GPSMAP® 64s
Това е залепена тема.
  • GPSMAP® 64s
    64 серия е в продажба отскоро.
    Важното е, че ти е полезен и ти върши работа.
    Както казах винаги ще се очаква нещо ново на хоризонта.
    Иначе с прозрението, че телефоните не са за тази работа всеки стига рано или късно.
    Особено за цели извън колата
    Технически характеристики на модела.
    Review
    Претърпени до момента промени в софтуера. Начален софтуер 2.20 /най-долу/.
    Всички версии на софтуера може да си ги дръпнете от тук.
    GPSMAP 64 software version 3.00
    Changes made from version 2.90 to 3.00:
    Fixed issue with geocaching 'Next Stage' feature.
    Fixed potential issue with geocache filters.
    GPSMAP 64 software version 2.90
    Changes made from version 2.80 to 2.90:
    Added support for Android version of Garmin Connect Mobile app (for LiveTrack).
    Improved 3-axis compass performance.
    Fixed missing 'AA Battery Type' option when not using the optional rechargeable battery pack in Setup > System. This only affected the standard (yellow) GPSMAP 64 model.
    Fixed issue with barometer when auto calibration is turned off.
    Fixed missing ascent, descent, and elevation statistics when reviewing certain tracks.
    Fixed possible shutdown when using custom waypoint symbols.
    Fixed possible shutdown when displaying the option menu in Czech.
    GPSMAP 64 software version 2.80
    Changes made from version 2.60 to 2.80:
    ◦Fixed freeze when 'Geocaches' is present in the page sequence
    GPSMAP 64 software version 2.60
    Changes made from version 2.50 to 2.60:
    ◦Fixed issue causing possible slow boot times
    GPSMAP 64 software version 2.50
    Changes made from version 2.40 to 2.50:
    ◦Improved average ascent and average descent data fields
    ◦Improved vertical speed and grade data fields
    ◦Improved transfer speed between device and BaseCamp Mobile or Garmin Connect Mobile (64s/64st models)
    ◦Fixed potential issue when programming a chirp (64s/64st models)
    ◦Fixed potential shutdown when using smart notifications
    ◦Fixed displaying duplicate smart notifications in certain instances
    GPSMAP 64 software version 2.40
    Changes made from version 2.20 to 2.40:
    ◦Added support for additional ActiveRouting cartography
    ◦Improved display of marine-specific lines in BlueChart g2 maps
    GPSMAP 64 software version 2.20
    Какви карти отключени незаконно НЕ работят на този модел:
    City Navigator
    Cyclops
    Последно редактирано от Валери Недялков; 01-06-17, 16:10. Причина: Добре е важната информация да е в първото мнение.
    Враг усраине
    От: Garmin GPSMAP62ST vs. OREGON 600
    При един бърз поглед, почти не се различат като характеристики 64s и 62s.
    Има някакви нотификации, които не ти трябват и live tracking.
      Еми плюс възможност за работа с Глонас и вече възможност да се зареждат акумулатори през USB порта.
      Това второто не мисля, че е супер фийчъра (бачка само с гармински NiMH пакет) но още един метод за позициониране е добре дошъл.
      Враг усраине
        Напълно си прав. Бях останал с впечатлението, че има Glonass. Странна работа, Etrex 30 има.
          За 64-ката има доста отзиви, че са вкарали безумно работеща защита от качване на крадени гармински карти. Според пишещите тази защита блокира качването на доста свободни карти - примерно деривати на ОСМ (openstreetmap) и прочее. Последните, както е известно, са може би най-подробните карти в района на Западна Европа и Америка (за съжаление не и в България).
            Първоначално публикуван от dido2 Преглед на мнение
            За 64-ката има доста отзиви, че са вкарали безумно работеща защита от качване на крадени гармински карти...
            Полезна информация - благодаря.
            Моята 60-ка понеже е в отлично здраве, не съм се интересувал подробно от новите модели и този момент за 64 е новост за мен.
            Според пишещите - дотук с отключените IMG файлове...
            Добре е да се знае.
            Погледнах сега че имал и блутут... Не зная за какво точно би бил практичен по време на реална работа но има.
            П.С: То май модератор би било добре да отдели коментарите за 64 серия в отделна тема...
            Враг усраине
              От: GPSMAP® 64s
              Хм.Предстои ми закупуване на gps и се спрях на 64s.Наистина има отзиви че не работи с всички карти.(И при 62s нещата били подобни.)Днес мислех да поръчвам.Незнам има доста противоречиви мнения и съм в чудо.
                От: GPSMAP® 64s
                Първоначално публикуван от Немезис Преглед на мнение
                И на мен ми се искаше да сменя 60ката с нещо по-ново, единствено с цел да "рисува" картата по-бързо и да има барометър. Бях се спрял на 64s, но като се зачетох тук и видях отзиви, че има проблеми с компаса, когато е близо до метални предмети....замислих се, че моя GPS много рядко е далеч от метални предмети и се зачудих какво да се прави....някой някакви съвети по въпроса ?
                Ако няма къде да отидеш, ела на себе си!
                  От: GPSMAP® 64s
                  Взех си 64s, и понеже имам няколко устройства с абонамент, та си мислех да е@а дявола и да му прехвърля отключена топо картата. Да ама не. Не желае да я подкара. Знам за проблема на новите Гармини с "неправилно" отключените карти, но няма ли решение?! По принцип ще се ползва за състезания, където само ще пише и показва трака, но няма да е лошо и да му сложа някаква карта.
                  [SIGPIC][/SIGPIC]
                    От: GPSMAP® 64s
                    Ако е NT формат картата - има решение. За NTU - няма такова.
                    Nothing comes from nothing...
                      От: GPSMAP® 64s
                      Първоначално публикуван от Чичка Преглед на мнение
                      Такова нещо го бях писал аз. Беше кошмарно, а точността беше зле. За 64 става въпрос. Случвало се е да ми покаже,че съм на 1 км от мястото на което съм че съм и на близо 3000 м височина, т.е. би трябвало да летя. Това беше така, но сега е друго, поне за сега. Дали от обновяването, дали спътниците "работят" по-добре, но точността се подобри, с компаса няма вече проблеми. Точността е с една идея по-добра от на 62. За сега имам проблеми с картите и траковете. Понеже работя с мои карти , а те са много, като добавя някоя карта , то уреда по негово усмотрение престава да вижда някоя стара карта.С траковете е нещо подобно. 62 си ги вижда всичките, та затова ходя с двата, за всеки случай.
                        От: GPSMAP® 64s
                        Да попитам за какво може да се ползва блутута. Някъде бях чел, че става за прехвърляне на съобщения от телефона на ГПС. Като сдвоя ГПС с телефон и нищо не се случва.
                        Ако някой знае какво точно може да се прави ще бъде хубаво ако сподели.
                        EXC TPI 2019
                          От: GPSMAP® 64s
                          https://www8.garmin.com/manuals/webh...73B564F86.html
                          Your GPSMAP® 64s series device has several Bluetooth connected features for your compatible smartphone. Some features require you to install Garmin Connect™ Mobile on your smartphone. Go to www.garmin.com/apps for more information.
                          Phone notifications
                          Displays phone notifications and messages on your GPSMAP 64s series device.
                          LiveTrack
                          Allows friends and family to follow your activities in real time. You can invite followers using email or social media, allowing them to view your live data on a Garmin Connect tracking page.
                          Activity uploads to Garmin Connect
                          Automatically sends your activity to Garmin Connect as soon as you finish recording the activity.
                          За да работи, трябва да си свалиш и приложението на Гармин на телефона - Garmin Connect и да си направиш акаунт.
                          Последно редактирано от connann; 15-01-17, 21:46.
                            От: GPSMAP® 64s
                            Нещо не се получават нещата както трябва. Веднъж се връзва, но отново не получавам известия за пропуснати повиквания... Получих известие да си ъпдейтна софтуера на навигацията, но пък според навигацията.... е с най новата версия. Ще се помъча още малко и ако не става здраве да е.
                            Изпратено от моят Lenovo P1a42 с помощта на Tapatalk
                            EXC TPI 2019
                              От: GPSMAP® 64s
                              Аз на моя тази функция не съм я ползвал никога, но довечера ще видя как е, че в последно време много не го ползвам gps-a. При първоначалното качване на софтуера на телефона, получих някакво съобщение на екрана, но не се загледах особено.
