Garmin Mobile XT for Symbian S60 3rd v. 5.00.40
  • Garmin Mobile XT for Symbian S60 3rd v. 5.00.40
    новата версия на мобайл хт. надявам се да решава проблема с високата консумация.
    Changes made from version 5.00.20 to 5.00.30:
    • Provide support for Nokia 5800 (S60 touch screen).
    • Provide a background service that monitors incoming messages which may contain information used by Garmin Mobile XT. A new setting will allow the user to turn this option off (Tools -> Settings -> System -> Launch Background Service).
    • Improve map drawing performance.
    http://www8.garmin.com/software/Garm...tion_50030.exe
    последна версия на спийд камерите и засадите: http://paralax.org/garmin/
    До: Garmin Mobile XT for Symbian S60 3rd v. 5.00.30
    Инсталирах сега зареждам телефона (е66) - довечера ще стане ясно дали има одобрения. Надеждата е тук - "This Garmin Mobile XT application is designed for use on Symbian smartphone devices running S60(ie. Nokia E6x, Nokia N7x) 3rd Edition OS ."
      Той проблема с консумацията беше май само при Е51, аз затова се върнах към старата версия.
        Отново висока консумация при Е51.
          Проблема с консумацията не е само на Е51, а с цялата серия Е на Нокия.
          ПОВЕЧЕ ОРЪЖИЕ, ПО-МАЛКО ПРЕСТЪПНОСТ !
          ( John R. Lott, Jr.)
            Честито,най -после нормална версия
            Ok as i guess this will be the version that all of us will use now on (tsautostart fixed! see below)
            Here is a special standalone version 5.00.30 with Greek and English (UK & American) voices -languages-help files only (24 MB) :
            1)file properties modified so as not to create problems.
            2)latest Garmin speedcams (february 2009 FIXED) of europe included
            3)includes some vehicles (so many so as not to demand more ram)
            4) and..... i created a surprise splash-screen which is included (as i am bored of the original splashscreen and many of you too i guess).dont worry it works with all mobile resolutions:
            Code:
            or
            and two suggestions:
            so as to have tsautostart closed now on you have to do these simple steps
            1)first open garmin and set the launch background service inside tools-> system to active.
            2)then close garmin.
            3)then open again.
            4)deactivate the same option.
            5)now tsautostart.exe process will close every time you close garmin and will be no more a problem thats consumes battery!
            so as not to ask you to connect garmin gps or activation code during installation
            just be sure to have sw.unl inside garmin folder during installation
            -> if you want to use your own languages just download the above file and place the extra multi language files (all languages except Greek and English Uk & Us included here) (36MB) from:
            Code:
            or
            JUST ALL YOU NEED!
              Интересно дали и старите версии ще се лекуват по този начин?
                Първоначално публикуван от milstan Преглед на мнение
                Пробвай това и след излизане от програмата, процесът TRS... вече го няма:
                1) tools/settings/system/Launch background servise и маркираме enabeled
                2)Затваряме Гармин Мобиле ХТ
                3)Отново стартираме Гармин Мобиле ХТ
                4)tools/settings/system/Launch background servise и маркираме disabled
                5) Процесът вече го няма
                П.П. Упс! DTMF вече ме е изпреварил с инструкцията, не го видях, сори!
                [URL]http://doglickingscreen.com/dog.swf[/URL]
                  Още снощи го пробвах и си работи. Нещо редакцията на поста ми не е излязла. В старите версии изобщо липсва тази функция.
                    след ъпдейта при мен проблема с консумацията е решен (нокия е66).
                      И на моя 6110 Навигатор се оправи проблема с консумацията.С 5.00.30 този процес TSR вече не се включва и липсва.
                        Въпрос къде да видя този процес TSR дали го има или не,какъв таск менъджер да ползвам за Nokia n 73 ?
                        И тука се появи проблема с консумацията при инстал на 5.00.20
                        инсталирах после и .30 и пак заминава батерията за 1 ден?
                        Благодаря предварително
                        Последно редактирано от alone_rider; 06-03-09, 21:46.
                          След инсталиране на 5.00.30 трябва да извършиш горната процедура и тогава се оправя.
                          Последно редактирано от milstan; 06-03-09, 23:18.
                            Първоначално публикуван от alone_rider Преглед на мнение
                            Опитай с този таскмениджър - http://jbak.ru/jbaktaskman_en.php . Ако преди това си имал друга версия на GMXT и си й правил магии като да триеш и преименуваш файлове, ти препоръчвам да форматираш SD картата и да инсталираш GMXT 5.00.30 наново. Успех
                              Тайванска версия на GM XT 5.00.30 - тук
                              Тайванска версия на GM XT 5.00.30 Online - тук
                              Други тайвански версии на GM XT - тук
                              П.П.: Интересно ми е някой да сподели дали има разлика и каква е от оригиналния гармински XT
                              Последно редактирано от asterix85; 07-03-09, 21:13.
