Garmin - Oregon
Това е залепена тема.
  • До: Garmin - Oregon
    Излезе фърмуер 3.10 за Орегон. Това вече не е бета,а финален. GPS софтуера си е 3.40. Не виждам нищо ново спрямо 3.01 бета. Тези дни ще го тествам сериозно. Засега се държи добре.
    Новата версия е достъпна чрез Уеб ъпдейтъра. Има я и на тези 2 места:
    http://garminoregon.wikispaces.com/f...dater__310.gcd
    http://htftp.offroad-bulgaria.com/ne...on300%20v3.10/
    Последно редактирано от Валери Недялков; 30-07-09, 07:44.
      Това са промените спрямо 2.80:
      Changes made from version 2.80 to 3.10:
      Added Waypoint Averaging application (For more information visit our new Trail Tech website at http://garmin.blogs.com/softwareupdates/trail-tech/)
      Added Sight 'N Go application for the Oregon 300/400i/400c/400t
      Added Man Overboard application
      Added big numbers option to the trip computer
      Added customizable text to unit power-on screen (see \Garmin\startup.txt)
      Added ability to load maps from any img file in the Garmin directory
      Added new trip computer dashboards
      Added option to display four configurable data fields on the map
      Added 'search near' option to Geocaches search
      Added the ability to view geocache logs separate from the description
      Added ability to see a list of points from the map when several points are at the same location
      Added ability to edit a waypoint from the waypoint review
      Added support for Custom POI database and category selection
      Added distance and bearing to point when reviewing a Custom POI
      Added POI subcategories
      Added change location to Sun and Moon
      Added change location to Hunt and Fish
      Added ability to force the Oregon into mass storage mode by holding the power button for 30 seconds while plugged into a USB cable
      Added NMEA 9600 baud
      Improved render quality of GB Discoverer maps and maps with satellite imagery
      Improved map zooming
      Improved map draw speed
      Improved map panning and zooming when shaded relief is turned on
      Improved automatic route recalculation
      Improved Custom POI spell search
      Improved Main Menu setup and added option to add and remove items
      Improved readability of configurable data fields
      Improved display of numeric degrees and mils
      Improved GPS performance at slow speeds in tree cover
      Improved compass responsiveness in challenging GPS environments
      Improved battery gage for NiMH batteries
      Improved stability when changing profiles
      Improved Wherigo stability
      Improved connection reliability with Spanner
      Improved Spanish keyboard
      Fixed airport points not displaying on the map
      Fixed lockup when a search returns no results
      Fixed elevation errors when reviewing a point other than a waypoint
      Increased the number of waypoints viewable from the Waypoint Manager and Where To?>Waypoints
      Още нещо интересно:
      http://garmin.blogs.com/softwareupda...nd-oregon.html
      Последно редактирано от Валери Недялков; 30-07-09, 09:12.
      • Re: До: Garmin - Oregon
        Първоначално публикуван от nick_todorov Преглед на мнение
        1. Ако имаш изобщо българско меню, дори и в момента да ти е на друг език, при писане, на последната странца има и буквите на кирилица.
        При мен не става...
          Първоначално публикуван от emovla Преглед на мнение
          При мен не става...
          По принцип не става така. Ако Орегона е на Български език основна клавиатура е кирилицата,като има и добавена латиница. В обратният случай(когато Орегона е на друг език),обаче кирилица не се добавя.
          Сега за новата версия на фърмуера. Бъга със самоизключването на уреда при опит за изчистване на личните данни,ако не са въведени преди това фабричните настройки съществува и в тази версия.
          Открих,обаче какво го предизвиква и смятам да пиша на Гармин.
          Тъпо,но смяната на тапета води до този проблем. С дефолтният този гаф отсъства.
          Последно редактирано от Валери Недялков; 30-07-09, 17:46.
          • Re: Garmin - Oregon
            Мисля си да 'преведа' обратно българския превод на английски, тъпо е, ама няма файл с низовете за английски...
              Нова Бета!!! Версия 3.12. Съвсем прясна. Сега ще я тествам. Променен е GPS софтуера-версията му е 3.70. За малкото време в което съм тествал новата бета се държи добре. Прословутият проблем с изчистването на личните данни не е оправен. По-сериозни тестове утре,а в неделя на Рилските езера.
              Последно редактирано от Валери Недялков; 31-07-09, 23:18.
                Тук е редно да се каже,че имейджа на фърмуера за всички досегашни уреди от серията Орегон(с номер завършващ на 00 - 200,300,400с,i,t) е един и същ,но за новите апарати с номер завършващ на 50(550,550t) е различен. Затова и в Уикито има отделна страница с история на фърмуерите за тях:
                http://garminoregon.wikispaces.com/Versions+x50
                Ето и оригиналният текст:
                Garmin Oregon 200, 300, 400i, 400c, 400t Software Summary
                There has never been an issue with loading the image for one model of Oregon onto a different model. The image for the 200, 300, 400i, 400t and 400c has been identical. The software image for the x50 Oregon (550 and 550t) is different from the x00 image.
                  И с тази нова beta, продължавам да имам периодични проблеми със стартирането на Gps-а. Така и не успях да го хвана кога и защо го прави
                  Знам само, че стига до "Loading wayponts, tracks..." и изгасва. Тръгва само ако махна картата (а на нея има само карти и снимки). След стартиране без карта, трябва да ида да изтрия всички тракове и потребителски точки, за да тръгне и с карта
                  Много неприятно, ако ми се случи извън България - картата ще е на допълнителната памет - ако го пусна без нея, няма да имам карта за рутиране. Другия вариант е, да си изтрия всичко и ще остана без тракове от там....
                  Seat Leon FR 2017 1.8 TSI
                  Seat Leon 2007 1.9 TDI
                    Аз го имах същия проблем със стартирането на Орегона. Появи се след като качих 2.99 бета, и след това със 3.01 даже се влоши. При мен се оправи по следния начин:
                    Върнах по-старата версия 2.98 бета. Със нея проблемите изчезнаха. Докато беше със 2.98, ресетирах уреда - задържаш натиснат горния ляв ъгъл на екрана докато се стартира. След това качих версия 3.01 бета, и от тогава не е правил никакви проблеми. Сега съм с официалната 3.10, пак работи без проблеми.
                    "Аз знам, че нищо не знам. Но вие и това не знаете."
                      Точно тези проблеми ги проимах с 3.10 и 3.12 Бета. При мен ги прави когато е на български език. На английски не. Той на Български си работи добре,но ако при стартирането е бил на английски и след това е превключен на Български.
                      Иначе траковете и поведението на новият GPS софтуер(3.70) ми харесаха много. По-чувствителен е приемника и трака е по-равномерен.
                      Открих един бъг свързан със запис и редактиране на нова точка. Правя точката и избирам опция "save & edit". Редактирам символ и име,всичко е наред,но липсва бутона за връщане назад. Единственият начин за излизане е изключване на уреда. Хубавото поне е,че промените по точката са записани коректно. Този гаф го имаше в някоя от първите Бети.
                      Последно редактирано от Валери Недялков; 03-08-09, 20:19.
                        Първоначално публикуван от neptun61 Преглед на мнение
                        Аз си го държа само на български. Ще сложа картата на латиница и ще видя дали пак го има проблема.
                        Относно едита на точка, в уикито четох, че май трябва да избереш покажи на картата и от там хикса и в главното меню.
                          Благодаря за инфото относно редактиране на каквато и да е(не само новозаписана)точка. Пробвах го. Системата е: 1)избор на опцията "view map"; 2)натискане на бутона "go"; 3)на страницата за изчисляване на маршрут вече има бутон "Х" за излизане в главното меню.
                          Относно нестабилното стртиране,когато уреда е на Български език,мога да кажа,че го има отдавна и при различните версии на фърмуера поведението на Орегона е различно,но когато при стартиране е на Английски рядко има проблеми(да не кажа почти никога). Затова и помолих Събин да възстанови поддръжката на ML варианта на OFRM 4.90.
                          Последно редактирано от Валери Недялков; 04-08-09, 12:41.
                            Това е заключението за последната Бета 3.12 в GPSFix:
                            First off, I should mention that there are several issues in this release if you are thinking about upgrading:
                            After you edit a waypoint you cannot return to the main menu by hitting “X” since that button has disappeared. The workaround is to select View Maps and quit from the map page.
                            In auto mode the compass can get stuck on for about 90 seconds even if you are moving. This causes your heading, compass pointer and map pointer to freeze.
                            With the compass in auto mode I’ve seen a number of shutoffs when starting and stopping or moving at slow speeds. The workaround for the last two issues is to disable the compass.
                            I’ve only be able to test the receiver twice on my test course since upgrading and I can see that the tracks are much smoother but the Oregon still displays zero speed when moving slowly and records significantly more stopped time than the 60CSx. There is also no noticeable improvement in the ability to lock WAAS and hold a WAAS signal under cover. The test tracks I’ve recorded look good but I’ll be testing all week to see how the receiver performance compares to prior releases.
                            Note this release is only applicable to the Oregon 200, 300, 400i, 400c and 400t and not the Oregon 550 or 550t.
                            А това от Уикито:
                            Software 3.12 (beta)
                            GPS Firmware changes to 3.70. Tracklogs are more averaged, feels like we are going back to 2.8 with more heavily averaged location and tracklog data at the expense of accuracy.
                            Моето мнение е,че новата версия на GPS софтуера(3.70) е по-добра от 3.40.
                              Излезе нова бета-3.13. Оправени са проблема с липсващият бутон за връщане в главното меню при редактиране на POI и проблема с компаса.
                              Качих я на уреда.Проблема с липсващият бутон е решен. Утре ще тествам и компаса. Първите ми впечатления са,че и този проблем е ликвидиран.
                              Линк за сваляне:
                              http://htftp.offroad-bulgaria.com/ne...0v3.13%20Beta/
                              Последно редактирано от Валери Недялков; 08-08-09, 00:29.
                                Прословутият проблем с изчистването на личните данни отново не е оправен. Другите 2 от 3.12,обаче са оправени. Орегона работи много стабилно и траковете му са добри. В гората е по-чувствителен спрямо официалната версия 3.10(изобщо спрямо всички фърмуери с GPS софтуер 3.40). Препоръчвам ъпдейт до тази бета(3.13).
                                По отношение на проблема с изчистването на личните данни имам усещането,че в Гармин не знаят. Аз им писах,но не ми отговориха. Може и да съм объркал нещо с писмото. Ако някой има желание да им опише пак проблема ще стане много добре. Все пак редно е това да се оправи.
                                Пак припомням,че при опит за изчистване на личните данни,ако тапета не е дефолтният уреда се самоизключва. Това се решава като преди това се въведат заводските настройки или просто се избере опцията Default за тапета.
