Производство на медикаменти в полеви условия.
  • Производство на медикаменти в полеви условия.
    Да започнем с Penicillin-a. Ето и една извадка от световната мрежа:
    Did you know that penicillin can be grown outside of a lab? This mold-based antibiotic can be grown as a science project using a slice of bread. Please note that these instructions should be used for experimentation only; when there is a medical need for penicillin, it should be obtained through a doctor. Making penicillin does require some scientific equipment, and it is very important to keep the area sterile while you are growing penicillin. Here’s how to make penicillin:
    Supplies:
    Slice of bread or citrus peel
    750ml Erlenmeyer flask
    Media (see Step 4)
    1000ml (1 L) graduated cylinder
    Several clean milk bottles
    1. Prepare a penicillium culture.
    Expose a slice of bread or a citrus peel to a 70 degree Fahrenheit environment. A blue-green mold should develop.
    2. Sterilize the equipment. Place the flask in the oven at 315 degrees Fahrenheit for one hour, or sterilize in a pressure cooker for at least 15 minutes. Wash the milk bottles.
    3. Fill the Erlenmeyer flask. Cut the bread or citrus peel into small pieces and fill the flask. Allow to incubate in the dark at 70 degrees Fahrenheit for 5 days. After this incubation period, the flask can be stored in the refrigerator for no more than 10-14 days.
    4. Prepare the media. Dissolve the following ingredients, in the order listed, into 500ml of cold tap water: 44.0 grams Lactose Monohydrate, 25.0 grams cornstarch, 3.0 grams sodium nitrate, 0.25 grams magnesium sulfate, 0.50 grams potassium phosphate mono, 2.75 grams glucose monohydrate, 0.044 grams zinc sulfate, 0.044 grams manganese sulfate. Then add enough cold tap water to make one liter. Use hydrochloric acid to adjust the pH to between 5.0 and 5.5.
    5. Fill the bottles with media. Fill the milk bottles with this media. Use only enough so that when the bottle is placed in its side, the media does not reach the plug.
    6. Add the penicillin spores. First sterilize the bottles of media in a pressure cooker or in the stove, as you did the Erlenmeyer flask. When they have cooled, add approximately one tablespoon of the spores from the bread or citrus peel.
    7. Incubate the bottles. Allow the bottles to rest undisturbed on their sides at 70 degrees Fahrenheit for 7 days. If the culture has worked to produce penicillin, it will be in the liquid portion of the media following this incubation period. Finally, filter the media and refrigerate immediately. If you must use it, although this should be avoided, use as soon as possible.
    The penicillin made from this experiment should not be used unless it is a survival situation. It is possible for other, toxic molds to grow along with the penicillin, even if you know what you are doing. It is also possible for mold inhibitors to grow, stopping the growth of the penicillin spores.
    LZ1EMS
    От: Производство на медикаменти в полеви условия.
    Интересно , а така ли са правели пеницилина едно време ?
    0 8 9 8 4 8 1 3 3 0
      По подобен начин го е открил Флеминг
        Ако нямаш време за на български - пиши на ЛС, да го дадем на преводачите.
        Следващото лесно и мощно което се сешам, е пърхутката. Ама не помня как се казва на латински((
          Ако нямаш време за на български... да го дадем на преводачите.
          Пеницилинът може да бъде синтезиран и в домашни условия, с помощта на филийка хляб или кори от цитрусови плодове. Необходимо е да се отбележи, че инструкциите за това следва да се използват само за експерименти
          Когато имате нужда от антибиотик е необходимо да се обърнете към лекар, който да Ви го назначи
          За да е успешно култивирането на пеницилиновите спори е необходимо да имате оборудване, гарантиращо оптималната стерилност на експерименталната среда.
          Необходими са:
          - филийка хляб или кори от цитрусови плодове
          - Ерленмайерова колба от 750 ml
          - инкубационна среда (приготвя се по време на експеримента)
          - градуиран цилиндър от 1000 ml
          - няколко стъклени бутилки с широк отвор
          1. Поставете филийката хляб или цитрусовите кори на открито, при температура от 70 градуса по Фаренхайт - за няколко дни обичайно се развива синьо-зелена плесен.
          2. Колбата и стъклените бутилки се поставят в печката за един час, при температура от 315 градуса по Фаренхайт, или се изваряват в тенджера под налягане за около 15 минути.
          3. Филийката хляб или цитрусовите кори се раздробяват на малки парченца и се поставят в колбата. Последната се оставя да престои на тъмно в продължение на 5 дни, при температура от 70 градуса по Целзий. След това може да се съхранява в хладилник, но за не повече от две седмици.
          4. В 500 ml студена вода се разтварят: 44.0 g монохидратна лактоза, 25.0 g царевично нишесте, 3.0 g натриев нитрат, 0.25 g магнезиев сулфат, 0.50 g калиев монофосфат, 2.75 g монохидратна глюкоза, 0.044 g цинков сулфат, и 0.044 g манганов сулфат. Добавя се вода до 1000 ml, pH на разтвора се коригира до 5.0 и 5.5 с помощта на солна киселина.
          5. Стъклените бутилки се напълват с така получената инкубационна среда. Количеството на последната е такова, че при страничното им накланяне течността да не прелива.
          6. Към бутилките се добавя по една супена лъжица от раздробената филийка хляб / цитрусови кори.
          7. Бутилките се оставят при температура от 70 градуса по Целзий в продължение на една седмица. Пеницилинът се натрупва в течната компонента на инкубационната смес, която следва да се филтрира и съхрани при минусови температури. Ако е необходимо полученият разтвор следва да се използва възможно най-скоро.
          Синтезираният в резултат на този експеримент пеницилин не трябва да се прилага, освен в изключително екстремни условия. Въпреки предприетите мерки за стерилност е възможно да настъпи замърсяване с отглеждане на различни плесенни щамове, имащи подчертана токсичност спрямо човешкият организъм
          Последно редактирано от emanuilis; 26-12-11, 15:31.
          LZ1EMS
            Първоначално публикуван от emanuilis Преглед на мнение
            2. Колбата и стъклените бутилки се поставят в печката за един час, при температура от 315 градуса по Фаренхайт, или се изваряват в тенджера под налягане за около 15 минути...
            Нещо подобно требе да е:
            Редакция:
            Ако на някой модератор му се занимава може да редактира горното мнение и да изтрие това...
            И коментаторите...
              Тия няколкото дни или пък откритото къде ги видяхте??
              1. Prepare a penicillium culture. Expose a slice of bread or a citrus peel to a 70 degree Fahrenheit environment. A blue-green mold should develop.
              То така или иначе статията е за начеващи отровители, ама дайте поне преводът да е верен
                ,,Видяхме ги" между редовете - това е смислов, а не дословен превод.
                За първото си има работни пчелички, а за последното - Google Translate.
                p.s.1 в градуси по Целзий се получава съответно около 21 за 70 F и 157 за 315 F.
                p.s.2 допуснал съм неволна грешка, записвайки две от стойностите с Целзий - всичко следва да е с Фаренхайт.
                Последно редактирано от emanuilis; 26-12-11, 18:52.
                LZ1EMS
                  В случая "на открито" е много важен елемент. Това се прави с цел развитие на "флората и фауната" която очакваме. Няма ли достъп до атмосферата и свеж въздух е много вероятно да се развият само нежелани патогенни гъбички. Явно е важен балансът. В тази връзка е важно и да се знае, какъв все пак трябва да е хлябът. Истински или от този по магазините..., разликата е доста голяма според мен, най-вече поради голямата разлика в PH-то, което вероятно ще означава и различни резултати... Имайки предвид, че методът е стар, вероятно иде реч за пълнозърнест т.е. черен хляб приготвен с квас...
                  VPetrov.photography
                    В магазинския хляб има противоплесенни инхибитори
                    (Така де, поне би трябвало да има.)
                      Нямам такива практически наблюдения, а ти
                      LZ1EMS
                        Така пише по разни рецептури. Дали си го спестяват, виж не знам.
                        Както и да. Няма да се обаждам повече.
                          Поне в къщи си мухлясва по БДС - на третия ден е готов...
                            ...p.s.2 допуснал съм неволна грешка, записвайки две от стойностите с Целзий - всичко следва да е с Фаренхайт.
                            Имах предвид точно обратното. Би трябвало всички единици да са по система СИ - градуси Целзий и т.н.
                            И коментаторите...
                              Не мога да ви разбера, защо сте се заплеснали по този пеницилин !?
                              Той е първият открит антибиотик и вече не са останали много малко бактерии, които не са развили резистентност към него.
                              Освен това, как ще сте сигурни, че точно него сте произвели ?
                              И как ще го дозирате ? А знаете ли, че само някои негови съединения се резорбират през червата и употребен по този начин най-вероятно ще ви докара само дисбактериоза или някоя алергия, които ще влошат състоянието ви !?
                              Аз, на времето служих като "бацил"(санитарен инструктор). Там учехме "действие на сан. инструктор при попадане на батальона в обкръжение", та ето какво си спомням:
                              При болки в стомаха и повръщане - една/две лъжици риванолов р-р 1/10000;
                              При болки в червата и разтройство - 2-3 капки йодна тинктура в чаша вода;
                              При болки в гърлото и ангина - гаргара с 0,5% избистрен р-р на хлорна вар;
                              При кръвотечение от носа - 10% р-р на готварска сол.
                              Правилото Аспирин до кръста/Аналгин над кръста е задължително с изключение на болки в стомаха, за да не прикрие някое възпаление на апандисита.
                              Не падай духом където ти падне !
