Sensor
    P0032 HO2S HeaterCtrl Circ Hi (bank1, Sensor
    P0033 Turbo ChargerBypass Valve Ctrl Circ
    P0034 Turbo ChargerBypass Valve Ctrl Circ Lo
    P0035 Turbo ChargerBypass Valve Ctrl Circ Hi
    P0036 HO2S HeaterCtrl Circ (bank1, Sensor2)
    P0037 HO2S HeaterCtrl Circ Lo (bank1, Sensor2)
    P0038 HO2S HeaterCtrl Circ Hi (bank1, Sensor2)
    P0039 T/S ChargerBypass Valve Ctrl Circ Range/Perf
    P0040 O2 SensorSignals Swapped Bank1 Sensor 1/ Bank2 Sensor 1
    P0041 O2 SensorSignals Swapped Bank1 Sensor 2/ Bank2 Sensor 2
    P0042 HO2S HeaterCtrl Circ (bank1, Sensor 3)
    P0043 HO2S HeaterCtrl Circ Lo (bank1, Sensor 3)
    P0044 HO2S HeaterCtrl Circ Hi (bank1, Sensor 3)
    P0045 T/S ChargerBoost Ctrl Solenoid Circ/Open
    P0046 T/S ChargerBoost Ctrl Solenoid Circ Range/Perf
    P0047 T/S ChargerBoost Ctrl Solenoid Circ Low
    P0048 T/S ChargerBoost Ctrl Solenoid Circ High
    P0049 T/S ChargerTurbine Overspeed
    P0050 HO2S HeaterCtrl Circ (bank2, Sensor)
    P0051 HO2S HeaterCtrl Circ Lo (bank2, Sensor)
    P0052 HO2S HeaterCtrl Circ Hi (bank2, Sensor)
    P0053 HO2S HeaterResistance Bank1 Sensor 1
    P0054 HO2S HeaterResistance Bank1 Sensor 2
    P0055 HO2S HeaterResistance Bank1 Sensor 3
    P0056 HO2S HeaterCtrl Circ (bank2, Sensor2)
    P0057 HO2S HeaterCtrl Circ Lo (bank2, Sensor2)
    P0058 HO2S HeaterCtrl Circ Hi (bank2, Sensor2)
    P0059 HO2S HeaterResistance Bank2 Sensor 1
    P0060 HO2S HeaterResistance Bank2 Sensor 2
    P0061 HO2S HeaterResistance Bank2 Sensor 3
    P0062 HO2S HeaterCtrl Circ (bank2, Sensor 3)
    P0063 HO2S HeaterCtrl Circ Lo (bank2, Sensor 3)
    P0064 HO2S HeaterCtrl Circ Hi (bank2, Sensor 3)
    P0065 Air AssistedInjector Ctrl Range/Perf
    P0066 Air AssistedInjector Ctrl Circ/Circ Lo
    P0067 Air AssistedInjector Ctrl Circ Hi
    P0068MAP/MAF-Throttle Pos Correlation
    P0069 MAP-BarometricPress Correlation
    P0070 Ambient AirTemp Sensor Circ
    P0071 Ambient AirTemp Sensor Range/Perf
    P0072 Ambient AirTemp Sensor Circ Lo Input
    P0073 Ambient AirTemp Sensor Circ Hi Input
    P0074 Ambient AirTemp Sensor Circ Interm
    P0075 Intake ValveCtrl Circ (bank)
    P0076 Intake ValveCtrl Circ Lo (bank)
    P0077 Intake ValveCtrl Circ Hi (bank)
    P0078 Exhaust ValveCtrl Circ (bank)
    P0079 Exhaust ValveCtrl Circ Lo (bank)
    P0080 Exhaust ValveCtrl Circ Hi (bank)
    P0081 Intake ValveCtrl Circ (bank2)
    P0082 Intake ValveCtrl Circ Lo (bank2)
    P0083 Intake ValveCtrl Circ Hi (bank2)
    P0084 Exhaust ValveCtrl Circ (bank2)
    P0085 Exhaust ValveCtrl Circ Lo (bank2)
    P0086 Exhaust ValveCtrl Circ Hi (bank2)
    P0087 Fuel Rail/SysPres-Too Lo
    P0088 Fuel Rail/SysPres-Too Hi
    P0089 Fuel Pres RegPerf
    P0090 Fuel Pres RegCtrl Circ
    P0091 Fuel Pres RegCtrl Circ Lo
    P0092 Fuel Pres RegCtrl Circ Hi
    P0093 Fuel Sys LeakDetected-Large Leak
    P0094 Fuel Sys LeakDetected-Small Leak
    P0095 Intake Air TempSensor 2 Circ
    P0096 Intake Air TempSensor 2 Circ Range/Perf
    P0097 Intake Air TempSensor 2 Circ Low
    P0098 Intake Air TempSensor 2 Circ High
    P0099 Intake Air TempSensor 2 Circ Interm/Erratic
    P0100 Mass/Volume AirFlow Circ Error
    P0101 Mass/Volume AirFlow Circ Range/Perf
    P0102 Mass/Volume AirFlow Circ Lo Input
    P0103 Mass/Volume AirFlow Circ Hi Input
    P0104 Mass/Volume AirFlow Circ Interm
    P0105 MAP/Baro PresCirc Error
    P0106 MAP/Baro PresCirc Range/Perf
    P0107 MAP/Baro PresCirc Lo Input
    P0108 MAP/Baro PresCirc Hi Input
    P0109 MAP/Baro PresCirc Interm
    P0110 Intake Air TempCirc Error
    P0111 Intake Air TempCirc Range/Perf
    P0112 Intake Air TempCirc Lo Input
    P0113 Intake Air TempCirc Hi Input
    P0114 Intake Air TempCirc Interm
    P0115 Eng CoolantTemp Circ Error
    P0116 Eng CoolantTemp Circ Range/Perf
    P0117 Eng CoolantTemp Circ Lo Input
    P0118 Eng CoolantTemp Hi Input
    P0119 Eng CoolantTemp Interm
    P0120 Throttle PosSensor/Switch A Circ Error
    P0121 Throttle PosSensor/Switch A Circ Range/Perf
    P0122 Throttle PosSensor/Switch A Circ Lo Input
    P0123 Throttle PosSensor/Switch A Circ Hi Input
    P0124 Throttle PosSensor/Switch A Circ Interm
    P0125 Insuff CoolantTemp for Closed Loop Fuel Ctrl
    P0126 Insuff CoolantTemp Stable Operation
    P0127 Intake Air TempToo Hi
    P0128 Coolant Tempbelow Thermostat
    P0129 BarometricPress Too Low
    P0130 Oxy Sensor Circ(bank1, Sensor)
    P0131 Oxy Sensor CircLo Voltage (bank1, Sensor)
    P0132 Oxy Sensor CircHi Voltage (bank1, Sensor)
    P0133 Oxy Sensor CircSlow Response (bank1, Sens)
    P0134 Oxy Sens CircNo Activity Detected (bank1 Sens)
    P0135 Oxy SensorHeater Circ (bank1, Sensor)
    P0136 Oxy Sensor Circ(bank1, Sensor2)
    P0137 Oxy Sensor CircLo Voltage (bank1, Sensor2)
    P0138 Oxy Sensor CircHi Voltage (bank1, Sensor2)
    P0139 Oxy Sensor CircSlow Response (bank1, Sensor2)
    P0140 Oxy Sens CircNo Activity Detected (bank1 Sens2)
    P0141 Oxy SensorHeater Circ (bank1, Sensor2)
    P0142 Oxy Sensor Circ(bank1, Sensor 3)
    P0143 Oxy Sensor CircLo Voltage (bank1, Sensor 3)
    P0144 Oxy Sensor CircHi Voltage (bank1, Sensor 3)
    P0145 Oxy Sensor CircSlow Response (bank1, Sensor 3)
    P0146 Oxy Sensor CircNo Activity Detected (bank1 Sens3)
    P0147 Oxy SensorHeater Circ (bank1, Sensor 3)
    P0148 Fuel DeliveryError
    P0149 Fuel TimingError
    P0150 Oxy Sensor Circ(bank2, Sensor
    P0151 Oxy Sensor CircLo Voltage (bank2, Sensor)
    P0152 Oxy Sensor CircHi Voltage (bank2, Sensor)
    P0153 Oxy Sensor CircSlow Response (bank2, Sensor)
    P0154 Oxy Sensor CircNo Activity Detected (bank2 Sensor)
    P0155 Heated OxySensor Heater Circ (bank2, Sensor
    P0156 Oxy Sensor Circ(bank2, Sensor2)
    P0157 Oxy Sensor CircLo Voltage (bank2, Sensor2)
    P0158 Oxy Sensor CircHi Voltage (bank2, Sensor2)
    P0159 Oxy Sensor CircSlow Response (bank2, Sensor2)
    P0160 Oxy Sensor CircNo Activity Detected (bank2 Sens2)
    P0161 Heated OxySensor Heater Circ (bank2, Sensor2)
    P0162 Oxy Sensor Circ(bank2, Sensor 3)
    P0163 Oxy Sensor CircLo Voltage (bank2, Sensor 3)
    P0164 Oxy Sensor CircHi Voltage (bank2, Sensor 3)
    P0165 Oxy Sensor CircSlow Response (bank2, Sensor 3)
    P0166 Oxy Sensor CircNo Activity Detected (bank2 Sens3)
    P0167 Heated OxySensor Heater Circ (bank2, Sensor 3)
    P0168 Eng Fuel TempHi
    P0169 Incorrect FuelComPos
    P0170 Fuel Trim Error(bank)
    P0171 Sys too Lean(bank)
    P0172 Sys too Rich(bank)
    P0173 Fuel Trim Error(bank2)
    P0174 Sys too Lean(bank2)
    P0175 Sys too Rich(bank2)
    P0176 Fuel ComPosSensor Circ Error
    P0177 Fuel ComPosSensor Circ Range/Perf
    P0178 Fuel ComPosSensor Circ Lo Input
    P0179 Fuel ComPosSensor Circ Hi Input
    P0180 Fuel TempSensorA Circ Error
    P0181 Fuel TempSensorA Circ Range/Perf
    P0182 Fuel TempSensorA Circ Lo Input
    P0183 Fuel TempSensorA Circ Hi Input
    P0184 Fuel Temp SensorACirc Interm
    P0185 Fuel TempSensorB Circ Error
    P0186 Fuel TempSensorB Circ Range/Perf
    P0187 Fuel TempSensorB Circ Lo Input
    P0188 Fuel TempSensorB Circ Hi Input
    P0189 Fuel TempSensorB Circ Interm
    P0190 Fuel Rail PresSensor Circ Error
    P0191 Fuel Rail PresSensor Circ Range/Perf
    P0192 Fuel Rail PresSensor Circ Lo Input
    P0193 Fuel Rail PresSensor Circ Hi Input
    P0194 Fuel Rail PresSensor Circ Interm
    P0195 Eng Oil TempSensor Error
    P0196 Eng Oil TempSensor Range/Perf
    P0197 Eng Oil Temp SensorCirc Lo Input
    P0198 Eng Oil TempSensor Circ Hi Input
    P0199 Eng Oil TempSensor Interm
    P0200 Injector CircError
    P0201 Injector CircError-Cyl1
    P0202 Injector CircError-Cyl2
    P0203 Injector CircError-Cyl3
    P0204 Injector CircError-Cyl4
    P0205 Injector CircError-Cyl5
    P0206 Injector CircError-Cyl6
    P0207 Injector CircError-Cyl7
    P0208 Injector CircError-Cyl8
    P0209 Injector CircError-Cyl9
    P0210 Injector CircError-Cyl10
    P0211 Injector CircError-Cyl11
    P0212 Injector CircError-Cyl12
    P0213 Cold StartInjector 1 Error
    P0214 Cold StartInjector 2 Error
    P0215 Eng ShutoffSolenoid Error
    P0216 Inj Timing CtrlCirc Error
    P0217 Eng Over tempCondition
    P0218 Tran Over tempCondition
    P0219 Throttle Sw BCirc Error/Eng Over speed Condition
    P0220 Throttle PosSensor/Switch B Circ Error
    P0221 Throttle PosSensor/Switch B Circ Range/Perf
    P0222 Throttle PosSensor/Switch B Circ Lo Input
    P0223 Throttle PosSensor/Switch B Circ Hi Input
    P0224 Throttle PosSensor/Switch B Circ Interm
    P0225 Throttle PosSensor/Switch C Circ Error
    P0226 Throttle PosSensor/Switch C Circ Range/Perf
    P0227 Throttle PosSensor/Switch C Circ Lo Input
    P0228 Throttle PosSensor/Switch C Circ Hi Input
    P0229 Throttle PosSensor/Switch C Circ Interm
    P0230 Fuel Pump RelayDvr Fail
    P0231 Fuel Pump RelayDvr Circ Fail On
    P0232 Fuel Pump RelayDvr Circ Fail Off
    P0233 Fuel Pump RelayDvr Interm
    P0234 Eng Over boostCondition
    P0235 Turbo BoostSensorA Circ Error
    P0236 Turbo BoostSensorA Circ Perf
    P0237 Turbo BoostSensorA Circ Lo Input
    P0238 Turbo BoostSensorA Circ Hi Input
    P0239 Turbo BoostSensorB Circ Error
    P0240 Turbo BoostSensorB Circ Perf
    P0241 Turbo BoostSensorB Circ Lo Input
    P0242 Turbo BoostSensorB Circ Hi Input
    P0243 Turbo WastegateSolenoid A Error
    P0244 Turbo WastegateSolenoid A Range/Perf
    P0246 Turbo WastegateSolenoid A Hi
    P0247 Turbo WastegateSolenoid A Error
    P0248 Turbo WastegateSolenoid A Range/Perf
    P0249 Turbo WastegateSolenoid A Lo
    P0250 Turbo WastegateSolenoid A Hi
    P0251 Inj Pump FuelMetering Ctrl A Error
    P0252 Inj Pump FuelMetering Ctrl A Range/Perf
    P0253 Inj Pump FuelMetering Ctrl A Lo
    P0254 Inj Pump FuelMetering Ctrl A Hi
    P0255 Inj Pump FuelMetering Ctrl A Interm
    P0256 Inj Pump FuelMetering Ctrl A Error
    P0257 Inj Pump FuelMetering Ctrl A Range/Perf
    P0258 Inj Pump FuelMetering Ctrl A Lo
    P0259 Inj Pump FuelMetering Ctrl A Hi
    P0260 Inj Pump FuelMetering Ctrl A Interm
    P0261 Injector CircLo-Cyl1c
    P0262 Injector CircHi-Cyl1
    P0263 Cyl1Contribution/Balance Fault
    P0264 Injector CircLo-Cyl2
    P0265 Injector CircHi-Cyl2
    P0266 Cyl2Contribution/Balance Fault
    P0267 Injector CircLo-Cyl3
    P0268 Injector CircHi-Cyl3
    P0269 Cyl3Contribution/Balance Fault
    P0270 Injector CircLo-Cyl4
    P0271 Injector CircHi-Cyl4
    P0272 Cyl4Contribution/Balance Fault
    P0273 Injector CircLo-Cyl5
    P0274 Injector CircHi-Cyl5
    P0275 Cyl5Contribution/Balance Fault
    P0276 Injector CircLo-Cyl6
    P0277 Injector CircHi-Cyl6
    P0278 Cyl6Contribution/Balance Fault
    P0279 Injector CircLo-Cyl7
    P0280 Injector CircHi-Cyl7
    P0281 Cyl7Contribution/Balance Fault
    P0282 Injector CircLo-Cyl8
    P0283 Injector CircHi-Cyl8
    P0284 Cyl8Contribution/Balance Fault
    P0285 Injector CircLo-Cyl9
    P0286 Injector Circ Hi-Cyl9
    P0287 Cyl9Contribution/Balance Fault
    P0288 Injector CircLo-Cyl10
    P0289 Injector CircHi-Cyl10
    P0290 Cyl10Contribution/Balance Fault
    P0291 Injector CircLo-Cyl11
    P0292 Injector CircHi-Cyl11
    P0293 Cyl11Contribution/Balance Fault
    P0294 Injector CircLo-Cyl12
    P0295 Injector CircHi-Cyl12
    P0296 Cyl12Contribution/Balance Fault
    P0297 VehicleOverspeed Condition
    P0298 Eng Oil Overtemp Condition
    P0299 T/S ChargerUnderboost
    P0300 Random/MultipleCylinder Misfire Detected
    P0301 Fault CylinderA-Misfire Detected (CYL)
    P0302 Fault CylinderB-Misfire Detected (CYL2)
    P0303 Fault CylinderD-Misfire Detected (CYL3)
    P0304 Fault CylinderE-Misfire Detected (CYL4)
    P0305 Fault CylinderF-Misfire Detected (CYL5)
    P0306 Fault CylinderG-Misfire Detected (CYL6)
    P0307 Fault CylinderC-Misfire Detected (CYL7)
    P0308 Fault CylinderH-Misfire Detected (CYL
    P0309 Fault CylinderI-Misfire Detected (CYL9)
    P0310 Fault CylinderJ-Misfire Detected (CYL10)
    P0311 Fault CylinderK-Misfire Detected (CYL1)
    P0312 Fault CylinderL-Misfire Detected (CYL12)
    P0313 MisfireDetected with Lo Fuel
    P0314 1 CylinderMisfire (Cylinder not specific)
    P0315 Crank Pos SysVariation Not Learned
    P0316 Engine MisfireDetected on Startup (First 1000 Revs)
    P0317 Rough RoadHardware Not Present
    P0318 Rough RoadSensorA Signal Circ
    P0319 Rough RoadSensorB
    P0320 Ign/DistributorEng Speed Input Circ Error
    P0321 Ign/DistributorEng Speed Input Circ Range/Perf
    P0322 Ign/DistributorEng Speed Input Circ No Signal
    P0323 Ign/DistributorEng Speed Input Circ Interm
    P0324 Knock Ctrl SysError
    P0325 Knock Sensor1Circ Error (bank1/1 Sensor)
    P0326 Knock Sensor1Circ Range/Perf (bank1/1 Sensor)
    P0327 Knock Sensor1Circ Lo Input (bank1/1 Sensor)
    P0328 Knock Sensor1 CircHi Input (bank1/1 Sensor)
    P0329 Knock Sensor1Circ Interm (bank1/1 Sensor)
    P0330 Knock Sensor2Circ Error (bank2)
    P0331 Knock Sensor2Circ Range/Perf (bank2)
    P0332 Knock Sensor2Circ Lo Input (bank2)
    P0333 Knock Sensor2Circ Hi Input (bank2)
    P0334 Knock Sensor2Circ Interm (bank2)
    P0335 Crank PosSensorA Circ Error
    P0336 Crank PosSensorA Circ Range/Perf
    P0337 Crank PosSensorA Circ Lo Input
    P0338 Crank PosSensorA Circ Hi Input
    P0339 Crank PosSensorA Circ Interm
    P0340 Camshaft PosSensor Circ Error (bank1/1 Sensor)
    P0341 Camshaft PosSensor Circ Perf (bank1/1 Sensor)
    P0342 Camshaft PosSensor Circ Lo Input (bank1/1 Sensor)
    P0343 Camshaft PosSensor Circ Hi Input (bank1/1 Sensor)
    P0344 Camshaft PosSensor Circ Interm (bank1/1 Sens)
    P0345 Camshaft PosSensor Circ Error (bank2)
    P0346 Camshaft PosSensor Circ Perf (bank2)
    P0347 Camshaft PosSensor Circ Lo Input (bank2)
    P0348 Camshaft PosSensor Circ Hi Input (bank2)
    P0349 Camshaft PosSensor Circ Interm (bank2)
    P0350 Ignition CoilPri/Sec Circ Error
    P0351 Ignition Coil APri/Sec Circ Error
    P0352 Ignition Coil BPri/Sec Circ Error
    P0353 Ignition Coil CPri/Sec Circ Error
    P0354 Ignition Coil DPri/Sec Circ Error
    P0355 Ignition Coil EPri/Sec Circ Error
    P0356 Ignition Coil FPri/Sec Circ Error
    P0357 Ignition Coil GPri/Sec Circ Error
    P0358 Ignition Coil HPri/Sec Circ Error
    P0359 Ignition Coil IPri/Sec Circ Error
    P0360 Ignition Coil JPri/Sec Circ (Glow Plug) Error
    P0361 Ignition Coil KPri/Sec Circ (Glow Plug Indicator) Error
    P0362 Ignition Coil LPri/Sec Circ Error
    P0363 MisfireDetected-Fueling Disabled
    P0364 Reserved
    P0365 Crank PosSensorB Circ Error (bank)
    P0366 Crank PosSensorB Circ Range/Perf (bank)
    P0367 Crank PosSensorB Circ Lo Input (bank)
    P0368 Crank PosSensorB Circ Hi Input (bank)
    P0369 Crank PosSensorB Circ Interm (bank)
    P0370 Timing Ref HiRes Signal A Error
    P0371 Timing Ref HiRes Signal A Too Many Pulses
    P0372 Timing Ref HiRes Signal A Too Few Pulses
    P0373 Timing Ref HiRes Signal A Interm/Erratic Pulses
    P0374 Timing Ref HiRes Signal A No Pulses
    P0375 Timing Ref HiRes Signal B Error
    P0376 Timing Ref HiRes Signal B Too Many Pulses
    P0377 Timing Ref HiRes Signal B Too Few Pulses
    P0378 Timing Ref HiRes Signal B Interm/Erratic Pulses
    P0379 Timing Ref HiRes Signal B No Pulses
    P0380 Glow Plug CircError Circ A
    P0381 Glow PlugIndicator Circ Error
    P0382 Glow Plug CircError Circ B
    P0383 P0384 Reservedby document
    P0385 Crank PosSensorB Circ Error
    P0386 Crank PosSensorB Circ Range/Perf
    P0387 Crank PosSensorB Circ Lo Input
    P0388 Crank PosSensorB Circ Hi Input
    P0389 Crank PosSensorB Circ Interm
    P0390 Crank PosSensorB Circ Error (bank2)
    P0391 Crank PosSensorB Circ Range/Perf (bank2)
    P0392 Crank PosSensorB Circ Lo Input (bank2)
    P0393 Crank PosSensorB Circ Hi Input (bank2)
    P0394 Crank PosSensorB Circ Interm (bank2)
    P0400 Exhaust GasRecirculation Flow Error
    P0401 Exhaust GasRecirculation Flow Insuff Detected
    P0402 Exhaust GasRecirculation Flow Excessive Detected
    P0403 Exhaust GasRecirculation Circ Error
    P0404 Exhaust GasRecirculation Circ Range/Perf
    P0405 Exhaust GasRecirculation SensorA Circ Lo
    P0406 Exhaust GasRecirculation SensorA Circ Hi
    P0407 Exhaust GasRecirculation SensorB Circ Lo
    P0408 Exhaust GasRecirculation SensorB Circ Hi
    P0409 Exhaust GasRecirculation SensorA Circ
    P0410 Sec Air Inj SysError
    P0411 Sec Air Inj SysIncorrect Flow Detected
    P0412 Sec Air Inj SysSwitching Valve A Circ Error
    P0413 Sec Air Inj SysSwitching Valve A Circ Open
    P0414 Sec Air Inj SysSwitching Valve A Circ Shorted
    P0415 Sec Air Inj SysSwitching Valve B Circ Error
    P0416 Sec Air Inj SysSwitching Valve B Circ Open
    P0417 Sec Air Inj SysSwitching Valve B Circ Shorted
    P0418 Sec Air Inj SysRelay A Circ Error
    P0419 Sec Air Inj SysRelay B Circ Error
    P0420 Catalyst SysEfficiency below Threshold (bank)
    P0421 Warm UpCatalyst Efficiency below Thresh (bank)
    P0422 Main CatalystEfficiency below Threshold (bank)
    P0423 Heated CatalystEfficiency below Threshold (bank)
    P0424 Heated CatalystTemp below Threshold (bank)
    P0425 Catalyst TempSensor (bank)
    P0426 Catalyst TempSensor Range/Perf (bank)
    P0427 Catalyst TempSensor Lo Input (bank)
    P0428 Catalyst TempSensor Hi Input (bank0
    P0429 Catalyst HeaterCtrl Circ (bank)
    P0430 Catalyst SysEfficiency below Threshold (bank2)
    P0431 Warm UpCatalyst Efficiency below Thresh (bank2)
    P0432 Main CatalystEfficiency below Threshold (bank2)
    P0433 Heated CatalystEfficiency below Threshold (bank2)
    P0434 Heated CatalystTemp below Threshold (bank2)
    P0435 Catalyst TempSensor (bank2)
    P0436 Catalyst TempSensor Range/Perf (bank2)
    P0437 Catalyst TempSensor Lo Input (bank2)
    P0438 Catalyst TempSensor Hi Input (bank2)
    P0439 Catalyst HeaterCtrl Circ (bank2)
    P0440? Evap EmissionCtrl Sys Error
    P0441? Evap EmissionCtrl Sys Incorrect Purge Flow
    P0442? Evap EmissionCtrl Sys Leak Detected (small leak)
    P0443? Evap EmissionCtrl Sys Purge Ctrl Valve Circ Error
    P0444 Evap EmissionCtrl Sys Purge Ctrl Valve Circ Open
    P0445 Evap EmissionCtrl Sys Purge Ctrl Valve Circ Shorted
    P0446 Evap EmissionCtrl Sys Vent Ctrl Circ Error
    P0447 Evap EmissionCtrl Sys Vent Ctrl Circ Open
    P0448 Evap EmissionCtrl Sys Vent Ctrl Circ Shorted
    P0449 Evap EmissionCtrl Sys Vent Valve/Solenoid Circ Error
    P0450 Evap EmissionCtrl Sys Pres Sensor Error
    P0451 Evap EmissionCtrl Sys Pres Sensor Range/Perf
    P0452 Evap EmissionCtrl Sys Pres Sensor Lo Input
    P0453 Evap EmissionCtrl Sys Pres Sensor Hi Input
    P0454 Evap EmissionCtrl Sys Pres Sensor Interm
    P0455 Evap EmissionCtrl Sys Gross Leak Detected
    P0456 Evap EmissionCtrl Sys Very Small Leak Detected)
    P0457 Evap EmissionCtrl Sys Leak (fuel cap loose/off)
    P0458 EvaporativeEmission Sys Purge Ctrl Valve Circ Low
    P0459 EvaporativeEmission Sys Purge Ctrl Valve Circ High
    P0460 Fuel Tank LevelIndicator Circ Error
    P0461 Fuel LevelSensor Circ Range/Perf
    P0462 Fuel LevelSensor Circ Lo Input
    P0463 Fuel LevelSensor Circ Hi Input
    P0464 Fuel LevelSensor Circ Interm
    P0465 EVAP Purge FlowSensor Circ
    P0466 EVAP Purge FlowSensor Circ Range/Perf
    P0467 EVAP Purge FlowSensor Circ Lo Input
    P0468 EVAP Purge FlowSensor Circ Hi Input
    P0469 EVAP Purge FlowSensor Circ Interm
    P0470 Exhaust BackPres Sensor Circ Error
    P0471 Exhaust BackPres Sensor Circ Perf
    P0472 Exhaust BackPres Sensor Circ Lo Input
    P0473 Exhaust BackPres Sensor Circ Hi Input
    P0474 Exhaust BackPres Sensor Interm
    P0475 Exhaust PresCtrl Valve Error
    P0476 Exhaust PresCtrl Valve Range/Perf
    P0477 Exhaust PresCtrl Valve Lo Output
    P0478 Exhaust PresCtrl Valve Hi Input
    P0479 Exhaust PresCtrl Valve Interm
    P0480 Cooling Fan 1Ctrl Circ Error
    P0481 Cooling Fan 2Ctrl Circ Error
    P0482 Cooling Fan 3Ctrl Circ Error
    P0483 Cooling FanRationality Check Error
    P0484 Cooling FanCirc over Current
    P0485 Cooling FanPower/Ground Circ Error
    P0486 EGR SensorBCirc
    P0487 EGR ThrottlePos Ctrl Circ
    P0488 EGR ThrottlePos Ctrl Range/Perf
    P0489 Exhaust GasRecirculation Ctrl Circ Low
    P0490 Exhaust GasRecirculation Ctrl Circ High
    P0491 Sec Air Inj Sys(bank)
    P0492 Sec Air Inj Sys(bank2)
    P0493 Fan Overspeed
    P0494 Fan Speed Low
    P0495 Fan Speed High
    P0496 EvaporativeEmission Sys High Purge Flow
    P0497 EvaporativeEmission Sys Low Purge Flow
    P0500 Vehicle SpeedSensor (VSS) Error
    P0501 Vehicle SpeedSensor Range/Perf
    P0502 Vehicle SpeedSensor Lo Input
    P0503 Vehicle SpeedSensor Noisy
    P0504 Brake SwitchA/B Correlation
    P0505 Idle Ctrl SysError
    P0506 Idle Ctrl SysRPM Lower Than Expected
    P0507 Idle Ctrl SysRPM Higher Than Expected
    P0508 Idle Ctrl SysCirc Lo
    P0509 Idle Ctrl SysCirc Hi
    P0510 Closed ThrottlePos Switch Error
    P0511 Idle Air CtrlCirc
    P0512 Starter RequestCirc
    P0513 IncorrectImmobilizer Key
    P0514 Battery TempSensor Circ Range/Perf
    P0515 Battery TempSensor Circ
    P0516 Battery TempSensor Circ Lo
    P0517 Battery TempSensor Circ Hi
    P0518 Idle Air CtrlCirc Interm
    P0519 Idle Air CtrlSys Perf
    P0520 Eng Oil PresSensor/Switch Circ Error
    P0521 Eng Oil PresSensor/Switch Circ Range/Perf
    P0522 Eng Oil PresSensor/Switch Circ Lo Voltage
    P0523 Eng Oil PresSensor/Switch Circ Hi Voltage
    P0524 Eng Oil PresToo Lo
    P0525 Cruise CtrlServo Ctrl Circ Range/Perf
    P0526 Fan SpeedSensor Circ
    P0527 Fan SpeedSensor Circ Range/Perf
    P0528 Fan SpeedSensor Circ No Signal
    P0529 Fan SpeedSensor Circ Interm
    P0530 A/C RefrigerantPres Sensor Circ Error
    P0531 A/C RefrigerantPres Sensor Circ Range/Perf
    P0532 A/C RefrigerantPres Sensor Circ Lo Input
    P0533 A/C RefrigerantPres Sensor Circ Hi Input
    P0534 Air ConditionerRefrigerant Charge Loss
    P0535 A/C EvaporatorTemp Sensor Circ
    P0536 A/C EvaporatorTemp Sensor Circ Range/Perf
    P0537 A/C EvaporatorTemp Sensor Circ Low
    P0538 A/C EvaporatorTemp Sensor Circ High
    P0539 A/C EvaporatorTemp Sensor Circ Interm
    P0540 Manifold IntakeAir Heater Circ
    P0541 Manifold IntakeAir Heater Circ Lo
    P0542 Manifold IntakeAir Heater Circ Hi
    P0543 Intake AirHeater A Circ Open
    P0544 EGT Sensor Circbank1
    P0545 EGT Sensor CircLo bank1
    P0546 EGT Sensor CircHi bank1
    P0547 EGT Sensor Circbank2
    P0548 EGT Sensor CircLo bank2
    P0549 EGT Sensor CircHi bank2
    P0550 Power SteeringPres Sensor Circ Error
    P0551 Power SteeringPres Sensor Circ Range/Perf
    P0552 Power SteeringPres Sensor Circ Lo Input
    P0553 Power SteeringPres Sensor Circ Hi Input
    P0554 Power SteeringPres Sensor Circ Interm
    P0555 Brake BoosterPress Sensor Circ
    P0556 Brake BoosterPress Sensor Circ Range/Perf
    P0557 Brake BoosterPress Sensor Circ Low Input
    P0558 Brake BoosterPress Sensor Circ High Input
    P0559 Brake BoosterPress Sensor Circ Interm
    P0560 Sys VoltageError
    P0561 Sys VoltageUnstable
    P0562 Sys Voltage Lo
    P0563 Sys Voltage Hi
    P0564 Cruise CtrlMulti-Func Input Signal
    P0565 Cruise Ctrl ONSignal Error
    P0566 Cruise Ctrl OFFSignal Error
    P0567 Cruise CtrlRESUME Signal Error
    P0568 Cruise Ctrl SETSignal Error
    P0569 Cruise CtrlCOAST Signal Error
    P0570 Cruise CtrlACCEL Signal Error
    P0571 CruiseCtrl/Brake Switch A Circ Fail
    P0572 CruiseCtrl/Brake Switch A Circ Lo
    P0573 CruiseCtrl/Brake Switch A Circ Hi
    P0574 Cruise Ctrl SysVehicle Speed Too Hi
    P0575 Cruise CtrlInput Circ
    P0576 Cruise CtrlInput Circ Lo
    P0577 Cruise CtrlInput Circ Hi
    P0578 Cruise CtrlMulti-Func Input A Circ Stuck
    P0579 Cruise CtrlMulti-Func Input A Circ Range/Perf
    P0580 Cruise CtrlMulti-Func Input A Circ Low
    P0581 Cruise CtrlMulti-Func Input A Circ High
    P0582 Cruise CtrlVacuum Ctrl Circ/Open
    P0583 Cruise CtrlVacuum Ctrl Circ Low
    P0584 Cruise CtrlVacuum Ctrl Circ High
    P0585 Cruise CtrlMulti-Func Input A/B Correlation
    P0586 Cruise Ctrl VentCtrl Circ/Open
    P0587 Cruise CtrlVent Ctrl Circ Low
    P0588 Cruise CtrlVent Ctrl Circ High
    P0589 Cruise CtrlMulti-Func Input B Circ
    P0590 Cruise CtrlMulti-Func Input B Circ Stuck
    P0591 Cruise CtrlMulti-Func Input B Circ Range/Perf
    P0592 Cruise CtrlMulti-Func Input B Circ Low
    P0593 Cruise CtrlMulti-Func Input B Circ High
    P0594 Cruise CtrlServo Ctrl Circ/Open
    P0595 Cruise CtrlServo Ctrl Circ Low
    P0596 Cruise CtrlServo Ctrl Circ High
    P0597 ThermostatHeater Ctrl Circ/Open
    P0598 ThermostatHeater Ctrl Circ Low
    P0599 ThermostatHeater Ctrl Circ High
    P0600 Serial CommsLink Error
    P0601 Internal CtrlMod Memory Check Sum Error
    P0602 Ctrl ModProgramming Error
    P0603 Internal CtrlMod KAM Error
    P0604 Internal CtrlMod RAM Error
    P0605 Internal CtrlMod ROM Error
    P0606 PCM ProcessorFault
    P0607 Powertrain CtrlMod Perf
    P0608 Powertrain CtrlMod VSS Output A Error
    P0609 Powertrain CtrlMod VSS Output B Error
    P0610 Powertrain CtrlMod Vehicle Options Error
    P0611 Fuel InjectorCtrl Mod Perf
    P0612 Fuel InjectorCtrl Mod Ctrl Circ
    P0613 TCM Processor
    P0614 ECM / TCMIncompatible
    P0615 Starter RelayCirc
    P0616 Starter RelayCirc Lo
    P0617 Starter RelayCirc Hi
    P0618 AlternativeFuel Ctrl Mod KAM Error
    P0619 AlternativeFuel Ctrl Mod RAM/ROM Error
    P0620 Generator CtrlCirc Error
    P0621 Generator LampL Ctrl Circ Error
    P0622 Generator FieldF Ctrl Circ Error
    P0623 Generator LampCtrl Circ Error
    P0624 Fuel Cap LampCtrl Circ Error
    P0625 Generator Field/FTerminal Circ Low
    P0626 GeneratorField/F Terminal Circ High
    P0627 Fuel Pump ACtrl Circ /Open
    P0628 Fuel Pump ACtrl Circ Low
    P0629 Fuel Pump ACtrl Circ High
    P0630 VIN NotProgrammed/Mismatch-ECM/PCM
    P0631 VIN NotProgrammed/Mismatch-TCM
    P0632 Odometer NotProgrammed-ECM/PCM
    P0633 Immobilizer KeyNot Programmed-ECM/PCM
    P0634 PCM/ECM/TCMInternal Temp Too High
    P0635 Power SteeringCtrl Circ
    P0636 Power SteeringCtrl Circ Lo
    P0637 Power SteeringCtrl Circ Hi
    P0638 ThrottleActuator Ctrl Range/Perf bank1
    P0639 ThrottleActuator Ctrl Range/Perf bank2
    P0640 Manifold IntakeAir Heater Ctrl Circ
    P0641 Sensor RefVoltage A Circ/Open
    P0642 Sensor RefVoltage A Circ Low
    P0643 Sensor RefVoltage A Circ High
    P0644 Driver DisplaySerial Comm Circ
    P0645 A/C ClutchRelay Ctrl Circ
    P0646 A/C ClutchRelay Ctrl Circ Lo
    P0647 A/C ClutchRelay Ctrl Circ Hi
    P0648 ImmobilizerLamp Ctrl Circ
    P0649 Cruise CtrlLamp Ctrl Circ
    P0650 Error IndicatorLamp (MIL) Ctrl Circ Error
    P0651 Sensor RefVoltage B Circ/Open
    P0652 Sensor RefVoltage B Circ Low
    P0653 Sensor RefVoltage B Circ High
    P0654 Eng RPM OutputCirc Error
    P0655 Eng Hot LampOutput Ctrl Circ MalFunc
    P0656 Fuel LevelOutput Circ Error
    P0657 Actuator SupplyVoltage A Circ/Open
    P0658 Actuator SupplyVoltage A Circ Low
    P0659 Actuator SupplyVoltage A Circ High
    P0660 Intake ManifTuning Valve Ctrl Circ bank1
    P0661 Intake ManifTuning Valve Ctrl Circ Lo bank1
    P0662 Intake ManifTuning Valve Ctrl Circ Hi bank1
    P0663 Intake ManifTuning Valve Ctrl Circ bank2
    P0664 Intake ManifTuning Valve Ctrl Circ Lo bank2
    P0665 Intake ManifTuning Valve Ctrl Circ Hi bank2
    P0666 Cruise 'OnSignal Error
    P0667 Cruise 'Resume'Signal Error
    P0668 Cruise Set'Signal Error
    P0669 Cruise Coast'Signal Error
    P0670 Glow plug CtrlCirc Error
    P0671 Glow plug #1Circ failure
    P0672 Glow plug #2Circ failure
    P0673 Glow plug #3Circ failure
    P0674 Glow plug #4Circ failure
    P0675 Glow plug #5Circ failure
    P0676 Glow plug #6Circ failure
    P0677 Glow plug #7Circ failure
    P0678 Glow plug #8Circ failure
    P0679 Reserve forfuture Glow plug #9
    P0680 Reserve forfuture Glow plug #10
    P0681 Reserve forfuture Glow plug #11
    P0682 Reserve forfuture Glow plug #12
    P0683 Glow Plug CtrlMod to PCM Comm Circ
    P0684 Glow Plug CtrlMod to PCM Comm Circ
    Range/Perf
    P0685 ECM/PCM PowerRelay Ctrl Circ /Open
    P0686 ECM/PCM PowerRelay Ctrl Circ Low
    P0687 ECM/PCM PowerRelay Ctrl Circ High
    P0688 ECM/PCM PowerRelay Sense Circ /Open
    P0689 ECM/PCM PowerRelay Sense Circ Low
    P0690 ECM/PCM PowerRelay Sense Circ High
    P0691 Fan 1 Ctrl CircLow
    P0692 Fan 1 Ctrl CircHigh
    P0693 Fan 2 Ctrl CircLow
    P0694 Fan 2 Ctrl CircHigh
    P0695 Fan 3 Ctrl CircLow
    P0696 Fan 3 Ctrl CircHigh
    P0697 Sensor RefVoltage C Circ/Open
    P0698 Sensor RefVoltage C Circ Low
    P0699 Sensor RefVoltage C Circ High
    P0700 Tran Ctrl SysError
    P0701 Tran Ctrl SysRange/Perf
    P0702 Tran Ctrl SysElectrical
    P0703 Brake Switch BCirc Error
    P0704 Clutch PedalPos Switch Input Circ Error
    P0705 Tran RangeSensor Circ Error
    P0706 Tran RangeSensor Circ Range/Perf
    P0707 Tran RangeSensor Circ Lo Input
    P0708 Tran RangeSensor Circ Hi Input
    P0709 Tran RangeSensor Circ Interm
    P0710 Tran Fluid TempSensor Circ Error
    P0711 Tran Fluid TempSensor Circ Range/Perf
    P0712 Tran Fluid TempSensor CKT Lo Input
    P0713 Tran Fluid TempSensor CKT Hi Input
    P0714 Tran Fluid TempSensor Circ Interm
    P0715 Input/TurbineSpeed Sensor Circ Error
    P0716 Input/TurbineSpeed Sensor Circ Range/Perf
    P0717 Input/TurbineSpeed Sensor Circ No Signal
    P0718 Input/TurbineSpeed Sensor Circ Interm
    P0719 Torq Conv/BrakeSwitch B Circ Lo
    P0720 Output SpeedSensor Circ Error
    P0721 Output SpeedSensor Range/Perf
    P0722 Output SpeedSensor No Signal
    P0723 Output SpeedSensor Interm
    P0724 Torq Conv/BrakeSwitch B Circ Hi
    P0725 Eng Speed inputCirc Error
    P0726 Eng Speed InputCirc Range/Perf
    P0727 Eng Speed InputCirc No Signal
    P0728 Eng Speed InputCirc Interm
    P0729 Gear 6Incorrect Ratio
    P0730 Incorrect GearRatio
    P0731 Gear One RatioError
    P0732 Gear Two RatioError
    P0733 Gear ThreeRatio Error
    P0734 Gear Four RatioError
    P0735 Gear Five RatioError
    P0736 Reverse GearRatio Error
    P0737 TCM Eng SpeedOutput Circ
    P0738 TCM Eng SpeedOutput Circ Lo
    P0739 TCM Eng SpeedOutput Circ Hi
    P0740 Torq ConvClutch Circ MalFunc
    P0741 Torq ConvClutch Circ Perf/Stuck Off
    P0742 Torq ConvClutch Circ Stuck On
    P0743 Torq ConvClutch Sys Electrical Failure
    P0744 Torq ConvClutch Circ Interm
    P0745 Pres CtrlSolenoid Error
    P0746 Pres CtrlSolenoid Perf/Stuck Off
    P0747 Pres CtrlSolenoid Stuck On
    P0748 Pres CtrlSolenoid Electrical
    P0749 Pres CtrlSolenoid Interm
    P0750 Shift SolenoidA Error
    P0751 Shift SolenoidA Perf/St
    uck Off
    P0752 Shift SolenoidA Stuck On
    P0753 Shift SolenoidA Electrical
    P0754 Shift SolenoidA Interm
    P0755 Shift SolenoidB Error
    P0756 Shift SolenoidB Perf/Stuck Off
    P0757 Shift SolenoidB Stuck On
    P0758 Shift SolenoidB Electrical
    P0759 Shift SolenoidB Interm
    P0760 Shift SolenoidC Error
    P0761 Shift SolenoidC Perf/Stuck Off
    P0762 Shift SolenoidC Stuck On
    P0763 Shift SolenoidC Electrical
    P0764 Shift SolenoidC Interm
    P0765 Shift SolenoidD Error
    P0766 Shift SolenoidD Perf/Stuck Off
    P0767 Shift SolenoidD Stuck On
    P0768 Shift SolenoidD Electrical
    P0769 Shift SolenoidD Interm
    P0770 Shift SolenoidE Error
    P0771 Shift SolenoidE Perf/Stuck Off
    P0772 Shift SolenoidE Stuck On
    P0773 Shift SolenoidE Electrical
    P0774 Shift SolenoidE Interm
    P0775 Pres CtrlSolenoid B
    P0776 Pres CtrlSolenoid B Perf/Stuck Off
    P0777 Pres CtrlSolenoid B Stuck On
    P0778 Pres CtrlSolenoid B Electrical
    P0779 Pres CtrlSolenoid B Interm
    P0780 ShiftError
    P0781 1-2 Shift Error
    P0782 2-3 Shift Error
    P0783 3-4 Shift Error
    P0784 4-5 Shift Error
    P0785 Shift/Timing Solenoid Error
    P0786 Shift/Timing Solenoid Range/Perf
    P0787 Shift/Timing Solenoid Lo
    P0788 Shift/Timing Solenoid Hi
    P0789 Shift/Timing Solenoid Interm
    P0790 Normal/Perf Switch Circ Error
    P0791 Intermediate Shaft Speed Sensor Circ
    P0792 Intermediate Shaft Speed Sensor CircRange/Perf
    P0793 Intermediate Shaft Speed Sensor Circ NoSignal
    P0794 Intermediate Shaft Speed Sensor CircInterm
    P0795 Pres Ctrl Solenoid C
    P0796 Pres Ctrl Solenoid C Perf/Stuck Off
    P0797 Pres Ctrl Solenoid C Stuck On
    P0798 Pres Ctrl Solenoid C Electrical
    P0799 Pres Ctrl Solenoid C Interm
    P0800 Transfer Case Ctrl Sys (MIL Request)
    P0801 Reverse Inhibit Ctrl Circ Error
    P0802 Trans Ctrl Sys MIL Request Circ/Open
    P0803 1-4 Up shift (Skip Shift) Solenoid CtrlCirc Error
    P0804 1-4 Up shift (Skip Shift) Lamp Ctrl CircError
    P0805 Clutch Pos Sensor Circ
    P0806 Clutch Pos Sensor Circ Range/Perf
    P0807 Clutch Pos Sensor Circ Lo
    P0808 Clutch Pos Sensor Circ Hi
    P0809 Clutch Pos Sensor Circ Interm
    P0810 Clutch Pos Ctrl Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circ
    P0813 Reverse Output Circ
    P0814 Tran Range Display Circ
    P0815 Up Shift Switch Circ
    P0816 Down shift Switch Circ
    P0817 Starter Disable Circ
    P0818 Driveline Disconnect Switch Input Circ
    P0819 Up and Down Shift Switch to Trans RangeCorrelation
    P0820 Gear Lever X-Y Pos Sensor Circ
    P0821 Gear Lever X Pos Sensor Circ
    P0822 Gear Lever Y Pos Sensor Circ
    P0823 Gear Lever X Pos Sensor Circ Interm
    P0824 Gear Lever Y Pos Sensor Circ Interm
    P0825 Gear Lever Push/Pull Switch Circ (ShiftAnticipate)
    P0826 Up and Down Shift Switch Circ
    P0827 Up and Down Shift Switch Circ Low
    P0828 Up and Down Shift Switch Circ High
    P0829 5-6 Shift
    P0830 Clutch Pedal Switch A Circ
    P0831 Clutch Pedal Switch A Circ Lo
    P0832 Clutch Pedal Switch A Circ Hi
    P0833 Clutch Pedal Switch B Circ
    P0834 Clutch Pedal Switch B Circ Lo
    P0835 Clutch Pedal Switch B Circ Hi
    P0836 4WD Switch Circ
    P0837 4WD Switch Circ Range/Perf
    P0838 4WD Switch Circ Lo
    P0839 4WD Switch Circ Hi
    P0840 Tran Fluid Pres Sensor/Switch A Circ
    P0841 Tran Fluid Pres Sensor/Switch A CircRange/Perf
    P0842 Tran Fluid Pres Sensor/Switch A Circ Lo
    P0843 Tran Fluid Pres Sensor/Switch A Circ Hi
    P0844 Tran Fluid Pres Sensor/Switch A CircInterm
    P0845 Tran Fluid Pres Sensor/Switch B Circ
    P0846 Tran Fluid Pres Sensor/Switch B CircRange/Perf
    P0847 Tran Fluid Pres Sensor/Switch B Circ Lo
    P0848 Tran Fluid Pres Sensor/Switch B Circ Hi
    P0849 Tran Fluid Pres Sensor/Switch B CircInterm
    P0850 Park/Neutral Switch Input Circ
    P0851 Park/Neutral Switch Input Circ Low
    P0852 Park/Neutral Switch Input Circ High
    P0853 Drive Switch Input Circ
    P0854 Drive Switch Input Circ Low
    P0855 Drive Switch Input Circ High
    P0856 Traction Ctrl Input Signal
    P0857 Traction Ctrl Input Signal Range/Perf
    P0858 Traction Ctrl Input Signal Low
    P0859 Traction Ctrl Input Signal High
    P0860 Gear Shift Mod Comm Circ
    P0861 Gear Shift Mod Comm Circ Low
    P0862 Gear Shift Mod Comm Circ High
    P0863 TCM Comm Circ
    P0864 TCM Comm Circ Range/Perf
    P0865 TCM Comm Circ Low
    P0866 TCM Comm Circ High
    P0867 Trans Fluid Press
    P0868 Trans Fluid Press Low
    P0869 Trans Fluid Press High
    P0870 Trans Fluid Press Sensor/Switch C Circ
    P0871 Trans Fluid Press Sensor/Switch C CircRange/Perf
    P0872 Trans Fluid Press Sensor/Switch C CircLow
    P0873 Trans Fluid Press Sensor/Switch C CircHigh
    P0874 Trans Fluid Press Sensor/Switch C CircInterm
    P0875 Trans Fluid Press Sensor/Switch D Circ
    P0876 Trans Fluid Press Sensor/Switch D CircRange/Perf
    P0877 Trans Fluid Press Sensor/Switch D CircLow
    P0878 Trans Fluid Press Sensor/Switch D CircHigh
    P0879 Trans Fluid Press Sensor/Switch D CircInterm
    P0880 TCM Power Input Signal
    P0881 TCM Power Input Signal Range/Perf
    P0882 TCM Power Input Signal Low
    P0883 TCM Power Input Signal High
    P0884 TCM Power Input Signal Interm
    P0885 TCM Power Relay Ctrl Circ/Open
    P0886 TCM Power Relay Ctrl Circ Low
    P0887 TCM Power Relay Ctrl Circ High
    P0888 TCM Power Relay Sense Circ
    P0889 TCM Power Relay Sense Circ Range/Perf
    P0890 TCM Power Relay Sense Circ Low
    P0891 TCM Power Relay Sense Circ High
    P0892 TCM Power Relay Sense Circ Interm
    P0893 Multiple Gears Engaged
    P0894 Trans Component Slipping
    P0895 Shift Time Too Short
    P0896 Shift Time Too Long
    P0897 Trans Fluid Deteriorated
    P0898 Trans Ctrl Sys MIL Request Circ Low
    P0900 Clutch Actuator Circ/Open
    P0901 Clutch Actuator Circ Range/Perf
    P0902 Clutch Actuator Circ Low
    P0903 Clutch Actuator Circ High
    P0904 Gate Select Pos Circ
    P0905 Gate Select Pos Circ Range/Perf
    P0906 Gate Select Pos Circ Low
    P0907 Gate Select Pos Circ High
    P0908 Gate Select Pos Circ Interm
    P0909 Gate Select Ctrl Error
    P0910 Gate Select Actuator Circ/Open
    P0911 Gate Select Actuator Circ Range/Perf
    P0912 Gate Select Actuator Circ Low
    P0913 Gate Select Actuator Circ High
    P0914 Gear Shift Pos Circ
    P0915 Gear Shift Pos Circ Range/Perf
    P0916 Gear Shift Pos Circ Low
    P0917 Gear Shift Pos Circ High
    P0918 Gear Shift Pos Circ Interm
    P0919 Gear Shift Pos Ctrl Error
    P0920 Gear Shift Forward Actuator Circ/Open
    P0921 Gear Shift Forward Actuator CircRange/Perf
    P0922 Gear Shift Forward Actuator Circ Low
    P0923 Gear Shift Forward Actuator Circ High
    P0924 Gear Shift Reverse Actuator Circ/Open
    P0925 Gear Shift Reverse Actuator CircRange/Perf
    P0926 Gear Shift Reverse Actuator Circ Low
    P0927 Gear Shift Reverse Actuator Circ High
    P0928 Gear Shift Lock Solenoid Ctrl Circ/Open
    P0929 Gear Shift Lock Solenoid Ctrl CircRange/Perf
    P0930 Gear Shift Lock Solenoid Ctrl Circ Low
    P0931 Gear Shift Lock Solenoid Ctrl Circ High
    P0932 Hydraulic Press Sensor Circ
    P0933 Hydraulic Press Sensor Range/Perf
    P0934 Hydraulic Press Sensor Circ Low
    P0935 Hydraulic Press Sensor Circ High
    P0936 Hydraulic Press Sensor Circ Interm
    P0937 Hydraulic Oil Temp Sensor Circ
    P0938 Hydraulic Oil Temp Sensor Range/Perf
    P0939 Hydraulic Oil Temp Sensor Circ Low
    P0940 Hydraulic Oil Temp Sensor Circ High
    P0941 Hydraulic Oil Temp Sensor Circ Interm
    P0942 Hydraulic Press Unit
    P0943 Hydraulic Press Unit Cycling Period TooShort
    P0944 Hydraulic Press Unit Loss of Press
    P0945 Hydraulic Pump Relay Circ/Open
    P0946 Hydraulic Pump Relay Circ Range/Perf
    P0947 Hydraulic Pump Relay Circ Low
    P0948 Hydraulic Pump Relay Circ High
    P0949 Auto Shift Manual Adaptive Learning NotComplete
    P0950 Auto Shift Manual Ctrl Circ
    P0951 Auto Shift Manual Ctrl Circ Range/Perf
    P0952 Auto Shift Manual Ctrl Circ Low
    P0953 Auto Shift Manual Ctrl Circ High
    P0954 Auto Shift Manual Ctrl Circ Interm
    P0955 Auto Shift Manual Mode Circ
    P0956 Auto Shift Manual Mode Circ Range/Perf
    P0957 Auto Shift Manual Mode Circ Low
    P0958 Auto Shift Manual Mode Circ High
    P0959 Auto Shift Manual Mode Circ Interm
    P0960 Press Ctrl Solenoid A Ctrl Circ/Open
    P0961 Press Ctrl Solenoid A Ctrl CircRange/Perf
    P0962 Press Ctrl Solenoid A Ctrl Circ Low
    P0963 Press Ctrl Solenoid A Ctrl Circ High
    P0964 Press Ctrl Solenoid B Ctrl Circ/Open
    P0965 Press Ctrl Solenoid B Ctrl CircRange/Perf
    P0966 Press Ctrl Solenoid B Ctrl Circ Low
    P0967 Press Ctrl Solenoid B Ctrl Circ High
    P0968 Press Ctrl Solenoid C Ctrl Circ/Open
    P0969 Press Ctrl Solenoid C Ctrl CircRange/Perf
    P0970 Press Ctrl Solenoid C Ctrl Circ Low
    P0971 Press Ctrl Solenoid C Ctrl Circ High
    P0972 Shift Solenoid A Ctrl Circ Range/Perf
    P0973 Shift Solenoid A Ctrl Circ Low
    P0974 Shift Solenoid A Ctrl Circ High
    P0975 Shift Solenoid B Ctrl Circ Range/Perf
    P0976 Shift Solenoid B Ctrl Circ Low
    P0977 Shift Solenoid B Ctrl Circ High
    P0978 Shift Solenoid C Ctrl Circ Range/Perf
    P0979 Shift Solenoid C Ctrl Circ Low
    P0980 Shift Solenoid C Ctrl Circ High
    P0981 Shift Solenoid D Ctrl Circ Range/Perf
    P0982 Shift Solenoid D Ctrl Circ Low
    P0983 Shift Solenoid D Ctrl Circ High
    P0984 Shift Solenoid E Ctrl Circ Range/Perf
    P0985 Shift Solenoid E Ctrl Circ Low
    P0986 Shift Solenoid E Ctrl Circ High P0987 TransFluid Press Sensor/Switch E Circ
    P0988 Trans Fluid Press Sensor/Switch E CircRange/Perf
    P0989 Trans Fluid Press Sensor/Switch E CircLow
    P0990 Trans Fluid Press Sensor/Switch E CircHigh
    P0991 Trans Fluid Press Sensor/Switch E CircInterm
    P0992 Trans Fluid Press Sensor/Switch F Circ
    P0993 Trans Fluid Press Sensor/Switch F CircRange/Perf
    P0994 Trans Fluid Press Sensor/Switch F CircLow
    P0995 Trans Fluid Press Sensor/Switch F CircHigh
    P0996 Trans Fluid Press Sensor/Switch F CircInterm
    P0997 Shift Solenoid F Ctrl Circ Range/Perf
    P0998 Shift Solenoid F Ctrl Circ Low
    P0999 Shift Solenoid F Ctrl Circ High
    P0A00 Motor Electronics Coolant Temp SensorCirc
    P0A01 Motor Electronics Coolant Temp SensorCirc Range/Perf
    P0A02 Motor Electronics Coolant Temp SensorCirc Low
    P0A03 Motor Electronics Coolant Temp SensorCirc High
    P0A04 Motor Electronics Coolant Temp SensorCirc Interm
    P0A05 Motor Electronics Coolant Pump CtrlCirc/Open
    P0A06 Motor Electronics Coolant Pump Ctrl CircLow
    P0A07 Motor Electronics Coolant Pump Ctrl CircHigh
    P0A08 DC/DC Converter Status Circ
    P0A09 DC/DC Converter Status Circ Low Input
    P0A10 DC/DC Converter Status Circ High Input
    P0A11 DC/DC Converter Enable Circ/Open
    P0A12 DC/DC Converter Enable Circ Low
    P0A13 DC/DC Converter Enable Circ High
    P0A14 Engine Mount Ctrl Circ/Open
    P0A15 Engine Mount Ctrl Circ Low
    P0A16 Engine Mount Ctrl Circ High
    P0A17 Motor Torque Sensor Circ
    P0A18 Motor Torque Sensor Circ Range/Perf
    P0A19 Motor Torque Sensor Circ Low
    P0A20 Motor Torque Sensor Circ High
    P0A21 Motor Torque Sensor Circ Interm
    P0A22 Generator Torque Sensor Circ
    P0A23 Generator Torque Sensor Circ Range/Perf
    P0A24 Generator Torque Sensor Circ Low
    P0A25 Generator Torque Sensor Circ High
    P0A26 Generator Torque Sensor Circ Interm
    P0A27 Battery Power Off Circ
    P0A28 Battery Power Off Circ Low
    P0A29 Battery Power Off Circ High
    P1000 Monitor Checks Not Complete-More DrivingRequired
    P1105 Sec Vacuum Sensor Circ
    P1106 MAP Sens Circ Interm Hi Volts
    P1107 MAP Sens Circ Interm Lo Volts
    P1108 BARO to MAP Sens Comparison Too Hi
    P1109 Sec Port Throttle Sys
    P1111 Intake Air Temp Sens Circ Interm HiVolts
    P1112 Intake Air Temp Sens Circ Interm LoVolts
    P1113 Intake Resonance Switchover SolenoidCtrl Circ
    P1114 Eng Coolant Temp Sens Circ Interm LoVolts
    P1115 Eng Coolant Temp Sens Circ Interm HiVolts
    P1116 Eng Coolant Temp Sig Unstable or Interm
    P1117 Eng Coolant Temp Sig Out-Of-Range Lo
    P1118 Eng Coolant Temp Sig Out-Of-Range Hi
    P1119 Eng Coolant Temp Sig Out-Of-Range WithTFT Sens
    P1120 Throttle Pos Sens1 Circ
    P1121 Throttle Pos Sens Circ Interm Hi Volts
    P1122 Throttle Pos Sens Circ Interm Lo Volts
    P1125 APP Sys
    P1130 HO2S Circ Lo Variance Bank1 Sens1
    P1131 HO2S Circ Lo Variance Bank1 Sens2
    P1132 HO2S Circ Lo Variance Bank2 Sens1
    P1133 HO2S Insufficient Switching Bank1 Sens1
    P1134 HO2S Transition Time Ratio Bank1 Sens1
    P1135 HO2S Lean Mean Bank1 Sens1
    P1136 HO2S Rich Mean Bank1 Sens1
    P1137 HO2S Bank1 Sens2 Lean Sys or Lo Volts
    P1138 HO2S Bank1 Sens2 Rich or Hi Volts
    P1139 HO2S Insuff Switching Bank1 Sens2
    P1140 HO2S Transition Time Ratio Bank1 Sens2
    P1141 HO2S Heater Ctrl Circ Bank1 Sens2
    P1143 HO2S Bank1 Sens3 Lean Sys or Lo Volts
    P1144 HO2S Bank1 Sens3 Rich or Hi Volts
    P1153 HO2S Insufficient Switching Bank2 Sens1
    P1154 HO2S Transition Time Ratio Bank2 Sens1
    P1155 HO2S Lean Mean Bank2 Sens1
    P1156 HO2S Rich Mean Bank2 Sens1
    P1157 HO2S Bank2 Sens2 Lean Sys or Lo Volts
    P1158 HO2S Bank2 Sens2 Rich or Hi Volts
    P1159 HO2S Cross Counts Bank2 Sens2
    P1164 HO2S Bank2 Sens3 Rich or Hi Volts
    P1165 HO2S Cross Counts Bank2 Sens3
    P1170 Bank to Bank Fuel Trim Offset
    P1171 Fuel Sys Lean during Acceleration
    P1185 Eng Oil Temp Circ
    P1186 EOT Circ Perf
    P1187 EOT Sens Circ Lo Volts
    P1188 EOT Sens Circ Hi Volts
    P1189 Eng Oil Press (EOP) Switch Circ
    P1190 Eng Vacuum Leak
    P1191 Intake Air Duct Air Leak
    P1200 Injector Ctrl Circ
    P1201 (Alt. Fuel) Gas Mass Sens CircRange/Perf
    P1202 (Alt. Fuel) Gas Mass Sens Circ Lo Freq
    P1203 (Alt. Fuel) Gas Mass Sens Circ Hi Freq
    P1211 Mass Air Flow Circ Interm Hi
    P1212 Mass Air Flow Circ Interm Lo
    P1214 Inject Pump Timing Offset
    P1215 Gnd Fault Detection Indicated
    P1216 Fuel Solenoid Response Time Too Short
    P1217 Fuel Solenoid Response Time Too Long
    P1218 Inject Pump Calibration Circ
    P1219 Throttle Pos Sens Ref Volts
    P1220 Throttle Pos (TP) Sens2 Circ
    P1221 Fuel Pump Sec Circ Lo
    P1222 Injector Ctrl Circ Interm
    P1225 Injector Circ Cyl2 Interm
    P1228 Injector Circ Cyl3 Interm
    P1231 Injector Circ Cyl4 Interm
    P1234 Injector Circ Cyl5 Interm
    P1237 Injector Circ Cyl6 Interm
    P1240 Injector Circ Cyl7 Interm
    P1243 Injector Circ Cyl8 Interm
    P1245 Intake Plenum Switchover Valve
    P1250 Early Fuel Evaporation Heater Circ
    P1257 Supercharger Sys Over boost
    P1258 Eng Coolant over Temp-Protection ModeActive
    P1260 Last Test Failed SCC ENTER More Info.
    P1270 Accelerator Pedal Pos Sens A/D ConverterError
    P1271 Accelerator Pedal Pos (APP) Sens1-2Correlation
    P1272 Accelerator Pedal Pos Sens2
    P1273 Accelerator Pedal Pos Sens1
    P1274 Injectors Wired Incorrectly
    P1275 Accelerator Pedal Pos (APP) Sens1 Circ
    P1276 Accelerator Pedal Pos Sens1 Circ Perf
    P1277 Accelerator Pedal Pos Sens1 Circ LoVolts
    P1278 Accelerator Pedal Pos Sens1 Circ HiVolts
    P1280 Accelerator Pedal Pos (APP) Sens2 Circ
    P1281 Accelerator Pedal Pos Sens2 Circ Perf
    P1282 Accelerator Pedal Pos Sens2 Circ LoVolts
    P1283 Accelerator Pedal Pos Sens2 Circ HiVolts
    P1285 Accelerator Pedal Pos Sens3 Circ
    P1286 Accelerator Pedal Pos Sens3 Circ Perf
    P1287 Accelerator Pedal Pos Sens3 Circ LoVolts
    P1288 Accelerator Pedal Pos Sens3 Circ HiVolts
    P1300 Igniter Circ
    P1305 Ign Coil 2 Pri Feedback Circ
    P1310 Ign Coil 3 Pri Feedback Circ
    P1315 Ign Coil 4 Pri Feedback Circ
    P1320 C 4X Ref Circ Interm
    P1321 Electronic Ign Sys Fault Line
    P1322 EI Sys or Ign Ctrl Extra or Missing
    P1323 IC 24X Ref Circ Lo Freq
    P1324 Crank RPM Too Lo
    P1335 CKP Circ
    P1336 Crank Pos (CKP) Sys Variation NotLearned
    P1345 Crank Pos (CKP)-Camshaft Pos (CMP)Correlation
    P1346 Intake Camshaft Pos [CMP] Sens Sys Perf
    P1350 Ign Ctrl Sys
    P1351 Ign Coil Ctrl Circ Hi Volts
    P1352 IC Output Hi/Pulse Detected when GNDCyl. 2
    P1353 IC Output Hi/Pulse Detected when GNDCyl. 3
    P1354 IC Output Hi/Pulse Detected when GNDCyl. 4
    P1355 IC Output Hi/Pulse Detected when GNDCyl. 5
    P1356 IC Output Hi/Pulse Detected when GNDCyl. 6
    P1357 IC Output Hi/Pulse Detected when GNDCyl. 7
    P1358 IC Output Hi/Pulse Detected when GNDCyl. 8
    P1359 Ignition Coil Group 1 Ctrl Circ
    P1360 Ignition Coil Group 2 Ctrl Circ
    P1361 Ignition Coil Ctrl Circ Lo Volts
    P1362 IC Cyl2 Not Toggling After Enable
    P1363 IC Cyl3 Not Toggling After Enable
    P1364 IC Cyl4 Not Toggling After Enable
    P1365 IC Cyl5 Not Toggling After Enable
    P1366 IC Cyl6 Not Toggling After Enable
    P1367 IC Cyl7 Not Toggling After Enable
    P1368 IC Cyl8 Not Toggling After Enable
    P1370 IC 4X Ref Circ Too Many Pulses
    P1371 IC 4X Ref Circ Too Few Pulses
    P1372 Crank Pos (CKP) SensorA-B Correlation
    P1374 3X Ref Circ
    P1375 IC 24X Ref Circ Hi Volts
    P1376 Ignition Gnd Circ
    P1377 IC Cam Pulse To 4X Ref Pulse
    P1380 Misfire Detected-Rough Road Data NotAvailable
    P1381 Misfire Detected-No Comm with Brake CtrlMod
    P1390 Wheel Speed Sensor1-G-Sensor Circ
    P1391 Wheel Speed Sensor1-G-Sensor Circ Perf
    P1392 Wheel Speed Sensor1-G-Sensor Circ LoVolts
    P1393 Wheel Speed Sensor1-G-Sensor Circ HiVolts
    P1394 Wheel Speed Sensor1-G-Sensor Circ Interm
    P1395 Wheel Speed Sensor2-G-Sensor Circ
    P1396 Wheel Speed Sensor2-G-Sensor Circ Perf
    P1397 Wheel Speed Sensor2-G-Sensor Circ LoVolts
    P1398 Wheel Speed Sensor2-G-Sensor Circ HiVolts
    P1399 Wheel Speed Sensor2-G-Sensor Circ Interm
    P1403 Exhaust Gas Recirc Sys Valve 1
    P1404 Exhaust Gas Recirc (EGR) Closed Pos Perf
    P1405 Exhaust Gas Recirc Sys Valve 3
    P1406 EGR Valve Pintle Pos Circ
    P1407 EGR Air Intrusion in Exhaust Supply toEGR Valve
    P1408 Intake Manifold Press Sensor Circ
    P1409 EGR Vacuum Sys Leak
    P1410 Fuel Tank Press Sys
    P1415 Sec Air Inject (AIR) Sys Bank1
    P1416 Sec Air Inject (AIR) Sys Bank2
    P1418 Sec Air Inject Sys Relay A Ctrl Circ Hi
    P1420 Intake Air Lo Press Switch Circ Lo Volts
    P1421 Intake Air Lo Press Switch Circ Hi Volts
    P1423 Intake Air Hi Press Switch Circ Hi Volts
    P1431 Fuel Level Sensor2 Circ Perf
    P1432 Fuel Level Sensor2 Circ Lo Volts
    P1433 Fuel Level Sensor2 Circ Hi Volts
    P1441 EVAP Emission Sys Flow during Non-Purge
    P1442 EVAP Vacuum Sw. Hi Volts duringIgnition. On
    P1450 Barometric Press Sensor Circ
    P1451 Barometric Press Sensor Perf
    P1460 Cooling Fan Ctrl Sys
    P1480 Fan Sec Lo With Lo Fan On
    P1481 Fan Sec Lo With Hi Fan On
    P1483 Eng Cooling Sys Perf
    P1500 Starter Signal Circ
    P1501 Vehicle Speed Sensor Circ Interm
    P1501 Theft Deterrent Sys
    P1502 Theft Deterrent Fuel Enable Signal Not
    P1503 Theft Deterrent Sys-Password Incorrect
    P1504 Vehicle Speed Output Circ
    P1508 IAC Sys Lo RPM
    P1509 IAC Sys Hi RPM
    P1510 Back Up Power Supply
    P1511 Throttle Ctrl Sys-Backup Sys Perf
    P1514 Air Flow to TP Sensor Correlation Hi
    P1515 Electronic Throttle Sys Throttle Pos
    P1516 Electronic Throttle Mod Throttle Pos
    P1517 Electronic Throttle Mod
    P1518 Electronic Throttle Mod to PCM Comm
    P1519 Electronic Throttle Mod Lo Volts Comm.Disable
    P1520 Gear Indicator Sys
    P1521 Trans Engaged at Hi Throttle Angle
    P1522 Park/Neutral to Drive/Reverse at Hi RPM
    P1523 Elec. Throttle Ctrl Throttle Return
    P1524 TP Sen. Learned Cl. Throttle. Angle ?Out of Range
    P1525 Throttle Body Service Required
    P1526 TP Sensor Learn Not Complete
    P1527 Trans. Range/Press Switch Comparison
    P1528 Governor
    P1529 Heated Windshield Request Problem
    P1530 Ignition Timing Adjustment Switch Circ
    P1531 A/C Lo Side Temp Sensor Fault
    P1532 A/C Evaporator Temp Sensor Circ LoVoltage
    P1533 A/C Evaporator Temp Sensor Circ HiVoltage
    P1534 A/C Hi Side Temp. Sensor Lo Voltage
    P1535 A/C Hi Side Temp Sensor Circ
    P1536 A/C Sys-ECT Over Temp
    P1537 A/C Request Circ Lo Voltage
    P1538 A/C Request Circ Hi Voltage
    P1539 A/C Clutch Status Circ High Volts
    P1540 A/C Sys Hi Press
    P1541 A/C Hi Side Over Temp
    P1542 A/C Sys Hi Press Hi Temp
    P1543 A/C Sys Perf
    P1544 A/C Refrigerant Condition Very Lo
    P1545 A/C Clutch Relay Ctrl Circ
    P1546 A/C Clutch Status Circ Lo Voltage
    P1547 A/C Sys Perf Degraded
    P1548 A/C Recirculation Circ
    P1554 Cruise Engaged Circ Hi Voltage
    P1555 Electronic Variable Orifice Output
    P1558 Cruise Ctrl Servo Indicates Lo
    P1559 Cruise Ctrl Power Mgmt Mode
    P1560 Cruise Ctrl Sys-Transaxle Not In Drive
    P1561 Cruise Vent Solenoid
    P1562 Cruise Vacuum Solenoid
    P1563 Cruise Vehicle Speed/Set SpeedDifference Too Hi
    P1564 Cruise Ctrl Sys-Vehicle Accel Too Hi
    P1566 Cruise Ctrl Sys-Engine RPM Too Hi
    P1567 Cruise Ctrl Sys-Active Braking CtrlActive
    P1568 Cruise Servo Stroke Greater thanCommanded in Cruise
    P1569 Cruise Servo Stroke Hi While not inCruise
    P1570 Cruise Ctrl Sys-Traction Ctrl Active
    P1571 TCS PWM Circ No Frequency
    P1572 ASR Active Circ Lo Too Long
    P1573 PCM/EBTCM Serial Data Circ
    P1574 EBTCM Sys-Stop Lamp Switch Circ Hi Volts
    P1575 Extended Travel Brake Sw. Circ Hi Volts
    P1576 BBV Sensor Circ Hi Voltage
    P1577 BBV Sensor Circ Lo Voltage
    P1578 BBV Sensor Circ Lo Vacuum
    P1579 P/N to D/R at Hi Throttle Angle
    P1580 Cruise Move Circ Lo Voltage
    P1581 Cruise Move Circ Hi Voltage
    P1582 Cruise Direction Circ Lo Voltage
    P1583 Cruise Direction Circ Hi Voltage
    P1584 Cruise Ctrl Disabled
    P1585 Cruise Inhibit Ctrl Circ
    P1586 Cruise Ctrl Brake Switch 2 Circ
    P1587 Cruise Ctrl Clutch Ctrl Circ Lo
    P1588 Cruise Ctrl Clutch Ctrl Circ Hi
    P1599 Eng Stall or Near Stall Detected
    P1600 PCM Battery/TCM Watchdog
    P1601 Serial Comm. Problem with Device 1
    P1602 Loss of EBTCM Serial Data
    P1603 Loss of SDM Serial Data
    P1604 Loss of IPC Serial Data
    P1605 Loss of HVAC Serial Data
    P1606 Serial Comm Problem with Device 6
    P1607 Serial Comm Problem with Device 7
    P1608 Serial Comm Problem with Device 8
    P1609 Loss of TCS Serial Data
    P1610 Loss of PZM Serial Data
    P1611 Loss of CVRTD Serial Data
    P1612 Loss of IPM Serial Data
    P1613 Loss of DIM Serial Data
    P1614 Loss of RIM Serial Data
    P1615 Loss of VTD Serial Data
    P1617 Engine Oil Level Switch Circ
    P1619 Engine Oil Life Monitor Reset Circ
    P1620 Lo Coolant Circ
    P1621 PCM Memory Perf
    P1622 Cylinder Select
    P1623 Trans Temp Pull-Up Resistor
    P1624 Customer Snapshot Data Available
    P1625 PCM Sys Reset
    P1626 Theft Deterrent Sys Fuel Enable Circ
    P1627 A/D Perf
    P1628 ECT Pull-Up Resistor
    P1629 Theft Deterrent Sys-Cranking Signal
    P1630 Theft Deterrent Sys-PCM In Learn Mode
    P1631 Theft Deterrent Sys-Password Incorrect
    P1632 Theft Deterrent Sys-Fuel disabled
    P1633 Ignition Supply Power Circ Lo Voltage
    P1634 Ignition 1 Power Circ Lo Voltage
    P1635 5 Volt Ref Lo
    P1636 PCM Stack Overrun
    P1637 Generator L-Terminal Circ
    P1638 Generator F-Terminal Circ
    P1639 5 Volt Ref 2 Circ
    P1640 Driver 1-Input Hi Voltage
    P1641 FC Relay 1 Ctrl Circ
    P1642 FC Relay 2 and 3 Ctrl Circ
    P1643 Engine Speed Output Circ
    P1644 Traction Ctrl Delivered Torque OutputCirc
    P1645 EVAP Emission (EVAP) Vent Solenoid CtrlCirc
    P1646 Driver 1 Line 6
    P1647 Driver 1 Line 7
    P1650 Driver 2-Input Hi Voltage
    P1651 Fan 1 Relay Ctrl Circ
    P1652 VSS Output Circ
    P1653 Oil Level Lamp Ctrl Circ
    P1654 Service Throttle Soon Lamp Ctrl Circ
    P1655 EVAP Purge Solenoid Ctrl Circ
    P1656 Driver 2 Line 6
    P1657 1-4 Up shift Solenoid Ctrl Circ
    P1658 Starter Enable Relay Ctrl Circ
    P1660 Cooling Fans Ctrl Circ
    P1661 MIL Ctrl Circ
    P1662 Cruise Ctrl Inhibit Ctrl Circ
    P1663 Oil Life Lamp Ctrl Circ
    P1664 1-4 Up shift Lamp Ctrl Circ
    P1665 Driver 3 Line 5
    P1666 Driver 3 Line 6
    P1667 Reverse Inhibit Solenoid Ctrl Circ
    P1669 ABS Unit Expected
    P1670 Driver 4
    P1671 Driver 4 Line 1
    P1672 Lo Engine Oil Level Lamp Ctrl Circ
    P1673 Engine Hot Lamp Ctrl Circ
    P1674 Tachometer Ctrl Circ
    P1675 EVAP Vent Solenoid Ctrl Circ
    P1676 Driver 4 Line 6
    P1677 Driver 4 Line 7
    P1680 Driver 5
    P1681 Driver 5 Line 1
    P1682 Driver 5 Line 2
    P1683 Driver 5 Line 3
    P1684 Driver 5 Line 4
    P1685 Driver 5 Line 5
    P1686 Driver 5 Line 6
    P1687 Driver 5 Line 7
    P1689 Delivered Torque Circ Fault
    P1690 ECM Loop Overrun
    P1691 Coolant Gage Circ Lo Voltage
    P1692 Coolant Gage Circ Hi Voltage
    P1693 Tachometer Circ Lo Voltage
    P1694 Tachometer Circ Hi Voltage
    P1695 Remote Keyless Entry Circ Lo
    P1696 Remote Keyless Entry Voltage Hi
    P1700 Trans. MIL Request
    P1701 Trans. MIL Request Circ
    P1705 P/N Signal Output Circ
    P1740 Torque Reduction Signal Circ
    P1743 TP Signal from ECM
    P1760 TCM Supply Volts Interrupted
    P1779 Eng Torque Delivered to TCM Signal
    P1780 Park/Neutral Pos [PNP] Switch Circ
    P1781 Eng Torque Signal Circ
    P1790 Trans Ctrl Mod Checksum
    P1791 Trans Ctrl Mod Loop
    P1792 Trans Ctrl Mod Reprogrammable Memory
    P1792 ECM to TCM Eng Coolant Signal
    P1793 Trans Ctrl Mod Stack Overrun
    P1795 CAN Bus-Throttle Body Pos
    P1800 TCM Power Relay Ctrl Circ
    P1801 Perf Selector Switch Failure
    P1804 Gnd Ctrl Relay
    P1810 TFP Valve Pos Switch Circ
    P1811 Maximum Adapt and Long Shift
    P1812 Trans over Temp Condition
    P1813 Torque Ctrl
    P1814 Torq Conv Overstressed
    P1815 Trans Range Switch-Start In Wrong Range
    P1816 TFP Valve Pos Sw.-Park/Neutral withDrive Ratio
    P1817 TFP Valve Pos Sw.-Reverse With DriveRatio
    P1818 TFP Valve Pos Sw.-Drive Without DriveRatio
    P1819 Internal Mode Switch-No Start\WrongRange
    P1820 Internal Mode Switch Circ A Low
    P1822 Internal Mode Switch Circ B High
    P1823 Internal Mode Switch Circ P Low
    P1825 Internal Mode Switch-Invalid Range
    P1826 Internal Mode Switch Circ C-High
    P1831 PC Solenoid Power Circ-Low Volts
    P1833 A/T Solenoids Power Circ-Low Volts
    P1835 Kick-Down Switch Circ
    P1836 Kick-Down Switch Failed Open
    P1837 Kick-Down Switch Failed Short
    P1842 1-2 Shift Solenoid Circ Low Volts
    P1843 1-2 Shift Solenoid Circ High Volts
    P1844 Torque Reduction Signal Circ Desired ByTCM
    P1845 2-3 Shift Solenoid Circ Low Volts
    P1847 2-3 Shift Solenoid Circ High Volts
    P1850 BrakeBand Apply Solenoid Circ
    P1851 Brake Band Apply Solenoid Perf
    P1852 Brake Band Apply Solenoid Low Volts
    P1853 Brake Band Apply Solenoid High Volts
    P1860 TCC PWM Solenoid Circ Electrical
    P1864 Torq Conv Clutch Circ
    P1868 Trans Fluid Life
    P1870 Trans Component Slipping
    P1871 Undefined Gear Ratio
    P1873 TCC Stator Temp Switch Circ Low
    P1874 TCC Stator Temp Switch Circ High
    P1875 4WD Low Switch Circ Electrical
    P1884 TCC Enable/Shift Light Circ
    P1886 Shift Timing Solenoid
    P1887 TCC Release Switch Circ
    P1890 ECM Data Input Circ
    P1890 Throttle Pos Signal Input
    P1891 Throttle Pos Sensor PWM Signal Low
    P1892 Throttle Pos Sensor PWM Signal High
    P1893 Eng Torque Signal Low Volts
    P1894 Eng Torque Signal High Volts
    P1895 TCM to ECM Torque Reduction Circ
    P2000 NOx Trap Efficiency Below ThresholdBank1
    P2001 NOx Trap Efficiency Below ThresholdBank2
    P2002 Particulate Trap Efficiency BelowThreshold Bank1
    P2003 Particulate Trap Efficiency BelowThreshold Bank2
    P2004 Intake Manifold Runner Ctrl Stuck OpenBank1
    P2005 Intake Manifold Runner Ctrl Stuck OpenBank2
    P2006 Intake Manifold Runner Ctrl Stuck ClosedBank1
    P2007 Intake Manifold Runner Ctrl Stuck ClosedBank2
    P2008 Intake Manifold Runner Ctrl Circ/OpenBank1
    P2009 Intake Manifold Runner Ctrl Circ LowBank1
    P2010 Intake Manifold Runner Ctrl Circ HighBank1
    P2011 Intake Manifold Runner Ctrl Circ/OpenBank2
    P2012 Intake Manifold Runner Ctrl Circ LowBank2
    P2013 Intake Manifold Runner Ctrl Circ HighBank2
    P2014 Intake Manifold Runner Pos Sensor/SwitchCirc Bank1
    P2015 Intake Manifold Runner Pos Sensor/SwitchCirc
    Range/Perf Bank1
    P2016 Intake Manifold Runner Pos Sensor/SwitchCirc Low Bank1
    P2017 Intake Manifold Runner Pos Sensor/SwitchCirc High Bank1
    P2018 Intake Manifold Runner Pos Sensor/SwitchCirc Interm Bank1
    P2019 Intake Manifold Runner Pos Sensor/SwitchCirc Bank2
    P2020 Intake Manifold Runner Pos Sensor/SwitchCirc Range/Perf Bank2
    P2021 Intake Manifold Runner Pos Sensor/SwitchCirc Low Bank2
    P2022 Intake Manifold Runner Pos Sensor/SwitchCirc High Bank2
    P2023 Intake Manifold Runner Pos Sensor/SwitchCirc Interm Bank2
    P2024 EVAP Fuel Vapor Temp Sensor Circ
    P2025 EVAP Fuel Vapor Temp Sensor Perf
    P2026 EVAP Fuel Vapor Temp Sensor Circ LowVoltage
    P2027 EVAP Fuel Vapor Temp Sensor Circ HighVoltage
    P2028 EVAP Fuel Vapor Temp Sensor Circ Interm
    P2029 Fuel Fired Heater Disabled
    P2030 Fuel Fired Heater Perf
    P2031 Exhaust Gas Temp Sensor Circ Bank1Sensor 2
    P2032 Exhaust Gas Temp Sensor Circ Low Bank1Sensor 2
    P2033 Exhaust Gas Temp Sensor Circ High Bank1Sensor 2
    P2034 Exhaust Gas Temp Sensor Circ Bank2Sensor 2
    P2035 Exhaust Gas Temp Sensor Circ Low Bank2Sensor 2
    P2036 Exhaust Gas Temp Sensor Circ High Bank2Sensor 2
    P2037 Reductant Inj Air Press Sensor Circ
    P2038 Reductant Inj Air Press Sensor CircRange/Perf
    P2039 Reductant Inj Air Press Sensor Circ LowInput
    P2040 Reductant Inj Air Press Sensor Circ HighInput
    P2041 Reductant Inj Air Press Sensor CircInterm
    P2042 Reductant Temp Sensor Circ
    P2043 Reductant Temp Sensor Circ Range/Perf
    P2044 Reductant Temp Sensor Circ Low Input
    P2045 Reductant Temp Sensor Circ High Input
    P2046 Reductant Temp Sensor Circ Interm
    P2047 Reductant Injector Circ/Open Bank1 Unit 1
    P2048 Reductant Injector Circ Low Bank1 Unit 1
    P2049 Reductant Injector Circ High Bank1 Unit1
    P2050 Reductant Injector Circ/Open Bank2 Unit1
    P2051 Reductant Injector Circ Low Bank2 Unit 1
    P2052 Reductant Injector Circ High Bank2 Unit1
    P2053 Reductant Injector Circ/Open Bank1 Unit2
    P2054 Reductant Injector Circ Low Bank1 Unit 2
    P2055 Reductant Injector Circ High Bank1 Unit2
    P2056 Reductant Injector Circ/Open Bank2 Unit2
    P2057 Reductant Injector Circ Low Bank2 Unit 2
    P2058 Reductant Injector Circ High Bank2 Unit2
    P2059 Reductant Inj [COLOR=#0072BC !important][COLOR=#0072BC ! important]Air [COLOR=#0072BC !important]Pump[/COLOR][/COLOR][/COLOR] Ctrl Circ/Open
    P2060 Reductant Inj Air Pump Ctrl Circ Low
    P2061 Reductant Inj Air Pump Ctrl Circ High
    P2062 Reductant Supply Ctrl Circ/Open
    P2063 Reductant Supply Ctrl Circ Low
    P2064 Reductant Supply Ctrl Circ High
    P2065 Fuel Level SensorB Circ
    P2066 Fuel Level SensorB Perf
    P2067 Fuel Level SensorB Circ Low
    P2068 Fuel Level SensorB Circ High
    P2069 Fuel Level SensorB Circ Interm
    P2070 Intake Manifold Tuning (IMT) Valve StuckOpen
    P2071 IMT Valve Stuck Closed
    P2075 IMT Valve Pos Sensor/Switch Circ
    P2076 IMT Valve Pos Sensor/Switch CircRange/Perf
    P2077 IMT Valve Pos Sensor/Switch Circ Low
    P2078 IMT Valve Pos Sensor/Switch Circ High
    P2079 IMT Valve Pos Sensor/Switch Circ Interm
    P2080 Exhaust Gas Temp Sensor Circ Range/PerfBank1 Sensor 1
    P2081 Exhaust Gas Temp Sensor Circ IntermBank1 Sensor 1
    P2082 Exhaust Gas Temp Sensor Circ Range/PerfBank2 Sensor 1
    P2083 Exhaust Gas Temp Sensor Circ IntermBank2 Sensor 1
    P2084 Exhaust Gas Temp Sensor Circ Range/PerfBank1 Sensor 2
    P2085 Exhaust Gas Temp Sensor Circ IntermBank1 Sensor 2
    P2086 Exhaust Gas Temp Sensor Circ Range/PerfBank2 Sensor 2
    P2087 Exhaust Gas Temp Sensor Circ IntermBank2 Sensor 2
    P2088 A Camshaft Pos Actuator Ctrl Circ LowBank1
    P2089 A Camshaft Pos Actuator Ctrl Circ HighBank1
    P2090 B Camshaft Pos Actuator Ctrl Circ LowBank1
    P2091 B Camshaft Pos Actuator Ctrl Circ HighBank1
    P2092 A Camshaft Pos Actuator Ctrl Circ LowBank2
    P2093 A Camshaft Pos Actuator Ctrl Circ HighBank2
    P2094 B Camshaft Pos Actuator Ctrl Circ LowBank2
    P2095 B Camshaft Pos Actuator Ctrl Circ HighBank2
    P2096 Post Catalyst Fuel Trim Sys Too LeanBank1
    P2097 Post Catalyst Fuel Trim Sys Too RichBank1
    P2098 Post Catalyst Fuel Trim Sys Too LeanBank2
    P2099 Post Catalyst Fuel Trim Sys Too RichBank2
    P2100 Throttle Actuator Ctrl Motor Circ/Open
    P2101 Throttle Actuator Ctrl Motor CircRange/Perf
    P2102 Throttle Actuator Ctrl Motor Circ Low
    P2103 Throttle Actuator Ctrl Motor Circ High
    P2104 Throttle Actuator Ctrl Sys-Forced Idle
    P2105 Throttle Actuator Ctrl Sys-Forced EngineShutdown
    P2106 Throttle Actuator Ctrl Sys-ForcedLimited Power
    P2107 Throttle Actuator Ctrl Mod Processor
    P2108 Throttle Actuator Ctrl Mod Perf
    P2109 Throttle/Pedal Pos SensorA Minimum StopPerf
    P2110 Throttle Actuator Ctrl Sys-ForcedLimited RPM
    P2111 Throttle Actuator Ctrl Sys-Stuck Open
    P2112 Throttle Actuator Ctrl Sys-Stuck Closed
    P2113 Throttle/Pedal Pos SensorB Minimum StopPerf
    P2114 Throttle/Pedal Pos Sensor C Minimum StopPerf
    P2115 Throttle/Pedal Pos Sensor D Minimum StopPerf
    P2116 Throttle/Pedal Pos Sensor E Minimum StopPerf
    P2117 Throttle/Pedal Pos Sensor F Minimum StopPerf
    P2118 Throttle Actuator Ctrl Motor CurrentRange/Perf
    P2119 Throttle Actuator Ctrl Throttle BodyRange/Perf
    P2120 Throttle/Pedal Pos Sensor/Switch D Circ
    P2121 Throttle/Pedal Pos Sensor/Switch D CircRange/Perf
    P2122 Throttle/Pedal Pos Sensor/Switch D CircLow Input
    P2123 Throttle/Pedal Pos Sensor/Switch D CircHigh Input
    P2124 Throttle/Pedal Pos Sensor/Switch D CircInterm
    P2125 Throttle/Pedal Pos Sensor/Switch E Circ
    P2126 Throttle/Pedal Pos Sensor/Switch E CircRange/Perf
    P2127 Throttle/Pedal Pos Sensor/Switch E CircLow Input
    P2128 Throttle/Pedal Pos Sensor/Switch E CircHigh Input
    P2129 Throttle/Pedal Pos Sensor/Switch E CircInterm
    P2130 Throttle/Pedal Pos Sensor/Switch F Circ
    P2131 Throttle/Pedal Pos Sensor/Switch F CircRange Perf
    P2132 Throttle/Pedal Pos Sensor/Switch F CircLow Input
    P2133 Throttle/Pedal Pos Sensor/Switch F CircHigh Input
    P2134 Throttle/Pedal Pos Sensor/Switch F CircInterm
    P2135 Throttle/Pedal Pos Sensor/Switch A / BVoltage Correlation
    P2136 Throttle/Pedal Pos Sensor/Switch A / CVoltage Correlation
    P2137 Throttle/Pedal Pos Sensor/Switch B / CVoltage Correlation
    P2138 Throttle/Pedal Pos Sensor/Switch D / EVoltage Correlation
    P2139 Throttle/Pedal Pos Sensor/Switch D / FVoltage Correlation
    P2140 Throttle/Pedal Pos Sensor/Switch E / FVoltage Correlation
    P2141 Exhaust Gas Recirculation Throttle CtrlCirc Low
    P2142 Exhaust Gas Recirculation Throttle CtrlCirc High
    P2143 Invalid Data From Body Ctrl Mod A
    • #47
      От: Първи проблем с Renegade 800X
      Хубаво е че си се справил. Искам да те питам за шарнирите разбра ли от какво стават?
      • #48
        Колегата Paksss малко несериозен излезе,с риск да го обидя от 2 месеца ги праща тея шарнири и едни гуми щеше да ми праща но уви,сигурно е много зает и няма време,като съдя по себе си и аз по някога нямам време да се усмихна и хич не ми се занимава с глупости.Надявам се все пак да намери малко време и да ми изпрати нещо,иначе не съм имал време да се занимавам и да търся,последно нищо не успях да намеря.
        Не е важно да влагаш чувства, важното е да чувстваш влага...
        • #49
          За съжаление пак ще подновявам темата,последните няколко карания забелязвам че когато мина 70-80км и започва да губи мощност,прекъсва все едно няма гориво и от време на време аха аха да изгасне,подавам газ то забива муцуната.Днес точно когато за пореден път се появи този проблем спряхме да почиваме и чувам едно съскане от резервоара,развиха капачката и се беше образувал вакум.Помислих че отдушника се е запушил нещо и че проблема се дължи на това,но НЕ.Продължаваме да караме и 20км мъки,до към 4000об/мин долу горе върви,после ту върви ту неще,луда работа.Спряхме да ядем и на тръгване въртя ключа и чувам странен звук от помпата,не е нормалното бръмчене,а едно такова изтормозено все едно стърже нещо и бръмчи три пъти по дълго от обикновено.Помислих че помпата е заминала и се надявах поне да ме прибере до гаража,обаче за мое голямо учудване няколко минути по късно всичко се оправи и се прибрах без проблеми,в гаража се оказа че звукът на помпата пак си е нормален и всичко е наред.
          Някой имал ли е подобен проблем и възможно ли е тази помпа да не работи нормално само когато в резервоара има между 10-13л гориво.Отново много странен проблем.
          Помагайте ако можете.
