Близкия изток
  • От: Близкия изток
    Great stories and pictures Doug! I enjoy reading it! Your bike is great. You can never get bored with it
    • От: Близкия изток
      Какво става с Дъг? Не го пуснаха в Сирия ли? Гледам, че се върна в Турция, след като стоя повече от ден на Турско-Сирийската граница и вече е в Караманмараш.
      Златомир Попов - Forry
      • От: Близкия изток
        Crossing the border back to turkey sucked, of course nothing on the Iraq side is organized, AT ALL
        I got my passport stamped, & headed for the exit, where I figured they would check out the bike & let me out.
        No, I have to go back to the import area, & do everything like I was coming in, only backwards.
        Finally, thats all done, & I go to TR.
        this is the worse TR border Id been to. buncha idiots, & very paranoid about anything coming in that shouldnt.
        Took awhile, but finally got thru, right at dark. I went to the same hotel from a couple days before, not the cheapest, but its nice, & safe parking.
        Heading west again, along the border for Syria.
        Bike was running a little rough, so I found the only tree for 50 miles, & parked under it to see what was up.
        From the way the points were sparking, I figured the condensor was bad.
        No problem, as I always carry a couple extra, theres a small parts stash under the battery.
        When I pulled the battery, & looked at it, I found it was dry. I refilled it with water, & checked the charging system, it seemed
        to be pushing a little too much voltage.
        But, it seems to be better now that I've ridden it some, & the coils arent so hot.
        Im guessing the battery was overcharging a little, boiled the water out, which made the alternator work harder, making more volts,
        which could be why the coils were cooking.
        never heard of it happening like that, but thats the only thing I can think of.
        Its runnin good now, and thats what is important!
        this part of TR is hot, flat, & boring. he roads are ok, but they are still working on them.
        I found a hotel in a town, then walked around to find an atm.
        people have changed. Sure, everyone still says hello, but its not followed by 'money money'
        I walk down the street, & people stop me to say hi, where am I from, please come to have some tea.
        Much nicer here!
        Прекосяването на границата обратно към Турция беше гадно. Естествено нямаше никаква организация от иракската страна, АМА ИЗОБЩО.
        Подпечатаха ми паспорта и се насочих към изхода, където предполагах, че ще ми проверят мотора и ще ме пуснат навън.
        Не, трябвало да се върна обратно в зоната за влизащи и да направя всичко, което свърших на влизане, само че в обратен ред.
        Най-накрая, всичко е готово и аз минавам в Турция.
        Това е най-скапаната турска граница, през която съм минавал. Една камара идиоти, които са адски параноични относно всичко влизащо в страната, което не би трябвало да влиза. Отне ми известно време, но най-накрая преминах, точно на мръкване. Отидох в същия хотел, в който бях преди няколко дни, който не е най-евтиния, но е хубав и има обезопасен паркинг.
        Насочвам се отново на запад, по продължение на границата със Сирия.
        Моторът не върви много гладко, затова откривам единственото дърво в продължение на 80 км и паркирам под него, за да проверя какво не е наред.
        От начина по който искреше при чукчето и наковалнята, реших че кондензатора е повреден.
        Няма проблем, тъй като винаги нося няколко резервни. Имам си запас от дребни части под акумулатора.
        Когато свалих акумулатора и го разгледах, открих че е сух. Долях му вода и прегледах зарядната система. Изглеждаше, че дава твърде високо зарядно напрежение.
        Но сега, след като вече го бял карал известно време, изглеждаше по-добре и бобините не бяха толкова горещи.
        Предполагам, че акумулатора леко се е презареждал и е изпарил водата, което е накарало алтернатора да работи по-усилено и да произвежда по-високо напрежение.
        Което може и да е причината бобините да се нагряваха толкова.
        Не съм чувал да се случва нещо подобно, но това е единственото обяснение, което ми идва на ум.
        Сега работи добре и това е важното!
        Тази част от Турция е гореща, равнинна и скучна. Пътищата са наред, но все още се работи по тях.
        Намерих хотел в един град, а после се поразходих за да намеря банкомат.
        Хората се промениха. Действително, все още всички ти казват "здравей", но това не е последвано от "пари, пари".
        Вървя си по улицата, а хората спират за да ми кажат здравей, да попитат откъде съм, "моля, заповядайте на по чай".
        Тук е много по-хубаво!
        farewell to Iraq (for now)
        Сбогом на Ирак (засега)
        welcome back to turkey
        Добре дошли отново в Турция
        roadside workshop
        Крайпътна работилница
        Последно редактирано от sabin; 08-09-10, 10:19.
        • От: Близкия изток
          the fence on the left is the border with Syria
          Оградата отляво е границата със Сирия.
          while I was having tea with these guys, a car pulled out in front of a bike.
          no one hurt tho, they picked up the bike, yelled a bit, then both went on their way
          these little chinese bikes are everywhere in this region
          Докато пиех чай с тези хора, една кола изскочи пред един мотор.
          За радост нямаше пострадали. След като вдигнаха мотора, те си покрещяха малко и после всеки си хвана пътя.
          В този регион е пълно с такива малки китайски мотори.
          Последно редактирано от sabin; 08-09-10, 06:47.
          • От: Близкия изток
            I stopped at Harran, an ancient city, famous mostly for the beehive houses here.
            It was pretty cool, there had been a city here for thousands of years.
            Many civlizations thru the years, hittites, romans, persians, & then of course the mongols came & tore it up.
            those mongols were pretty badassed.
            they tore up everything!
            Спрях в Харан - древен град, известен най-вече с къщите си, които наподобяват пчелни кошери.
            Той беше доста интересен. Имало е град на това място в продължение на хилядолетия.
            Много цивилизации са били тук през годините - хети, римляни, перси. И накрая естествено, идват монголците и го разрушават.
            Тези монголци са били доста брутални.
            Разрушавали са всичко!
            the old gate in front
            Старата порта отпред
            some of the beehive houses, they had some restored as a museum also
            Няколко от кошероподобните къщи. Част от тях са били възстановени и превърнати в музеи.
            Последно редактирано от sabin; 08-09-10, 07:01.
            • От: Близкия изток
              • От: Близкия изток
                the old fortress
                • От: Близкия изток
                  • От: Близкия изток
                    off in the distance is the old university, the tall tower was for astronomy
                    На заден план се вижда старият университет. Високата кула е била предназначена за астрономия.
                    all around it is an underground city, theres still excavating going on
                    Университетът е заобикален от всички страни от подземен град. Все още се извършват разкопки по него.
                    Последно редактирано от sabin; 08-09-10, 07:06.
                    • От: Близкия изток
                      after Harran, I went to the syria border. got out of turkey, crossed the border, & went to the syria part.
                      cop looks at my passport. 'where is visa?'
                      I need to buy one here.
                      hmm, wait a minute
                      he jumps on a bike with my passport, & rides off.
                      a little while later he comes back
                      sorry, cant buy visa here.
                      shit.
                      hmm, is there any way I can get a visa?
                      is there an extra 'fee' I can pay?
                      (the diplomatic way to offer a bribe)
                      nope, cant get one here.
                      ok, so back to turkey.
                      Now you CAN buy a visa at the border at Killic, TR border, but thats about 250km SW of here.
                      but I guess thats the only one. Well, I had to try!
                      so that leaves a dilemma
                      do I travel 250km sw, just to ride straight south into syria?
                      (I had wanted to travel at an angle thru syria, coming out at Killic, that way it was adding more miles, but not going the wrong way, which leads to backtracking, which I hate doing)
                      plus I have 2 tires getting a bit 'slippery', clutch is about shot, chain is sloppy.
                      on top of this, I lost almost 2 weeks dickin around waiting on parts, not to mention the $ I lost while sitting.
                      going into syria will cost AT LEAST $200 just ad the border, for visa, import fees, insurance, etc.
                      the same for Lebanon, & maybe more (Leb is expensive to get a bike into)
                      then again, to get BACK into Syria.
                      I have to be back in Bulgaria in 2 weeks.
                      So I feel like a pussy, but I guess I'm just gonna wander thru Turkey, see some stuff, & head back to BG.
                      I guess technically I DID go into Syria, altho not very far.
                      hahahahahha
                      I had already cut Jordan out of my plans, due to time, so I will just plan on returning & seeing the whole area later.
                      maybe by then I'll have better luck with visa's for Saudi & Iran
                      Im sure I'll still have some fun & see some cool stuff in the next week tho!
                      Had I known this was gonna happen, I'da spent a few more days in Iraq.
                      At least I got to visit there, that was probably the main place I wanted to visit, if for no other reason than to say 'I did'
                      След Харан, се запътих към сирийската граница. Излязох от Турция, пресякох границата и стигнах до сирийската част.
                      Ченгето разглежда паспорта ми и пита "Къде е визата?"
                      - Трябва да си купя виза оттук.
                      - Хмм, изчакайте малко.
                      Той се метна на един мотор с моя паспорт и замина нанякъде.
                      Малко по-късно се върна обратно.
                      - Съжалявам, не можете да купите виза оттук.
                      Мамка му.
                      - Хмм, има ли някакъв начин да получа виза? Има ли някаква допълнителна 'такса', която да платя?
                      (дипломатичния начин да предложиш подкуп)
                      - Няма начин. Не може да се купи виза оттук.
                      И така, обратно в Турция.
                      Всъщност, МОЖЕШ да си купиш виза на границата в Килик, на турската граница, но това е на около 250 км на югозапад оттук.
                      Но предполагам, това е единственото място, където може. Е, длъжен бях да опитам!
                      Това обаче ме поставя пред дилема.
                      Дали да пропътувам 250 км на югозапад и след това да карам на право на юг в Сирия?
                      (Искаше ми се да пътувам под ъгъл през Сирия и да излеза през Килик. По този начин щях да пропътувам повече километри, но нямаше да се движа в грешната посока, което води до връщане по вече преминат маршрут, а аз мразя това).
                      Освен това, имам две вече 'поизтъркани' гуми, съединителя е почти заминал и веригата е хлабава.
                      На всичко отгоре, загубих почти две седмици да се мотая насам-натам, докато чаках доставка на резервни части, да не говорим за похарчените пари докато чаках.
                      Влизането в Сирия ще струва ПОНЕ 200 долара само на границата, за виза, вносни такси, застраховка, и т.н.
                      Същото важи и за Ливан, а може би и повече (в Ливан излиза доста солено да се вкара мотор).
                      А после отново, при влизането ОБРАТНО в Сирия.
                      А трябва да съм в България след две седмици.
                      Чувствам се като п*тка, но изглежда ще попътувам напосоки през Турция, ще разгледам това-онова и ще се насоча към България.
                      Предполагам, че от техническа гледна точка БЯХ в Сирия, просто не много навътре.
                      хахахахахаха
                      Вече изключих Йордания от плановете ми, поради ограниченото време, така че просто ще планирам завръщане и разглеждане на целия район по-нататък във времето.
                      Може би дотогава ще извадя по-голям късмет с визите за Саудитска Арабия и Иран.
                      Сигурен съм, че въпреки всичко ще се забавлявам и ще видя някои готини неща през следващата седмица!
                      Ако знаех, че нещата ще се стекат по този начин, щях да прекарам няколко дена повече в Ирак.
                      Поне успях да го посетя. Това беше вероятно главното място, което исках да посетя, ако не за друго, дори и само за да кажа "Бях там".
                      Последно редактирано от sabin; 10-09-10, 10:46.
                      • От: Близкия изток
                        So back to Urfa, & find a room. I got there right at dark, traffic is horrible. Im looking for a hotel, finally find one, but it
                        looks REAL fancy & expensive, like a castle. Well, doesnt hurt to ask, so I go in to see.
                        yep, its expensive! I see the 5 stars above the door, thats a giveaway.
                        So I ask the clerk, if there is something close by thats a little cheaper?
                        he asks what my price range is.
                        One thing I have learned in travelling (doesnt work everywhere) but to ask this, then tell em your looking for something 25% or so
                        cheaper, and usually they will offer you the room at your price.
                        its sorta like priceline.com on the road.
                        So I got the room for less, & the bellhop carried my dirty bags up to the room, carefully, as to not get anything on him
                        hahaha
                        he was dressed like MC Hammer.
                        I had a room overlooking a huge castle on top of a hill, so I got up early to walk around & see it.
                        И така, обратно към Урфа и търсене на хотел. Стигнах там точно по мръкване, а движението беше ужасно. Обикалям в търсене на хотел и най-накрая откривам един, но той изглежда НАИСТИНА луксозен и скъп, и прилича на замък. Е, не боли човек да попита, така че влизам вътре за да проверя.
                        Да, определено цените са високи! Виждам 5-те звезди над вратата, което си е индикация.
                        Затова питам служителя на рецепцията, дали наоколо има хотел, който е малко по-евтин?
                        Той ме пита за какъв бюджет става дума.
                        Едно нещо, което научих по време на пътуванията ми (не важи за всички места) е когато ти зададат подобен въпрос - отговори че търсиш нещо около 25% по-евтино, и обикновено ще ти предложат стая на твоята цена.
                        Нещо като priceline.com на колела.
                        И така, получих стая на по-ниска цена, а пиколото качи мръсните ми чанти до стаята, като внимаваше да не се изцапа.
                        хахаха
                        Той беше облечен като MC Hammer.
                        Дадоха ми стая с изглед към огромен замък на върха на хълма, така че станах рано за да се поразходя и да го разгледам.
                        Последно редактирано от sabin; 10-09-10, 10:22.
                        • От: Близкия изток
                          I guess when they widened the road, they just ripped down the houses that were in the way
                          Предполагам, че когато са разширявали пътя, просто са срутили къщите, които са пречели.
                          Последно редактирано от sabin; 10-09-10, 10:24.
                          • От: Близкия изток
                            legend says that king nimrod didnt like abraham here as he was destroying pagan gods, so he had him burned.
                            the fire turned to water, & the coals to fish.
                            Легендата гласи, че цар Нимрод не харесвал Авраам, защото той унищожавал езическите богове, и наредил да го изгорят.
                            Огънят се превърнал във вода, а въглените в риби.
                            the pools at the bottom are full of carp. they say if you catch the carp, you will go blind, so these are very spoiled fat fish.
                            many people feed them, and it becomes a frenzy, the fish actually come out of the water after food
                            Басейните на снимките по-долу гъмжат от шарани. Говори се, че ако хванеш някой от тях, ще ослепееш, така че това са много глезени дебели риби.
                            Много хора ги хранят и рибата направо се побърква и изскача от водата за храна.
                            Последно редактирано от sabin; 10-09-10, 10:35.
                            • От: Близкия изток
                              • От: Близкия изток
                                my crappy hotel
