GARMIN ZUMO 550. Какво ви е мнението?
    Re: GARMIN ZUMO 550. Какво ви е мнението?
    Днес (макар и със Стара дата 14-ти) се появи Новият Firmware 3.0 за Zumo550 можете да го свалите от http://www.garmin.com/support/collec...t=010-00567-00
    Промените са МНОГО и (за сега) все много добри (ще сложа в червено тези който НАЙ-Много ми липсваха
    Changes made from version 2.50 to 3.00:
    • Allow panning from main map. Touching vehicle on main map displays coordinates and elevation in save dialog.
    • Added more fields to the trip computer including fuel gauge odometer.
    • Enabled compass display full time with additional data fields. (Тук е добваена и ВИСОЧИНАТА Най-накрая)
    • Enhanced XM weather support which is available from XM button on the main menu.
    • Enhanced traffic incident reporting.
    • Added support for SDHC cards and increased MP3 playlist limit to 1000 songs.
    • Added Audible books support.
    • Added option to limit BT headset audio to phone only.
    • Added option to display track log on map.
    • Added track log archive function. (според мен значително е Увеличен ТракЛогът)
    • Modified import /share pictures to work directly from jpeg viewer without the checklist.
    • Added support for the modified drawing styles present in certain specialty maps.
    • Display unpaved roads differently than alleys, expanded zoom level where favorites are displayed.
    • Disables auto-zoom operation when off-road.
    • Added ability to treat certain route vias as shaping points which will not be flagged or announced. Qualified shaping points are Intersections and points on roads which are not addresses, such as I-35N or HwyA. Requires routes to be created with MapSource 6.12.1 or using the zumo route planner.
    • Enhanced off-route recalculation for mixed on/off road routes and routes with shaping points.
    • Added support for new Pre-Recorded voices for Brazil, Bulgaria, Lithuania, Romania, Serbia.
    • Updated US/Canada Daylight Saving time support.
    • Correct shutdown when enter more than 4 vias.
    • Correct issue preventing conversion of tracks to routes in southern hemisphere.
    • Correct issue which prevented writing recent tracks to the GPX file.
    • Correct issue which prevented finding points of interest after search where city was spelled.
    • Correct issue which prevented finding some addresses with overlapping maps.
    • Correct issue where a truncated route could contain an erroneous point.
    • Correct issue where a truncated route could be stopped incorrectly.
    • Correct behavior when two Cyclops safety cameras are in range.
    • Correct handling of track to route conversions that are completely off road.
    • Correct issues with simulator going off route.
    Общо взето Зумо-то става Много Готино Устроиство!!!
    Навъртях му >2 хиляди километра и мога да кажа че е Много по-удобно от досегашните ГПС-и (аз имам и ползвам още 2-3)
      Излезна и 3.10 и пак не ви съветвам да ползвате Българският глас - загасвана от време на време цялото устроиство - с англииският си е ОК
        Явно са нямали пред вид гасенето при българският глас. Имах оплакване че зумото се гаси и без да се ползва с български глас с моята карта - след ъпдейта на 3.10 проблема изчезна.
        А забеляза ли че имената на улиците вече се изписват на екрана? Преди се изписваха само където го пуснеш и като се махнеш от там нито една улица не и се изписваше името. Сега тук-там има по някоя улица, което е далече от перфектното, но пак имат някакъв напредък.
          каква му е цената
          "Ако не можеш да ги убедиш, объркай ги."
            1660лв
              Първоначално публикуван от sabin Преглед на мнение
              Ето тука към края го има:
              Ама обади се да ви го продам аз де
              Аз много се интересувам от този модел. Вероятността да купя е голяма, но преди това имам няколко въпросчета. Та ако търсиш купувачи обади се на lacho_australia@mail.bg
                До: GARMIN ZUMO 550. Какво ви е мнението?
                Предстои ми да си купувам навигация за мотора.
                Понеже не съм наясно със серията Zumo, разчитам на съветите и препоръките на по- запознатите.
                Зима иде
                  някой продава ли стойка за Garmin ZUMO 500 за кола? благодаря предварително
                    Първоначално публикуван от Lubomir dimitrow Преглед на мнение
                    подарих я преди няколко месеца
                      Знае ли някой дали може да се прехвърлят Favorites (около 200 на брой) от Garmin 660 на Garmin Zumo 550?
                      Мирослав
