Каква чудесна джаджа: "Ritz POWER SHIFT MS-00124 (Professional Use)"
  • Каква чудесна джаджа: "Ritz POWER SHIFT MS-00124 (Professional Use)"
    ... се продава в Amazon
    Product Features
    • Enhance fuel efficiency - saves gas
    • Increase engine torque - increase power
    • Reduce car emissions - contribute to the environment unconsciously
    • Improve car audio sounds and 6 more improvements that you possibly feel.
    • The small device cleans the entire car electrically including its body.
    и малко по-надолу пише:
    ...It is especially recommended for RVs, SUVs,trucks, buses with larger engine.
    LR Disco II, Td5
    От: Какава чудесна джаджа: "Ritz POWER SHIFT MS-00124 (Professional Use)"
    Аре, пак ще се открива перпетуума!
    Ми аз като имам 3 гнезда? Сигурно ще ми прелее резервоара!
      Прекрасно. Това се вижда. Можеш за секунда да разпознаеш глупака.
      Да бяха направили лепенка. Същата работа.
        Спокойно, не припадайте, ТЕ за всичко са помислили - попаднах и на следния "magic pill" в ebay - еднакво добро както за бензин, така и за дизел - да му мислят тези с метаните и пропаните :-))
        сигурно линка ще изчезне след 3-4 дни но е то част от "рекламата"
        You are buying one tablet which will treat up to 60 litres of fuel in 15 litre increments. We recommend you double dose for first use then as per instructions
        - Save 15% - 25%* fuel consumption
        - Reduce emissions 40%-80%*
        - Clean and maintain your engine
        - Eliminate smoke
        - Easy to use
        - Over 15 years of successful sales in over 53 countries
        HOW IT WORKS
        The Force Pill is made largely of combustion catalyst, Octane Booster, and Detergent, however also contains a Diesel Bug Eliminator, Injector Cleaner, Lead replacement, and smoke inhibitor. These components are explained below:
        Combustion Catalyst
        When the fuel is burned in the combustion chamber not all the fuel is used and a proportion goes out of the exhaust as poisonous emissions. This is fuel that you have paid for and not used.
        The Force pill acts as a combustion catalyst hence burning ALL the fuel within the combustion chamber, this leads to a more complete and more powerful combustion process hence reducing fuel consumption, increasing power, and reducing emissions of Hydrocarbons (HC) and Carbon Monoxide (CO).
        Octane
        The Force Pill has also been shown to increase the level of Octane, this will lead to increased power, lower engine vibrations, a smoother ride, and reduced fuel consumption.
        Detergent
        The detergent properties of the Force Pill are essential in cleaning the engine of carbon deposits and lacquer build-up within the engine and fuel lines resulting in cleaner and more efficient engine, hence resulting in a more efficient burn and a large reduction in emissions and smoke
        Water
        Fuel contains entrained water which creates additional risks of corrosion and fuel contamination which provides a breeding ground for bacterial and fungal growth around the water. This leads to the formation of sludge within the engine and fuel lines and over time these micro organisms will multiply, contaminating fuel lines and clogging filters and injectors, causing poor performance and high emissions. This is commonly seen through the formation of smoke and reduced performance in older vehicles. When the Force Pill is added to fuel, it is not able to separate from water hence eliminating the breeding ground for these micro-organisms.
        Lead Replacement
        The Force Pill acts as a lead replacement as it provides a protective coating over the spark plugs, piston face, and combustion chamber dome which retards the formation of carbon deposits
        Smoke Inhibitor
        The Force Pill decreases the temperature at which carbon will burn, hence reducing carbon deposits leading to a reduction in smoke and hence a reduction in emissions
        All Force products are manufactured to ISO9001 standards and have been comprehensively tested by leading independent testing institutes and major companies.
        The Force pill is fully compatible with Leaded Petrol, Unleaded Petrol, or Diesel fuel.
        и така нататък ... но най-интригуващото е "More than 10 available / 9 sold"
        LR Disco II, Td5
          Уникално.
            мания. Хем пере, хем чисти, хем глади Сигурно и свирки прави, но не са го споменали, заради някое правило...
            Ако лекува и пневмония, направо да си взимам едно?
              Ако си купиш такова нещо, значи не е пневмония. Друго ти има.
                Първоначално публикуван от damyan_rm Преглед на мнение
                Няма какво да му мислят тия с метаните и пропаните. Просто гълтат по едно преди шофиране.
                  Не бре, пневмонията си я изкарах вече.
                  Не съм се загнал да купувам ... кондензатори имам предостатъчно горе, а хапчета аз не пия без свръхкрайна необходимост, камо ли на колата си да давам
                    От: Каква чудесна джаджа: "Ritz POWER SHIFT MS-00124 (Professional Use)"
                    Това е вече остаряла технология- кабели, жици, хапчета...
                    Аз съм разработил революционен продукт с нова формула, даващ най-малко 99% икономия!
                    Формата е ръбат цилиндър около 25-30см, черен на цвят. Приложението е дискретно- трансанално.
                    Мислите ли, че ще има пазарен успех?
                    There is no dark side of the moon really. As a matter of fact it's all dark.
                    No wahalla.
                      При добра реклама и красива опаковка - успеха е гарантиран. Не му разбирам на тоя занаят (да продавам оцветена водичка, грубо казано), за съжаление ... мое
                        Много убава джаджа. Предлагам да се организираме и да направим групова поръчка, та да докаране тънка цена на тоя чуден икономайзер. За мен 10 броя! Само някой да ме е изпреварил или да вземе моите бройки!
                        И коментаторите...
