Списък с грешки при диагностика . За тези на които им върши работа пием раКИА
  • Списък с грешки при диагностика . За тези на които им върши работа пием раКИА
    OBDII_NEW
    P0001Fuel Volume Regulator Control Circuit Open
    P0002Fuel Volume Regulator Control CKT Range/Perf
    P0003Fuel Volume Regulator Control Circuit Low
    P0004Fuel Volume Regulator Control Circuit High
    P0005Fuel Shutoff Vlv. A Control Circuit Open
    P0006Fuel Shutoff Vlv. A Control Circuit Low
    P0007Fuel Shutoff Vlv. A Control Circuit High
    P0008Engine Position System Performance (Bank 1)
    P0009Engine Position System Performance (Bank 2)
    P0010Camshaft Position Actuator A - Bank 1 Circuit Malfunction
    P0011Camshaft Position Actuator A -Bank 1 Timing Over-Advan.
    P0012Camshaft Position Actuator A - Bank 1 Timing Over-Retard
    P0013Camshaft Position Actuator B - Bank 1 Circuit Malfunction
    P0014Camshaft Position Actuator B - Bank 1 Timing Over-Advan.
    P0015Camshaft Position Actuator B - Bank 1 Timing Over-Retard
    P0016Cam/Crankshaft Pos. Correlation Sensor A - Bank 1
    P0017Cam/Crankshaft Pos. Correlation Sensor B - Bank 1
    P0018Cam/Crankshaft Pos. Correlation Sensor A - Bank 2
    P0019Cam/Crankshaft Pos. Correlation Sensor B - Bank 2
    P0020Camshaft Position Actuator A - Bank 2 Circuit Malfunction
    P0021Camshaft Position Actuator A - Bank 2 Timing Over-Advan.
    P0022Camshaft Position Actuator A - Bank 2 Timing Over-Retard
    P0023Camshaft Position Actuator B - Bank 2 Circuit Malfunction
    P0024Camshaft Position Actuator B - Bank 2 Timing Over-Advan.
    P0025Camshaft Position Actuator B - Bank 2 Timing Over-Retard
    P0026Intake Valve-Bank 1 Control Solenoid CKT Range/Perf
    P0027Exhaust Valve-Bank1 Control Solenoid CKT Range/Perf
    P0028Intake Valve-Bank 2 Control Solenoid CKT Range/Perf
    P0029Exhaust Valve-Bank2 Control Solenoid CKT Range/Perf
    P0030HO2S Bank 1 Sen 1 Heater Circuit
    P0031HO2S Bank 1 Sen 1 Heater Circuit Low
    P0032HO2S Bank 1 Sen 1 Heater Circuit High
    P0033Turbo/Sup Wastegate Control Circuit
    P0034Turbo/Sup Wastegate Control Circuit Low
    P0035Turbo/Sup Wastegate Control Circuit High
    P0036HO2S Bank 1 Sen 2 Heater Circuit
    P0037HO2S Bank 1 Sen 2 Heater Circuit Low
    P0038HO2S Bank 1 Sen 2 Heater Circuit High
    P0039Turbo/Super Charger Bypass Cntrl CKT Performance
    P0040O2 Bank 1 Sensor 1 Signals Swapped w/ O2 Bank 2 Sensor 1
    P0041O2 Bank 1 Sensor 2 Signals Swapped w/ O2 Bank 2 Sensor 2
    P0042HO2S Bank 1 Sen 3 Heater Circuit
    P0043HO2S Bank 1 Sen 3 Heater Circuit Low
    P0044HO2S Bank 1 Sen 3 Heater Circuit High
    P0045Turbo/Super Charger Boost Control Solenoid A Circuit Open
    P0046Turbo/Super Charger Boost Control Solenoid A Circuit Range/ Perform ance
    P0047Turbo/Super Charger Boost Control Solenoid A Circuit Low
    P0048Turbo/Super Charger Boost Control Solenoid A Circuit High
    P0049Turbo/Super Charger Boost Input/Turbine Speed Overspeed
    P0050HO2S Bank 2 Sen 1 Heater Circuit
    P0051HO2S Bank 2 Sen 1 Heater Circuit Low
    P0052HO2S Bank 2 Sen 1 Heater Circuit High
    P0053HO2S Bank 1 Sen 1 Heater Resistance
    P0054HO2S Bank 1 Sen 2 Heater Resistance
    P0055HO2S Bank 1 Sen 3 Heater Resistance
    P0056HO2S Bank 2 Sen 2 Heater Circuit
    P0057HO2S Bank 2 Sen 2 Heater Circuit Low
    P0058HO2S Bank 2 Sen 2 Heater Circuit High
    P0059HO2S Bank 2 Sen 1 Heater Resistance
    P0060HO2S Bank 2 Sen 2 Heater Resistance
    P0061HO2S Bank 2 Sen 3 Heater Resistance
    P0062HO2S Bank 2 Sen 3 Heater Circuit
    P0063HO2S Bank 2 Sen 3 Heater Circuit Low
    P0064HO2S Bank 2 Sen 3 Heater Circuit High
    P0065Air Assisted Injec. Control Range/Performance
    P0066Air Assisted Injec. Control Circuit Low
    P0067Air Assisted Injec. Control Circuit High
    P0068MAF/MAP Sensor Throttle Position Correlation
    P0069MAP/BARO Correlation
    P0070Ambient Air Temp. Sensor Circuit
    P0071Ambient Air Temp. Sensor Range/Performance
    P0072Ambient Air Temp. Sensor Circuit Low
    P0073Ambient Air Temp. Sensor Circuit High
    P0074Ambient Air Temp. Sensor CKT Intermittent
    P0075Intake Valve-Bank 1 Control Circuit
    P0076Intake Valve-Bank 1 Control Circuit Low
    P0077Intake Valve-Bank 1 Control Circuit High
    P0078Exhaust Valve-Bank1 Control Circuit
    P0079Exhaust Valve-Bank1 Control Circuit Low
    P0080Exhaust Valve-Bank1 Control Circuit High
    P0081Intake Valve-Bank 2 Control Circuit
    P0082Intake Valve-Bank 2 Control Circuit Low
    P0083Intake Valve-Bank 2 Control Circuit High
    P0084Exhaust Valve-Bank2 Control Circuit
    P0085Exhaust Valve-Bank2 Control Circuit Low
    P0086Exhaust Valve-Bank2 Control Circuit High
    P0087Fuel Rail Pressure Too Low
    P0088Fuel Rail Pressure Too High
    P0089Fuel Pressure Reg 1 Performance
    P0090Fuel Pressure Reg 1 Control Circuit
    P0091Fuel Pressure Reg 1 Control Circuit Low
    P0092Fuel Pressure Reg 1 Control Circuit High
    P0093Fuel System Leak (Large)
    P0094Fuel System Leak (Small)
    P0095IAT Sensor 2 Circuit
    P0096IAT Sensor 2 CKT Range/Perf
    P0097IAT Sensor 2 Circuit Low
    P0098IAT Sensor 2 Circuit High
    P0099IAT Sensor 2 CKT Intermittent
    P0100MAF or VAF A Circuit Malfunction
    P0101MAF or VAF A Circuit Range/Perf
    P0102MAF or VAF A Circuit Low Input
    P0103MAF or VAF A Circuit High Input
    P0104MAF or VAF A Circuit Intermittent
    P0105MAP/BARO Circuit Malfunction
    P0106MAP/BARO CKT Range/Perf
    P0107MAP/BARO Circuit Low Input
    P0108MAP/BARO Circuit High Input
    P0109MAP/BARO CKT Intermittent
    P0110IAT Sensor Circuit Malfunction
    P0111IAT Sensor 1 CKT Range/Perf
    P0112IAT Sensor 1 Circuit Low Input
    P0113IAT Sensor 1 Circuit High Input
    P0114IAT Sensor 1 CKT Intermittent
    P0115Engine Coolant Temp Circuit Malfunction
    P0116Engine Coolant Temp CKT Range/Perf
    P0117Engine Coolant Temp Circuit Low Input
    P0118Engine Coolant Temp Circuit High Input
    P0119Engine Coolant Temp CKT Intermittent
    P0120TPS/Pedal Position Sensor A Circuit Malfunction
    P0121TPS/Pedal Position Sensor A CKT Range/Perf
    P0122TPS/Pedal Position Sensor A Circuit Low Input
    P0123TPS/Pedal Position Sensor A Circuit High Input
    P0124TPS/Pedal Position Sensor A CKT Intermittent
    P0125Clsd Loop Fuel Ctrl Insufficient Coolant Temp
    P0126Coolant Temp Insufficient Stable Operation
    P0127IAT Sensor Too High
    P0128Coolant Temp Below Thermostat Regulating Temp
    P0129Barometric Pressure Too Low
    P0130O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131O2 Sensor Circuit Low Volts (Bank 1 Sensor 1)
    P0132O2 Sensor Circuit High Volts (Bank 1 Sensor 1)
    P0133O2 Sensor CKT Slow Response (Bank 1 Sensor 1)
    P0134O2 Sensor CKT No Activity (Bank 1 Sensor 1)
    P0135O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137O2 Sensor Circuit Low Volts (Bank 1 Sensor 2)
    P0138O2 Sensor Circuit High Volts (Bank 1 Sensor 2)
    P0139O2 Sensor CKT Slow Response (Bank 1 Sensor 2)
    P0140O2 Sensor CKT No Activity (Bank 1 Sensor 2)
    P0141O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143O2 Sensor Circuit Low Volts (Bank 1 Sensor 3)
    P0144O2 Sensor Circuit High Volts (Bank 1 Sensor 3)
    P0145O2 Sensor CKT Slow Response (Bank 1 Sensor 3)
    P0146O2 Sensor CKT No Activity (Bank 1 Sensor 3)
    P0147O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0148Fuel Delivery Malfunction
    P0149Fuel Timing Malfunction
    P0150O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151O2 Sensor Circuit Low Volts (Bank 2 Sensor 1)
    P0152O2 Sensor Circuit High Volts (Bank 2 Sensor 1)
    P0153O2 Sensor CKT Slow Response (Bank 2 Sensor 1)
    P0154O2 Sensor CKT No Activity (Bank 2 Sensor 1)
    P0155O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157O2 Sensor Circuit Low Volts (Bank 2 Sensor 2)
    P0158O2 Sensor Circuit High Volts (Bank 2 Sensor 2)
    P0159O2 Sensor CKT Slow Response (Bank 2 Sensor 2)
    P0160O2 Sensor CKT No Activity (Bank 2 Sensor 2)
    P0161O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163O2 Sensor Circuit Low Volts (Bank 2 Sensor 3)
    P0164O2 Sensor Circuit High Volts (Bank 2 Sensor 3)
    P0165O2 Sensor CKT Slow Response (Bank 2 Sensor 3)
    P0166O2 Sensor CKT No Activity (Bank 2 Sensor 3)
    P0167O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0168Engine Fuel Temperature Too High
    P0169Fuel Composition Incorrect
    P0170Fuel Trim Malfunction (Bank 1)
    P0171System Too Lean (Bank 1)
    P0172System Too Rich (Bank 1)
    P0173Fuel Trim Malfunction (Bank 2)
    P0174System Too Lean (Bank 2)
    P0175System Too Rich (Bank 2)
    P0176Fuel Compensation Sensor Circuit Malfunction
    P0177Fuel Compensation Sensor CKT Range/Perf
    P0178Fuel Compensation Sensor Circuit Low Input
    P0179Fuel Compensation Sensor Circuit High Input
    P0180Fuel Temperature Sensor A Circuit Malfunction
    P0181Fuel Temperature Sensor A CKT Range/Perf
    P0182Fuel Temperature Sensor A Circuit Low Input
    P0183Fuel Temperature Sensor A Circuit High Input
    P0184Fuel Temperature Sensor A CKT Intermittent
    P0185Fuel Temperature Sensor B Circuit Malfunction
    P0186Fuel Temperature Sensor B CKT Range/Perf
    P0187Fuel Temperature Sensor B Circuit Low Input
    P0188Fuel Temperature Sensor B Circuit High Input
    P0189Fuel Temperature Sensor B CKT Intermittent
    P0190Fuel Rail Pressure Sensor Circuit Malfunction
    P0191Fuel Rail Pressure Sensor CKT Range/Perf
    P0192Fuel Rail Pressure Sensor Circuit Low Input
    P0193Fuel Rail Pressure Sensor Circuit High Input
    P0194Fuel Rail Pressure Sensor CKT Intermittent
    P0195Engine Oil Temp Sensor Circuit Malfunction
    P0196Engine Oil Temp Sensor CKT Range/Perf
    P0197Engine Oil Temp Sensor Circuit Low Input
    P0198Engine Oil Temp Sensor Circuit High Input
    P0199Engine Oil Temp Sensor CKT Intermittent
    P0200Injector Circuit Open
    P0201Injector Circuit Open Cylinder 1
    P0202Injector Circuit Open Cylinder 2
    P0203Injector Circuit Open Cylinder 3
    P0204Injector Circuit Open Cylinder 4
    P0205Injector Circuit Open Cylinder 5
    P0206Injector Circuit Open Cylinder 6
    P0207Injector Circuit Open Cylinder 7
    P0208Injector Circuit Open Cylinder 8
    P0209Injector Circuit Open Cylinder 9
    P0210Injector Circuit Open Cylinder 10
    P0211Injector Circuit Open Cylinder 11
    P0212Injector Circuit Open Cylinder 12
    P0213Cold Start Injector 1 Malfunction
    P0214Cold Start Injector 2 Malfunction
    P0215Engine Shutoff Solenoid Malfunction
    P0216Injection Timing Control Circuit Malfunction
    P0217Engine Overtemp Condition
    P0218Trans Overtemp Condition
    P0219Engine Overspeed Condition
    P0220TPS/Pedal Position Sensor/Switch B Circuit Malfunction
    P0221TPS/Pedal Position Sensor/Switch B CKT Range/Perf
    P0222TPS/Pedal Position Sensor/Switch B Circuit Low Input
    P0223TPS/Pedal Position Sensor/Switch B Circuit High Input
    P0224TPS/Pedal Position Sensor/Switch B CKT Intermittent
    P0225TPS/Pedal Position Sensor/Switch C Circuit Malfunction
    P0226TPS/Pedal Position Sensor/Switch C CKT Range/Perf
    P0227TPS/Pedal Position Sensor/Switch C Circuit Low Input
    P0228TPS/Pedal Position Sensor/Switch C Circuit High Input
    P0229TPS/Pedal Position Sensor/Switch C CKT Intermittent
    P0230Fuel Pump Primary Circuit Malfunction
    P0231Fuel Pump Secondary Circuit Low
    P0232Fuel Pump Secondary Circuit High
    P0233Fuel Pump Secondary Circuit Intermittent Ckt
    P0234Engine Overboost Condition
    P0235Turbo/Super Boost Sensor A Circuit Malfunction
    P0236Turbo/Super Boost Sensor A CKT Range/Perf
    P0237Turbo/Super Boost Sensor A Circuit Low Input
    P0238Turbo/Super Boost Sensor A Circuit High Input
    P0239Turbo/Super Boost Sensor B Circuit Malfunction
    P0240Turbo/Super Boost Sensor B CKT Range/Perf
    P0241Turbo/Super Boost Sensor B Circuit Low Input
    P0242Turbo/Super Boost Sensor B Circuit High Input
    P0243Turbo/Sup Wastegate Solenoid A Malfunction
    P0244Turbo/Sup Wastegate Solenoid A Range/Performance
    P0245Turbo/Sup Wastegate Solenoid A Low
    P0246Turbo/Sup Wastegate Solenoid A High
    P0247Turbo/Sup Wastegate Solenoid B Malfunction
    P0248Turbo /Sup Wastegate Solenoid B Range/Performance
    P0249Turbo/Sup Wastegate Solenoid B Low
    P0250Turbo/Sup Wastegate Solenoid B High
    P0251Injection Pump Metering Control A
    P0252Injection Pump Metering Control A Range/Performance
    P0253Injection Pump Metering Control A Low
    P0254Injection Pump Metering Control A High
    P0255Injection Pump Metering Control A Intermittent Ckt
    P0256Injection Pump Metering Control B Malfunction
    P0257Injection Pump Metering Control B Range/Performance
    P0258Injection Pump Metering Control B Low
    P0259Injection Pump Metering Control B High
    P0260Injection Pump Metering Control B Intermittent Ckt
    P0261Cylinder 1 Injector Control Circuit Low
    P0262Cylinder 1 Injector Control Circuit High
    P0263Cylinder 1 Contribution Balance Fault
    P0264Cylinder 2 Injector Control Circuit Low
    P0265Cylinder 2 Injector Control Circuit High
    P0266Cylinder 2 Contribution Balance Fault
    P0267Cylinder 3 Injector Control Circuit Low
    P0268Cylinder 3 Injector Control Circuit High
    P0269Cylinder 3 Contribution Balance Fault
    P0270Cylinder 4 Injector Control Circuit Low
    P0271Cylinder 4 Injector Control Circuit High
    P0272Cylinder 4 Contribution Balance Fault
    P0273Cylinder 5 Injector Control Circuit Low
    P0274Cylinder 5 Injector Control Circuit High
    P0275Cylinder 5 Contribution Balance Fault
    P0276Cylinder 6 Injector Control Circuit Low
    P0277Cylinder 6 Injector Control Circuit High
    P0278Cylinder 6 Contribution Balance Fault
    P0279Cylinder 7 Injector Control Circuit Low
    P0280Cylinder 7 Injector Control Circuit High
    P0281Cylinder 7 Contribution Balance Fault
    P0282Cylinder 8 Injector Control Circuit Low
    P0283Cylinder 8 Injector Control Circuit High
    P0284Cylinder 8 Contribution Balance Fault
    P0285Cylinder 9 Injector Control Circuit Low
    P0286Cylinder 9 Injector Control Circuit High
    P0287Cylinder 9 Contribution Balance Fault
    P0288Cylinder 10 Injector Control Circuit Low
    P0289Cylinder 10 Injector Control Circuit High
    P0290Cylinder 10 Contribution Balance Fault
    P0291Cylinder 11 Injector Control Circuit Low
    P0292Cylinder 11 Injector Control Circuit High
    P0293Cylinder 11 Contribution Balance Fault
    P0294Cylinder 12 Injector Control Circuit Low
    P0295Cylinder 12 Injector Control Circuit High
    P0296Cylinder 12 Contribution Balance Fault
    P0297Vehicle Overspeed Error
    P0298Engine Oil Temperature Too High
    P0299Turbo/Super Charger UnderBoost
    P0300Random/Multiple Cylinder Misfire Detected
    P0301Cylinder 1 Misfire Detected
    P0302Cylinder 2 Misfire Detected
    P0303Cylinder 3 Misfire Detected
    P0304Cylinder 4 Misfire Detected
    P0305Cylinder 5 Misfire Detected
    P0306Cylinder 6 Misfire Detected
    P0307Cylinder 7 Misfire Detected
    P0308Cylinder 8 Misfire Detected
    P0309Cylinder 9 Misfire Detected
    P0310Cylinder 10 Misfire Detected
    P0311Cylinder 11 Misfire Detected
    P0312Cylinder 12 Misfire Detected
    P0313Misfire Detected Low Fuel Level
    P0314Misfire Detected Cyl. not Specific
    P0315Crankshaft Position System Variation Not Learned
    P0316Misfire Detected 1st 1000 Revs.
    P0317Rough Road Hardware Not Present
    P0318Rough Road Sensor A Signal Circuit
    P0319Rough Road Sensor B
    P0320Ignition/Dist Engine Speed Input Circuit Malfunction
    P0321Ignition/Dist Engine Speed Input CKT Range/Perf
    P0322Ignition/Dist Engine Speed Input Circuit No Signal
    P0323Ignition/Dist Engine Speed Input CKT Intermittent
    P0324Knock Control System Malfunction
    P0325Knock Sensor 1 Circuit Malfunction Bank 1 or 1 Sensor
    P0326Knock Sensor 1 CKT Range/Perf Bank 1 or 1 Sensor
    P0327Knock Sensor 1 Circuit Low Input Bank 1 or 1 Sensor
    P0328Knock Sensor 1 Circuit High Input Bank 1 or 1 Sensor
    P0329Knock Sensor 1 CKT Intermittent Bank 1 or 1 Sensor
    P0330Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331Knock Sensor 2 CKT Range/Perf (Bank 2)
    P0332Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333Knock Sensor 2 Circuit High Input (Bank 2)
    P0334Knock Sensor 2 CKT Intermittent (Bank 2)
    P0335Crankshaft Position Sensor A Circuit Malfunction
    P0336Crankshaft Position Sensor A CKT Range/Perf
    P0337Crankshaft Position Sensor A Circuit Low Input
    P0338Crankshaft Position Sensor A Circuit High Input
    P0339Crankshaft Position Sensor A CKT Intermittent
    P0340Camshaft Position Sensor A - Bank 1 Circuit Malfunction
    P0341Camshaft Position Sensor A - Bank 1 CKT Range/Perf
    P0342Camshaft Position Sensor A - Bank 1 Circuit Low Input
    P0343Camshaft Position Sensor A - Bank 1 Circuit High Input
    P0344Camshaft Position Sensor A - Bank 1 CKT Intermittent
    P0345Camshaft Position Sensor A - Bank 2 Circuit Malfunction
    P0346Camshaft Position Sensor A - Bank 2 CKT Range/Perf
    P0347Camshaft Position Sensor A - Bank 2 Circuit Low Input
    P0348Camshaft Position Sensor A - Bank 2 Circuit High Input
    P0349Camshaft Position Sensor A - Bank 2 CKT Intermittent
    P0350Ignition Coil Primary/Secondary Circuit Malfunction
    P0351Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362Ignition Coil L Primary/Secondary Circuit Malfunction
    P0363Misfire Detected Fueling Disabled
    P0365Camshaft Position Sensor B - Bank 1 Circuit Malfunction
    P0366Camshaft Position Sensor B - Bank 1 CKT Range/Perf
    P0367Camshaft Position Sensor B - Bank 1 Circuit Low Input
    P0368Camshaft Position Sensor B - Bank 1 Circuit High Input
    P0369Camshaft Position Sensor B - Bank 1 CKT Intermittent
    P0370Timing Reference High Res Signal A Malfunction
    P0371Timing Reference High Res Signal A Too Many Pulses
    P0372Timing Reference High Res Signal A Too Few Pulses
    P0373Timing Reference High Res Signal A Erratic Pulses
    P0374Timing Reference High Res Signal A No Pulses
    P0375Timing Reference High Res Signal B Malfunction
    P0376Timing Reference High Res Signal B Too Many Pulses
    P0377Timing Reference High Res Signal B Too Few Pulses
    P0378Timing Reference High Res Signal B Erratic Pulses
    P0379Timing Reference High Res Signal B No Pulses
    P0380Glow Plug/Heater CKT A Malfunction
    P0381Glow Plug/Heater Indicator Circuit Malfunction
    P0382Glow Plug/Heater CKT B Malfunction
    P0383Glow Plug Module Control Circuit Low
    P0384Glow Plug Module Control Circuit High
    P0385Crankshaft Position Sensor B Circuit Malfunction
    P0386Crankshaft Position Sensor B CKT Range/Perf
    P0387Crankshaft Position Sensor B Circuit Low Input
    P0388Crankshaft Position Sensor B Circuit High Input
    P0389Crankshaft Position Sensor B CKT Intermittent
    P0390Camshaft Position Sensor B - Bank 2 Circuit Malfunction
    P0391Camshaft Position Sensor B - Bank 2 CKT Range/Perf
    P0392Camshaft Position Sensor B - Bank 2 Circuit Low Input
    P0393Camshaft Position Sensor B - Bank 2 Circuit High Input
    P0394Camshaft Position Sensor B - Bank 2 CKT Intermittent
    P0400EGR Flow Malfunction
    P0401EGR Flow Insufficient
    P0402EGR Flow Excessive
    P0403EGR Flow Circuit Malfunction
    P0404EGR Flow CKT Range/Perf
    P0405EGR Flow Sensor A Circuit Low Input
    P0406EGR Flow Sensor A Circuit High Input
    P0407EGR Flow Sensor B Circuit Low Input
    P0408EGR Flow Sensor B Circuit High Input
    P0409EGR Flow Sensor A Circuit
    P0410Secondary Air Injection System Malfunction
    P0411Secondary Air Injection System Incorrect Flow
    P0412Secondary Air Injection System Valve A Malfunction
    P0413Secondary Air Injection System Valve A CKT Open
    P0414Secondary Air Injection System Valve A CKT Short
    P0415Secondary Air Injection System Valve B Malfunction
    P0416Secondary Air Injection System Valve B CKT Open
    P0417Secondary Air Injection System Valve B CKT Short
    P0418Secondary Air Injection System Relay A Malfunction
    P0419Secondary Air Injection System Relay B Malfunction
    P0420Catalyst Efficiency Below Threshold (Bank 1)
    P0421Warm Up Catalyst Below Threshold (Bank 1)
    P0422Main Catalyst Below Threshold (Bank 1)
    P0423Heated Catalyst Below Threshold (Bank 1)
    P0424Htd Catalyst Temp Below Threshold (Bank 1)
    P0425Catalyst Temp. Sensor (Bank 1 Sensor 1)
    P0426Catalyst Temp. Sensor Performance (Bank 1 Sensor 1)
    P0427Catalyst Temp. Sensor Circuit Low (Bank 1 Sensor 1)
    P0428Catalyst Temp. Sensor Circuit High (Bank 1 Sensor 1)
    P0429Catalyst Heater Control (Bank 1)
    P0430Catalyst Efficiency Below Threshold (Bank 2)
    P0431Warm Up Catalyst Below Threshold (Bank 2)
    P0432Main Catalyst Below Threshold (Bank 2)
    P0433Heated Catalyst Below Threshold (Bank 2)
    P0434Htd Catalyst Temp Below Threshold (Bank 2)
    P0435Catalyst Temp. Sensor (Bank 2 Sensor 1)
    P0436Catalyst Temp. Sensor Performance (Bank 2 Sensor 1)
    P0437Catalyst Temp. Sensor Circuit Low (Bank 2 Sensor 1)
    P0438Catalyst Temp. Sensor Circuit High (Bank 2 Sensor 1)
    P0439Catalyst Heater Control (Bank 2)
    P0440EVAP Emission Control System Malfunction
    P0441EVAP Emission Control System Purge Flow Fault
    P0442EVAP Emission Control System Leak (Small)
    P0443EVAP Emission Control System Purge Valve C Fault
    P0444EVAP Emission Control System Purge Valve C Open
    P0445EVAP Emission Control System Purge Valve C Short
    P0446EVAP Emission Control System Vent Circuit Malf
    P0447EVAP Emission Control System Vent Circuit Open
    P0448EVAP Emission Control System Vent Circuit Short
    P0449EVAP Emission Control System Vent Vlv/Sol Malf
    P0450EVAP Emission Control System Pres Sensor Fault
    P0451EVAP Emission Control System Pres Sensor Range
    P0452EVAP Emission Control System Pres Sensor Low
    P0453EVAP Emission Control System Pres Sensor High
    P0454EVAP Emission Control System Pres Sensor Erratic
    P0455EVAP Emission Control System Leak (Large)
    P0456EVAP Emission Control System Leak Very Small
    P0457EVAP Emission Control System Leak Cap Loose/Off
    P0458EVAP System Canister Purge Sol Circuit Low
    P0459EVAP System Canister Purge Sol Circuit High
    P0460Fuel Level Sensor A Circuit Malfunction
    P0461Fuel Level Sensor A CKT Range/Perf
    P0462Fuel Level Sensor A Circuit Low Input
    P0463Fuel Level Sensor A Circuit High Input
    P0464Fuel Level Sensor A CKT Intermittent
    P0465EVAP Emission Purge Flow Sensor Circuit Malfunction
    P0466EVAP Emission Purge Flow Sensor CKT Range/Perf
    P0467EVAP Emission Purge Flow Sensor Circuit Low Input
    P0468EVAP Emission Purge Flow Sensor Circuit High Input
    P0469EVAP Emission Purge Flow Sensor CKT Intermittent
    P0470Exhaust Pressure Sensor Circuit Malfunction
    P0471Exhaust Pressure Sensor CKT Range/Perf
    P0472Exhaust Pressure Sensor Circuit Low Input
    P0473Exhaust Pressure Sensor Circuit High Input
    P0474Exhaust Pressure Sensor CKT Intermittent
    P0475Exhaust Pressure Control Valve Circuit Malfunction
    P0476Exhaust Pressure Control Valve CKT Range/Perf
    P0477Exhaust Pressure Control Valve Circuit Low Input
    P0478Exhaust Pressure Control Valve Circuit High Input
    P0479Exhaust Pressure Control Valve CKT Intermittent
    P0480Cooling Fan 1 Control Circuit
    P0481Cooling Fan 2 Control Circuit
    P0482Cooling Fan 3 Control Circuit
    P0483Control Fan Rationality Check Malfunction
    P0484Control Fan CKT Over Current
    P0485Control Fan Power/Ground Circuit Malfunction
    P0486EGR System Sensor B Circuit
    P0487EGR TPS Control Circuit
    P0488EGR TPS Control CKT Range/Perf
    P0489EGR Control Circuit Low
    P0490EGR Control Circuit High
    P0491Secondary Air System (Bank 1)
    P0492Secondary Air System (Bank 2)
    P0493Fan Speed Overspeed
    P0494Fan Speed Low
    P0495Fan Speed High
    P0496EVAP Emission High Purge Flow Fault
    P0497EVAP Emission Low Purge Flow Fault
    P0498EVAP Emission Vent Vlv/Sol Malf Circuit Low
    P0499EVAP Emission Vent Vlv/Sol Malf Circuit High
    P0500Veh Speed Sensor A Malfunction
    P0501Veh Speed Sensor A Range/Performance
    P0502Veh Speed Sensor A Circuit Low Input
    P0503Veh Speed Sensor A Erratic/High
    P0504Brake Switch A Brake Switch B Correlation
    P0505Idle Control System Malfunction
    P0506Idle Control System RPM Low
    P0507Idle Control System RPM High
    P0508Idle Control System Circuit Low
    P0509Idle Control System Circuit High
    P0510Closed Throttle Position Switch
    P0511Idle Air Control Circuit
    P0512Starter Signal Circuit
    P0513Immobilizer Incorrect
    P0514Battery Temperature Sensor CKT Range/Perf
    P0515Battery Temperature Sensor Circuit
    P0516Battery Temperature Circuit Low
    P0517Battery Temperature Circuit High
    P0518Idle Air Control CKT Intermittent
    P0519Idle Air Control System Performance
    P0520Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521Engine Oil Pressure Sensor/Switch Range/Performance
    P0522Engine Oil Pressure Sensor/Switch Low Voltage
    P0523Engine Oil Pressure Sensor/Switch High Voltage
    P0524Engine Oil Pressure Too Low
    P0525Cruise Servo CKT Range/Perf
    P0526Fan Speed Sensor Circuit
    P0527Fan Speed Sensor CKT Range/Perf
    P0528Fan Speed Sensor Circuit No Signal
    P0529Fan Speed Sensor CKT Intermittent
    P0530A/C Refrigerant Pressure Sensor A Circuit Malfunction
    P0531A/C Refrigerant Pressure Sensor A CKT Range/Perf
    P0532A/C Refrigerant Pressure Sensor A Circuit Low Input
    P0533A/C Refrigerant Pressure Sensor A Circuit High Input
    P0534A/C Refrigerant Charge Loss
    P0535A/C Evaporator Temperature Sensor Circuit
    P0536A/C Evaporator Temperature Sensor CKT Range/Perf
    P0537A/C Evaporator Temperature Sensor Circuit Low
    P0538A/C Evaporator Temperature Sensor Circuit High
    P0539A/C Evaporator Temperature Sensor CKT Intermittent
    P0540Intake Air Heater A Circuit
    P0541Intake Air Heater A Circuit Low
    P0542Intake Air Heater A Circuit High
    P0543Intake Air Heater A Circuit Open
    P0544Exhaust Gas Temp. Sensor Circuit (Bank 1 Sensor 1)
    P0545Exhaust Gas Temp. Sensor Circuit Low (Bank 1 Sensor 1)
    P0546Exhaust Gas Temp. Sensor Circuit High (Bank 1 Sensor 1)
    P0547Exhaust Gas Temp. Sensor Circuit (Bank 2 Sensor 1)
    P0548Exhaust Gas Temp. Sensor Circuit Low (Bank 2 Sensor 1)
    P0549Exhaust Gas Temp. Sensor Circuit High (Bank 2 Sensor 1)
    P0550Power Steering Pres Sensor Circuit Malfunction
    P0551Power Steering Pres Sensor CKT Range/Perf
    P0552Power Steering Pres Sensor Circuit Low Input
    P0553Power Steering Pres Sensor Circuit High Input
    P0554Power Steering Pres Sensor CKT Intermittent
    P0555Brake Booster Pressure Sensor Circuit
    P0556Brake Booster Pressure Sensor CKT Range/Perf
    P0557Brake Booster Pressure Sensor Circuit Low Input
    P0558Brake Booster Pressure Sensor Circuit High Input
    P0559Brake Booster Pressure Sensor CKT Intermittent
    P0560System Voltage Malfunction
    P0561System Voltage Unstable
    P0562System Voltage Low
    P0563System Voltage High
    P0564Cruise Control Multi Func. Input A Signal Error
    P0565Cruise Control On Signal Malfunction
    P0566Cruise Control Off Signal Malfunction
    P0567Cruise Control Resume Signal Malfunction
    P0568Cruise Control Set Signal Malfunction
    P0569Cruise Control Coast Signal Malfunction
    P0570Cruise Control Acceleration Signal Error
    P0571Brake Switch A Circuit Malfunction
    P0572Brake Switch A Circuit Low Input
    P0573Brake Switch A Circuit High Input
    P0574Cruise Control Vehicle Speed Too High
    P0575Cruise Control Circuit Malfunction
    P0576Cruise Control Circuit Low Input
    P0577Cruise Control Circuit High Input
    P0578Cruise Control Multi-Func. Input A Circuit Stuck
    P0579Cruise Control Multi-Func. Input A CKT Range/Perf
    P0580Cruise Control Multi-Func. Input A Circuit Low
    P0581Cruise Control Multi-Func. Input A Circuit High
    P0582Cruise Control Vacuum Control Circuit Open
    P0583Cruise Control Vacuum Control Circuit Low
    P0584Cruise Control Vacuum Control Circuit High
    P0585Cruise Control Multi-Func. Input Correlation
    P0586Cruise Control Vent Control Circuit Open
    P0587Cruise Control Vent Control Circuit Low
    P0588Cruise Control Vent Control Circuit High
    P0589Cruise Control Multi-Func. Input B Circuit
    P0590Cruise Control Multi-Func. Input B Circuit Stuck
    P0591Cruise Control Multi-Func. Input B CKT Range/Perf
    P0592Cruise Control Multi-Func. Input B Circuit Low
    P0593Cruise Control Multi-Func. Input B Circuit High
    P0594Cruise Control Servo Control Circuit Open
    P0595Cruise Control Servo Control Circuit Low
    P0596Cruise Control Servo Control Circuit High
    P0597Cruise Control Control Circuit Open
    P0598Cruise Control Control Circuit Low
    P0599Cruise Control Control Circuit High
    P0600Serial Comm Link Malfunction
    P0601Int Control Module Memory Check Sum Error
    P0602Control Module Programming Error
    P0603PCM Keep Alive Memory (KAM) Error
    P0604PCM Random Access Mem (RAM) Error
    P0605PCM Read Only Memory (ROM) Error
    P0606PCM Processor Fault
    P0607Control Module Performance
    P0608Control Module VSS Output A Malfunction
    P0609Control Module VSS Output B Malfunction
    P0610Control Module Vehicle Options Malfunction
    P0611Injector Control Module Performance
    P0612Injector Control Module Relay Control
    P0613TCM Processor Fault
    P0614ECM/TCM Incompatible
    P0615Starter Relay Circuit
    P0616Starter Relay Circuit Low
    P0617Starter Relay Circuit High
    P0618Alternative Fuel Module (KAM) Error
    P0619Alternative Fuel Module Memory
    P0620Generator Control Malfunction
    P0621Generator L-Term. Lamp Control
    P0622Generator F-Term. Field F Control
    P0623Generator Lamp Control Circuit
    P0624Fuel Cap Lamp Circuit
    P0625Generator F-Term. Circuit Low
    P0626Generator F-Term. Circuit High
    P0627Fuel Pump A Control Circuit Open
    P0628Fuel Pump A Control Circuit Low
    P0629Fuel Pump A Control Circuit High
    P0630PCM VIN Not Program. Or Missmatch
    P0631TCM VIN Not Program. Or Missmatch
    P0632Odometer Code Not Programmed ECM/PCM
    P0633Immobilizer Code Not Programmed ECM/PCM
    P0634PCM/ECM/TCM Internal Temp. Too High
    P0635Power Steering Control Circuit
    P0636Power Steering Control Circuit Low
    P0637Power Steering Control Circuit High
    P0638Throttle Actuator Range/Performance (Bank 1)
    P0639Throttle Actuator Range/Performance (Bank 2)
    P0640Intake Air Heater Control Circuit
    P0641Sensor A Reference Voltage Circuit Open
    P0642Sensor A Reference Voltage Circuit Low
    P0643Sensor A Reference Voltage Circuit High
    P0644Driver Display Serial Comm Link
    P0645A/C Clutch Relay Control Circuit
    P0646A/C Clutch Relay Control Circuit Low
    P0647A/C Clutch Relay Control Circuit High
    P0648Immobilizer Lamp Circuit
    P0649Cruise Control Lamp Circuit
    P0650MIL Control Circuit Malfunction
    P0651Sensor B Reference Voltage Circuit Open
    P0652Sensor B Reference Voltage Circuit Low
    P0653Sensor B Reference Voltage Circuit High
    P0654Engine RPM Circuit Malfunction
    P0655Engine Hot Lamp Output Circuit Malfunction
    P0656Fuel Level Output Circuit Malfunction
    P0657Actuator Supply Voltage A Circuit Open
    P0658Actuator Supply Voltage A Circuit Low
    P0659Actuator Supply Voltage A Circuit High
    P0660Intake Man Tuning Control CKT Open (Bank 1)
    P0661Intake Man Tuning Control CKT Low (Bank 1)
    P0662Intake Man Tuning Control CKT High (Bank 1)
    P0663Intake Man Tuning Control CKT Open (Bank 2)
    P0664Intake Man Tuning Control CKT Low (Bank 2)
    P0665Intake Man Tuning Control CKT High (Bank 2)
    P0666PCM/ECM/TCM Internal Temp. Sensor Circuit
    P0667PCM/ECM/TCM Internal Temp. Sensor Range/Perf.
    P0668PCM/ECM/TCM Internal Temp. Sensor Circuit Low
    P0669PCM/ECM/TCM Internal Temp. Sensor Circuit High
    P0670Glow Plug/Heater Module Control
    P0671Glow Plug/Heater Cylinder 1
    P0672Glow Plug/Heater Cylinder 2
    P0673Glow Plug/Heater Cylinder 3
    P0674Glow Plug/Heater Cylinder 4
    P0675Glow Plug/Heater Cylinder 5
    P0676Glow Plug/Heater Cylinder 6
    P0677Glow Plug/Heater Cylinder 7
    P0678Glow Plug/Heater Cylinder 8
    P0679Glow Plug/Heater Cylinder 9
    P0680Glow Plug/Heater Cylinder 10
    P0681Glow Plug/Heater Cylinder 11
    P0682Glow Plug/Heater Cylinder 12
    P0683Glow Plug/Heater Module Comm Problem
    P0684Glow Plug/Heater Comm Problem CKT Range/Perf
    P0685ECM/PCM Power Relay Control Circuit Open
    P0686ECM/PCM Power Relay Control Circuit Low
    P0687ECM/PCM Power Relay Control Circuit High
    P0688ECM/PCM Power Relay Sense Circuit Open
    P0689ECM/PCM Power Relay Sense Circuit Low
    P0690ECM/PCM Power Relay Sense Circuit High
    P0691Fan 1 Control Circuit Low
    P0692Fan 1 Control Circuit High
    P0693Fan 2 Control Circuit Low
    P0694Fan 2 Control Circuit High
    P0695Fan 3 Control Circuit Low
    P0696Fan 3 Control Circuit High
    P0697Sensor C Reference Voltage Circuit Open
    P0698Sensor C Reference Voltage Circuit Low
    P0699Sensor C Reference Voltage Circuit High
    P0700Trans Control Sys Malfunction
    P0701Trans Control Sys Range/Performance
    P0702Trans Control Sys Electrical
    P0703Brake Switch B Circuit Malfunction
    P0704Clutch Switch Input Circuit Malfunction
    P0705Trans Range Sensor Circuit Malfunction (PRNDL Input)
    P0706Trans Range Sensor CKT Range/Perf
    P0707Trans Range Sensor Circuit Low Input
    P0708Trans Range Sensor Circuit High Input
    P0709Trans Range Sensor CKT Intermittent
    P0710Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711Trans Fluid Temp Sensor A CKT Range/Perf
    P0712Trans Fluid Temp Sensor A Circuit Low Input
    P0713Trans Fluid Temp Sensor A Circuit High Input
    P0714Trans Fluid Temp Sensor A CKT Intermittent
    P0715Input/Turbine Speed Sensor A Circuit Malfunction
    P0716Input/Turbine Speed Sensor A CKT Range/Perf
    P0717Input/Turbine Speed Sensor A Circuit No Signal
    P0718Input/Turbine Speed Sensor A CKT Intermittent
    P0719Brake Switch B Circuit Low Input
    P0720Output Speed Sensor Circuit Malfunction
    P0721Output Speed Sensor Circuit Range/Perf
    P0722Output Speed Sensor Circuit No Signal
    P0723Output Speed Sensor CKT Intermittent
    P0724Brake Switch B Circuit High Input
    P0725Engine Speed Sensor Circuit Malfunction
    P0726Engine Speed Sensor CKT Range/Perf
    P0727Engine Speed Sensor Circuit No Signal
    P0728Engine Speed Sensor CKT Intermittent
    P0729Gear 6 Ratio Incorrect
    P0730Gear Ratio Incorrect
    P0731Gear 1 Ratio Incorrect
    P0732Gear 2 Ratio Incorrect
    P0733Gear 3 Ratio Incorrect
    P0734Gear 4 Ratio Incorrect
    P0735Gear 5 Ratio Incorrect
    P0736Reverse Ratio Incorrect
    P0737TCM Engine Speed Output Circuit
    P0738TCM Engine Speed Output Circuit Low
    P0739TCM Engine Speed Output Circuit High
    P0740TCC Circuit Malfunction
    P0741Torque Converter CKT Performance Or Stuck Off
    P0742Torque Converter Circuit Stuck On
    P0743Torque Converter Circuit Electrical
    P0744Torque Converter CKT Intermittent
    P0745Pres Cntrl Sol. A Circuit Malfunction
    P0746Pres Cntrl Sol. A CKT Performance Or Stuck Off
    P0747Pres Cntrl Sol. A Circuit Stuck On
    P0748Pres Cntrl Sol. A Circuit Electrical
    P0749Pres Cntrl Sol. A CKT Intermittent
    P0750Shift Solenoid A Malfunction
    P0751Shift Solenoid A CKT Performance Or Stuck Off
    P0752Shift Solenoid A Circuit Stuck On
    P0753Shift Solenoid A Circuit Electrical
    P0754Shift Solenoid A CKT Intermittent
    P0755Shift Solenoid B Malfunction
    P0756Shift Solenoid B CKT Performance Or Stuck Off
    P0757Shift Solenoid B Circuit Stuck On
    P0758Shift Solenoid B Circuit Electrical
    P0759Shift Solenoid B CKT Intermittent
    P0760Shift Solenoid C Malfunction
    P0761Shift Solenoid C CKT Performance Or Stuck Off
    P0762Shift Solenoid C Circuit Stuck On
    P0763Shift Solenoid C Circuit Electrical
    P0764Shift Solenoid C CKT Intermittent
    P0765Shift Solenoid D Malfunction
    P0766Shift Solenoid D CKT Performance Or Stuck Off
    P0767Shift Solenoid D Circuit Stuck On
    P0768Shift Solenoid D Circuit Electrical
    P0769Shift Solenoid D CKT Intermittent
    P0770Shift Solenoid E Malfunction
    P0771Shift Solenoid E CKT Performance Or Stuck Off
    P0772Shift Solenoid E Circuit Stuck On
    P0773Shift Solenoid E Circuit Electrical
    P0774Shift Solenoid E CKT Intermittent
    P0775Pres Ctrl Sol. B Circuit Malfunction
    P0776Pres Ctrl Sol. B CKT Performance Or Stuck Off
    P0777Pres Ctrl Sol. B Circuit Stuck On
    P0778Pres Ctrl Sol. B Circuit Electrical
    P0779Pres Ctrl Sol. B CKT Intermittent
    P0780Shift Malfunction
    P07811-2 Shift Malfunction
    P07822-3 Shift Malfunction
    P07833-4 Shift Malfunction
    P07844-5 Shift Malfunction
    P0785Shift/Timing Solenoid Malfunction
    P0786Shift/Timing Solenoid Range/Performance
    P0787Shift/Timing Solenoid Low
    P0788Shift/Timing Solenoid High
    P0789Shift/Timing Solenoid Intermittent Ckt
    P0790Normal/Performance Switch Circuit Malfunction
    P0791Intermediate Shaft Speed Sensor A Circuit
    P0792Intermediate Shaft Speed Sensor A Circuit Range/Perf
    P0793Intermediate Shaft Speed Sensor A Circuit No Signal
    P0794Intermediate Shaft Speed Sensor A CKT Intermittent
    P0795Pres Ctrl Sol. C Malfunction
    P0796Pres Ctrl Sol. C CKT Performance Or Stuck Off
    P0797Pres Ctrl Sol. C Circuit Stuck On
    P0798Pres Ctrl Sol. C Circuit Electrical
    P0799Pres Ctrl Sol. C CKT Intermittent
    P0800Transfer Case Control System MIL Request
    P0801Reverse Inhibit Control Circuit Malfunction
    P0802Trans Control Sys MIL Request Circuit Open
    P08031-4 Upshift Solenoid Circuit Malfunction
    P08041-4 Upshift Lamp Circuit Malfunction
    P0805Clutch Position Sensor Circuit Malfunction
    P0806Clutch Position Sensor Circuit Range/Performance
    P0807Clutch Position Sensor Circuit Low
    P0808Clutch Position Sensor Circuit High
    P0809Clutch Position Sensor Circuit Intermittent Ckt
    P0810Clutch Position Control Malfunction
    P0811Clutch Slippage Excessive
    P0812Reverse Input Circuit Malfunction
    P0813Reverse Output Circuit Malfunction
    P0814Trans Range Display Circuit Malfunction
    P0815Upshift Switch Circuit Malfunction
    P0816Downshift Switch Circuit Malfunction
    P0817Starter Disable Circuit
    P0818Driveline Disconn. Switch Input
    P0819Up/Down Shift SW Transmission Range Correlation
    P0820Gear Lever X-Y Sensor Circuit
    P0821Gear Lever X Sensor Circuit
    P0822Gear Lever Y Sensor Circuit
    P0823Gear Lever X Sensor Circuit Intermittent Ckt
    P0824Gear Lever Y Sensor Circuit Intermittent Ckt
    P0825Gear Lever Push/Pull Switch (Shift Anticipate)
    P0826Upshift Switch Downshift Switch Circuit
    P0827Upshift Switch Downshift Switch Circuit Low
    P0828Upshift Switch Downshift Switch Circuit High
    P08295-6 Shift
    P0830Clutch Position Switch A Circuit Malfunction
    P0831Clutch Position Switch A Circuit Low
    P0832Clutch Position Switch A Circuit Highb
    P0833Clutch Position Switch B Circuit Malfunction
    P0834Clutch Position Switch B Circuit Low
    P0835Clutch Position Switch B Circuit High
    P08364 Wheel Drive Switch Circuit Malfunction
    P08374 Wheel Drive Switch CKT Range/Perf
    P08384 Wheel Drive Switch Circuit Low
    P08394 Wheel Drive Switch Circuit High
    P0840Trans Fluid Press Sensor/Switch A Circuit Malfunction
    P0841Trans Fluid Press Sensor/Switch A CKT Range/Perf
    P0842Trans Fluid Press Sensor/Switch A Circuit Low
    P0843Trans Fluid Press Sensor/Switch A Circuit High
    P0844Trans Fluid Press Sensor/Switch A CKT Intermittent
    P0845Trans Fluid Press Sensor/Switch B Circuit Malfunction
    P0846Trans Fluid Press Sensor/Switch B CKT Range/Perf
    P0847Trans Fluid Press Sensor/Switch B Circuit Low
    P0848Trans Fluid Press Sensor/Switch B Circuit High
    P0849Trans Fluid Press Sensor/Switch B CKT Intermittent
    P0850Park/Neutral Switch Input Circuit
    P0851Park/Neutral Switch Circuit Low Input
    P0852Park/Neutral Switch Circuit High Input
    P0853Drive Switch Input Circuit
    P0854Drive Switch Circuit Low Input
    P0855Drive Switch Circuit High Input
    P0856Traction Control Input Signal
    P0857Traction Control Input Signal Range/Performance
    P0858Traction Control Input Signal Low
    P0859Traction Control Input Signal High
    P0860Gear Shift Module Communications Circuit
    P0861Gear Shift Module Communications Circuit Low
    P0862Gear Shift Module Communications Circuit High
    P0863TCM Communications Circuit
    P0864TCM Communications CKT Range/Perf
    P0865TCM Communications Circuit Low
    P0866TCM Communications Circuit High
    P0867Trans Fluid Press
    P0868Trans Fluid Press Low
    P0869Trans Fluid Press High
    P0870Trans Fluid Press Sensor/Switch C Circuit
    P0871Trans Fluid Press Sensor/Switch C CKT Range/Perf
    P0872Trans Fluid Press Sensor/Switch C Circuit Low
    P0873Trans Fluid Press Sensor/Switch C Circuit High
    P0874Trans Fluid Press Sensor/Switch C CKT Intermittent
    P0875Trans Fluid Press Sensor/Switch D Circuit
    P0876Trans Fluid Press Sensor/Switch D CKT Range/Perf
    P0877Trans Fluid Press Sensor/Switch D Circuit Low
    P0878Trans Fluid Press Sensor/Switch D Circuit High
    P0879Trans Fluid Press Sensor/Switch D CKT Intermittent
    P0880TCM Power Input Signal
    P0881TCM Power Input Signal Range/Performance
    P0882TCM Power Input Signal Low
    P0883TCM Power Input Signal High
    P0884TCM Power Input Signal CKT Intermittent
    P0885TCM Power Relay Control Circuit Open
    P0886TCM Power Relay Control Circuit Low
    P0887TCM Power Relay Control Circuit High
    P0888TCM Power Relay Sense Circuit
    P0889TCM Power Relay Sense CKT Range/Perf
    P0890TCM Power Relay Sense Circuit Low
    P0891TCM Power Relay Sense Circuit High
    P0892TCM Power Relay Sense CKT Intermittent
    P0893Multiple Gears Engaged
    P0894Transmission Comp. Slipping
    P0895Shift Time Too Short
    P0896Shift Time Too Long
    P0897Transmission Fluid Deteriorated
    P0898Transmission Ctrl. MIL Request Circuit Low
    P0899Transmission Ctrl. MIL Request Circuit High
    P0900Clutch Actuator Circuit Open
    P0901Clutch Actuator CKT Range/Perf
    P0902Clutch Actuator Circuit Low
    P0903Clutch Actuator Circuit High
    P0904Gate Select Position Circuit
    P0905Gate Select Position CKT Range/Perf
    P0906Gate Select Position Circuit Low
    P0907Gate Select Position Circuit High
    P0908Gate Select Position CKT Intermittent
    P0909Gate Select Control Error
    P0910Gate Select Actuator Circuit Open
    P0911Gate Select Actuator CKT Range/Perf
    P0912Gate Select Actuator Circuit Low
    P0913Gate Select Actuator Circuit High
    P0914Gear Shift Position Circuit
    P0915Gear Shift Position CKT Range/Perf
    P0916Gear Shift Position Circuit Low
    P0917Gear Shift Position Circuit High
    P0918Gear Shift Position CKT Intermittent
    P0919Gear Shift Position Control Error
    P0920Gear Shift Forward Actuator Circuit Open
    P0921Gear Shift Forward Actuator CKT Range/Perf
    P0922Gear Shift Forward Actuator Circuit Low
    P0923Gear Shift Forward Actuator Circuit High
    P0924Gear Shift Reverse Actuator Circuit Open
    P0925Gear Shift Reverse Actuator CKT Range/Perf
    P0926Gear Shift Reverse Actuator Circuit Low
    P0927Gear Shift Reverse Actuator Circuit High
    P0928Gear Shift Lock Solenoid Ctrl Circuit Open
    P0929Gear Shift Lock Solenoid Ctrl CKT Range/Perf
    P0930Gear Shift Lock Solenoid Ctrl Circuit Low
    P0931Gear Shift Lock Solenoid Ctrl Circuit High
    P0932Hydraulic Pressure Sensor Circuit
    P0933Hydraulic Pressure Sensor CKT Range/Perf
    P0934Hydraulic Pressure Sensor Circuit Low
    P0935Hydraulic Pressure Sensor Circuit High
    P0936Hydraulic Pressure Sensor CKT Intermittent
    P0937Hydraulic Oil Temp Sensor Circuit
    P0938Hydraulic Oil Temp Sensor CKT Range/Perf
    P0939Hydraulic Oil Temp Sensor Circuit Low
    P0940Hydraulic Oil Temp Sensor Circuit High
    P0941Hydraulic Oil Temp Sensor CKT Intermittent
    P0942Hyd. Pressure Unit
    P0943Hyd. Pressure Unit Unit Cycling Too Short
    P0944Hyd. Pressure Unit Loss of Pressure
    P0945Hyd. Pump Relay Circuit Open
    P0946Hyd. Pump Relay CKT Range/Perf
    P0947Hyd. Pump Relay Circuit Low
    P0948Hyd. Pump Relay Circuit High
    P0949Auto Shift Adaptive Learning Not Complete
    P0950Auto Shift Manual Control Circuit
    P0951Auto Shift Manual Control CKT Range/Perf
    P0952Auto Shift Manual Control Circuit Low
    P0953Auto Shift Manual Control Circuit High
    P0954Auto Shift Manual Control CKT Intermittent
    P0955Auto Shift Manual Mode Circuit
    P0956Auto Shift Manual Mode CKT Range/Perf
    P0957Auto Shift Manual Mode Circuit Low
    P0958Auto Shift Manual Mode Circuit High
    P0959Auto Shift Manual Mode CKT Intermittent
    P0960Pressure Control Solenoid A Control Circuit Open
    P0961Pressure Control Solenoid A Control CKT Range/Perf
    P0962Pressure Control Solenoid A Control Circuit Low
    P0963Pressure Control Solenoid A Control Circuit High
    P0964Pressure Control Solenoid B Control Circuit Open
    P0965Pressure Control Solenoid B Control CKT Range/Perf
    P0966Pressure Control Solenoid B Control Circuit Low
    P0967Pressure Control Solenoid B Control Circuit High
    P0968Pressure Control Solenoid C Control Circuit Open
    P0969Pressure Control Solenoid C Control CKT Range/Perf
    P0970Pressure Control Solenoid C Control Circuit Low
    P0971Pressure Control Solenoid C Control Circuit High
    P0972Shift Solenoid A Control CKT Range/Perf
    P0973Shift Solenoid A Control Circuit Low
    P0974Shift Solenoid A Control Circuit High
    P0975Shift Solenoid B Control CKT Range/Perf
    P0976Shift Solenoid B Control Circuit Low
    P0977Shift Solenoid B Control Circuit High
    P0978Shift Solenoid C Control CKT Range/Perf
    P0979Shift Solenoid C Control Circuit Low
    P0980Shift Solenoid C Control Circuit High
    P0981Shift Solenoid D Control CKT Range/Perf
    P0982Shift Solenoid D Control Circuit Low
    P0983Shift Solenoid D Control Circuit High
    P0984Shift Solenoid E Control CKT Range/Perf
    P0985Shift Solenoid E Control Circuit Low
    P0986Shift Solenoid E Control Circuit High
    P0987Trans Fluid Press Sensor/Switch E Circuit
    P0988Trans Fluid Press Sensor/Switch E CKT Range/Perf
    P0989Trans Fluid Press Sensor/Switch E Circuit Low
    P0990Trans Fluid Press Sensor/Switch E Circuit High
    P0991Trans Fluid Press Sensor/Switch E CKT Intermittent
    P0992Trans Fluid Press Sensor/Switch F Circuit
    P0993Trans Fluid Press Sensor/Switch F CKT Range/Perf
    P0994Trans Fluid Press Sensor/Switch F Circuit Low
    P0995Trans Fluid Press Sensor/Switch F Circuit High
    P0996Trans Fluid Press Sensor/Switch F CKT Intermittent
    P0997Shift Solenoid F Control CKT Range/Perf
    P0998Shift Solenoid F Control Circuit Low
    P0999Shift Solenoid F Control Circuit High
    P2000NOx Trap Eff Below Threshold Bank1
    P2001NOx Trap Eff Below Threshold Bank2
    P2002Particulate Trap Eff Below Threshold Bank1
    P2003Particulate Trap Eff Below Threshold Bank2
    P2004Intake Manif Runner Ctrl Stuck Open Bank1
    P2005Intake Manif Runner Ctrl Stuck Open Bank2
    P2006Intake Manif Runner Ctrl Stuck Closed Bank1
    P2007Intake Manif Runner Ctrl Stuck Closed Bank2
    P2008Intake Manif Runner Ctrl Circ/Open Bank1
    P2009Intake Manif Runner Ctrl Circ Low Bank1
    P2010Intake Manif Runner Ctrl Circ Hi Bank1
    P2011Intake Manif Runner Ctrl Circ/Open Bank2
    P2012Intake Manif Runner Ctrl Circ Low Bank2
    P2013Intake Manif Runner Ctrl Circ Hi Bank2
    P2014Intake Manif Runner Pos Sens/Switch Circ Bank1
    P2015Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank 1
    P2016Intake Manif Runner Pos Sens/Switch Circ Low Bank1
    P2017Intake Manif Runner Pos Sens/Switch Circ Hi Bank1
    P2018Intake Manif Runner Pos Sens/Switch Circ Interm Bank1
    P2019Intake Manif Runner Pos Sens/Switch Circ Bank2
    P2020Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank 2
    P2021Intake Manif Runner Pos Sens/Switch Circ Low Bank2
    P2022Intake Manif Runner Pos Sens/Switch Circ Hi Bank2
    P2023Intake Manif Runner Pos Sens/Switch Circ Interm Bank2
    P2024EVAP Emissions (EVAP) Fuel Vapor Temp Sens Circ
    P2025EVAP Fuel Vapor Temp Sens Perf
    P2026EVAP Fuel Vapor Temp Sens Circ Low Voltage
    P2027EVAP Fuel Vapor Temp Sens Circ Hi Voltage
    P2028EVAP Fuel Vapor Temp Sens Circ Interm
    P2029Fuel Fired Heater Disabled
    P2030Fuel Fired Heater Perf
    P2031Exhaust Gas Temp Sens Circ Bank1 Sens2
    P2032Exhaust Gas Temp Sens Circ Low Bank1 Sens2
    P2033Exhaust Gas Temp Sens Circ Hi Bank1 Sens2
    P2034Exhaust Gas Temp Sens Circ Bank2 Sens2
    P2035Exhaust Gas Temp Sens Circ Low Bank2 Sens2
    P2036Exhaust Gas Temp Sens Circ Hi Bank2 Sens2
    P2037Reductant Inj Air Press Sens Circ
    P2038Reductant Inj Air Press Sens Circ Range/Perf
    P2039Reductant Inj Air Press Sens Circ Low Input
    P2040Reductant Inj Air Press Sens Circ Hi Input
    P2041Reductant Inj Air Press Sens Circ Interm
    P2042Reductant Temp Sens Circ
    P2043Reductant Temp Sens Circ Range/Perf
    P2044Reductant Temp Sens Circ Low Input
    P2045Reductant Temp Sens Circ Hi Input
    P2046Reductant Temp Sens Circ Interm
    P2047Reductant Injector Circ/Open Bank1 Unit 1
    P2048Reductant Injector Circ Low Bank1 Unit 1
    P2049Reductant Injector Circ Hi Bank1 Unit 1
    P2050Reductant Injector Circ/Open Bank2 Unit 1
    P2051Reductant Injector Circ Low Bank2 Unit 1
    P2052Reductant Injector Circ Hi Bank2 Unit 1
    P2053Reductant Injector Circ/Open Bank1 Unit 2
    P2054Reductant Injector Circ Low Bank1 Unit 2
    P2055Reductant Injector Circ Hi Bank1 Unit 2
    P2056Reductant Injector Circ/Open Bank2 Unit 2
    P2057Reductant Injector Circ Low Bank2 Unit 2
    P2058Reductant Injector Circ Hi Bank2 Unit 2
    P2059Reductant Inj Air Pump Ctrl Circ/Open
    P2060Reductant Inj Air Pump Ctrl Circ Low
    P2061Reductant Inj Air Pump Ctrl Circ Hi
    P2062Reductant Supply Ctrl Circ/Open
    P2063Reductant Supply Ctrl Circ Low
    P2064Reductant Supply Ctrl Circ Hi
    P2065Fuel Level Sens B Circ
    P2066Fuel Level Sens B Perf
    P2067Fuel Level Sens B Circ Low
    P2068Fuel Level Sens B Circ Hi
    P2069Fuel Level Sens B Circ Interm
    P2070Intake Manif Tuning (IMT) Valve Stuck Open
    P2071IMT Valve Stuck Closed
    P2075IMT Valve Pos Sens/Switch Circ
    P2076IMT Valve Pos Sens/Switch Circ Range/Perf
    P2077IMT Valve Pos Sens/Switch Circ Low
    P2078IMT Valve Pos Sens/Switch Circ Hi
    P2079IMT Valve Pos Sens/Switch Circ Interm
    P2080Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens1
    P2081Exhaust Gas Temp Sens Circ Interm Bank1 Sens1
    P2082Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens1
    P2083Exhaust Gas Temp Sens Circ Interm Bank2 Sens1
    P2084Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens2
    P2085Exhaust Gas Temp Sens Circ Interm Bank1 Sens2
    P2086Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens2
    P2087Exhaust Gas Temp Sens Circ Interm Bank2 Sens2
    P2088A Camshaft Pos Actuator Ctrl Circ Low Bank1
    P2089A Camshaft Pos Actuator Ctrl Circ Hi Bank1
    P2090B Camshaft Pos Actuator Ctrl Circ Low Bank1 c)
    P2091B Camshaft Pos Actuator Ctrl Circ Hi Bank1 c)
    P2092A Camshaft Pos Actuator Ctrl Circ Low Bank2
    P2093A Camshaft Pos Actuator Ctrl Circ Hi Bank2
    P2094B Camshaft Pos Actuator Ctrl Circ Low Bank2 c)
    P2095B Camshaft Pos Actuator Ctrl Circ Hi Bank2 c)
    P2096Post Catalyst Fuel Trim Sys Too Lean Bank1
    P2097Post Catalyst Fuel Trim Sys Too Rich Bank1
    P2098Post Catalyst Fuel Trim Sys Too Lean Bank2
    P2099Post Catalyst Fuel Trim Sys Too Rich Bank2
    P2100Throttle Actuator Ctrl Motor Circ/Open
    P2101Throttle Actuator Ctrl Motor Circ Range/Perf
    P2102Throttle Actuator Ctrl Motor Circ Low
    P2103Throttle Actuator Ctrl Motor Circ Hi
    P2104Throttle Actuator Ctrl Sys-Forced Idle
    P2105Throttle Actuator Ctrl Sys-Forced Engine Shutdown
    P2106Throttle Actuator Ctrl Sys-Forced Limited Power
    P2107Throttle Actuator Ctrl Mod Processor
    P2108Throttle Actuator Ctrl Mod Perf
    P2109Throttle/Pedal Pos Sens A Minimum Stop Perf
    P2110Throttle Actuator Ctrl Sys-Forced Limited RPM
    P2111 Throttle Actuator Ctrl Sys-Stuck Open
    P2112Throttle Actuator Ctrl Sys-Stuck Closed
    P2113Throttle/Pedal Pos Sens B Minimum Stop Perf
    P2114Throttle/Pedal Pos Sens C Minimum Stop Perf
    P2115Throttle/Pedal Pos Sens D Minimum Stop Perf
    P2116Throttle/Pedal Pos Sens E Minimum Stop Perf
    P2117Throttle/Pedal Pos Sens F Minimum Stop Perf
    P2118Throttle Actuator Ctrl Motor Current Range/Perf
    P2119Throttle Actuator Ctrl Throttle Body Range/Perf
    P2120Throttle/Pedal Pos Sens/Switch D Circ
    P2121Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
    P2122Throttle/Pedal Pos Sens/Switch D Circ Low Input
    P2123Pedal Pos Sens1 Hi
    P2124Throttle/Pedal Pos Sens/Switch D Circ Interm
    P2125Throttle/Pedal Pos Sens/Switch E Circ
    P2126Throttle/Pedal Pos Sens/Switch E Circ Range/Perf
    P2127Pedal Pos Validation Switch 2 Low
    P2128Pedal Pos Validation Switch 2 Hi
    P2129Throttle/Pedal Pos Sens/Switch E Circ Interm
    P2130Throttle/Pedal Pos Sens/Switch F Circ
    P2131Throttle/Pedal Pos Sens/Switch F Circ Range Perf
    P2132Throttle/Pedal Pos Sens/Switch F Circ Low Input
    P2133Throttle/Pedal Pos Sens/Switch F Circ Hi Input
    P2134Throttle/Pedal Pos Sens/Switch F Circ Interm
    P2135Throttle/Pedal Pos Sens/Switch A/B Voltage Correlation
    P2136Throttle/Pedal Pos Sens/Switch A/C Voltage Correlation
    P2137Throttle/Pedal Pos Sens/Switch B/C Voltage Correlation
    P2138Throttle/Pedal Pos Sens/Switch D/E Voltage Correlation
    P2139Throttle/Pedal Pos Sens/Switch D/F Voltage Correlation
    P2140Throttle/Pedal Pos Sens/Switch E/F Voltage Correlation
    P2141Exhaust Gas Recirculation Throttle Ctrl Circ Low
    P2142Exhaust Gas Recirculation Throttle Ctrl Circ Hi
    P2143Exhaust Gas Recirculation Vent Ctrl Circ/Open
    P2144Exhaust Gas Recirculation Vent Ctrl Circ Low
    P2145Exhaust Gas Recirculation Vent Ctrl Circ Hi
    P2146Fuel Injector Group 1 Supply Voltage Circ
    P2147Fuel Injector Group 1 Supply Voltage Low
    P2148Fuel Injector Group 1 Supply Voltage Hi
    P2149Fuel Injector Group 2 Supply Voltage Circ
    P2150Fuel Injector Group 2 Supply Voltage Low
    P2151Fuel Injector Group 2 Supply Voltage Hi
    P2152Fuel Injector Group C Supply Voltage Circ/Open
    P2153Fuel Injector Group C Supply Voltage Circ Low
    P2154Fuel Injector Group C Supply Voltage Circ Hi
    P2155Fuel Injector Group D Supply Voltage Circ/Open
    P2156Fuel Injector Group D Supply Voltage Circ Low
    P2157Fuel Injector Group D Supply Voltage Circ Hi
    P2158Vehicle Speed Sens B
    P2159Vehicle Speed Sens B Range/Perf
    P2160Vehicle Speed Sens B Circ Low
    P2161Vehicle Speed Sens B Interm/Erratic
    P2162Vehicle Speed Sens A / B Correlation
    P2163Throttle/Pedal Pos Sens A Maximum Stop Perf
    P2164Throttle/Pedal Pos Sens B Maximum Stop Perf
    P2165Throttle/Pedal Pos Sens C Maximum Stop Perf
    P2166Throttle/Pedal Pos Sens D Maximum Stop Perf
    P2167Throttle/Pedal Pos Sens E Maximum Stop Perf
    P2168Throttle/Pedal Pos Sens F Maximum Stop Perf
    P2169Exhaust Press Regulator Vent Solenoid Ctrl Circ/Open
    P2170Exhaust Press Regulator Vent Solenoid Ctrl Circ Low
    P2171Exhaust Press Regulator Vent Solenoid Ctrl Circ Hi
    P2172Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
    P2173Throttle Actuator Ctrl Sys-Hi Airflow Detected
    P2174Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
    P2175Throttle Actuator Ctrl Sys-Low Airflow Detected
    P2176Throttle Actuator Ctrl Sys-Idle Pos Not Learned
    P2177Sys Too Lean Off Idle Bank1
    P2178Sys Too Rich Off Idle Bank1
    P2179Sys Too Lean Off Idle Bank2
    P2180Sys Too Rich Off Idle Bank2
    P2181Cooling Sys Perf
    P2182Engine Coolant Temp Sens2 Circ
    P2183Engine Coolant Temp Sens2 Circ Range/Perf
    P2184Engine Coolant Temp Sens2 Circ Low
    P2185Engine Coolant Temp Sens2 Circ Hi
    P2186Engine Coolant Temp Sens2 Circ Interm/Erratic
    P2187Sys Too Lean at Idle Bank1
    P2188Sys Too Rich at Idle Bank1
    P2189Sys Too Lean at Idle Bank2
    P2190Sys Too Rich at Idle Bank2
    P2191Sys Too Lean at Hier Load Bank1
    P2192Sys Too Rich at Hier Load Bank1
    P2193Sys Too Lean at Hier Load Bank2
    P2194Sys Too Rich at Hier Load Bank2
    P2195O2 Sens Signal Stuck Lean Bank1 Sens1
    P2196O2 Sens Signal Stuck Rich Bank1 Sens1
    P2197O2 Sens Signal Stuck Lean Bank2 Sens1
    P2198O2 Sens Signal Stuck Rich Bank2 Sens1
    P2199Intake Air Temp Sens1 / 2 Correlation
    P2200NOx Sens Circ Bank1
    P2201NOx Sens Circ Range/Perf Bank1
    P2202NOx Sens Circ Low Input Bank1
    P2203NOx Sens Circ Hi Input Bank1
    P2204NOx Sens Circ Interm Input Bank1
    P2205NOx Sens Heater Ctrl Circ/Open Bank1
    P2206NOx Sens Heater Ctrl Circ Low Bank1
    P2207NOx Sens Heater Ctrl Circ Hi Bank1
    P2208NOx Sens Heater Sense Circ Bank1
    P2209NOx Sens Heater Sense Circ Range/Perf Bank1
    P2210NOx Sens Heater Sense Circ Low Input Bank1
    P2211NOx Sens Heater Sense Circ Hi Input Bank1
    P2212NOx Sens Heater Sense Circ Interm Bank1
    P2213NOx Sens Circ Bank2
    P2214NOx Sens Circ Range/Perf Bank2
    P2215NOx Sens Circ Low Input Bank2
    P2216NOx Sens Circ Hi Input Bank2
    P2217NOx Sens Circ Interm Input Bank2
    P2218NOx Sens Heater Ctrl Circ/Open Bank2
    P2219NOx Sens Heater Ctrl Circ Low Bank2
    P2220NOx Sens Heater Ctrl Circ Hi Bank2
    P2221NOx Sens Heater Sense Circ Bank2
    P2222NOx Sens Heater Sense Circ Range/Perf Bank2
    P2223NOx Sens Heater Sense Circ Low Bank2
    P2224NOx Sens Heater Sense Circ Hi Bank2
    P2225NOx Sens Heater Sense Circ Interm Bank2
    P2226Barometric Press Circ
    P2227Barometric Press Circ Range/Perf
    P2228Barometric Press Circ Low
    P2229Barometric Press Circ Hi
    P2230Barometric Press Circ Interm
    P2231O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens1
    P2232O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens2
    P2233O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens3
    P2234O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens1
    P2235O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens2
    P2236O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens3
    P2237O2 Sens Positive Current Ctrl Circ/Open Bank1 Sens1
    P2238O2 Sens Positive Current Ctrl Circ Low Bank1 Sens1
    P2239O2 Sens Positive Current Ctrl Circ Hi Bank1 Sens1
    P2240O2 Sens Positive Current Ctrl Circ/Open Bank2 Sens1
    P2241O2 Sens Positive Current Ctrl Circ Low Bank2 Sens1
    P2242O2 Sens Positive Current Ctrl Circ Hi Bank2 Sens1
    P2243O2 Sens Ref Voltage Circ/Open Bank1 Sens1
    P2244O2 Sens Ref Voltage Perf Bank1 Sens1
    P2245O2 Sens Ref Voltage Circ Low Bank1 Sens1
    P2246O2 Sens Ref Voltage Circ Hi Bank1 Sens1
    P2247O2 Sens Ref Voltage Circ/Open Bank2 Sens1
    P2248O2 Sens Ref Voltage Perf Bank2 Sens1
    P2249O2 Sens Ref Voltage Circ Low Bank2 Sens1
    P2250O2 Sens Ref Voltage Circ Hi Bank2 Sens1
    P2251O2 Sens Negative Current Ctrl Circ/Open Bank1 Sens1
    P2252O2 Sens Negative Current Ctrl Circ Low Bank1 Sens1
    P2253O2 Sens Negative Current Ctrl Circ Hi Bank1 Sens1
    P2254O2 Sens Negative Current Ctrl Circ/Open Bank2 Sens1
    P2255O2 Sens Negative Current Ctrl Circ Low Bank2 Sens1
    P2256O2 Sens Negative Current Ctrl Circ Hi Bank2 Sens1
    P2257Sec Air Inj Sys Ctrl A Circ Low
    P2258Sec Air Inj Sys Ctrl A Circ Hi
    P2259Sec Air Inj Sys Ctrl B Circ Low
    P2260Sec Air Inj Sys Ctrl B Circ Hi
    P2261T/Super Charger Bypass Valve-Mechanical
    P2262Turbo Boost Press Not Detected-Mechanical
    P2263T/Super Charger Boost Sys Perf
    P2264Water in Fuel Sens Circ
    P2265Water in Fuel Sens Circ Range/Perf
    P2266Water in Fuel Sens Circ Low
    P2267Water in Fuel Sens Circ Hi
    P2268Water in Fuel Sens Circ Interm
    P2269Water in Fuel Condition
    P2270O2 Sens Signal Stuck Lean Bank1 Sens2
    P2271O2 Sens Signal Stuck Rich Bank1 Sens2
    P2272O2 Sens Signal Stuck Lean Bank2 Sens2
    P2273O2 Sens Signal Stuck Rich Bank2 Sens2
    P2274O2 Sens Signal Stuck Lean Bank1 Sens3
    P2275O2 Sens Signal Stuck Rich Bank1 Sens3
    P2276O2 Sens Signal Stuck Lean Bank2 Sens3
    P2277O2 Sens Signal Stuck Rich Bank2 Sens3
    P2278O2 Sens Signals Swapped Bank1 Sens3 / Bank2 Sens3
    P2279Intake Air Sys Leak
    P2280Air Flow Restriction / Air Leak Between Air Filter and MAF
    P2281Air Leak Between MAF and Throttle Body
    P2282Air Leak Between Throttle Body and Intake Valves
    P2283Injector Ctrl Press Sens Circ
    P2284Injector Ctrl Press Sens Circ Range/Perf
    P2285Injector Ctrl Press Sens Circ Low
    P2286Injector Ctrl Press Sens Circ Hi
    P2287Injector Ctrl Press Sens Circ Interm
    P2288Injector Ctrl Press Too Hi
    P2289Injector Ctrl Press Too Hi-Engine Off
    P2290Injector Ctrl Press Too Low
    P2291Injector Ctrl Press Too Low-Engine Cranking
    P2292Injector Ctrl Press Erratic
    P2293Fuel Press Regulator 2 Perf
    P2294Fuel Press Regulator 2 Ctrl Circ
    P2295Fuel Press Regulator 2 Ctrl Circ Low
    P2296Fuel Press Regulator 2 Ctrl Circ Hi
    P2297O2 Sens Out of Range During Deceleration Bank1 Sens1
    P2298O2 Sens Out of Range During Deceleration Bank2 Sens1
    P2299Brake Pedal Pos / Accelerator Pedal Pos Incompatible
    P2300Ignition Coil A Primary Ctrl Circ Low
    P2301Ignition Coil A Primary Ctrl Circ Hi
    P2302Ignition Coil A Sec Circ
    P2303Ignition Coil B Primary Ctrl Circ Low
    P2304Ignition Coil B Primary Ctrl Circ Hi
    P2305Ignition Coil B Sec Circ
    P2306Ignition Coil C Primary Ctrl Circ Low
    P2307Ignition Coil C Primary Ctrl Circ Hi
    P2308Ignition Coil C Sec Circ
    P2309Ignition Coil D Primary Ctrl Circ Low
    P2310Ignition Coil D Primary Ctrl Circ Hi
    P2311Ignition Coil D Sec Circ
    P2312Ignition Coil E Primary Ctrl Circ Low
    P2313Ignition Coil E Primary Ctrl Circ Hi
    P2314Ignition Coil E Sec Circ
    P2315Ignition Coil F Primary Ctrl Circ Low
    P2316Ignition Coil F Primary Ctrl Circ Hi
    P2317Ignition Coil F Sec Circ
    P2318Ignition Coil G Primary Ctrl Circ Low
    P2319Ignition Coil G Primary Ctrl Circ Hi
    P2320Ignition Coil G Sec Circ
    P2321Ignition Coil H Primary Ctrl Circ Low
    P2322Ignition Coil H Primary Ctrl Circ Hi
    P2323Ignition Coil H Sec Circ
    P2324Ignition Coil I Primary Ctrl Circ Low
    P2325Ignition Coil I Primary Ctrl Circ Hi
    P2326Ignition Coil I Sec Circ
    P2327Ignition Coil J Primary Ctrl Circ Low
    P2328Ignition Coil J Primary Ctrl Circ Hi
    P2329Ignition Coil J Sec Circ
    P2330Ignition Coil K Primary Ctrl Circ Low
    P2331Ignition Coil K Primary Ctrl Circ Hi
    P2332Ignition Coil K Sec Circ
    P2333Ignition Coil L Primary Ctrl Circ Low
    P2334Ignition Coil L Primary Ctrl Circ Hi
    P2335Ignition Coil L Sec Circ
    P2336Cylinder #1 Above Knock Threshold
    P2337Cylinder #2 Above Knock Threshold
    P2338Cylinder #3 Above Knock Threshold
    P2339Cylinder #4 Above Knock Threshold
    P2340Cylinder #5 Above Knock Threshold
    P2341Cylinder #6 Above Knock Threshold
    P2342Cylinder #7 Above Knock Threshold
    P2343Cylinder #8 Above Knock Threshold
    P2344Cylinder #9 Above Knock Threshold
    P2345Cylinder #10 Above Knock Threshold
    P2346Cylinder #11 Above Knock Threshold
    P2347Cylinder #12 Above Knock Threshold
    P2400EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
    P2401EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
    P2402EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
    P2403EVAP Emission Sys Leak Detection Pump Sense Circ/Open
    P2404EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
    P2405EVAP Emission Sys Leak Detection Pump Sense Circ Low
    P2406EVAP Emission Sys Leak Detection Pump Sense Circ Hi
    P2407EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
    P2408Fuel Cap Sens/Switch Circ
    P2409Fuel Cap Sens/Switch Circ Range/Perf
    P2410 Fuel Cap Sens/Switch Circ Low
    P2411Fuel Cap Sens/Switch Circ Hi
    P2412Fuel Cap Sens/Switch Circ Interm/Erratic
    P2413Exhaust Gas Recirculation Sys Perf
    P2414O2 Sens Exhaust Sample Error Bank1 Sens1
    P2415O2 Sens Exhaust Sample Error Bank2 Sens1
    P2416O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
    P2417O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
    P2418EVAP Emission Sys Switching Valve Ctrl Circ /Open
    P2419EVAP Emission Sys Switching Valve Ctrl Circ Low
    P2420EVAP Emission Sys Switching Valve Ctrl Circ Hi
    P2421EVAP Emission Sys Vent Valve Stuck Open
    P2422EVAP Emission Sys Vent Valve Stuck Closed
    P2423HC Adsorption Catalyst Eff Below Threshold Bank1
    P2424HC Adsorption Catalyst Eff Below Threshold Bank2
    P2425Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
    P2426Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
    P2427Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
    P2428Exhaust Gas Temp Too Hi Bank1
    P2429Exhaust Gas Temp Too Hi Bank2
    P2430Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
    P2431Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
    P2432Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
    P2433Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
    P2434Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
    P2435Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
    P2436Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
    P2437Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
    P2438Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
    P2439Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
    P2440Sec Air Inj Sys Switching Valve Stuck Open Bank1
    P2441Sec Air Inj Sys Switching Valve Stuck Closed Bank1
    P2442Sec Air Inj Sys Switching Valve Stuck Open Bank2
    P2443Sec Air Inj Sys Switching Valve Stuck Closed Bank2
    P2444Sec Air Inj Sys Pump Stuck On Bank1
    P2445Sec Air Inj Sys Pump Stuck Off Bank1
    P2446Sec Air Inj Sys Pump Stuck On Bank2
    P2447Sec Air Inj Sys Pump Stuck Off Bank2
    P2500Generator Lamp/L-Terminal Circ Low
    P2501Generator Lamp/L-Terminal Circ Hi
    P2502Charging Sys Output Voltage
    P2503Charging Sys Output Voltage Low
    P2504Charging Sys Output Voltage Hi
    P2505ECM/PCM Power Input Signal
    P2506ECM/PCM Power Input Signal Range/Perf
    P2507ECM/PCM Power Input Signal Low
    P2508ECM/PCM Power Input Signal Hi
    P2509CM/PCM Power Input Signal Interm
    P2510ECM/PCM Power Relay Sense Circ Range/Perf
    P2511 ECM/PCM Power Relay Sense Circ Interm
    P2512Event Data Recorder Request Circ/ Open
    P2513Event Data Recorder Request Circ Low
    P2514Event Data Recorder Request Circ Hi
    P2515A/C Refrigerant Press Sens B Circ
    P2516A/C Refrigerant Press Sens B Circ Range/Perf
    P2517A/C Refrigerant Press Sens B Circ Low
    P2518A/C Refrigerant Press Sens B Circ Hi
    P2519A/C Request A Circ
    P2520A/C Request A Circ Low
    P2521A/C Request A Circ Hi
    P2522A/C Request B Circ
    P2523A/C Request B Circ Low
    P2524A/C Request B Circ Hi
    P2525Vacuum Reservoir Press Sens Circ
    P2526Vacuum Reservoir Press Sens Circ Range/Perf
    P2527Vacuum Reservoir Press Sens Circ Low
    P2528Vacuum Reservoir Press Sens Circ Hi
    P2529Vacuum Reservoir Press Sens Circ Interm
    P2530Ignition Switch Run Pos Circ
    P2531Ignition Switch Run Pos Circ Low
    P2532Ignition Switch Run Pos Circ Hi
    P2533Ignition Switch Run/Start Pos Circ
    P2534Ignition Switch Run/Start Pos Circ Low
    P2535Ignition Switch Run/Start Pos Circ Hi
    P2536Ignition Switch Accessory Pos Circ
    P2537Ignition Switch Accessory Pos Circ Low
    P2538Ignition Switch Accessory Pos Circ Hi
    P2539Low Press Fuel Sys Sens Circ
    P2540Low Press Fuel Sys Sens Circ Range/Perf
    P2541Low Press Fuel Sys Sens Circ Low
    P2542Low Press Fuel Sys Sens Circ Hi
    P2543Low Press Fuel Sys Sens Circ Interm
    P2544Torque Management Request Input Signal A
    P2545Torque Management Request Input Signal A Range/Perf
    P2546Torque Management Request Input Signal A Low
    P2547Torque Management Request Input Signal A Hi
    P2548Torque Management Request Input Signal B
    P2549Torque Management Request Input Signal B Range/Perf
    P2550Torque Management Request Input Signal B Low
    P2551Torque Management Request Input Signal B Hi
    P2552Throttle/Fuel Inhibit Circ
    P2553Throttle/Fuel Inhibit Circ Range/Perf
    P2554Throttle/Fuel Inhibit Circ Low
    P2555Throttle/Fuel Inhibit Circ Hi
    P2556Engine Coolant Level Sens/Switch Circ
    P2557Engine Coolant Level Sens/Switch Circ Range/Perf
    P2558Engine Coolant Level Sens/Switch Circ Low
    P2559Engine Coolant Level Sens/Switch Circ Hi
    P2560Engine Coolant Level Low
    P2561A/C Ctrl Mod Requested MIL Illumination
    P2562Turbocharger Boost Ctrl Pos Sens Circ
    P2563Turbocharger Boost Ctrl Pos Sens Circ Range/Perf
    P2564Turbocharger Boost Ctrl Pos Sens Circ Low
    P2565Turbocharger Boost Ctrl Pos Sens Circ Hi
    P2566Turbocharger Boost Ctrl Pos Sens Circ Interm
    P2567Direct Ozone Reduction Catalyst Temp Sens Circ
    P2568Direct Ozone Reduction Catalyst Temp Sens Circ Range/Perf
    P2569Direct Ozone Reduction Catalyst Temp Sens Circ Low
    P2570Direct Ozone Reduction Catalyst Temp Sens Circ Hi
    P2571Direct Ozone Reduction Catalyst Temp Sens Circ Interm/Erratic
    P2572Direct Ozone Reduction Catalyst Deterioration Sens Circ
    P2573Direct Ozone Reduction Catalyst Deterioration Sens Circ Range/Perf
    P2574Direct Ozone Reduction Catalyst Deterioration Sens Circ Low
    P2575Direct Ozone Reduction Catalyst Deterioration Sens Circ Hi
    P2576Direct Ozone Reduction Catalyst Deterioration Sens Circ Interm/Erratic
    P2577Direct Ozone Reduction Catalyst Eff Below Threshold
    P2600Coolant Pump Ctrl Circ/Open
    P2601Coolant Pump Ctrl Circ Range/Perf
    P2602Coolant Pump Ctrl Circ Low
    P2603Coolant Pump Ctrl Circ Hi
    P2604Intake Air Heater A Circ Range/Perf
    P2605Intake Air Heater A Circ/Open
    P2606Intake Air Heater B Circ Range/Perf
    P2607Intake Air Heater Relay 2 Low
    P2608Intake Air Heater Relay 2 Hi
    P2609Intake Air Heater Sys Perf
    P2610ECM/PCM Internal Engine Off Timer Perf
    P2611A/C Refrigerant Distribution Valve Ctrl Circ/Open
    P2612A/C Refrigerant Distribution Valve Ctrl Circ Low
    P2613A/C Refrigerant Distribution Valve Ctrl Circ Hi
    P2614Camshaft Pos Signal Output Circ/Open
    P2615Camshaft Pos Signal Output Circ Low
    P2616Camshaft Pos Signal Output Circ Hi
    P2617Crank Pos Signal Output Circ/Open
    P2618Crank Pos Signal Output Circ Low
    P2619Crank Pos Signal Output Circ Hi
    P2620Throttle Pos Output Circ/Open
    P2621Throttle Pos Output Circ Low
    P2622Throttle Pos Output Circ Hi
    P2623Injector Ctrl Press Regulator Circ/Open
    P2624Injector Ctrl Press Regulator Circ Low
    P2625Injector Ctrl Press Regulator Circ Hi
    P2626O2 Sens Pumping Current Trim Circ/Open Bank1 Sens1
    P2627O2 Sens Pumping Current Trim Circ Low Bank1 Sens1
    P2628O2 Sens Pumping Current Trim Circ Hi Bank1 Sens1
    P2629O2 Sens Pumping Current Trim Circ/Open Bank2 Sens1
    P2630O2 Sens Pumping Current Trim Circ Low Bank2 Sens1
    P2631O2 Sens Pumping Current Trim Circ Hi Bank2 Sens1
    P2632Fuel Pump B Ctrl Circ /Open
    P2633Fuel Pump B Ctrl Circ Low
    P2634Fuel Pump B Ctrl Circ Hi
    P2635Fuel Pump A Low Flow / Perf
    P2636Fuel Pump B Low Flow / Perf
    P2637Torque Management Feedback Signal A
    P2638Torque Management Feedback Signal A Range/Perf
    P2639Torque Management Feedback Signal A Low
    P2640Torque Management Feedback Signal A Hi
    P2641Torque Management Feedback Signal B
    P2642Torque Management Feedback Signal B Range/Perf
    P2643Torque Management Feedback Signal B Low
    P2644Torque Management Feedback Signal B Hi
    P2645A Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2646A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2647A Rocker Arm Actuator Sys Stuck On Bank1
    P2648A Rocker Arm Actuator Ctrl Circ Low Bank1
    P2649A Rocker Arm Actuator Ctrl Circ Hi Bank1
    P2650B Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2651B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2652B Rocker Arm Actuator Sys Stuck On Bank1
    P2653B Rocker Arm Actuator Ctrl Circ Low Bank1
    P2654B Rocker Arm Actuator Ctrl Circ Hi Bank1
    P2655A Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2656A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2657A Rocker Arm Actuator Sys Stuck On Bank2
    P2658A Rocker Arm Actuator Ctrl Circ Low Bank2
    P2659A Rocker Arm Actuator Ctrl Circ Hi Bank2
    P2660B Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2661B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2662B Rocker Arm Actuator Sys Stuck On Bank2
    P2663B Rocker Arm Actuator Ctrl Circ Low Bank2
    P2664B Rocker Arm Actuator Ctrl Circ Hi Bank2
    P2665Fuel Shutoff Valve B Ctrl Circ/Open
    P2666Fuel Shutoff Valve B Ctrl Circ Low
    P2667Fuel Shutoff Valve B Ctrl Circ Hi
    P2668Fuel Mode Indicator Lamp Ctrl Circ
    P2669Actuator Supply Voltage B Circ /Open
    P2670Actuator Supply Voltage B Circ Low
    P2671Actuator Supply Voltage B Circ Hi
    P2700Trans Friction Element A Apply Time Range/Perf
    P2701Trans Friction Element B Apply Time Range/Perf
    P2702Trans Friction Element C Apply Time Range/Perf
    P2703Trans Friction Element D Apply Time Range/Perf
    P2704Trans Friction Element E Apply Time Range/Perf
    P2705Trans Friction Element F Apply Time Range/Perf
    P2706Shift Solenoid F
    P2707Shift Solenoid F Perf or Stuck Off
    P2708Shift Solenoid F Stuck On
    P2709Shift Solenoid F Electrical
    P2710Shift Solenoid F Interm
    P2711Unexpected Mechanical Gear Disengagement
    P2712Hydraulic Power Unit Leakage
    P2713Press Ctrl Solenoid D
    P2714Press Ctrl Solenoid D Perf or Stuck Off
    P2715Press Ctrl Solenoid D Stuck On
    P2716Press Ctrl Solenoid D Electrical
    P2717Press Ctrl Solenoid D Interm
    P2718Press Ctrl Solenoid D Ctrl Circ / Open
    P2719Press Ctrl Solenoid D Ctrl Circ Range/Perf
    P2720Press Ctrl Solenoid D Ctrl Circ Low
    P2721Press Ctrl Solenoid D Ctrl Circ Hi
    P2722Press Ctrl Solenoid E
    P2723Press Ctrl Solenoid E Perf or Stuck Off
    P2724Press Ctrl Solenoid E Stuck On
    P2725 Press Ctrl Solenoid E Electrical
    P2726Press Ctrl Solenoid E Interm
    P2727Press Ctrl Solenoid E Ctrl Circ / Open
    P2728Press Ctrl Solenoid E Ctrl Circ Range/Perf
    P2729Press Ctrl Solenoid E Ctrl Circ Low
    P2730Press Ctrl Solenoid E Ctrl Circ Hi
    P2731Press Ctrl Solenoid F
    P2732Press Ctrl Solenoid F Perf or Stuck Off
    P2733Press Ctrl Solenoid F Stuck On
    P2734Press Ctrl Solenoid F Electrical
    P2735Press Ctrl Solenoid F Interm
    P2736Press Ctrl Solenoid F Ctrl Circ/Open
    P2737Press Ctrl Solenoid F Ctrl Circ Range/Perf
    P2738Press Ctrl Solenoid F Ctrl Circ Low
    P2739Press Ctrl Solenoid F Ctrl Circ Hi
    P2740Trans Fluid Temp Sens B Circ
    P2741Trans Fluid Temp Sens B Circ Range Perf
    P2742Trans Fluid Temp Sens B Circ Low
    P2743Trans Fluid Temp Sens B Circ Hi
    P2744Trans Fluid Temp Sens B Circ Interm
    P2745Intermediate Shaft Speed Sens B Circ
    P2746Intermediate Shaft Speed Sens B Circ Range/Perf
    P2747Intermediate Shaft Speed Sens B Circ No Signal
    P2748Intermediate Shaft Speed Sens B Circ Interm
    P2749Intermediate Shaft Speed Sens C Circ
    P2750Intermediate Shaft Speed Sens C Circ Range/Perf
    P2751Intermediate Shaft Speed Sens C Circ No Signal
    P2752Intermediate Shaft Speed Sens C Circ Interm
    P2753Trans Fluid Cooler Ctrl Circ/Open
    P2754Trans Fluid Cooler Ctrl Circ Low
    P2755Trans Fluid Cooler Ctrl Circ Hi
    P2756Torque Conv Clutch Press Ctrl Solenoid
    P2757Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
    P2758Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
    P2759Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
    P2760Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ
    P2761Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
    P2762Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
    P2763Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Hi
    P2764Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
    P2765Input/Turbine Speed Sens B Circ
    P2766Input/Turbine Speed Sens B Circ Range/Perf
    P2767Input/Turbine Speed Sens B Circ No Signal
    P2768Input/Turbine Speed Sens B Circ Interm
    P2769Torque Conv Clutch Circ Low
    P2770Torque Conv Clutch Circ Hi
    P2771Four Wheel Drive (4WD) Low Switch Circ
    P2772Four Wheel Drive (4WD) Low Switch Circ Range/Perf
    P2773Four Wheel Drive (4WD) Low Switch Circ Low
    P2774Four Wheel Drive (4WD) Low Switch Circ Hi
    P2775Upshift Switch Circ Range/Perf
    P2776Upshift Switch Circ Low
    P2777Upshift Switch Circ Hi
    P2778Upshift Switch Circ Interm/Erratic
    P2779Downshift Switch Circ Range/Perf
    P2780Downshift Switch Circ Low
    P2781Downshift Switch Circ Hi
    P2782Downshift Switch Circ Interm/Erratic
    P2783Torque Conv Temp Too Hi
    P2784Input/Turbine Speed Sens A/B Correlation
    P2785Clutch Actuator Temp Too Hi
    P2786Gear Shift Actuator Temp Too Hi
    P2787Clutch Temp Too Hi
    P2788Auto Shift Manual Adaptive Learning at Limit
    P2789Clutch Adaptive Learning at Limit
    P2790Gate Select Direction Circ
    P2791Gate Select Direction Circ Low
    P2792Gate Select Direction Circ Hi
    P2793Gear Shift Direction Circ
    P2794Gear Shift Direction Circ Low
    P2795Gear Shift Direction Circ Hi
    P3400Cylinder Deactivation Sys Bank1
    P3401Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open
    P3402Cylinder 1 Deactivation/Intake Valve Ctrl Perf
    P3403Cylinder 1 Deactivation/Intake Valve Ctrl Circ Low
    P3404Cylinder 1 Deactivation/Intake Valve Ctrl Circ Hi
    P3405Cylinder 1 Exhaust Valve Ctrl Circ/Open
    P3406Cylinder 1 Exhaust Valve Ctrl Perf
    P3407Cylinder 1 Exhaust Valve Ctrl Circ Low
    P3408Cylinder 1 Exhaust Valve Ctrl Circ Hi
    P3409Cylinder 2 Deactivation/Intake Valve Ctrl Circ/Open
    P3410Cylinder 2 Deactivation/Intake Valve Ctrl Perf
    P3411Cylinder 2 Deactivation/Intake Valve Ctrl Circ Low
    P3412Cylinder 2 Deactivation/Intake Valve Ctrl Circ Hi
    P3413Cylinder 2 Exhaust Valve Ctrl Circ/Open
    P3414Cylinder 2 Exhaust Valve Ctrl Perf
    P3415Cylinder 2 Exhaust Valve Ctrl Circ Low
    P3416Cylinder 2 Exhaust Valve Ctrl Circ Hi
    P3417Cylinder 3 Deactivation/Intake Valve Ctrl Circ/Open
    P3418Cylinder 3 Deactivation/Intake Valve Ctrl Perf
    P3419Cylinder 3 Deactivation/Intake Valve Ctrl Circ Low
    P3420Cylinder 3 Deactivation/Intake Valve Ctrl Circ Hi
    P3421Cylinder 3 Exhaust Valve Ctrl Circ/Open
    P3422Cylinder 3 Exhaust Valve Ctrl Perf
    P3423Cylinder 3 Exhaust Valve Ctrl Circ Low
    P3424Cylinder 3 Exhaust Valve Ctrl Circ Hi
    P3425Cylinder 4 Deactivation/Intake Valve Ctrl Circ/Open
    P3426Cylinder 4 Deactivation/Intake Valve Ctrl Perf
    P3427Cylinder 4 Deactivation/Intake Valve Ctrl Circ Low
    P3428Cylinder 4 Deactivation/Intake Valve Ctrl Circ Hi
    P3429Cylinder 4 Exhaust Valve Ctrl Circ/Open
    P3430Cylinder 4 Exhaust Valve Ctrl Perf
    P3431Cylinder 4 Exhaust Valve Ctrl Circ Low
    P3432Cylinder 4 Exhaust Valve Ctrl Circ Hi
    P3433Cylinder 5 Deactivation/Intake Valve Ctrl Circ/Open
    P3434Cylinder 5 Deactivation/Intake Valve Ctrl Perf
    P3435Cylinder 5 Deactivation/Intake Valve Ctrl Circ Low
    P3436Cylinder 5 Deactivation/Intake Valve Ctrl Circ Hi
    P3437Cylinder 5 Exhaust Valve Ctrl Circ/Open
    P3438Cylinder 5 Exhaust Valve Ctrl Perf
    P3439Cylinder 5 Exhaust Valve Ctrl Circ Low
    P3440Cylinder 5 Exhaust Valve Ctrl Circ Hi
    P3441Cylinder 6 Deactivation/Intake Valve Ctrl Circ/Open
    P3442Cylinder 6 Deactivation/Intake Valve Ctrl Perf
    P3443Cylinder 6 Deactivation/Intake Valve Ctrl Circ Low
    P3444Cylinder 6 Deactivation/Intake Valve Ctrl Circ Hi
    P3445Cylinder 6 Exhaust Valve Ctrl Circ/Open
    P3446Cylinder 6 Exhaust Valve Ctrl Perf
    P3447Cylinder 6 Exhaust Valve Ctrl Circ Low
    P3448Cylinder 6 Exhaust Valve Ctrl Circ Hi
    P3449Cylinder 7 Deactivation/Intake Valve Ctrl Circ/Open
    P3450Cylinder 7 Deactivation/Intake Valve Ctrl Perf
    P3451Cylinder 7 Deactivation/Intake Valve Ctrl Circ Low
    P3452Cylinder 7 Deactivation/Intake Valve Ctrl Circ Hi
    P3453Cylinder 7 Exhaust Valve Ctrl Circ/Open
    P3454Cylinder 7 Exhaust Valve Ctrl Perf
    P3455Cylinder 7 Exhaust Valve Ctrl Circ Low
    P3456Cylinder 7 Exhaust Valve Ctrl Circ Hi
    P3457Cylinder 8 Deactivation/Intake Valve Ctrl Circ/Open
    P3458Cylinder 8 Deactivation/Intake Valve Ctrl Perf
    P3459Cylinder 8 Deactivation/Intake Valve Ctrl Circ Low
    P3460Cylinder 8 Deactivation/Intake Valve Ctrl Circ Hi
    P3461Cylinder 8 Exhaust Valve Ctrl Circ/Open
    P3462Cylinder 8 Exhaust Valve Ctrl Perf
    P3463Cylinder 8 Exhaust Valve Ctrl Circ Low
    P3464Cylinder 8 Exhaust Valve Ctrl Circ Hi
    P3465Cylinder 9 Deactivation/Intake Valve Ctrl Circ/Open
    P3466Cylinder 9 Deactivation/Intake Valve Ctrl Perf
    P3467Cylinder 9 Deactivation/Intake Valve Ctrl Circ Low
    P3468Cylinder 9 Deactivation/Intake Valve Ctrl Circ Hi
    P3469Cylinder 9 Exhaust Valve Ctrl Circ/Open
    P3470Cylinder 9 Exhaust Valve Ctrl Perf
    P3471Cylinder 9 Exhaust Valve Ctrl Circ Low
    P3472Cylinder 9 Exhaust Valve Ctrl Circ Hi
    P3473Cylinder 10 Deactivation/Intake Valve Ctrl Circ/Open
    P3474Cylinder 10 Deactivation/Intake Valve Ctrl Perf
    P3475Cylinder 10 Deactivation/Intake Valve Ctrl Circ Low
    P3476Cylinder 10 Deactivation/Intake Valve Ctrl Circ Hi
    P3477Cylinder 10 Exhaust Valve Ctrl Circ/Open
    P3478Cylinder 10 Exhaust Valve Ctrl Perf
    P3479Cylinder 10 Exhaust Valve Ctrl Circ Low
    P3480Cylinder 10 Exhaust Valve Ctrl Circ Hi
    P3481Cylinder 11 Deactivation/Intake Valve Ctrl Circ/Open
    P3482Cylinder 11 Deactivation/Intake Valve Ctrl Perf
    P3483Cylinder 11 Deactivation/Intake Valve Ctrl Circ Low
    P3484Cylinder 11 Deactivation/Intake Valve Ctrl Circ Hi
    P3485Cylinder 11 Exhaust Valve Ctrl Circ/Open
    P3486Cylinder 11 Exhaust Valve Ctrl Perf
    P3487Cylinder 11 Exhaust Valve Ctrl Circ Low
    P3488Cylinder 11 Exhaust Valve Ctrl Circ Hi
    P3489Cylinder 12 Deactivation/Intake Valve Ctrl Circ/Open
    P3490Cylinder 12 Deactivation/Intake Valve Ctrl Perf
    P3491Cylinder 12 Deactivation/Intake Valve Ctrl Circ Low
    P3492Cylinder 12 Deactivation/Intake Valve Ctrl Circ Hi
    P3493Cylinder 12 Exhaust Valve Ctrl Circ/Open
    U0001High Speed CAN Comm Bus
    U0002High Speed CAN Comm Bus Perf
    U0003High Speed CAN Comm Bus + Open
    U0004High Speed CAN Comm Bus + Low
    U0005High Speed CAN Comm Bus + High
    U0006High Speed CAN Comm Bus - Open
    U0007High Speed CAN Comm Bus - Low
    U0008High Speed CAN Comm Bus - High
    U0009High Speed CAN Comm Bus - shorted to Bus +
    U0010Medium Speed CAN Comm Bus
    U0011Medium Speed CAN Comm Bus Perf
    U0012Medium Speed CAN Comm Bus + Open
    U0013Medium Speed CAN Comm Bus + Low
    U0014Medium Speed CAN Comm Bus + High
    U0015Medium Speed CAN Comm Bus - Open
    U0016Medium Speed CAN Comm Bus - Low
    U0017Medium Speed CAN Comm Bus - High
    U0018Medium Speed CAN Comm Bus - shorted to Bus +
    U0019Low Speed CAN Comm Bus
    U0020Low Speed CAN Comm Bus Perf
    U0021Low Speed CAN Comm Bus + Open
    U0022Low Speed CAN Comm Bus + Low
    U0023Low Speed CAN Comm Bus + High
    U0024Low Speed CAN Comm Bus - Open
    U0025Low Speed CAN Comm Bus - Low
    U0026Low Speed CAN Comm Bus - High
    U0027Low Speed CAN Comm Bus - shorted to Bus +
    U0028Vehicle Comm Bus A
    U0029Vehicle Comm Bus A Perf
    U0030Vehicle Comm Bus A + Open
    U0031Vehicle Comm Bus A + Low
    U0032Vehicle Comm Bus A + High
    U0033Vehicle Comm Bus A - Open
    U0034Vehicle Comm Bus A - Low
    U0035Vehicle Comm Bus A - High
    U0036Vehicle Comm Bus A - shorted to Bus A +
    U0037Vehicle Comm Bus B
    U0038Vehicle Comm Bus B Perf
    U0039Vehicle Comm Bus B + Open
    U0040Vehicle Comm Bus B + Low
    U0041Vehicle Comm Bus B + High
    U0042Vehicle Comm Bus B - Open
    U0043Vehicle Comm Bus B - Low
    U0044Vehicle Comm Bus B - High
    U0045Vehicle Comm Bus B - shorted to Bus B +
    U0046Vehicle Comm Bus C
    U0047Vehicle Comm Bus C Perf
    U0048Vehicle Comm Bus C + Open
    U0049Vehicle Comm Bus C + Low
    U0050Vehicle Comm Bus C + High
    U0051Vehicle Comm Bus C - Open
    U0052Vehicle Comm Bus C - Low
    U0053Vehicle Comm Bus C - High
    U0054Vehicle Comm Bus C - shorted to Bus C +
    U0055Vehicle Comm Bus D
    U0056Vehicle Comm Bus D Perf
    U0057Vehicle Comm Bus D + Open
    U0058Vehicle Comm Bus D + Low
    U0059Vehicle Comm Bus D + High
    U0060Vehicle Comm Bus D - Open
    U0061Vehicle Comm Bus D - Low
    U0062Vehicle Comm Bus D - High
    U0063Vehicle Comm Bus D - shorted to Bus D +
    U0064Vehicle Comm Bus E
    U0065Vehicle Comm Bus E Perf
    U0066Vehicle Comm Bus E + Open
    U0067Vehicle Comm Bus E + Low
    U0068Vehicle Comm Bus E + High
    U0069Vehicle Comm Bus E - Open
    U0070Vehicle Comm Bus E - Low
    U0071Vehicle Comm Bus E - High
    U0072Vehicle Comm Bus E - shorted to Bus E +
    U0073Ctrl Mod Comm Bus Off
    U0074Reserved by Document
    U0075Reserved by Document
    U0076Reserved by Document
    U0077Reserved by Document
    U0078Reserved by Document
    U0079Reserved by Document
    U0080Reserved by Document
    U0081Reserved by Document
    U0082Reserved by Document
    U0083Reserved by Document
    U0084Reserved by Document
    U0085Reserved by Document
    U0086Reserved by Document
    U0087Reserved by Document
    U0088Reserved by Document
    U0089Reserved by Document
    U0090Reserved by Document
    U0091Reserved by Document
    U0092Reserved by Document
    U0093Reserved by Document
    U0094Reserved by Document
    U0095Reserved by Document
    U0096Reserved by Document
    U0097Reserved by Document
    U0098Reserved by Document
    U0099Reserved by Document
    U0100Lost Comm With ECM/PCM A
    U0101Lost Comm with TCM
    U0102Lost Comm with Transfer Case Ctrl Mod
    U0103Lost Comm With Gear Shift Mod
    U0104Lost Comm With Cruise Ctrl Mod
    U0105Lost Comm With Fuel Injector Ctrl Mod
    U0106Lost Comm With Glow Plug Ctrl Mod
    U0107Lost Comm With Throttle Actuator Ctrl Mod
    U0108Lost Comm With Alternative Fuel Ctrl Mod
    U0109Lost Comm With Fuel Pump Ctrl Mod
    U0110Lost Comm With Drive Motor Ctrl Mod
    U0111Lost Comm With Battery Energy Ctrl Mod A
    U0112Lost Comm With Battery Energy Ctrl Mod B
    U0113Lost Comm With Emissions Critical Ctrl Information
    U0114Lost Comm With 4-Wheel Drive Clutch Ctrl Mod
    U0115Lost Comm With ECM/PCM B
    U0116Reserved by Document
    U0117Reserved by Document
    U0118Reserved by Document
    U0119Reserved by Document
    U0120Reserved by Document
    U0121Lost Comm With Anti-Lock Brake System (ABS) Ctrl Mod
    U0122Lost Comm With Vehicle Dynamics Ctrl Mod
    U0123Lost Comm With Yaw Rate Sens Mod
    U0124Lost Comm With Lateral Acceleration Sens Mod
    U0125Lost Comm With Multi-axis Acceleration Sens Mod
    U0126Lost Comm With Steering Angle Sens Mod
    U0127Lost Comm With Tire Pressure Monitor Mod
    U0128Lost Comm With Park Brake Ctrl Mod
    U0129Lost Comm With Brake System Ctrl Mod
    U0130Lost Comm With Steering Effort Ctrl Mod
    U0131Lost Comm With Power Steering Ctrl Mod
    U0132Lost Comm With Ride Level Ctrl Mod
    U0133Reserved by Document
    U0134Reserved by Document
    U0135Reserved by Document
    U0136Reserved by Document
    U0137Reserved by Document
    U0138Reserved by Document
    U0139Reserved by Document
    U0140Lost Comm With Body Ctrl Mod
    U0141Lost Comm With Body Ctrl Mod A
    U0142Lost Comm With Body Ctrl Mod B
    U0143Lost Comm With Body Ctrl Mod C
    U0144Lost Comm With Body Ctrl Mod D
    U0145Lost Comm With Body Ctrl Mod E
    U0146Lost Comm With Gateway A
    U0147Lost Comm With Gateway B
    U0148Lost Comm With Gateway C
    U0149Lost Comm With Gateway D
    U0150Lost Comm With Gateway E
    U0151Lost Comm With Restraints Ctrl Mod
    U0152Lost Comm With Side Restraints Ctrl Mod Left
    U0153Lost Comm With Side Restraints Ctrl Mod Right
    U0154Lost Comm With Restraints Occupant Sensing Ctrl Mod
    U0155Lost Comm With Instrument Panel Cluster (IPC) Ctrl Mod
    U0156Lost Comm With Information Center A
    U0157Lost Comm With Information Center B
    U0158Lost Comm With Head Up Display
    U0159Lost Comm With Parking Assist Ctrl Mod
    U0160Lost Comm With Audible Alert Ctrl Mod
    U0161Lost Comm With Compass Mod
    U0162Lost Comm With Navigation Display Mod
    U0163Lost Comm With Navigation Ctrl Mod
    U0164Lost Comm With HVAC Ctrl Mod
    U0165Lost Comm With HVAC Ctrl Mod Rear
    U0166Lost Comm With Auxiliary Heater Ctrl Mod
    U0167Lost Comm With Vehicle Immobilizer Ctrl Mod
    U0168Lost Comm With Vehicle Security Ctrl Mod
    U0169Lost Comm With Sunroof Ctrl Mod
    U0170Lost Comm With Restraints System Sens A
    U0171Lost Comm With Restraints System Sens B
    U0172Lost Comm With Restraints System Sens C
    U0173Lost Comm With Restraints System Sens D
    U0174Lost Comm With Restraints System Sens E
    U0175Lost Comm With Restraints System Sens F
    U0176Lost Comm With Restraints System Sens G
    U0177Lost Comm With Restraints System Sens H
    U0178Lost Comm With Restraints System Sens I
    U0179Lost Comm With Restraints System Sens J
    U0180Lost Comm With Automatic Lighting Ctrl Mod
    U0181Lost Comm With Headlamp Leveling Ctrl Mod
    U0182Lost Comm With Lighting Ctrl Mod Front
    U0183Lost Comm With Lighting Ctrl Mod Rear
    U0184Lost Comm With Radio
    U0185Lost Comm With Antenna Ctrl Mod
    U0186Lost Comm With Audio Amplifier
    U0187Lost Comm With Digital Disc Player/Changer Mod A
    U0188Lost Comm With Digital Disc Player/Changer Mod B
    U0189Lost Comm With Digital Disc Player/Changer Mod C
    U0190Lost Comm With Digital Disc Player/Changer Mod D
    U0191Lost Comm With Television
    U0192Lost Comm With Personal Computer
    U0193Lost Comm With Digital Audio Ctrl Mod A
    U0194Lost Comm With Digital Audio Ctrl Mod B
    U0195Lost Comm With Subscription Entertainment Receiver Mod
    U0196Lost Comm With Rear Seat Entertainment Ctrl Mod
    U0197Lost Comm With Telephone Ctrl Mod
    U0198Lost Comm With Telematic Ctrl Mod
    U0199Lost Comm With Door Ctrl Mod A
    U0200Lost Comm With Door Ctrl Mod B
    U0201Lost Comm With Door Ctrl Mod C
    U0202Lost Comm With Door Ctrl Mod D
    U0203Lost Comm With Door Ctrl Mod E
    U0204Lost Comm With Door Ctrl Mod F
    U0205Lost Comm With Door Ctrl Mod G
    U0206Lost Comm With Folding Top Ctrl Mod
    U0207Lost Comm With Moveable Roof Ctrl Mod
    U0208Lost Comm With Seat Ctrl Mod A
    U0209Lost Comm With Seat Ctrl Mod B
    U0210Lost Comm With Seat Ctrl Mod C
    U0211Lost Comm With Seat Ctrl Mod D
    U0212Lost Comm With Steering Column Ctrl Mod
    U0213Lost Comm With Mirror Ctrl Mod
    U0214Lost Comm With Remote Function Actuation
    U0215Lost Comm With Door Switch A
    U0216Lost Comm With Door Switch B
    U0217Lost Comm With Door Switch C
    U0218Lost Comm With Door Switch D
    U0219Lost Comm With Door Switch E
    U0220Lost Comm With Door Switch F
    U0221Lost Comm With Door Switch G
    U0222Lost Comm With Door Window Motor A
    U0223Lost Comm With Door Window Motor B
    U0224Lost Comm With Door Window Motor C
    U0225Lost Comm With Door Window Motor D
    U0226Lost Comm With Door Window Motor E
    U0227Lost Comm With Door Window Motor F
    U0228Lost Comm With Door Window Motor G
    U0229Lost Comm With Heated Steering Wheel Mod
    U0230Lost Comm With Rear Gate Mod
    U0231Lost Comm With Rain Sensing Mod
    U0232Lost Comm With Side Obstacle Detect Ctrl Mod Left
    U0233Lost Comm With Side Obstacle Detect Ctrl Mod Right
    U0234Lost Comm With Convenience Recall Mod
    U0235Lost Comm With Cruise Ctrl Front Distance Range Sens
    U0300Internal Ctrl Mod Software Incompatibility
    U0301Software Incompatibility with ECM/PCM
    U0302Software Incompatibility with Trans Ctrl Mod
    U0303Software Incompatibility with Transfer Case Ctrl Mod
    U0304Software Incompatibility with Gear Shift Ctrl Mod
    U0305Software Incompatibility with Cruise Ctrl Mod
    U0306Software Incompatibility with Fuel Injector Ctrl Mod
    U0307Software Incompatibility with Glow Plug Ctrl Mod
    U0308Software Incompatibility with Throttle Actuator Ctrl Mod
    U0309Software Incompatibility with Alternative Fuel Ctrl Mod
    U0310Software Incompatibility with Fuel Pump Ctrl Mod
    U0311Software Incompatibility with Drive Motor Ctrl Mod
    U0312Software Incompatibility with Battery Energy Ctrl Mod A
    U0313Software Incompatibility with Battery Energy Ctrl Mod B
    U0314Software Incompatibility with 4-Wheel Drive Clutch Ctrl Mod
    U0315Software Incompatibility with Anti-Lock Brake System Ctrl Mod
    U0316Software Incompatibility with Vehicle Dynamics Ctrl Mod
    U0317Software Incompatibility with Park Brake Ctrl Mod
    U0318Software Incompatibility with Brake System Ctrl Mod
    U0319Software Incompatibility with Steering Effort Ctrl Mod
    U0320Software Incompatibility with Power Steering Ctrl Mod
    U0321Software Incompatibility with Ride Level Ctrl Mod
    U0322Software Incompatibility with Body Ctrl Mod
    U0323Software Incompatibility with Instrument Panel Ctrl Mod
    U0324Software Incompatibility with HVAC Ctrl Mod
    U0325Software Incompatibility with Auxiliary Heater Ctrl Mod
    U0326Software Incompatibility with Vehicle Immobilizer Ctrl Mod
    U0327Software Incompatibility with Vehicle Security Ctrl Mod
    U0328Software Incompatibility with Steering Angle Sens Mod
    U0329Software Incompatibility with Steering Column Ctrl Mod
    U0330Software Incompatibility with Tire Pressure Monitor Mod
    U0331Software Incompatibility with Body Ctrl Mod A
    U0400Invalid Data Rcvd
    U0401Invalid Data Rcvd From ECM/PCM
    U0402Invalid Data Rcvd From Trans Ctrl Mod
    U0403Invalid Data Rcvd From Transfer Case Ctrl Mod
    U0404Invalid Data Rcvd From Gear Shift Ctrl Mod
    U0405Invalid Data Rcvd From Cruise Ctrl Mod
    U0406Invalid Data Rcvd From Fuel Injector Ctrl Mod
    U0407Invalid Data Rcvd From Glow Plug Ctrl Mod
    U0408Invalid Data Rcvd From Throttle Actuator Ctrl Mod
    U0409Invalid Data Rcvd From Alternative Fuel Ctrl Mod
    U0410Invalid Data Rcvd From Fuel Pump Ctrl Mod
    U0411Invalid Data Rcvd From Drive Motor Ctrl Mod
    U0412Invalid Data Rcvd From Battery Energy Ctrl Mod A
    U0413Invalid Data Rcvd From Battery Energy Ctrl Mod B
    U0414Invalid Data Rcvd From 4-Wheel Drive Clutch Ctrl Mod
    U0415Invalid Data Rcvd From Anti-Lock Brake System Ctrl Mod
    U0416Invalid Data Rcvd From Vehicle Dynamics Ctrl Mod
    U0417Invalid Data Rcvd From Park Brake Ctrl Mod
    U0418Invalid Data Rcvd From Brake System Ctrl Mod
    U0419Invalid Data Rcvd From Steering Effort Ctrl Mod
    U0420Invalid Data Rcvd From Power Steering Ctrl Mod
    U0421Invalid Data Rcvd From Ride Level Ctrl Mod
    U0422Invalid Data Rcvd From Body Ctrl Mod
    U0423Invalid Data Rcvd From Instrument Panel Ctrl Mod
    U0424Invalid Data Rcvd From HVAC Ctrl Mod
    U0425Invalid Data Rcvd From Auxiliary Heater Ctrl Mod
    U0426Invalid Data Rcvd From Vehicle Immobilizer Ctrl Mod
    U0427Invalid Data Rcvd From Vehicle Security Ctrl Mod
    U0428Invalid Data Rcvd From Steering Angle Sens Mod
    U0429Invalid Data Rcvd From Steering Column Ctrl Mod
    U0430Invalid Data Rcvd From Tire Pressure Monitor Mod
    U0431Invalid Data Rcvd From Body Ctrl Mod A High
    BMW
    P1083Fuel control limit mixture too lean (bank 1 sensor1)
    P1084Fuel control limit mixture too rich (bank 1 sensor1)
    P1085Fuel control limit mixture too lean (bank 2 sensor1)
    P1086Fuel control limit mixture too rich (bank 2 sensor1)
    P108702 sensor circuit slow response in lean control range (bank 1 sensor1)
    P108802 sensor circuit slow response in rich control range (bank 1 sensor1)
    P108902 sensor circuit slow response in lean control range (bank 1 sensor2)
    P1090Pre catalyst fuel trim system too lean bank 1
    P1091Pre catalyst fuel trim system too rich bank 1
    P1092Pre catalyst fuel trim system too lean bank 2
    P1093Pre catalyst fuel trim system too rich bank 2
    P109402 sensor circuit slow response in rich control range (bank 2sensor1)
    P109502 sensor signal circuit slow switching from lean to rich (bank1 sensor1)
    P109602 sensor signal circuit slow switching from lean to rich (bank2 sensor1)
    P109702 sensor circuit slow response after coast down fuel cut-off (bank 1 sensor 2)
    P109802 sensor circuit slow response after coast down fuel cut-off (bank 2 sensor 2)
    P1111Engine coolant temperature radiator outlet sensor low input
    P1112Engine coolant temperature radiator outlet sensor high input
    P1115Coolant temperature sensor plausibility
    P1116Mass or volume air flow circuit range/performance problem (bank 2)
    P1117Mass or volume air flow circuit low input (bank 2)
    P1118Mass or volume air flow circuit high input (bank 2)
    P1120Pedal position sensor circuit
    P1121Pedal position sensor 1 range/performance problem
    P1122Pedal position sensor 1 low input
    P1123Pedal position sensor 1 high input
    P113202 sensor heater control circuit (bank1 sensor 1)
    P113302 sensor heater control circuit (bank2 sensor 1)
    P113402 sensor heater circiut signal intermittent (bank1 sensor1)
    P113502 sensor heater circiut low voltage (bank1 sensor1)
    P113602 sensor heater circiut high voltage (bank1 sensor1)
    P113702 sensor heater circiut signal intermittent (bank1 sensor2)
    P113802 Sensor heater circiut low voltage (bank1 sensor2)
    P113902 sensor heater circiut high voltage (bank1 sensor2)
    P1140Mass or volume air flow circuit range / performance problem
    P1145Solenoid valve running losses conrtol circuit electrical
    P115102 sensor heater circuit signal intermittent (bank 2 sensor 1)
    P115202 sensor heater circuit low voltage (bank 2 sensor 1)
    P115302 sensor heater circuit high voltage (bank 2 sensor 1)
    P115502 sensor heater circuit signal intermittent (bank 2 sensor 2)
    P115602 sensor heater circuit low voltage (bank 2 sensor 2)
    P115702 sensor heater circuit high voltage (bank 2 sensor 2)
    P1158Fuel trim adaptation additive bank 1 low
    P1159Fuel trim adaptation additive bank 1 high
    P1160Fuel trim adaptation additive bank 2 low
    P1161Fuel trim adaptation additive bank 2 high M52: Engine oil temperature sensor circuit
    P1162Fuel trim adaptation additive per ignition bank 1 low
    P1163Fuel trim adaptation additive per ignition bank 1 high
    P1164Fuel trim adaptation additive per ignition bank 2 low
    P1165Fuel trim adaptation additive per ignition bank 2 high
    P1174Fuel trim adaptation additive bank 1 malfunction
    P1175Fuel trim adaptation additive bank 2 malfunction
    P117602 sensor slow response bank 1
    P117702 sensor slow response bank 2
    P117802 sensor signal circuit slow switching from rich to lean (bank 1 sensor 1)
    P117902 sensor signal circuit slow switching from rich to lean (bank 2 sensor 1)
    P118002 sensor signal circuit slow switching from rich to lean (bank 1 sensor 2)
    P118102 sensor signal circuit slow switching from rich to lean (bank 2sensor 2)
    P118202 sensor (bank 1 sensor 2) open circuit during coast sown fuel cut-off
    P118302 sensor (bank 2 sensor 2) open circuit during coast down fuel cut-off
    P118602 sensor heater control circuit (bank 1 sensor 2)
    P118702 sensor heater control circuit (bank 2 sensor 2)
    P1188Fuel control (bank 1 sensor 1)
    P1189Fuel control (bank 2 sensor 1)
    P1190Pre catalyst fuel trim system bank 1
    P1191Pre catalyst fuel trim system bank 2
    P1192Post catalyst fuel trim system bank 1
    P1193Post catalyst fuel trim system bank 2
    P1221Pedal position sensor 2 range / performance problem
    P1222Pedal position sensor 2 low input
    P1223Pedal position sensor 2 high input
    P1270control module self-test, torque monitoring M73: Mass air flow sensor bank comparison plausibility
    P1271Ambient air pressure sensor electrical
    P1283Switching solenoid for air assisted injection valves bank 1 control circuit electrical
    P1284Switching solenoid for air assisted injection valves bank 1 control circuit signal low
    P1285Switching solenoid for air assisted injection valves bank 1 control circuit signal high
    P1287Switching solenoid for air assisted injection valves bank 2 control circuit electrical
    P1288Switching solenoid for air assisted injection valves bank 2 control circuit signal low
    P1289Switching solenoid for air assisted injection valves bank 2 control circuit signal high
    P1313'A' Camshaft position actuator plausibility
    P1317'B' Camshaft position actuator plausibility
    P1327Knock sensor 2 (bank 1) low input
    P1328Knock sensor 2 (bank 1) high input
    P1332Knock sensor 4 low input
    P1333Knock sensor 4 high input
    P1340Multiple cylinder misfire during start
    P1341Multiple cylinder misfire with fuel cut-off
    P1342Misfire during start cylinder 1
    P1343Misfire cylinder 1 with fuel cut-off
    P1344Misfire during start cylinder 2
    P1345Misfire cylinder 2 with fuel cut-off
    P1346Misfire during start cylinder 3
    P1347Misfire cylinder 3 with fuel cut-off
    P1348Misfire during start cylinder 4
    P1349Misfire cylinder 4 fuel cut-off
    P1350Misfire during start cylinder 5
    P1351Misfire cylinder 5 with fuel cut-off
    P1352Misfire during start cylinder 6
    P1353Misfire cylinder 6 with fuel cut-off
    P1354Misfire during start cylinder 7
    P1355Misfire cylinder 7 with fuel cut-off
    P1356Misfire during start cylinder 8
    P1357Misfire cylinder 8 with fuel cut-off
    P1358Misfire during start cylinder 9
    P1359Misfire cylinder 9 with fuel cut-off
    P1360Misfire during start cylinder 10
    P1361Misfire cylinder 10 with fuel cut-off
    P1362Misfire during start cylinder 11
    P1363Misfire cylinder 11 with fuel cut-off
    P1364Misfire during start cylinder 12
    P1365Misfire cylinder 12 with fuel cut-off
    P1384Knock sensor 3 circuit
    P1385Knock sensor 4 circuit
    P1386Control module self-test, knock control circuit baseline test bank 1
    P1396Crankshaft position sensor segment timing plausibility
    P1397Camshaft position sensor 'B' circuit (bank 1)
    P1400Heated catalyst battery voltage or current too low during heating (bank 1)
    P1401Heated catalyst current too high during heating (bank 1)
    P1402Heated catalyst power switch over temperature condition (bank 1)
    P1403Carbon canister shut-off valve control circuit electrical - or- M73: heated catalyst battery voltage of current too low during heating (bank 2)
    P1404Heated catalyst current too high during heating (bank 2)
    P1405Heated catalyst power switch over temperature condition (bank 2)
    P1406Heated catalyst internal control module checksum / ROM error
    P1413Secondary air injection pump relay control circuit signal low
    P1414Secondary air injection pump relay control circuit signal high
    P1420Secondary air valve control circuit electrical
    P1421Secondary air system bank 2
    P1423Secondary air system bank 1
    P1432Secondary air injection system incorrect flow detected
    P1438Purge control valve control open circuit
    P1439Purge control valve control circuit signal low
    P1440Purge control valve control circuit signal high
    P1441Leakage diagnostic pump control open circuit
    P1442Leakage diagnostic pump control circuit signal low
    P1443Leakage diagnostic pump control circuit signal high
    P1444Diagnostic module tank leakage (DM-TL) pump control open circuit
    P1445Diagnostic module tank leakage (DM-TL) pump control circuit signal low
    P1446Diagnostic module tank leakage (DM-TL) pump control circuit signal high
    P1447Diagnostic module tank leakage (DM-TL) pump current too high during switching solenoid test
    P1448Diagnostic module tank leakage (DM-TL) pump current too low during switching solenoid test
    P1449Diagnostic module tank leakage (DM-TL) pump current too high (during switching solenoid test)
    P1450Diagnostic module tank leakage (DM-TL) switching solenoid control open circuit
    P1451Diagnostic module tank leakage (DM-TL) switching solenoid control circuit signal low
    P1452Diagnostic module tank leakage (DM-TL) switching solenoid control circuit signal high
    P1453Secondary air injection pump relay control circuit electrical
    P1454Secondary air injection pump with series resistor control circuit electrical
    P1456Heated catalyst heater power supply open circuit (bank 1)
    P1457Heated catalyst power switch temperature sensor electrical (bank 1)
    P1459Heated catalyst heater power supply open circuit (bank 2)
    P1460Heated catalyst power switch temperature sensor electrical (bank 2)
    P1461Heated catalyst gate voltage signal low
    P1462Heated catalyst internal control module checksum / EEPROM error
    P1463Heated catalyst battery temperature sensor 1 electrical
    P1464Heated catalyst battery temperature sensor 2 electrical
    P1465Heated catalyst battery temperature sensor 1 or 2 plausibility
    P1466Heated catalyst power switch temperature sensor plausibility
    P1467Heated catalyst comparison battery voltages of power switches plausibility
    P1468Heated catalyst battery disconnecting switch plausibility
    P1470Leakage diagnostic pump control circuit electrical
    P1472Diagnostic module tank leakage (DM-TL) switching solenoid control circuit electrical
    P1473Diagnostic module tank leakage (DM-TL) pump current plausibility
    P1475Leakage diagnostic pump reed switch did not close
    P1476Leakage diagnostic pump clamped tube -or- M52 MY99/00: Leakage diagnostic pump reed switch circuit electrical
    P1477Leakage diagnostic pump reed switch did not open
    P1500Idle-speed control valve stuck open
    P1501Idle-speed control valve stuck closed
    P1502Idle-speed control valve closing solenoid control circuit signal high
    P1503Idle-speed control valve closing solenoid control circuit signal low
    P1504Idle-speed control valve closing solenoid control open circuit
    P1505Idle-speed control valve closing solenoid control circuit electrical
    P1506Idle-speed control valve opening solenoid control circuit signal high
    P1507Idle-speed control valve opening solenoid control circuit signal low
    P1508Idle-speed control valve opening solenoid control open circuit
    P1509Idle-speed control valve opening solenoid control circuit electrical
    P1510Idle-speed control valve stuck
    P1511DISA (differentiated intake manifold) control circuit electrical
    P1512DISA (differentiated intake manifold) control circuit signal low
    P1513DISA (differentiated intake manifold) control circuit signal high
    P1519'A' camshaft position actuator bank 1
    P1520'B' camshaft position actuator bank 1
    P1522'A' camshaft position actuator bank 2
    P1523'A' camshaft position actuator signal low bang 1 -or- M52: Camshaft position actuator tight or jammed
    P1524'A' camshaft position actuator control circuit signal high bank 1
    P1525'A' camshaft position actuator control open circuit bank 1
    P1526'A' camshaft position actuator control open circuit bank 2
    P1527'A' camshaft position actuator control circuit signal low bank 2
    P1528'A' camshaft position actuator control circuit signal high bank 2
    P1529'B' camshaft position actuator control circuit signal low bank1
    P1530'B' camshaft position actuator control circuit signal high bank1
    P1531'B' camshaft position actuator control open circuit bank 1
    P1532'B' camshaft position actuator control open circuit bank 2
    P1533'B' camshaft position actuator control circuit signal low bank 2
    P1534'B' camshaft position actuator control circuit signal high bank 2
    P1540Pedal position sensor
    P1541Pedal position sensor double error
    P1542Pedal position sensor electrical
    P1543Pedal position sensor
    P1544Pedal position sensor
    P1545Pedal position sensor
    P1546Pedal position sensor
    P1550Idle-speed control valve closing solenoid control circuit electrical
    P1552"A" Camshaft position actuator control open circuit bank 1
    P1556'A' Camshaft position actuator control open circuit bank 1
    P1560'B' Camshaft position actuator control open circuit bank 1
    P1564Control module selection
    P1565'B' Camshaft position actuator control open circuit bank 1
    P1569'A' Camshaft position actuator control open circuit bank 2
    P1573Electronic control module sensor supply B low output -or- S54/S62: 'A' Camshaft position actuator control circuit signal low bank 2
    P1580Throttle valve mechanically stuck
    P1581'B' Camshaft position actuator control open circuit bank 2
    P1589Control module self-test, knock control test pulse bank 1
    P1593DISA (Differentiated intake manifold ) control circuit electrical
    P1594'B' Camshaft position actuator control open circuit bank 2
    P1602Control module self-test, control module defective
    P1603Control module self-test, torque monitoring
    P1604Control module self-test, sqeed monitoring
    P1607CAN-Version
    P1608Serial communication link control module
    P1609Serial communication link EML (electronically engine-power regulation)
    P1611Serial communication link transmission control module
    P1619Map cooling thermostat control circuit signal low
    P1620Map cooling thermostat control circuit signal high
    P1622Map cooling thermostat control circuit electrical
    P1623Pedal position sensor potentiometer supply
    P1624Pedal position sensor potentiometer supply channel 1 electrical -or- M52: coolant thermostat (coolant temperature below thermostat regulating temperature)
    P1625Pedal position sensor potentiometer supply channel 2 electrical
    P1632Throttle valve adaptation; Adaptation conditions not met
    P1633Throttle valve adaptation; Limp-home position unknown
    P1634Throttle valve adaptation; Spring test failed
    P1635Throttle valve adaptation; Lower mechanical stop not adapted
    P1636Throttle valve control circuit
    P1637Throttle valve position control; Control deviation
    P1638Throttle valve position control; Throttle stuck temporarily
    P1639Throttle valve position control; Throttle stuck permanently
    P1640Internal control module (ROM/RAM) error
    P1690Malfunction indicator lamp (MIL) electrical
    P1734Pressure control solenoid 'B' electrical
    P1738Pressure control solenoid 'C' electrical
    P1743Pressure control solenoid 'E' electrical -or- M44/M52: Brake band electrical
    P1744Pressure control solenoid 'A' electrical
    P1746Transmission control module output stage
    P1747CAN-Bus monitoring
    P1748Transmission control module self-test
    P1749Secondary pressure solenoid communication error -or- M52: Transmission control module internal memory
    P1750Secondary pressure solenoid circuit range / performance -or- M44 / M52 / M62 / M73: System voltage input low
    P1751Secondary pressure solenoid open circuit -or- M52: System voltage input high
    P1761Shift lock solenoid malfunction
    P1765CAN throttle valve
    P1770CAN torque interface
    P1780CAN torque reduction
    CHR
    P1000Ignition Circ Low
    P1001Ignition Circ Hi
    P1004ECU Battery Feed & Power Grounds
    P1005Sys Ground Circ
    P1006EGR/EVAP Solenoid Circ Low
    P1007EGR/EVAP Solenoid Circ Hi
    P1008Power Steering Circ Low
    P1009Power Steering Circ Hi
    P1012MPA Circ Low
    P1013MPA Circ Hi
    P1014Fuel Pump Circ Low
    P1015Fuel Pump Circ Hi
    P1016Charge Air Temp Circ Low
    P1017Charge Air Temp Circ Hi
    P1018Serial Data Circ
    P1019Power Latch Not Set
    P1021Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions
    P1022Starter Relay Circ Low
    P1024ECU Start Circ Low
    P1025WOT Circ Low
    P1026WOT Circ Hi
    P1027ECU Sees Wide Open Throttle
    P1028ECU Does Not See Wide Open Throttle
    P1029ISA Closed Throttle Circ Low
    P1030ISA Closed Throttle Circ Hi
    P1031ECU Sees Closed Throttle
    P1032ECU Does Not See Closed Throttle
    P1033ISA Circs
    P1037TP Sens Circ Reads Low
    P1038Park/Neutral Line Hi
    P1039Park/Neutral Line Low
    P1040Latched B+ Line Low
    P1041Latched B+ Line Hi
    P1042No Latched B+ 1/2 Volt Drop
    P1043Shift Lamp Circ Grounded
    P1044D2ЁC1 Circ Low (A/T) or Upshift Lamp Circ (M/T) or Shift Lamp Circ Hi
    P1045Shift Lamp Circ Open
    P1047Wrong ECU
    P1048M/T Vehicle Configuration
    P1049A/T Vehicle Configuration
    P1050Idle RPM Low
    P1051Idle RPM Hi
    P1052MAP Sens Out Of Limits
    P1053Change In MAP Reading Out Of Limits
    P1054Coolant Sens & 5V Supply for TP Sens/MAP Circs Low
    P1055Coolant Sens Circ Hi
    P1056Inactive Coolant Temp Sens
    P1059A/C Request Circ Low
    P1060A/C Request Circ Hi
    P1061A/C Select Circ Low
    P1062A/C Select Circ Hi
    P1063A/C Clutch Circ Low
    P1064A/C Clutch Circ Hi & Power Steering Input
    P1068Latch Relay Circ Hi
    P1069No Tach
    P1074ECU Does Not See Speed Sens
    P1105Open or shorted condition detected in the baro read solenoid control circuit
    P1106MAP Sens Circ Interm Hi Voltage
    P1107MAP Sens Circ Interm Low Voltage
    P1110Decreased Engine Perf Due To Hi Intake Air Temp
    P1111IAT Sens Circ Interm Hi Voltage
    P1112IAT Sens Circ Interm Low Voltage
    P1114ECT Sens Circ Interm Low Voltage
    P1115ECT Sens Circ Interm Hi Voltage
    P1121TPS Circ Interm Hi Voltage
    P1122TPS Circ Interm Low Voltage
    P1125Accelerator Pedal Pos Sys
    P1133HO2S Insufficient Switching Bank1 Sens1
    P1134HO2S Insufficient Transition Time Ratio Bank1 Sens1
    P1153HO2S Insufficient Switching Bank2 Sens1
    P1154HO2S Insufficient Transition Time Ratio Bank2 Sens 1
    P1180Decreased Engine Perf Due To Hi Inj Pump Fuel Temp
    P1191Intake Air Duct Leak
    P1192Inlet Air Temp Sens Voltage Low
    P1193Inlet Air Temp Voltage Hi
    P119402 Heater Perf
    P11951/1 02 Sens Slow During Catalyst Monitor
    P11962/1 02 Sens Slow During Catalyst Monitor
    P11971/2 02 Sens Slow During Catalyst Monitor
    P1198Radiator Temp Sens Volts Too Hi
    P1199Radiator Temp Sens Volts Too Low
    P1214Inj Pump Timing Offset
    P1216Fuel Solenoid Response Time Too Short
    P1217Fuel Solenoid Response Time Too Long
    P1218Inj Pump Calibration Circ
    P1243Open or shorted condition detected in the turbocharger surge valve solenoid control
    P1271Accelerator Pedal Pos Sens1-2 Correlation
    P1272Accelerator Pedal Pos Sens2-3 Correlation
    P1273Accelerator Pedal Pos Sens1-3 Correlation
    P1275Accelerator Pedal Pos Sens1 Circ
    P1277Accelerator Pedal Pos Sens1 Low Voltage
    P1278Accelerator Pedal Pos Sens1 Hi Voltage
    P1280Accelerator Pedal Pos Sens2 Circ
    P1281Engine is Cold Too Long
    P1282Accelerator Pedal Pos Sens2 Low Voltage or Fuel Pump Relay Ctrl Circ
    P1283Accelerator Pedal Pos Sens2 Hi Voltage or Idle Select Signal Invalid
    P1284Fuel Inj Pump Battery Voltage Out Of Range
    P1285Accelerator Pedal Pos Sens3 Circ or Fuel Inj Pump Ctrller Always On
    P1286Accelerator Pos Sens Supply Voltage Too Hi
    P1287Accelerator Pedal Pos Sens3 Low Voltage or Fuel Inj Pump Ctrl Supply Voltage Low
    P1288Accelerator Pedal Pos Sens3 Hi Voltage or Intake Manif Short Runner Solenoid Circ
    P1289Manif Tune Valve Solenoid Circ
    P1290CNG Fuel Sys Press Too Hi
    P1291No Temp Rise Seen From Intake Heaters
    P1292CNG Press Sens Voltage Too Hi
    P1293CNG Press Sens Voltage Too Low
    P1294Target Idle Not Reached
    P1295No 5Vs to Throttle Pos Sens
    P1296No 5Vs to MAP Sens
    P1297No Change in MAP from Start To Run
    P1298Lean Operation at Wide Open Throttle
    P1299Vacuum Leak Found (IAC Fully Seated)
    P1336Crank Pos Sys Variation Not Learned
    P1345Crank Pos/Camshaft Pos Correlation
    P1351Ignition Ctrl Circ Hi Voltage
    P1361Ignition Ctrl Circ Low Voltage
    P1380Electronic Brake Ctrl Rough Road Data Unusable
    P1381Misfire Detected-No Electronic Brake Ctrl Data
    P1388Auto Shutdown Relay Ctrl Circ
    P1389No ASD Relay Output Voltage at PCM
    P1390Timing Belt Skipped 1 Tooth or More
    P1391Interm Loss of CMP or CKP
    P1398Misfire Adaptive Numerator at Limit
    P1399Wait to Start Lamp Circ
    P1403No 5Vs to EGR Sens
    P1404EGR Valve Closed Pintle Pos
    P1406EGR Valve Pos
    P1409EGR Valve Sys leak
    P1415AIR Sys Bank1
    P1416AIR Sys Bank1
    P1441Evap Emissions Flow During Non-Purge
    P1475Auxiliary 5V Supply Voltage Hi
    P1476Too Little Sec Air
    P1477Too Much Sec Air
    P1478Battery Temp Sens Volts Out of Limit
    P1479Trans Fan Relay Circ
    P1480PCV Solenoid Circ
    P1481EATX Misfire RPM Signal out of Range
    P1482Catalyst Temp Sens Circ Shorted Low
    P1483Catalyst Temp Sens Circ Shorted Hi
    P1484Catalytic Conv Overheat Detected
    P1485Air Inj Solenoid Circ
    P1486Eva Leak Monitor Pinched Hose Found
    P1487Hi Speed Radiator Fan CTRL Relay Circ
    P1488Auxiliary 5V Supply Output Too Low
    P1489Hi Speed Fan CTRL Relay Circ
    P1490Low Speed Fan CTRL Relay Circ
    P1491Radiator Fan Ctrl Relay Circ
    P1492Ambient/Battery Temp Sens Volts Too Hi
    P1493Ambient/Battery Temp Sens Volts Too Low
    P1494Leak Detection Pump Switch or Mechanical Fault
    P1495Leak Detection Pump Solenoid Circ
    P14965V Supply, Output Too Low
    P1498Hi Speed Radiator Fan Ground CTRL Relay Circ
    P1499Open or shorted condition detected in the hydraulic cooling fan solenoid control
    P1508IAC Sys Low RPM
    P1509IAC Sys Hi RPM
    P1594Charging Sys Voltage Too Hi
    P1595Speed Ctrl Solenoid Circs
    P1596Speed Ctrl Switch Always Hi
    P1597Speed Ctrl Switch Always Low
    P1598A/C Press Sens Volts Too Hi
    P1599A/C Press Sens Volts Too Low
    P1602PCM Not Programmed
    P1621PCM Memory Perf or Write
    P1626Vehicle Theft Sys Ctrl Loss of Data
    P1627A/D Perf
    P1630Vehicle Theft Sys PCM in Learn Mode
    P1631Vehicle Theft Sys Improper Password
    P16355V Ref ( Circ
    P16395V Ref ( Circ
    P1641MIL Ctrl Circ
    P1643Wait To Start Lamp Ctrl Circ
    P16465V Ref (C) Circ
    P1652J1850 Comms Bus
    P1653EGR Vent Solenoid Ctrl Circ
    P1654Service Throttle Soon Lamp Ctrl Circ
    P1655EGR Solenoid Ctrl Circ
    P1656Wastegate Solenoid Ctrl Circ
    P1680Clutch Released Switch Circ
    P1681No I/P Cluster CCD/J1850 Messages Received
    P1682Charging Sys Voltage Too Low
    P1683Speed Ctrl Power Relay; or S/C 12v Driver CKT
    P1684Battery Disconnected in the last 50 Starts
    P1685Skim Invalid Key
    P1686No SKIM BUS Messages Received
    P1687No Cluster BUS Message
    P1688Internal Fuel Inj Pump Ctrller Failure
    P1689No Comm between ECM & Inj Pump Mod
    P1690CKP Sens Does Not Agree with ECM CKP Sens
    P1691Fuel Sys ESS RPM Error
    P1692DTC Set In ECM
    P1693DTC Detected in Companion JTEC Mod
    P1694No BUS Message Received from ECM Mod
    P1695No CCD/J1850 Messages from the Body Ctrl Mod.
    P1696PCM Failure EEPROM Write Denied
    P1697PCM Failure SRI Mile Not Stored
    P1698No CCD/J1850 Message From TCM/PCM
    P1699No CCD/J1850 Messages received from the Climate Control Module(CCM)
    P1719Skip Shift Solenoid Circ
    P1740TCC or O/D Solenoid Perf
    P1756Gov Press Not Equal to Target @ not15-20 PSI
    P1757Gov Press above 3 PSI in gear with 0 MPH
    P1762Gov Press Sens Offset Volts Too Low or Hi
    P1763Governor Press Sens Volts Too Hi
    P1764Governor Press Sens Volts Too Low
    P1765Trans 12 Volt Supply Relay CTRL Circ
    P1830Open or shorted condition detected in the clutch pedal switch over-ride relay control
    P1899P/N Switch Stuck in Park or in Gear
    DTC-Generic
    P0001 Fuel Volume Regulator Control Circuit/Open
    P0002 Fuel Volume Regulator Control Circuit Range/Performance
    P0003 Fuel Volume Regulator Control Circuit Low
    P0004 Fuel Volume Regulator Control Circuit High
    P0005 Fuel Shutoff Valve C ontrol Circuit/Open
    P0006 Fuel Shutoff Valve C ontrol Circuit Low
    P0007 Fuel Shutoff Valve C ontrol Circuit H igh
    P0008 Engine Position System Performance (Bank1)
    P0009 Engine Position System Performance (Bank2)
    P0010 A Camshaft Position Actuator Circuit (Bank1)
    P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0012 A Camshaft Position - Timing O ver-Retarded (Bank 1)
    P0013 B Camshaft Position - Actuator Circuit (Bank1)
    P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0015 B Camshaft Position - Timing O ver-Retarded (Bank 1)
    P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
    P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
    P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
    P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
    P0020 A Camshaft Position Actuator Circuit (Bank 2)
    P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0022 A Camshaft Position - Timing O ver-Retarded (Bank 2)
    P0023 B Camshaft Position - Actuator Circuit (Bank 2)
    P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0025 B Camshaft Position - Timing O ver-Retarded (Bank 2)
    P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
    P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
    P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
    P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
    P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
    P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    P0033 Turbo Charger Bypass Valve Control Circuit
    P0034 Turbo Charger Bypass Valve Control Circuit Low
    P0035 Turbo Charger Bypass Valve Control Circuit High
    P0036 HO2S Heater Control C ircuit (Bank 1 Sensor 2)
    P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
    P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
    P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
    P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
    P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
    P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
    P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
    P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
    P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
    P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
    P0049 Turbo/Super Charger Turbine Overspeed
    P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
    P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
    P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
    P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
    P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
    P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
    P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
    P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
    P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
    P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
    P0062 HO2S Heater Control C ircuit (Bank 2 Sensor 3)
    P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
    P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
    P0065 Air Assisted Injector Control Range/Performance
    P0066 Air Assisted Injector Control Circuit or Circuit Low
    P0067 Air Assisted Injector Control Circuit High
    P0068 MAP/MAF Throttle Position Correlation
    P0069 Manifold Absolute Pressure Barometric Pressure Correlation
    P0070 Ambient Air Temperature Sensor Circuit
    P0071 Ambient Air Temperature Sensor Range/Performance
    P0072 Ambient Air Temperature Sensor C ircuit Low
    P0073 Ambient Air Temperature Sensor Circuit High
    P0074 Ambient Air Temperature Sensor Circuit Intermittent
    P0075 Intake Valve Control Solenoid Circuit (Bank 1)
    P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
    P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
    P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
    P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
    P0080 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 1)
    P0081 Intake Valve Control Solenoid Circuit (Bank 2)
    P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
    P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
    P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
    P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
    P0086 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 2)
    P0087 Fuel Rail/System Pressure - Too Low
    P0088 Fuel Rail/System Pressure - Too High
    P0089 Fuel Pressure Regulator 1 Performance
    P0090 Fuel Pressure Regulator 1 C ontrol Circuit
    P0091 Fuel Pressure Regulator 1 C ontrol Circuit Low
    P0092 Fuel Pressure Regulator 1 C ontrol Circuit High
    P0093 Fuel System Leak Detected Large Leak
    P0094 Fuel System Leak Detected Small Leak
    P0095 Intake Air Temperature Sensor 2 C ircuit
    P0096 Intake Air Temperature Sensor 2 C ircuit Range/Performance
    P0097 Intake Air Temperature Sensor 2 C ircuit Low
    P0098 Intake Air Temperature Sensor 2 Circuit High
    P0099 Intake Air Temperature Sensor 2 C ircuit Intermittent/Erratic
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle Position Sensor/Switch A Circuit Malfunction
    P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle Position Sensor/Switch A Circuit Low Input
    P0123 Throttle Position Sensor/Switch A Circuit High Input
    P0124 Throttle Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0128 Coolant Thermostat Malfunction
    P0129 Barometric Pressure Too Low
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170 Fuel Trim Malfunction (Bank 1)
    P0171 Fuel Trim too Lean (Bank 1)
    P0172 Fuel Trim too Rich (Bank 1)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0174 Fuel Trim too Lean (Bank 2)
    P0175 Fuel Trim too Rich (Bank 2)
    P0176 Fuel Composition Sensor Circuit Malfunction
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction - Cylinder 1
    P0202 Injector Circuit Malfunction - Cylinder 2
    P0203 Injector Circuit Malfunction - Cylinder 3
    P0204 Injector Circuit Malfunction - Cylinder 4
    P0205 Injector Circuit Malfunction - Cylinder 5
    P0206 Injector Circuit Malfunction - Cylinder 6
    P0207 Injector Circuit Malfunction - Cylinder 7
    P0208 Injector Circuit Malfunction - Cylinder 8
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Overtemp Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
    P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
    P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
    P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Engine Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Range Fault
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit Malfunction
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal A Malfunction
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Exhaust Gas Recirculation Flow Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
    P0427 Catalyst Temperature Sensor Low Input (Bank 1)
    P0428 Catalyst Temperature Sensor High Input (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
    P0437 Catalyst Temperature Sensor Low Input (Bank 2)
    P0438 Catalyst Temperature Sensor High Input (Bank 2)
    P0440 Evaporative Emission Control System Malfunction
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0500 Vehicle Speed Sensor Malfunction
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage Malfunction
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0562 A/C pressure sensor low voltage(Chrysler)
    P0563 System Voltage High
    P0565 Cruise Control On Signal Malfunction
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control Related Malfunction
    P0575 Cruise Control Related Malfunction
    P0576 Cruise Control Related Malfunction
    P0578 Cruise Control Related Malfunction
    P0579 Cruise Control Related Malfunction
    P0580 Cruise Control Related Malfunction
    P0600 Serial Communication Link Malfunction
    P0601 Control Module Read Only Memory(ROM)
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory (ROM) Error
    P0606 PCM Processor Fault
    P0608 Control Module VSS Output "A" Malfunction
    P0609 Control Module VSS Output "B" Malfunction
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction
    P0655 Engine Hot Lamp Output Control Circuit Malfucntion
    P0656 Fuel Level Output Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off/1-2 Shift Solenoid Valve Performance
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical/1-2 Shift Solenoid Circuit Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off/2-3 Shift Solenoid Valve Performance
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical/2-3 Shift Solenoid Circuit Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0775 Pressure Control Solenoid B Malfunction
    P0776 Pressure Control Solenoid B Performance
    P0777 Pressure Control Solenoid B Stuck On
    P0778 Pressure Control Solenoid B Electrical
    P0779 Pressure Control Solenoid B Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
    P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted
    P1102 MAF Sensor In Range But Lower Than Expected
    P1103 MAF Sensor In Range But Higher Than Expected
    P1104 MAF Ground Malfunction
    P1105 Dual Alternator Upper Fault
    P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
    P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
    P1108 Dual Alternator Battery Lamp Circuit Malfunction
    P1109 IAT - B Sensor Intermittent
    P1110 IAT Sensor (D/C) Open/Short
    P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
    P1113 IAT Sensor Open/Short
    P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
    P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
    P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
    P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
    P1118 Manifold Absolute Temperature Circuit Low Input
    P1119 Manifold Absolute Temperature Circuit High Input
    P1120 Throttle position sensor out of range
    P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
    P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    P1123 Throttle Position Sensor In Range But Higher Than Expected
    P1124 Throttle Position Sensor Out Of Self Test Range
    P1125 Throttle position sensor intermittent
    P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
    P1127 Exhaust Not Warm, Downstream O2 Sensor
    P1128 Upstream Heated O2 Sensors Swapped
    P1129 Downstream Heated O2 Sensors Swapped
    P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
    P1131 Lack Of HO2S Switch - Sensor Indicates Lean
    P1132 Lack Of HO2S Switch - Sensor Indicates Rich
    P1133 HO2S Insufficient Switching Sensor 1
    P1134 HO2S Transition Time Ratio Sensor 1
    P1135 Pedal Position Sensor A Circuit Intermittent
    P1136 Fan Control Circuit Malfunction
    P1137 Lack Of HO2S Switch - Sensor Indicates Lean
    P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
    P1139 Water In Fuel Indicator Circuit Malfunction
    P1140 Water In Fuel Condition
    P1141 Fuel Restriction Indicator Circuit Malfunction
    P1142 Fuel Restriction Condition
    P1143 Air Assist Control Valve Range/Performance
    P1144 Air Assist Control Valve Circuit Malfunction
    P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
    P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
    P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
    P1153 Bank 2 Fuel Control Shifted Lean
    P1154 Bank 2 Fuel Control Shifted Rich
    P1155 Alternative Fuel Controller
    P1156 Fuel Select Switch Malfunction
    P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
    P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
    P1159 Fuel Stepper Motor Malfunction
    P1167 Invalid Test,throttle not depressed
    P1168 Fuel Rail Sensor In-Range Low Failure
    P1169 Fuel Rail Sensor In-Range High Failure
    P1170 ESO - Engine Shut Off Solenoid Fault
    P1171 Rotor Sensor Fault
    P1172 Rotor Control Fault
    P1173 Rotor Calibration Fault
    P1174 Cam Sensor Fault
    P1175 Cam Control Fault
    P1176 Cam Calibration Fault
    P1177 Synchronization Fault
    P1178 ( open )
    P1180 Fuel Delivery System Malfunction - Low
    P1181 Fuel Delivery System Malfunction - High
    P1182 Fuel Shut Off Solenoid Malfunction
    P1183 Engine Oil Temperature Circuit Malfunction
    P1184 Engine Oil Temperature Out Of Self Test Range
    P1185 FTS High - Fuel Pump Temperature Sensor High
    P1186 FTS Low - Fuel Pump Temperature Sensor Low
    P1187 Variant Selection
    P1188 Calibration Memory Fault
    P1189 Pump Speed Signal Fault
    P1190 Calibration Resistor Out Of Range
    P1191 Key Line Voltage
    P1192 Voltage External
    P1193 EGR Drive Overcurrent
    P1194 ECU A/D Converter
    P1195 SCP HBCC Failed To Initialize
    P1196 Key Off Voltage High
    P1197 Key Off Voltage Low
    P1198 Pump Rotor Control Underfueling
    P1199 Fuel Level Input Circuit Low
    P1200 Injector Control Circuit
    P1201 Injector Circuit Open / Shorted - Cylinder #1
    P1202 Injector Circuit Open / Shorted - Cylinder #2
    P1203 Injector Circuit Open / Shorted - Cylinder #3
    P1204 Injector Circuit Open / Shorted - Cylinder #4
    P1205 Injector Circuit Open / Shorted - Cylinder #5
    P1206 Injector Circuit Open / Shorted - Cylinder #6
    P1209 Injector Control Pressure System Fault
    P1210 Injector Control Pressure Above Expected Level
    P1211 Injector Control Pressure Sensor Above / Below Desired
    P1212 Injector Control Pressure Not Detected During Crank
    P1213 Start Injector Circuit Malfunction
    P1214 Pedal Position Sensor B Circuit Intermittent
    P1215 Pedal Position Sensor C Circuit Low Input
    P1216 Pedal Position Sensor C Circuit High Input
    P1217 Pedal Position Sensor C Circuit Intermittent
    P1218 CID High
    P1219 CID Low
    P1220 Series Throttle Control System Malfunction
    P1221 Traction Control System Malfunction
    P1222 Traction Control Output Circuit Malfunction
    P1223 Pedal Demand Sensor B Circuit High Input
    P1224 Throttle Position Sensor B Out Of Self Test Range
    P1225 Needle Lift Sensor Malfunction
    P1226 Control Sleeve Sensor Malfunction
    P1227 Wastegate Failed Closed (Over Pressure)
    P1228 Wastegate Failed Open (Under Pressure)
    P1229 Intercooler Pump Driver Fault
    P1230 Fuel Pump Low Speed Malfunction
    P1231 Fuel Pump Secondary Circuit Low, High Speed
    P1232 Fuel Pump Speed Primary Circuit Malfunction
    P1233 Fuel Pump Driver Module Off Line
    P1234 Fuel Pump Driver Module Off Line
    P1235 Fuel Pump Control Out Of Range
    P1236 Fuel Pump Control Out Of Range
    P1237 Fuel Pump Secondary Circuit Malfunction
    P1238 Fuel Pump Secondary Circuit Malfunction
    P1239 Speed Fuel Pump Positive Feed Fault
    P1240 Sensor Power Supply Malfunction
    P1241 Sensor Power Supply Low Input
    P1242 Sensor Power Supply High Input
    P1243 Second Fuel Pump Faulty or Ground Fault
    P1244 Alternator Load Input Failed High
    P1245 Alternator Load Input Failed Low
    P1246 Alternator Load Input Failed
    P1247 Turbo Boost Pressure Low
    P1248 Turbo Boost Pressure Not Detected
    P1249 Wastegate Control Valve Performance
    P1250 PRC Solenoid Circuit Malfunction
    P1251 Air Mixture Solenoid Circuit Malfunction
    P1252 Pedal Correlation PDS1 and LPDS High
    P1253 Pedal Correlation PDS1 and LPDS Low
    P1254 Pedal Correlation PDS2 and LPDS High
    P1255 Pedal Correlation PDS2 and LPDS Low
    P1256 Pedal Correlation PDS1 and HPDS
    P1257 Pedal Correlation PDS2 and HPDS
    P1258 Pedal Correlation PDS1 and PDS2
    P1259 Immobilizer to PCM Signal Error
    P1260 THEFT Detected, Vehicle Immobilzed
    P1261 Cylinder #1 High To Low Side Short
    P1262 Cylinder #2 High To Low Side Short
    P1263 Cylinder #3 High To Low Side Short
    P1264 Cylinder #4 High To Low Side Short
    P1265 Cylinder #5 High To Low Side Short
    P1266 Cylinder #6 High To Low Side Short
    P1267 Cylinder #7 High To Low Side Short
    P1268 Cylinder #8 High To Low Side Short
    P1269 Immobilizer Code Not Programmed
    P1270 Engine RPM Or Speed Limiter Reached
    P1271 Cylinder #1 High To Low Side Open
    P1272 Cylinder #2 High To Low Side Open
    P1273 Cylinder #3 High To Low Side Open
    P1274 Cylinder #4 High To Low Side Open
    P1275 Cylinder #5 High To Low Side Open
    P1276 Cylinder #6 High To Low Side Open
    P1277 Cylinder #7 High To Low Side Open
    P1278 Cylinder #8 High To Low Side Open
    P1280 Injection Control Pressure Out Of Range Low
    P1281 Injection Control Pressure Out Of Range High
    P1282 Excessive Injection Control Pressure
    P1283 IPR Circuit Failure
    P1284 Aborted KOER - ICP Failure
    P1285 Cylinder head over temp sensed
    P1286 Fuel Pulse In Range But Lower Than Expected
    P1287 Fuel Pulse In Range But Higher Than Expected
    P1288 Cylinder Head Temp Sensor Out Of Self Test Range
    P1289 Cylinder Head Temp Sensor High Input
    P1290 Cylinder Head Temp Sensor Low Input
    P1291 Injector High Side Short To GND Or VBATT - Bank 1
    P1292 Injector High Side Short To GND Or VBATT - Bank 2
    P1293 Injector High Side Open - Bank 1
    P1294 Injector High Side Open - Bank 2/Target idle not reached
    P1295 Multi-faults - Bank 1 - With Low Side Shorts
    P1296 Multi-faults - Bank 2 - With Low Side Shorts
    P1297 Injector High Sides Shorted Together
    P1298 IDM Failure
    P1299 Cylinder Head Overtemperature Protection Active
    P1300 Boost Calibration Fault
    P1301 Boost Calibration High
    P1302 Boost Calibration Low
    P1303 EGR Calibration Fault
    P1304 EGR Calibration High
    P1305 EGR Calibration Low
    P1306 Kickdown Relay Pull - In Circuit Fault
    P1307 Kickdown Relay Hold Circuit Fault
    P1308 A/C Clutch Circuit Fault
    P1309 Misfire Monitor AICE Chip Fault
    P1313 Misfire Rate Catalyst Damage Fault - Bank 1
    P1314 Misfire Rate Catalyst Damage Fault - Bank 2
    P1315 Persistent Misfire
    P1316 Injector Circuit / IDM Codes Detected
    P1317 Injector Circuit / IDM Codes Not Updated
    P1336 Crank / Cam Sensor Range / Performance
    P1340 Camshaft Position Sensor B Circuit Malfunction
    P1341 Camshaft Position Sensor B Range / Performance
    P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
    P1346 Fuel Level Sensor B Circuit Malfunction
    P1347 Fuel Level Sensor B Range / Performance
    P1348 Fuel Level Sensor B Circuit Low
    P1349 Fuel Level Sensor B Circuit High
    P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
    P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
    P1352 Ignition Coil A Primary Circuit Malfunction
    P1353 Ignition Coil B Primary Circuit Malfunction
    P1354 Ignition Coil C Primary Circuit Malfunction
    P1355 Ignition Coil D Primary Circuit Malfunction
    P1360 Ignition Coil A Secondary Circuit Malfunction
    P1361 Ignition Control (IC) Circuit Low Voltage
    P1362 Ignition Coil C Secondary Circuit Malfunction
    P1363 Ignition Coil D Secondary Circuit Malfunction
    P1364 Ignition Coil Primary Circuit Failure
    P1365 Ignition Coil Secondary Circuit Failure
    P1366 Ignition Spare
    P1367 Ignition Spare
    P1368 Ignition Spare
    P1369 Engine Temperature Light Monitor Failure
    P1370 Insufficient RMP Increase During Spark Test
    P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
    P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
    P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
    P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
    P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
    P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
    P1380 Misfire Detected - Rough Road Data Not Available
    P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
    P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
    P1383 Variable Cam Timing Overretarded (Bank #1)
    P1384 VVT Solenoid A Malfunction
    P1385 Variable Cam Timing Solenoid B Malfunction
    P1386 Variable Cam Timing Overadvanced (Bank #2)
    P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
    P1388 Variable Cam Timing Overretarded (Bank #2)
    P1389 Glow Plug Circuit High Side Low Input
    P1390 Octane Adjust Pin Out Of Self Test Range
    P1391 Glow Plug Circuit Low Input (Bank #1)
    P1392 Glow Plug Circuit High Input (Bank #1)
    P1393 Glow Plug Circuit Low Input (Bank #2)
    P1394 Glow Plug Circuit High Input (Bank #2)
    P1395 Glow Plug Monitor Fault (Bank #1)
    P1396 Glow Plug Monitor Fault (Bank #2)
    P1397 System Voltage Out Of Self Test Range
    P1398 VVT Solenoid B Circuit High Input
    P1399 Glow Plug Circuit High Side, High Input
    P1400 DPFE Circuit Low Input
    P1401 DPFE Circuit High Input
    P1402 EGR Metering Orifice Restricted
    P1403 DPFE Sensor Hoses Reversed
    P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
    P1405 DPFE Sensor Upstream Hose Off Or Plugged
    P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
    P1407 EGR No Flow Detected
    P1408 EGR Flow Out Of Self Test Range
    P1409 EVR Control Circuit Malfunction
    P1411 SAI System Incorrect Downstream Flow Detected
    P1413 SAI System Monitor Circuit Low Input
    P1414 SAI System Monitor Circuit High Input
    P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
    P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
    P1417 Port Air Relief Circuit Malfunction
    P1418 Split Air #1 Circuit Malfunction
    P1419 Split Air #2 Circuit Malfunction
    P1420 Catalyst Temperature Sensor Failure
    P1421 Catalyst Damage
    P1422 EGI Temperature Sensor Failure
    P1423 EGI Functionality Test Failed
    P1424 EGI Glow Plug Primary Failure
    P1425 EGI Glow Plug Secondary Failure
    P1426 EGI Mini - MAF Failed Out Of Range
    P1427 EGI Mini - MAF Failed Short Circuit
    P1428 EGI Mini - MAF Failed Open Circuit
    P1429 Electric Air Pump Primary Failure
    P1430 Electric Air Pump Secondary Failure
    P1433 A/C Refrigerant Temperature Circuit Low
    P1434 A/C Refrigerant Temperature Circuit High
    P1435 A/C Refrigerant Temperature Circuit Range/Performance
    P1436 A/C Evaporator Air Temperature Circuit Low
    P1437 A/C Evaporator Air Temperature Circuit High
    P1438 A/C Evaporator Air Temperature Circuit Range/Performance
    P1439 Floor Temperature Switch Circuit Malfunction
    P1440 Purge Valve Stuck Open
    P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
    P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
    P1442 Evaporative Emission Control System Leak Detected
    P1443 Evaporative Emission Control System Control Valve
    P1444 Purge Flow Sensor Circuit Low Input
    P1445 Purge Flow Sensor Circuit High Input
    P1446 Evaporative Vac Solenoid Circuit Malfunction
    P1447 ELC System Closure Valve Flow Fault
    P1448 ELC System 2 Fault
    P1449 Evaporative Check Solenoid Circuit Malfunction
    P1450 Unable To Bleed Up Fuel Tank Vacuum
    P1451 Evap Emission Control Sys Vent Control Valve Circuit
    P1452 Unable To Bleed - Up Vacuum in Tank
    P1453 Fuel Tank Pressure Relief Valve Malfunction
    P1454 Evaporative System Vacuum Test Malfunction
    P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
    P1456 Fuel Tank Temperature Sensor Circuit Malfunction
    P1457 Unable To Pull Vacuum In Tank
    P1460 Wide open throttle A/C cutoff relay circuit
    P1461 A/C pressure sensor circuit voltage low
    P1462 A/C pressure sensor circuit voltage high
    P1463 A/C Pressure Sensor Insufficient Pressure Change
    P1464 A/C Demand Out of Self Test Range
    P1465 A/C Relay Circuit Malfunction
    P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
    P1467 A/C Compressor Temperature Sensor Malfunction
    P1468 SSPOD Open Circuit or Closed Circuit Fault
    P1469 Low A/C Cycling Period
    P1470 A/C Cycling Period Too Short
    P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
    P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
    P1473 Fan Secondary High With Fan(s) Off
    P1474 Low Fan Control Primary Circuit Malfunction
    P1475 Fan Relay (Low) Circuit Malfunction
    P1476 Fan Relay (High) Circuit Malfunction
    P1477 Additional Fan Relay Circuit Malfunction
    P1478 Cooling Fan Driver Fault
    P1479 High Fan Control Primary Circuit Malfunction
    P1480 Fan Secondary Low with Low Fan On
    P1481 Fan Secondary Low With High Fan On
    P1482 SCP
    P1483 Power To Fan Circuit Overcurrent
    P1484 Open Power To Ground VCRM
    P1485 EGRV Circuit Malfunction
    P1486 EGRA Circuit Malfunction
    P1487 EGRCHK Solenoid Circuit Malfunction
    P1490 Secondary Air Relief Solenoid Circuit Malfunction
    P1491 Secondary Switch Solenoid Circuit Malfunction
    P1492 APLSOL Solenoid Circuit Malfunction
    P1493 RCNT Solenoid Circuit Malfunction
    P1494 SPCUT Solenoid Circuit Malfunction
    P1495 TCSPL Solenoid Circuit Malfunction
    P1500 Vehicle Speed Sensor Intermittent
    P1501 Vehicle Speed Sensor Out Of Self Test Range
    P1502 Vehicle Speed Sensor Intermittent Malfunction
    P1503 Auxillary Speed Sensor Fault
    P1504 Idle Air Control Circuit Malfunction
    P1505 Idle Air Control System At Adaptive Clip
    P1506 Idle Air Control Overspeed Error
    P1507 Idle Air Control Underspeed Error
    P1508 Idle Control System Circuit Open
    P1509 Idle Control System Circuit Shorted
    P1510 Idle Signal Circuit Malfunction
    P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
    P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
    P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
    P1514 High Load Neutral/Drive Fault
    P1515 Electric Current Circuit Malfunction
    P1516 IMRC Input Error (Bank 1)
    P1517 IMRC Input Error (Bank 2)
    P1518 Intake Manifold Runner Control (Stuck Open)
    P1519 Intake Manifold Runner Control (Stuck Closed)
    P1520 Intake Manifold Runner Control Circuit Malfunction
    P1521 Variable Intake Solenoid #1 Circuit Malfunction
    P1522 Variable Intake Solenoid #2 Circuit Malfunction
    P1523 IVC Solenoid Circuit Malfunction
    P1524 Variable Intake Solenoid System
    P1525 Air Bypass Valve System
    P1526 Air Bypass System
    P1527 Accelerate Warmup Solenoid Circuit Malfunction
    P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
    P1529 SCAIR Solenoid Circuit Malfunction
    P1530 A/C Clutch Circuit Malfunction
    P1531 Invalid Test - Accelerator Pedal Movement
    P1532 IMCC Circuit Malfunction, Bank B
    P1533 AAI Circuit Malfunction
    P1534 Inertia Switch Activated
    P1535 Blower Fan Speed Circuit Range/Performance
    P1536 Parking Brake Switch Circuit Failure
    P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
    P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
    P1539 Power To A/C Clutch Circuit Overcurrent
    P1540 Air Bypass Valve Circuit Malfunction
    P1549 IMCC Circuit Malfunction, Bank B
    P1550 PSPS Out Of Self Test Range
    P1565 Speed Control Command Switch Out of Range High
    P1566 Speed Control Command Switch Out of Range Low
    P1567 Speed Control Output Circuit Continuity
    P1568 Speed Control Unable to Hold Speed
    P1571 Brake Switch Malfunction
    P1572 Brake Pedal Switch Circuit Malfunction
    P1573 Throttle Position Not Available
    P1574 Throttle Position Sensor Disagreement btwn Sensors
    P1575 Pedal Position Out of Self Test Range
    P1576 Pedal Position Not Available
    P1577 Pedal Position Sensor Disagreement btwn Sensors
    P1578 ETC Power Less Than Demand
    P1579 ETC In Power Limiting Mode
    P1580 Electronic Throttle Monitor PCM Override
    P1581 Electronic Throttle Monitor Malfunction
    P1582 Electronic Throttle Monitor Data Available
    P1583 Electronic Throttle Monitor Cruise Disable
    P1584 TCU Detected IPE Circuit Malfunction
    P1585 Throttle Control Unit Malfunction
    P1586 Throttle Control Unit Throttle Position Malfunction
    P1587 Throttle Control Unit Modulated Command Malfunction
    P1588 Throttle Control Unit Detected Loss of Return Spring
    P1589 TCU Unable To Control Desired Throttle Angle
    P1600 Loss of KAM Power; Open Circuit
    P1601 ECM/TCM Serial Communication Error
    P1602 Immobilizer/ECM Communication Error
    P1603 EEPROM Malfunction
    P1604 Code Word Unregestered
    P1605 Keep Alive Memory Test Failure
    P1606 ECM Control Relay O/P Circuit Malfunction
    P1607 MIL O/P Circuit Malfunction
    P1608 Internal ECM Malfunction
    P1609 Diagnostic Lamp Driver Fault
    P1610 SBDS Interactive Codes
    P1611 SBDS Interactive Codes
    P1612 SBDS Interactive Codes
    P1613 SBDS Interactive Codes
    P1614 SBDS Interactive Codes
    P1615 SBDS Interactive Codes
    P1616 SBDS Interactive Codes
    P1617 SBDS Interactive Codes
    P1618 SBDS Interactive Codes
    P1619 SBDS Interactive Codes
    P1620 SBDS Interactive Codes
    P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
    P1622 Immobilizer ID Does Not Match
    P1623 Immobilizer Code Word/ID Number Write Failure
    P1624 Anti Theft System
    P1625 B+ Supply To VCRM Fan Circuit Malfunction
    P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
    P1627 Module Supply Voltage Out Of Range
    P1628 Module Ignition Supply Input Malfunction
    P1629 Internal Voltage Regulator Malfunction
    P1630 Internal Vref Malfunction
    P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
    P1632 Smart Alternator Faults Sensor/Circuit Malfunction
    P1633 KAM Voltage Too Low
    P1634 Data Output Link Circuit Failure
    P1635 Tire / Axle Ratio Out of Acceptable Range
    P1636 Inductive Signature Chip Communication Error
    P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
    P1638 Can Link ECM/INSTM Circuit / Network Malfunction
    P1639 Vehicle ID Block Corrupted or Not Programmed
    P1640 Powertrain DTCs Available in Another Module
    P1641 Fuel Pump Primary Circuit Failure
    P1642 Fuel Pump Monitor Circuit High Input
    P1643 Fuel Pump Monitor Circuit Low Input
    P1644 Fuel Pump Speed Control Circuit Malfunction
    P1645 Fuel Pump Resistor Switch Circuit Malfunction
    P1650 PSP Switch Out of Self Test Range
    P1651 PSP Switch Input Malfunction
    P1652 IAC Monitor Disabled by PSP Switch Failed On
    P1653 Power Steering Output Circuit Malfunction
    P1654 Recirculation Override Circuit Malfunction
    P1655 Starter Disable Circuit Malfunction
    P1660 Output Circuit Check Signal High
    P1661 Output Circuit Check Signal Low
    P1662 IDM_EN Circuit Failure
    P1663 Fuel Demand Command Signal Circuit Malfunction
    P1667 CI Circuit Malfunction
    P1668 PCM - IDM Communications Error
    P1670 Electronic Feedback Signal Not Detected
    P1680 Metering Oil Pump Malfunction
    P1681 Metering Oil Pump Malfunction
    P1682 Metering Oil Pump Malfunction
    P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
    P1684 Metering Oil Pump Position Sensor Circuit Malfunction
    P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
    P1689 Oil Pressure Control Solenoid Circuit Malfunction
    P1690 Wastegate Solenoid Circuit Malfunction
    P1691 Turbo Pressure Control Solenoid Circuit Malfunction
    P1692 Turbo Control Solenoid Circuit Malfunction
    P1693 Turbo Charge Control Circuit Malfunction
    P1694 Turbo Charge Relief Circuit Malfunction
    P1700 Transmission Indeterminate Failure (Failed to Neutral)
    P1701 Reverse Engagement Error
    P1702 TRS Circuit Intermittent Malfunction
    P1703 Brake Switch Out Of Self Test Range
    P1704 Digital TRS Failed to Transition States in KOEO / KOER
    P1705 Not in P or N During KOEO / KOER
    P1706 High Vehicle Speed Observed in Park
    P1707 Transfer Case Neutral Indicator Hard Fault Present
    P1708 Clutch Switch Circuit Malfunction
    P1709 PNP Switch Out Of Self Test Range
    P1711 TFT Sensor Out Of Self Test Range
    P1712 Trans Torque Reduction Request Signal Malfunction
    P1713 TFT Sensor In Range Failure Low Value
    P1714 SSA Inductive Signature Malfunction
    P1715 SSB Inductive Signature Malfunction
    P1716 SSC Inductive Signature Malfunction
    P1717 SSD Inductive Signature Malfunction
    P1718 TFT Sensor In Range Failure High
    P1720 Vehicle Speed (Meter) Circuit Malfunction
    P1721 Gear 1 Incorrect Ratio
    P1722 Gear 2 Incorrect Ratio
    P1723 Gear 3 incorrect Ratio
    P1724 Gear 4 Incorrect Ratio
    P1725 Insufficient Engine Speed Increase During Self Test
    P1726 Insufficient Engine Speed Decrease During Self Test
    P1727 Coast Clutch Solenoid Inductive Signature Malfunction
    P1728 Transmission Slip Error
    P1729 4x4 Low Switch Error
    P1730 Gear Control Malfunction 2,3,5
    P1731 1-2 Shift Malfunction
    P1732 2-3 Shift Malfunction
    P1733 3-4 Shift Malfunction
    P1734 Gear Control Malfunction
    P1735 First Gear Switch Circuit Malfunction
    P1736 Second Gear Switch Circuit Malfunction
    P1737 Lockup Solenoid System
    P1738 Shift Time Error
    P1739 Slip Solenoid System
    P1740 Torque Converter Clutch Inductive Signature Malfunction
    P1741 Torque Converter Clutch Control Error
    P1742 Torque Converter Clutch Solenoid Failed On
    P1743 Torque Converter Clutch Solenoid Failied On
    P1744 Torque Converter Clutch System Performance
    P1745 Line Pressure Solenoid System
    P1746 Pressure Control Solenoid "A" Open Circuit
    P1747 Pressure Control Solenoid "A" Short Circuit
    P1748 EPC Malfunction
    P1749 Pressure Control Solenoid Failed Low
    P1751 Shift Solenoid A Performance
    P1754 Coast Clutch Solenoid Circuit Malfunction
    P1755 Intermediate Speed Sensor (ISS) Malfunction
    P1756 Shift Solenoid B Performance
    P1760 Pressure Control Solenoid "A" Short Circuit
    P1761 Shift Solenoid C Performance
    P1762 Overdrive Band Failed Off
    P1765 Timing Solenoid Circuit Malfunction
    P1767 Torque Converter Clutch Circuit Malfunction
    P1768 Performance / Normal / Winter Mode Input Malfunction
    P1769 AG4 Transmission Torque Modulation Fault
    P1770 Clutch Solenoid Circuit Malfunction
    P1775 Transmission System MIL Fault
    P1776 Ignition Retard Request Duration Fault
    P1777 Ignition Retard Request Circuit Fault
    P1778 Transmission Reverse I/P Circuit Malfunction
    P1779 TCIL Circuit Malfunction
    P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
    P1781 4X4 Switch Out of Self Test Range
    P1782 P/ES Circuit Out Of Self Test Range
    P1783 Transmission Overtemperature Condition
    P1784 Transmission Mechanical Failure - First And Reverse
    P1785 Transmission Mechanical Failure - First And Second
    P1786 3-2 Downshift Error
    P1787 2-1 Downshift Error
    P1788 Pressure Control Solenoid "B" Open Circuit
    P1789 Pressure Control Solenoid "B" Short Circuit
    P1790 TP (Mechanical) Circuit Malfunction
    P1791 TP (Electric) Circuit Malfunction
    P1792 Barometer Pressure Circuit Malfunction
    P1793 Intake Air Volume Circuit Malfunction
    P1794 Battery Voltage Circuit Malfunction
    P1795 Idle Switch Circuit Malfunction
    P1796 Kick Down Switch Circuit Malfunction
    P1797 Neutral Switch Circuit Malfunction
    P1798 Coolant Temperature Circuit Malfunction
    P1799 Hold Switch Circuit Malfunction
    P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
    P1801 Transmission Clutch Interlock Safety Switch Open Circuit
    P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
    P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
    P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
    P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
    P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
    P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
    P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
    P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
    P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
    P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
    P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
    P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
    P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
    P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
    P1816 Transmission Neutral Safety Switch Circuit Failure
    P1817 Transmission Neutral Safety Switch Open Circuit
    P1818 Transmission Neutral Safety Switch Short Circuit To Battery
    P1819 Transmission Neutral Safety Switch Short Circuit To Ground
    P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
    P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
    P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
    P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
    P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
    P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
    P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
    P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
    P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
    P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
    P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
    P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
    P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
    P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
    P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
    P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
    P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
    P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
    P1838 Transmission Transfer Case Shift Motor Circuit Failure
    P1839 Transmission Transfer Case Shift Motor Open Circuit
    P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
    P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
    P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
    P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
    P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
    P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
    P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
    P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit
    P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
    P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
    P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
    P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit
    P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
    P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
    P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
    P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit
    P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
    P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
    P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
    P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit
    P1860 TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
    P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
    P1862 Transmission Transfer Case Contact Plate Power Circuit Failure
    P1863 Transmission Transfer Case Contact Plate Power Open Circuit
    P1864 Transmission Transfer Case Contact Plate Power Short To Battery
    P1865 Transmission Transfer Case Contact Plate Power Short To Ground
    P1866 Transmission Transfer Case System Concern - Servicing Required
    P1867 Transmission Transfer Case Contact Plate General Circuit Failure
    P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
    P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
    P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
    P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
    P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
    P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
    P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure
    P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical
    P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
    P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
    P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure
    P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit
    P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery
    P1881 Engine Coolant Level Switch Circuit Failure, GEM
    P1882 Engine Coolant Level Switch Circuit Short to Ground
    P1883 Engine Coolant Level Switch Circuit Failure, GEM
    P1884 Engine Coolant Level Lamp Circuit Short to Ground
    P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground
    P1886 4X4 Initialization Failure
    P1890 Transmission 4WD Mode Select Return Input Circuit Failure
    P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
    P1900 OSS Circuit Intermittent Malfunction
    P1901 TSS Circuit Intermittent Malfunction
    P1902 Pressure Control Solenoid "B" Intermittent Short
    P1903 Pressure Control Solenoid "C" Short Circuit
    P1904 Pressure Control Solenoid "C" Open Circuit
    P1905 Pressure Control Solenoid "C" Intermittent Short
    P1906 Kickdown Pull Relay Open or Short Circuit to Ground
    P1907 Kickdown Hold Relay Open or Short Circuit to Ground
    P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground
    P1909 Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd
    P1910 VFS A Pressure Output Failed Low
    P1911 VFS B Pressure Output Failed Low
    P1912 VFS C Pressure Output Failed Low
    P1913 Pressure Switch A Circuit Malfunction
    P1914 Manually Shifted Automatic (MSA) Sw Circuit Malf
    P1915 Reverse Switch Circuit Malfunction
    P1916 High Clutch Drum Speed Sensor Malfunction
    P1917 High Clutch Drum Speed Sensor Intermittent
    P1918 Transmission Range Display Circuit Malfunction
    C1091 Speed Wheel Sensor All Coherency Failure
    C1095 ABS Hydraulic Pump Motor Circuit Failure
    C1096 ABS Hydraulic Pump Motor Circuit Open
    C1097 ABS Hydraulic Pump Motor Circuit Short To Ground
    C1098 ABS Hydraulic Pump Motor Circuit Short To Battery
    C1100 ABS Pump Switch Circuit Failure
    C1101 ABS Hydraulic Valve Circuit Failure
    C1102 ABS Acceleration Switch Circuit Failure
    C1103 ABS Hydraulic Brake Switch Circuit Failure
    C1104 Traction Control Active Lamp - Circuit Short to Battery
    C1105 Traction Control Disable Lamp - Circuit Short to Battery
    C1106 Traction Control Disable Switch Circuit Short to Battery
    C1107 ABS Function Enabled Input Circuit Failure
    C1109 Speed Control Actuator Assembly Cable Release Failure
    C1110 ABS Power Relay Coil Circuit Failure
    C1111 ABS Power Relay Coil Open Circuit
    C1112 ABS Power Relay Coil Short Circuit To Ground
    C1113 ABS Power Relay Coil Short Circuit To Battery
    C1114 ABS Power Relay Output Short Circuit To Ground
    C1115 ABS Power Relay Output Short Circuit To Battery
    C1116 Starter Motor Circuit Failure
    C1117 RPM Input Circuit Failure
    C1123 Vehicle Speed Sensor Input Short to Battery
    C1124 Input shaft speed signal missing/faulted
    C1125 Brake Fluid Level Sensor Input Circuit Failure
    C1126 Cruise Control Command Switch Assembly Circuit Failure
    C1127 Cruise Control Deactivator Brake Switch Circuit Failure
    C1132 Clutch position ckt short to ground
    C1133 Clutch position ckt short to battery
    C1134 Gear Shift position short to ground
    C1135 Gear Shift position short to battery
    C1136 Gear Select position short to ground
    C1137 ECU is Defective
    C1138 Gear Select position short to Battery
    C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault
    C1140 Hydraulic Base Brake Failure
    C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault
    C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault
    C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault
    C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault
    C1145 Speed Wheel Sensor RF Input Circuit Failure
    C1146 Speed Wheel Sensor RF Circuit Open
    C1148 Speed Wheel Sensor RF Coherency Fault
    C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure
    C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt
    C1155 Speed Wheel Sensor LF Input Circuit Failure
    C1156 Speed Wheel Sensor LF Circuit Open
    C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure
    C1158 Speed Wheel Sensor LF Coherency Fault
    C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd
    C1161 Air Pressure Low Circuit Short to Gnd
    C1162 Park Brake Switch # 2 Released Circuit Failure
    C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd
    C1164 Park Brake Actuator Assembly Switch Circuit Failure
    C1165 Speed Wheel Sensor RR Input Circuit Failure
    C1166 Speed Wheel Sensor RR Input Open Circuit
    C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd
    C1168 Speed Wheel Sensor RR Coherency Fault
    C1169 ABS Fluid Dumping Exceeds Maximum Timing
    C1170 PRNDL Switch Circuit Failure
    C1172 Park Brake Switch # 1 Applied Circuit Failure
    C1173 Park Brake Switch # 1 Released Circuit Short to Gnd
    C1174 Park Brake Switch # 2 Applied Circuit Failure
    C1175 Speed Wheel Sensor LR Input Circuit Failure
    C1176 Speed Wheel Sensor LR Circuit Open
    C1177 Park Brake Actuator Assembly Switch Released Circuit Failure
    C1178 Speed Wheel Sensor LR Coherency Fault
    C1179 Speed Control Actuator Assembly Cable Slack Failure
    C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure
    C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound
    C1182 Park Lamp Flash Relay Circuit Failure
    C1183 Park Lamp Flash Relay Circuit Short to Battery
    C1184 ABS System Is Not Operational
    C1185 ABS Power Relay Output Circuit Failure
    C1186 ABS Power Relay Output Open Circuit
    C1187 Brake Fluid Level Sensor Input Open Circuit
    C1188 Brake Fluid Level Sensor Input Short Circuit To Battery
    C1189 Brake Fluid Level Sensor Input Short Circuit To Ground
    C1190 Speed Wheel Sensor LF Input Short Circuit To Battery
    C1191 Speed Wheel Sensor LF Input Short Circuit To Ground
    C1192 Speed Wheel Sensor RF Input Short Circuit To Battery
    C1193 Speed Wheel Sensor RF Input Short Circuit To Ground
    C1194 ABS Outlet Valve Coil LF Circuit Failure
    C1195 ABS Outlet Valve Coil LF Circuit Open
    C1196 ABS Outlet Valve Coil LF Circuit Short To Battery
    C1197 ABS Outlet Valve Coil LF Circuit Short To Ground
    C1198 ABS Inlet Valve Coil LF Circuit Failure
    C1199 ABS Inlet Valve Coil LF Circuit Open
    C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
    C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
    C1202 ABS Outlet Valve Coil Rear Circuit Failure
    C1203 ABS Outlet Valve Coil Rear Circuit Open
    C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery
    C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground
    C1206 ABS Inlet Valve Coil Rear Circuit Failure
    C1207 ABS Inlet Valve Coil Rear Circuit Open
    C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery
    C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground
    C1210 ABS Outlet Valve Coil RF Circuit Failure
    C1211 ABS Outlet Valve Coil RF Circuit Open
    C1212 ABS Outlet Valve Coil RF Circuit Short To Battery
    C1213 ABS Outlet Valve Coil RF Circuit Short To Ground
    C1214 ABS Inlet Valve Coil RF Circuit Failure
    C1215 ABS Inlet Valve Coil RF Circuit Open
    C1216 ABS Inlet Valve Coil RF Circuit Short To Battery
    C1217 ABS Inlet Valve Coil RF Circuit Short To Ground
    C1218 Lamp ABS Warning Output Circuit Failure
    C1219 Lamp ABS Warning Output Circuit Open
    C1220 Lamp ABS Warning Output Circuit Short To Battery
    C1221 Lamp ABS Warning Output Circuit Short To Ground
    C1222 Speed Wheel Mismatch
    C1223 Lamp Brake Warning Output Circuit Failure
    C1224 Lamp Brake Warning Output Circuit Open
    C1225 Lamp Brake Warning Output Circuit Short To Battery
    C1226 Lamp Brake Warning Output Circuit Short To Ground
    C1227 Speed Wheel Sensor LR Input Short Circuit To Battery
    C1228 Speed Wheel Sensor LR Input Short Circuit To Ground
    C1229 Speed Wheel Sensor Rear Center Coherency Fault
    C1230 Speed Wheel Sensor Rear Center Input Circuit Failure
    C1231 Speed Wheel Sensor Rear Center Circuit Open
    C1232 Speed Wheel Sensor Rear Center Input Short Circuit To Battery
    C1233 Speed Wheel LF Input Signal Missing
    C1234 Speed Wheel RF Input Signal Missing
    C1235 Speed Wheel RR Input Signal Missing
    C1236 Speed Wheel LR Input Signal Missing
    C1237 Speed Wheel Rear Input Signal Missing
    C1238 ABS Hydraulic Pressure Differential Switch Input Circuit Failure
    C1239 ABS Hydraulic Pressure Differential Switch Input Open Circuit
    C1240 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Battery
    C1241 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Ground
    C1242 ABS Outlet Valve Coil LR Circuit Failure
    C1243 ABS Outlet Valve Coil LR Circuit Open
    C1244 ABS Outlet Valve Coil LR Circuit Short To Battery
    C1245 ABS Outlet Valve Coil LR Circuit Short To Ground
    C1246 ABS Outlet Valve Coil RR Circuit Failure
    C1247 ABS Outlet Valve Coil RR Circuit Open
    C1248 ABS Outlet Valve Coil RR Circuit Short To Battery
    C1249 ABS Outlet Valve Coil RR Circuit Short To Ground
    C1250 ABS Inlet Valve Coil LR Circuit Failure
    C1251 ABS Inlet Valve Coil LR Circuit Open
    C1252 ABS Inlet Valve Coil LR Circuit Short To Battery
    C1253 ABS Inlet Valve Coil LR Circuit Short To Ground
    C1254 ABS Inlet Valve Coil RR Circuit Failure
    C1255 ABS Inlet Valve Coil RR Circuit Open
    C1256 ABS Inlet Valve Coil RR Circuit Short To Battery
    C1257 ABS Inlet Valve Coil RR Circuit Short To Ground
    C1258 Speed Wheel LF Comparison Failure
    C1259 Speed Wheel RF Comparison Failure
    C1260 Speed Wheel RR Comparison Failure
    C1261 Speed Wheel LR Comparison Failure
    C1262 Lamp Warning Relay Circuit Failure
    C1263 Lamp Warning Relay Circuit Open
    C1264 Lamp Warning Relay Circuit Short To Battery
    C1265 Lamp Warning Relay Circuit Short To Ground
    C1266 ABS Valve Power Relay Circuit Failure
    C1267 ABS Functions Temporarily Disabled
    C1268 Motor Relay # 1 Circuit Failure
    C1269 Motor Relay # 1 Circuit Short to Battery
    C1270 Motor # 1 Input Circuit Failure
    C1271 Motor # 1 Input Circuit Short to Gnd
    C1272 Motor # 2 Input Circuit Failure
    C1273 Motor # 2 Input Circuit Short to Vbat
    C1274 Solenoid Relay # 1 Circuit Failure
    C1275 Solenoid Relay # 1 Circuit Short to Vbatt
    C1276 Park Brake Actuator Assembly Switch Applied Circuit Short to Gnd
    C1277 STEERING Wheel Angle 1and 2 Circuit Failure
    C1278 STEERING Wheel Angle 1and 2 Signal Faulted
    C1279 Yaw Rate Sensor circuit Failure
    C1280 Yaw Rate Sensor Signal Fault
    C1281 Lateral Accelerometer circuit Failure
    C1282 Lateral Accelerometer Signal Fault
    C1283 Switch Test Signal Failure
    C1284 Oil Pressure Switch Failure
    C1285 Booster Solenoid circuit Failure
    C1286 Booster Mechanical Failure
    C1287 Booster Pedal Force switch circuit Failure
    C1288 Pressure Transducer Main / Primary Input Circuit Failure
    C1289 Pressure Transducer Redundant / Secondary Input Circuit Failure
    C1400 Traction Control Valve RF Circuit Failure
    C1401 Traction Control Valve RF Circuit Open
    C1402 Traction Control Valve RF Circuit Short To Ground
    C1403 Traction Control Valve RF Circuit Short To Battery
    C1404 Traction Control Valve Rear Circuit Failure
    C1405 Traction Control Valve Rear Circuit Open
    C1406 Traction Control Valve Rear Circuit Short To Ground
    C1407 Traction Control Valve Rear Circuit Short To Battery
    C1410 Traction Control Valve LF Circuit Failure
    C1411 Traction Control Valve LF Circuit Open
    C1412 Traction Control Valve LF Circuit Short To Ground
    C1413 Traction Control Valve LF Circuit Short To Battery
    C1414 Incorrect Module Design Level
    C1415 Incorrect Module Configuration
    C1416 Damper RF Circuit Short To Battery
    C1417 Damper RF Circuit Short to Ground
    C1418 Damper RF Circuit Failure
    C1419 Damper RF Circuit Open
    C1420 Hydraulic Fluid Pressure/ Flow Circuit Short to Vbatt
    C1421 Damper LF Circuit Short To Battery
    C1422 Damper LF Circuit Short to Ground
    C1423 Damper LF Circuit Failure
    C1424 Damper LF Circuit Open
    C1425 Damper RR Circuit Short to Ground
    C1426 Damper RR Circuit Short To Battery
    C1427 Damper RR Circuit Open
    C1428 Damper RR Circuit Failure
    C1429 Input-shaft-speed input circuit failure
    C1430 Damper LR Circuit Open
    C1431 Damper LR Circuit Short To Battery
    C1432 Damper LR Circuit Short to Ground
    C1433 Damper LR Circuit Failure
    C1435 Accelerometer Rear Circuit Failure
    C1436 Accelerometer Rear Circuit Signal Is Not Sensed
    C1437 Accelerometer Rear Circuit Short To Ground
    C1438 Accelerometer Rear Circuit Short To Battery
    C1439 Vehicle Acceleration EEC-IV Circuit Failure
    C1440 Pressure Transducer Main / Primary signal Faulted
    C1441 Steering Phase A Circuit Signal Is Not Sensed
    C1442 Steering Phase B Circuit Signal Is Not Sensed
    C1443 Steering Phase A Circuit Short To Ground
    C1444 Steering Phase B Circuit Short To Ground
    C1445 Speed Vehicle Signal Circuit Failure
    C1446 Brake Switch Circuit Failure
    C1447 Traction Control Module Request Circuit Failure
    C1448 Lamp Adaptive Damping Warning Circuit Failure
    C1449 Traction Control Motor Coherency Fault
    C1450 Traction Control Motor Circuit Failure
    C1451 Traction Control Motor Circuit Open
    C1452 Traction Control Motor Circuit Short to Battery
    C1453 Traction Control Motor Circuit Short to Ground
    C1454 Front Lateral Accelerometer Circuit Failure
    C1455 Accelerometer Front Circuit Failure
    C1456 Accelerometer Front Circuit Is Not Sensed
    C1457 Accelerometer Front Circuit Short To Ground
    C1458 Accelerometer Front Circuit Short To Battery
    C1459 Adaptive Mode Switch Circuit Failure
    C1460 Vehicle Accelerometer Power Circuit Failure
    C1461 Vehicle Accelerometer Power Circuit Short to Battery
    C1462 Left Front Vertical Accelerometer Circuit Failure
    C1463 Right Front Vertical Accelerometer Circuit Failure
    C1464 Pressure Transducer Redundant / Secondary Signal Faulted
    C1465 Damper High Side Front Circuit Short To Battery
    C1466 Damper Circuit Failure
    C1467 Damper High Side Rear Circuit Short To Battery
    C1468 Damper Low Side Front Circuit Failure
    C1469 Damper Low Side Rear Circuit Failure
    C1495 Traction Control Motor Potentiometer Circuit Failure
    C1496 Traction Control Motor Potentiometer Circuit Open
    C1497 Traction Control Motor Potentiometer Circuit Short to Battery
    C1498 Traction Control Motor Potentiometer Circuit Short to Ground
    C1499 Transfer Case Contact Plate "A" Encoder Circuit Failure
    C1500 Transfer Case Contact Plate "B" Encoder Circuit Failure
    C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure
    C1502 Transfer Case Contact Plate "D" Encoder Circuit Failure
    C1503 Dynamic Stability Control Left Front Valve Malfunction
    C1504 Dynamic Stability Control Right Front Valve Malfunction
    C1505 Dynamic Stability Control Left Rear Valve Malfunction
    C1506 Dynamic Stability Control Right Rear Valve Malfunction
    C1507 Traction Control of Brake Exceeds Time-Out
    C1508 Traction Control of Engine Exceeds Time-Out
    C1510 Right Front Wheel Pressure Reduction Performance Problem
    C1511 Left Front Wheel Pressure Reduction Performance Problem
    C1512 Right Rear Wheel Pressure Reduction Performance Problem
    C1513 Left rear Wheel Pressure Reduction Performance Problem
    C1699 Left Rear Sensor Circuit Short to Vbat
    C1700 Left Rear Sensor Circuit Failure
    C1701 Left Rear Sensor Circuit Fault
    C1702 RightRear Sensor Circuit Short to Vbat
    C1703 Right Rear Sensor Circuit Failure
    C1704 Right Rear Sensor Circuit Fault
    C1705 Left Rear Center Sensor Circuit Short to Vbat
    C1706 Left Rear Center Sensor Circuit Failure
    C1707 Left Rear Center Sensor Circuit Fault
    C1708 Right Rear Center Sensor Circuit Short to Vbat
    C1709 Right Rear Center Sensor Circuit Failure
    C1710 Right Rear Center Sensor Circuit Fault
    C1711 Left Front Sensor Circuit Short to Vbat
    C1712 Left Front Sensor Circuit Failure
    C1713 Left Front Sensor Circuit Fault
    C1714 Right Front Sensor Circuit Short to Vbat
    C1715 Right Front Sensor Circuit Failure
    C1716 Right Front Sensor Circuit Fault
    C1717 Left Front Center Sensor Circuit Short to Vbat
    C1718 Left Front Center Sensor Circuit Failure
    C1719 Left Front Center Sensor Circuit Fault
    C1721 Air Suspension Height Sensor Power Circuit Open
    C1722 Air Suspension Height Sensor Power Circuit Short To Battery
    C1723 Air Suspension Height Sensor Power Circuit Short To Ground
    C1724 Air Suspension Height Sensor Power Circuit Failure
    C1725 Air Suspension Front Pneumatic Failure
    C1726 Air Suspension Rear Pneumatic Failure
    C1727 Air Suspension Reservoir Pneumatic Failure
    C1728 Transfer Case unable to transition between 2H and 4H
    C1729 Transfer Case unable to transition between 4H and 4L
    C1730 Reference Voltage Out of Range (+5 v)
    C1731 Air Suspension LF Corner Up Timeout
    C1732 Air Suspension LF Corner Down Timeout
    C1733 Air Suspension RF Corner Up Timeout
    C1734 Air Suspension RF Corner Down Timeout
    C1735 Air Suspension LR Corner Up Timeout
    C1736 Air Suspension LR Corner Down Timeout
    C1737 Air Suspension RR Corner Up Timeout
    C1738 Air Suspension RR Corner Down Timeout
    C1739 Right Front Center Sensor Circuit Short to Vbat
    C1740 Right Front Center Sensor Circuit Failure
    C1741 Right Front Center Sensor Circuit Fault
    C1742 Rear Sounder Circuit Failure
    C1743 Rear Sounder Circuit Short to Vbatt
    C1744 Front Sounder Circuit Failure
    C1745 Front Sounder Circuit Short to Vbatt
    C1748 Switch input Circuit Short to Gnd
    C1749 Trailer Input Circuit Failure
    C1750 Accelerator Position Sensor Out of Range
    C1751 Vehicle Speed Sensor # 1 Output Circuit Short to Vbatt
    C1752 Vehicle Speed Sensor # 1 Output Circuit Short to Gnd
    C1753 Hydraulic Clutch Actuator Valve Signal Fault
    C1754 Hydraulic Clutch Actuator Valve Circuit Failure
    C1755 Power Limit Shutdown Fault
    C1756 Air Suspension Front Height Sensor High (SE) Signal Circuit Failure
    C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open
    C1758 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Battery
    C1759 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Ground
    C1760 Air Suspension Rear Height Sensor High (SE) Signal Circuit Failure
    C1761 Air Suspension Rear Height Sensor High (SE) Signal Circuit Open
    C1762 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Battery
    C1763 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Ground
    C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure
    C1766 Air Suspension Rear Height Sensor Low Signal Circuit Open
    C1767 Air Suspension Rear Height Sensor Low Signal Circuit Short To Battery
    C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground
    C1770 Air Suspension Vent Solenoid Output Circuit Failure
    C1771 Air Suspension Vent Solenoid Output Circuit Open
    C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery
    C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground
    C1774 Coolant Temp Out of Range
    C1775 DC-DC Converter Failure
    C1776 Heater System Failure
    C1777 Vacuum Pressure Circuit Failure
    C1778 Power Steering Failure
    C1779 Blower Switch Failure
    C1780 Temperature Select Failure
    C1781 Engine Coolant Temperature Signal Missing/Fault
    C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure
    C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open
    C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery
    C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground
    C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure
    C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open
    C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery
    C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground
    C1800 Air Suspension Reservoir Solenoid Circuit Failure
    C1805 Mismatched PCM and/or ABS-TC Module
    C1813 Air Suspension LR Vent Request Exceeded Max Timing
    C1814 Air Suspension RR Vent Request Exceeded Max Timing
    C1818 Air Suspension LR Air Compress Request Exceeded Max Timing
    C1819 Air Suspension RR Air Compress Request Exceeded Max Timing
    C1820 Air Suspension RF Air Compress Request Exceeded Max Timing
    C1830 Air Suspension Compressor Relay Circuit Failure
    C1831 Air Suspension Compressor Relay Circuit Open
    C1832 Air Suspension Compressor Relay Circuit Short To Battery
    C1833 Air Suspension Compressor Relay Circuit Short To Ground
    C1834 Gauge Drive Current Fault
    C1835 Current Sense Circuit Failure
    C1836 Battery Temp out of Range
    C1837 Battery Heater Circuit Failure
    C1838 Charging System Fault
    C1839 Leakage Fault
    C1840 Air Suspension Disable Switch Circuit Failure
    C1841 Air Suspension Disable Switch Circuit Open
    C1842 Air Suspension Disable Switch Circuit Short To Battery
    C1843 Air Suspension Disable Switch Circuit Short To Ground
    C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure
    C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure
    C1846 Air Suspension Front Inflator Solenoid Output Circuit Open
    C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery
    C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground
    C1849 Master Cylinder Pressure Out of Range
    C1850 Air Suspension Warning Lamp Circuit Failure
    C1851 Air Suspension Warning Lamp Circuit Open
    C1852 Air Suspension Warning Lamp Circuit Short To Battery
    C1853 Air Suspension Warning Lamp Circuit Short To Ground
    C1854 Motor Temperature Out of Range
    C1855 Acceleration Position Sensor Conflict
    C1856 Traction Motor Encoder circuit Failure
    C1859 PRNDL Input #2 Circuit Failure
    C1860 PRNDL Input #3 Circuit Failure
    C1861 PRNDL Input #4 Circuit Failure
    C1862 Contactor Circuit Failure
    C1863 External Charging Fault
    C1864 Battery Module Fault
    C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure
    C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open
    C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery
    C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground
    C1869 Air Suspension Gate Solenoid Output Circuit Failure
    C1870 Air Suspension Gate Solenoid Output Circuit Open
    C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery
    C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground
    C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure
    C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open
    C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery
    C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground
    C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure
    C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open
    C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery
    C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground
    C1881 Air Suspension RF Height Sensor Circuit Failure
    C1882 Air Suspension RF Height Sensor Circuit Open
    C1883 Air Suspension RF Height Sensor Circuit Short To Battery
    C1884 Air Suspension RF Height Sensor Circuit Short To Ground
    C1885 Air Suspension RR Height Sensor Circuit Failure
    C1886 Air Suspension RR Height Sensor Circuit Open
    C1887 Air Suspension RR Height Sensor Circuit Short To Battery
    C1888 Air Suspension RR Height Sensor Circuit Short To Ground
    C1889 Air Suspension LF Height Sensor Circuit Failure
    C1890 Air Suspension LF Height Sensor Circuit Open
    C1891 Air Suspension LF Height Sensor Circuit Short To Battery
    C1892 Air Suspension LF Height Sensor Circuit Short To Ground
    C1893 Air Suspension LR Height Sensor Circuit Failure
    C1894 Air Suspension LR Height Sensor Circuit Open
    C1895 Air Suspension LR Height Sensor Circuit Short To Battery
    C1896 Air Suspension LR Height Sensor Circuit Short To Ground
    C1897 Steering VAPS II Circuit Loop Failure
    C1898 Steering VAPS II Circuit Loop Open
    C1899 Steering VAPS II Circuit Loop Short To Battery
    C1900 Steering VAPS II Circuit Loop Short To Ground
    C1901 Ride Control RR Shock Actuator Circuit Failure
    C1902 Ride Control RR Shock Actuator Circuit Open
    C1903 Ride Control RR Shock Actuator Circuit Short To Battery
    C1904 Ride Control RR Shock Actuator Circuit Short To Ground
    C1905 Ride Control LR Shock Actuator Circuit Failure
    C1906 Ride Control LR Shock Actuator Circuit Open
    C1907 Ride Control LR Shock Actuator Circuit Short To Battery
    C1908 Ride Control LR Shock Actuator Circuit Short To Ground
    C1909 Ride Control RF Shock Actuator Circuit Failure
    C1910 Ride Control RF Shock Actuator Circuit Open
    C1911 Ride Control RF Shock Actuator Circuit Short To Battery
    C1912 Ride Control RF Shock Actuator Circuit Short To Ground
    C1913 Ride Control LF Shock Actuator Circuit Failure
    C1914 Ride Control LF Shock Actuator Circuit Open
    C1915 Ride Control LF Shock Actuator Circuit Short To Battery
    C1916 Ride Control LF Shock Actuator Circuit Short To Ground
    C1917 Steering EVO Out-of-Range Fault
    C1918 Air Suspension Ride Height Select Switch Circuit Failure
    C1920 Led #1 Circuit Failure
    C1921 VAPS Solenoid Actuator Output Circuit Failure
    C1922 VAPS Solenoid Actuator Output Circuit Open
    C1923 VAPS Solenoid Actuator Output Circuit Short To Battery
    C1924 VAPS Solenoid Actuator Output Circuit Short To Ground
    C1925 VAPS Solenoid Actuator Return Circuit Failure
    C1926 VAPS Solenoid Actuator Return Circuit Open
    C1927 VAPS Solenoid Actuator Return Circuit Short To Battery
    C1928 VAPS Solenoid Actuator Return Circuit Short To Ground
    C1929 Air Suspension Front Compressor Relay Circuit Failure
    C1930 Air Suspension Front Compressor Relay Circuit Open
    C1931 Air Suspension Front Compressor Relay Circuit Short To Battery
    C1932 Air Suspension Front Compressor Relay Circuit Short To Ground
    C1933 Solenoid Current Out Of Range
    C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure
    C1935 Chime Circuit Failure
    C1936 Hydraulic Pump Relay Circuit Failure
    C1937 Steering Wheel Angle Sensor Offset Failure
    C1938 Invalid Steering Wheel Angle Sensor ID
    C1939 Brake Pressure Switch Input Circuit Failure
    C1940 Brake Pressure Switch Mechanical Failure
    C1942 Unrecognized Powertrain Configuration
    C1943 Airbag Deployment Indication Input Fault
    C1944 Gauge Driver Circuit Fault
    C1945 Park Switch Indicates Park with Vehicle Moving
    C1946 Seat Track Position Switch Circuit Open
    C1947 Seat Track Position Switch Circuit Short to Ground
    C1948 Seat Track Position Switch Circuit Resistance Out of Range
    C1949 Accelerometer Sensor Circuit Open
    C1950 Accelerometer Sensor Circuit Failure
    C1951 Lateral Accelerometer Sensor Circuit Open
    C1952 Yaw Rate Sensor Circuit Open
    C1953 Master Cylinder Pressure Sensor Circuit Open
    C1954 Master Cylinder Pressure Sensor Circuit Failure
    C1955 Steering Angle Sensor Circuit Open
    C1956 Steering Angle Sensor Circuit Failure
    C1957 Dynamic Stability Control Valve RF Circuit Failure
    C1958 Dynamic Stability Control Valve LF Circuit Failure
    C1959 Lateral Accelerometer Sensor Circuit Failure
    C1960 Driver Brake Apply Circuit Fault
    C1961 Park Lamp Relay Coil Circuit Failure
    C1962 Park Lamp Relay Coil Short to Battery
    C1963 Stability Control Inhibit Warning
    B1200 Climate Control Pushbutton Circuit Failure
    B1201 Fuel Sender Circuit Failure
    B1202 Fuel Sender Circuit Open
    B1203 Fuel Sender Circuit Short To Battery
    B1204 Fuel Sender Circuit Short To Ground
    B1205 EIC Switch-1 Assembly Circuit Failure
    B1206 EIC Switch-1 Assembly Circuit Open
    B1207 EIC Switch-1 Assembly Circuit Short To Battery
    B1208 EIC Switch-1 Assembly Circuit Short To Ground
    B1209 EIC Switch-2 Assembly Circuit Failure
    B1210 EIC Switch-2 Assembly Circuit Open
    B1211 EIC Switch-2 Assembly Circuit Short To Battery
    B1212 EIC Switch-2 Assembly Circuit Short To Ground
    B1213 Anti-Theft Number of Programmed Keys Is Below Minimum
    B1214 Running Board Lamp Circuit Failure
    B1215 Running Board Lamp Circuit Short to Battery
    B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground
    B1217 Horn Relay Coil Circuit Failure
    B1218 Horn Relay Coil Circuit Short to Vbatt
    B1219 Fuel Tank Pressure Sensor Circuit Failure
    B1220 Fuel Tank Pressure Sensor Circuit Open
    B1222 Fuel Temperature Sensor #1 Circuit Failure
    B1223 Fuel Temperature Sensor #1 Circuit Open
    B1224 Fuel Temperature Sensor #1 Circuit Short to Battery
    B1225 Fuel Temperature Sensor #1 Circuit Short to Ground
    B1226 Fuel Temperature Sensor #2 Circuit Failure
    B1227 Fuel Temperature Sensor #2 Circuit Open
    B1228 Fuel Temperature Sensor #2 Circuit Short to Battery
    B1229 Fuel Temperature Sensor #2 Circuit Short to Ground
    B1231 Longitudinal Acceleration Threshold Exceeded
    B1232 See Manufacturer
    B1233 Glass Break Sensor Failure
    B1234 Mirror Switch Invalid Code
    B1235 Window Feedback Failure
    B1236 Window Feedback Loss of Signal
    B1237 Window Feedback Out of Range
    B1238 Over Temperature Fault
    B1239 Air Flow Blend Door Driver Circuit Failure
    B1240 Wiper Washer Rear Pump Relay Circuit Failure
    B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery
    B1242 Air Flow Recirculation Door Driver Circuit Failure
    B1243 Express Window Down Switch Circuit Short to Battery
    B1244 Wiper Rear Motor Run Relay Circuit Failure
    B1245 Wiper Rear Motor Run Relay Circuit Short to Battery
    B1246 Dim Panel Potentiometer Switch Circuit Failure
    B1247 Panel Dim Switch Circuit Open
    B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground
    B1249 Blend Door Failure
    B1250 Air Temperature Internal Sensor Circuit Failure
    B1251 Air Temperature Internal Sensor Circuit Open
    B1252 Air Temperature Internal Sensor Circuit Short To Battery
    B1253 Air Temperature Internal Sensor Circuit Short To Ground
    B1254 Air Temperature External Sensor Circuit Failure
    B1255 Air Temperature External Sensor Circuit Open
    B1256 Air Temperature External Sensor Circuit Short To Battery
    B1257 Air Temperature External Sensor Circuit Short To Ground
    B1258 Solar Radiation Sensor Circuit Failure
    B1259 Solar Radiation Sensor Circuit Open
    B1260 Solar Radiation Sensor Circuit Short To Battery
    B1261 Solar Radiation Sensor Circuit Short To Ground
    B1262 Servo Motor Defrost Circuit Failure
    B1263 Servo Motor Vent Circuit Failure
    B1264 Servo Motor Foot Circuit Failure
    B1265 Servo Motor Coolair Bypass Circuit Failure
    B1266 Servo Motor Airintake Left Circuit Failure
    B1267 Servo Motor Airintake Right Circuit Failure
    B1268 Servo Motor Potentiometer Defrost Circuit Failure
    B1269 Servo Motor Potentiometer Defrost Circuit Open
    B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery
    B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground
    B1272 Servo Motor Potentiometer Vent Circuit Failure
    B1273 Servo Motor Potentiometer Vent Circuit Open
    B1274 Servo Motor Potentiometer Vent Circuit Short To Battery
    B1275 Servo Motor Potentiometer Vent Circuit Short To Ground
    B1276 Servo Motor Potentiometer Foot Circuit Failure
    B1277 Servo Motor Potentiometer Foot Circuit Open
    B1278 Servo Motor Potentiometer Foot Circuit Short To Battery
    B1279 Servo Motor Potentiometer Foot Circuit Short To Ground
    B1280 Servo Motor Potentiometer Coolair Circuit Failure
    B1281 Servo Motor Potentiometer Coolair Circuit Open
    B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery
    B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground
    B1284 Servo Motor Potentiometer Airintake Left Circuit Failure
    B1285 Servo Motor Potentiometer Airintake Left Circuit Open
    B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery
    B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground
    B1288 Servo Motor Potentiometer Airintake Right Circuit Failure
    B1289 Servo Motor Potentiometer Airintake Right Circuit Open
    B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery
    B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground
    B1292 Battery Power Relay Circuit Failure
    B1293 Battery Power Relay Circuit Open
    B1294 Battery Power Relay Circuit Short To Battery
    B1295 Battery Power Relay Circuit Short To Ground
    B1296 Power Supply Sensor Circuit Failure
    B1297 Power Supply Sensor Circuit Open
    B1298 Power Supply Sensor Circuit Short To Battery
    B1299 Power Supply Sensor Circuit Short To Ground
    B1300 Power Door Lock Circuit Failure
    B1301 Power Door Lock Circuit Open
    B1302 Accessory Delay Relay Coil Circuit Failure
    B1303 Accessory Delay Relay Coil Circuit Open
    B1304 Accessory Delay Relay Coil Circuit Short To Battery
    B1305 Accessory Delay Relay Coil Circuit Short To Ground
    B1306 Oil Level Switch Circuit Open
    B1307 Oil Level Switch Circuit Short To Battery
    B1308 Oil Level Switch Circuit Short To Ground
    B1309 Power Door Lock Circuit Short To Ground
    B1310 Power Door Unlock Circuit Failure
    B1311 Power Door Unlock Circuit Open
    B1312 Lamp Headlamp Input Circuit Short To Battery
    B1313 Battery Saver Relay Coil Circuit Failure
    B1314 Battery Saver Relay Coil Circuit Open
    B1315 Battery Saver Relay Coil Circuit Short To Battery
    B1316 Battery Saver Relay Coil Circuit Short To Ground
    B1317 Battery Voltage High
    B1318 Battery Voltage Low
    B1319 Driver Door Ajar Circuit Failure
    B1320 Driver Door Ajar Circuit Open
    B1321 Driver Door Ajar Circuit Short To Battery
    B1322 Driver Door Ajar Circuit Short To Ground
    B1323 Door Ajar Lamp Circuit Failure
    B1324 Door Ajar Lamp Circuit Open
    B1325 Door Ajar Lamp Circuit Short To Battery
    B1326 Door Ajar Lamp Circuit Short To Ground
    B1327 Passenger Door Ajar Circuit Failure
    B1328 Passenger Door Ajar Circuit Open
    B1329 Passenger Door Ajar Circuit Short To Battery
    B1330 Passenger Door Ajar Circuit Short To Ground
    B1331 Decklid Ajar Rear Door Circuit Failure
    B1332 Decklid Ajar Rear Door Circuit Open
    B1333 Decklid Ajar Rear Door Circuit Short To Battery
    B1334 Decklid Ajar Rear Door Circuit Short To Ground
    B1335 Door Ajar RR Circuit Failure
    B1336 Door Ajar RR Circuit Open
    B1337 Door Ajar RR Circuit Short To Battery
    B1338 Door Ajar RR Circuit Short To Ground
    B1339 Chime Input Request Circuit Short To Battery
    B1340 Chime Input Request Circuit Short To Ground
    B1341 Power Door Unlock Circuit Short To Ground
    B1342 ECU Is Defective
    B1343 Heated Backlite Input Circuit Failure
    B1344 Heated Backlite Input Circuit Open
    B1345 Heated Backlite Input Circuit Short To Ground
    B1346 Heated Backlite Input Circuit Short To Battery
    B1347 Heated Backlite Relay Circuit Failure
    B1348 Heated Backlite Relay Circuit Open
    B1349 Heated Backlite Relay Short To Battery
    B1350 Heated Backlite Relay Short To Ground
    B1351 Ignition Key-In Circuit Short To Battery
    B1352 Ignition Key-In Circuit Failure
    B1353 Ignition Key-In Circuit Open
    B1354 Ignition Key-In Circuit Short To Ground
    B1355 Ignition Run Circuit Failure
    B1356 Ignition Run Circuit Open
    B1357 Ignition Run Circuit Short To Battery
    B1358 Ignition Run Circuit Short To Ground
    B1359 Ignition Run/Acc Circuit Failure
    B1360 Ignition Run/Acc Circuit Open
    B1361 Ignition Run/Acc Circuit Short To Battery
    B1362 Ignition Run/Acc Circuit Short To Ground
    B1363 Ignition Start Circuit Failure
    B1364 Ignition Start Circuit Open
    B1365 Ignition Start Circuit Short To Battery
    B1366 Ignition Start Circuit Short To Ground
    B1367 Ignition Tach Circuit Failure
    B1368 Ignition Tach Circuit Open
    B1369 Ignition Tach Circuit Short To Battery
    B1370 Ignition Tach Circuit Short To Ground
    B1371 Illuminated Entry Relay Circuit Failure
    B1372 Illuminated Entry Relay Circuit Open
    B1373 Illuminated Entry Relay Short To Battery
    B1374 Illuminated Entry Relay Short To Ground
    B1375 Oil Change Lamp Circuit Open
    B1376 Oil Change Lamp Circuit Short To Battery
    B1377 Oil Change Lamp Circuit Failure
    B1378 Oil Change Lamp Circuit Short To Ground
    B1379 Oil Change Reset Button Circuit Short To Ground
    B1380 Oil Change Reset Button Circuit Failure
    B1381 Oil Change Reset Button Circuit Open
    B1382 Oil Change Reset Button Circuit Short To Battery
    B1383 Oil Level Lamp Circuit Short To Battery
    B1384 Oil Level Lamp Circuit Failure
    B1385 Oil Level Lamp Circuit Open
    B1386 Oil Level Lamp Circuit Short To Ground
    B1387 Oil Temperature Sensor Circuit Open
    B1388 Oil Temperature Sensor Circuit Short To Battery
    B1389 Oil Temperature Sensor Circuit Failure
    B1390 Oil Temperature Sensor Circuit Short To Ground
    B1391 Oil Level Switch Circuit Failure
    B1392 Power Door Memory Lock Relay Circuit Failure
    B1393 Power Door Memory Lock Relay Circuit Open
    B1394 Power Door Memory Lock Relay Circuit Short To Battery
    B1395 Power Door Memory Lock Relay Circuit Short To Ground
    B1396 Power Door Lock Circuit Short To Battery
    B1397 Power Door Unlock Circuit Short To Battery
    B1398 Driver Power Window One Touch Window Relay Circuit Failure
    B1399 Driver Power Window One Touch Window Relay Circuit Open
    B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery
    B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground
    B1402 Driver Power Window Down Switch Circuit Failure
    B1403 Driver Power Window Up Switch Circuit Failure
    B1404 Driver Power Window Down Circuit Open
    B1405 Driver Power Window Down Circuit Short To Battery
    B1406 Driver Power Window Down Circuit Short To Ground
    B1407 Driver Power Window Up Circuit Open
    B1408 Driver Power Window Up Circuit Short To Battery
    B1409 Driver Power Window Up Circuit Short To Ground
    B1410 Driver Power Window Motor Circuit Failure
    B1411 Driver Power Window Motor Circuit Open
    B1412 Driver Power Window Motor Circuit Short To Battery
    B1413 Driver Power Window Motor Circuit Short To Ground
    B1414 Power Window LR Motor Circuit Failure
    B1415 Power Window LR Motor Circuit Open
    B1416 Power Window LR Motor Circuit Short To Battery
    B1417 Power Window LR Motor Circuit Short To Ground
    B1418 Passenger Power Window Motor Circuit Failure
    B1419 Passenger Power Window Motor Circuit Open
    B1420 Passenger Power Window Motor Circuit Short To Battery
    B1421 Passenger Power Window Motor Circuit Short To Ground
    B1422 Power Window RR Motor Circuit Failure
    B1423 Power Window RR Motor Circuit Open
    B1424 Power Window RR Motor Circuit Short To Battery
    B1425 Power Window RR Motor Circuit Short To Ground
    B1426 Lamp Seat Belt Circuit Short To Battery
    B1427 Lamp Seat Belt Circuit Open
    B1428 Lamp Seat Belt Circuit Failure
    B1429 Lamp Seat Belt Circuit Short To Ground
    B1430 Seat Belt Switch Circuit Short To Ground
    B1431 Wiper Brake/Run Relay Circuit Failure
    B1432 Wiper Brake/Run Relay Circuit Short To Battery
    B1433 Wiper Brake/Run Relay Circuit Short To Ground
    B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure
    B1435 Wiper Hi/Low Speed Relay Coil Circuit Open
    B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery
    B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground
    B1438 Wiper Mode Select Switch Circuit Failure
    B1439 Wiper Mode Select Switch Circuit Open
    B1440 Wiper Mode Select Switch Circuit Short To Battery
    B1441 Wiper Mode Select Switch Circuit Short To Ground
    B1442 Door Handle Switch Circuit Failure
    B1443 Door Handle Switch Circuit Open
    B1444 Door Handle Switch Circuit Short To Battery
    B1445 Door Handle Switch Circuit Short To Ground
    B1446 Wiper Park Sense Circuit Failure
    B1447 Wiper Park Sense Circuit Open
    B1448 Wiper Park Sense Circuit Short To Battery
    B1449 Wiper Park Sense Circuit Short To Ground
    B1450 Wiper Wash/Delay Switch Circuit Failure
    B1451 Wiper Wash/Delay Switch Circuit Open
    B1452 Wiper Wash/Delay Switch Circuit Short To Battery
    B1453 Wiper Wash/Delay Switch Circuit Short To Ground
    B1454 Wiper Washer Fluid Lamp Circuit Failure
    B1455 Wiper Washer Fluid Lamp Circuit Open
    B1456 Wiper Washer Fluid Lamp Circuit Short To Battery
    B1457 Wiper Washer Fluid Lamp Circuit Short To Ground
    B1458 Wiper Washer Pump Motor Relay Circuit Failure
    B1459 Wiper Washer Pump Motor Relay Coil Circuit Open
    B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery
    B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground
    B1462 Seat Belt Switch Circuit Failure
    B1463 Seat Belt Switch Circuit Open
    B1464 Seat Belt Switch Circuit Short To Battery
    B1465 Wiper Brake/Run Relay Circuit Open
    B1466 Wiper Hi/Low Speed Not Switching
    B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery
    B1468 Chime Input Request Circuit Failure
    B1469 Chime Input Request Circuit Open
    B1470 Lamp Headlamp Input Circuit Failure
    B1471 Lamp Headlamp Input Circuit Open
    B1472 Lamp Headlamp Input Circuit Short To Ground
    B1473 Wiper Low Speed Circuit Motor Failure
    B1474 Battery Saver Power Relay Circuit Short To Battery
    B1475 Accessory Delay Relay Contact Short To Battery
    B1476 Wiper High Speed Circuit Motor Failure
    B1477 Wiper Hi/Low Circuit Motor Short To Ground
    B1478 Power Window One Touch Up/Down Activated Simultaneously
    B1479 Wiper Washer Fluid Level Sensor Circuit Failure
    B1480 Wiper Washer Fluid Level Sensor Circuit Open
    B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery
    B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground
    B1483 Brake Pedal Input Circuit Failure
    B1484 Brake Pedal Input Open Circuit
    B1485 Brake Pedal Input Circuit Battery Short
    B1486 Brake Pedal Input Circuit Ground Short
    B1487 Door Handle Right Front Circuit Failure
    B1488 Door Handle Right Front Circuit Open
    B1489 Door Handle Right Front Short To Battery
    B1490 Door Handle Right Front Short To Ground
    B1491 Ignition Cylinder Sensor Circuit Failure
    B1492 Ignition Cylinder Sensor Open Circuit
    B1493 Ignition Cylinder Sensor Battery Short
    B1494 Ignition Cylinder Sensor Ground Short
    B1495 Decklid Punch-Out Sensor Circuit Failure
    B1496 Decklid Punch-Out Sensor Open Circuit
    B1497 Decklid Punch-Out Sensor Battery Short
    B1498 Decklid Punch-Out Sensor Ground Short
    B1499 Lamp Turn Signal Left Circuit Failure
    B1500 Lamp Turn Signal Left Circuit Open
    B1501 Lamp Turn Signal Left Circuit Short To Battery
    B1502 Lamp Turn Signal Left Circuit Short To Ground
    B1503 Lamp Turn Signal Right Circuit Failure
    B1504 Lamp Turn Signal Right Circuit Open
    B1505 Lamp Turn Signal Right Circuit Short To Battery
    B1506 Lamp Turn Signal Right Circuit Short To Ground
    B1507 Flash To Pass Switch Circuit Failure
    B1508 Flash To Pass Switch Circuit Open
    B1509 Flash To Pass Switch Circuit Short To Battery
    B1510 Flash To Pass Switch Circuit Short To Ground
    B1511 Driver Door Handle Circuit Failure
    B1512 Driver Door Handle Circuit Open
    B1513 Driver Door Handle Circuit Short To Battery
    B1514 Driver Door Handle Circuit Short To Ground
    B1515 Seat Driver Occupied Switch Circuit Failure
    B1516 Seat Driver Occupied Switch Circuit Open
    B1517 Seat Driver Occupied Switch Circuit Short To Battery
    B1518 Seat Driver Occupied Switch Circuit Short To Ground
    B1519 Hood Switch Circuit Failure
    B1520 Hood Switch Circuit Open
    B1521 Hood Switch Circuit Short To Battery
    B1522 Hood Switch Circuit Short To Ground
    B1523 Keyless Entry Circuit Failure
    B1524 Keyless Entry Circuit Open
    B1525 Keyless Entry Circuit Short To Battery
    B1526 Keyless Entry Circuit Short To Ground
    B1527 Memory Set Switch Circuit Failure
    B1528 Memory Set Switch Circuit Open
    B1529 Memory Set Switch Circuit Short To Battery
    B1530 Memory Set Switch Circuit Short To Ground
    B1531 Memory 1 Switch Circuit Failure
    B1532 Memory 1 Switch Circuit Open
    B1533 Memory 1 Switch Circuit Short To Battery
    B1534 Memory 1 Switch Circuit Short To Ground
    B1535 Memory 2 Switch Circuit Failure
    B1536 Memory 2 Switch Circuit Open
    B1537 Memory 2 Switch Circuit Short To Battery
    B1538 Memory 2 Switch Circuit Short To Ground
    B1539 Mirror Driver Switch Assembly Circuit Failure
    B1540 Mirror Driver Switch Assembly Circuit Open
    B1541 Mirror Driver Switch Assembly Circuit Short To Battery
    B1542 Mirror Driver Switch Assembly Circuit Short To Ground
    B1543 Seat Direction Switch Assembly Circuit Failure
    B1544 Seat Direction Switch Assembly Circuit Open
    B1545 Seat Direction Switch Assembly Circuit Short To Battery
    B1546 Seat Direction Switch Assembly Circuit Short To Ground
    B1547 Power Window Master Circuit Failure
    B1548 Power Window Master Circuit Open
    B1549 Power Window Master Circuit Short To Battery
    B1550 Power Window Master Circuit Short To Ground
    B1551 Decklid Release Circuit Failure
    B1552 Decklid Release Circuit Open
    B1553 Decklid Release Circuit Short To Battery
    B1554 Decklid Release Circuit Short To Ground
    B1555 Ignition Run/Start Circuit Failure
    B1556 Ignition Run/Start Circuit Open
    B1557 Ignition Run/Start Circuit Short To Battery
    B1558 Ignition Run/Start Circuit Short To Ground
    B1559 Door Lock Cylinder Circuit Failure
    B1560 Door Lock Cylinder Circuit Open
    B1561 Door Lock Cylinder Circuit Short To Battery
    B1562 Door Lock Cylinder Circuit Short To Ground
    B1563 Door Ajar Circuit Failure
    B1564 Door Ajar Circuit Open
    B1565 Door Ajar Circuit Short To Battery
    B1566 Door Ajar Circuit Short To Ground
    B1567 Lamp Headlamp High-Beam Circuit Failure
    B1568 Lamp Headlamp High-Beam Circuit Open
    B1569 Lamp Headlamp High-Beam Circuit Short To Battery
    B1570 Lamp Headlamp High-Beam Circuit Short To Ground
    B1571 Door Ajar LR Circuit Failure
    B1572 Door Ajar LR Circuit Open
    B1573 Door Ajar LR Circuit Short To Battery
    B1574 Door Ajar LR Circuit Short To Ground
    B1575 Lamp Park Input Circuit Failure
    B1576 Lamp Park Input Circuit Open
    B1577 Lamp Park Input Circuit Short To Battery
    B1578 Lamp Park Input Circuit Short To Ground
    B1579 Dim Panel Increase Input Circuit Failure
    B1580 Dim Panel Increase Input Circuit Open
    B1581 Dim Panel Increase Input Circuit Short To Battery
    B1582 Dim Panel Increase Input Circuit Short To Ground
    B1583 Dim Panel Decrease Input Circuit Failure
    B1584 Dim Panel Decrease Input Circuit Open
    B1585 Dim Panel Decrease Input Circuit Short To Battery
    B1586 Dim Panel Decrease Input Circuit Short To Ground
    B1587 Autolamp Delay Increase Circuit Failure
    B1588 Autolamp Delay Increase Circuit Open
    B1589 Autolamp Delay Increase Circuit Short To Battery
    B1590 Autolamp Delay Increase Circuit Short To Ground
    B1591 Autolamp Delay Decrease Circuit Failure
    B1592 Autolamp Delay Decrease Circuit Open
    B1593 Autolamp Delay Decrease Circuit Short To Battery
    B1594 Autolamp Delay Decrease Circuit Short To Ground
    B1595 Ignition Switch Illegal Input Code
    B1596 Service Continuous Codes
    B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground
    B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground
    B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground
    B1600 PATS Ignition Key Transponder Signal Is Not Received
    B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
    B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
    B1603 Lamp Anti-Theft Indicator Circuit Failure
    B1604 Lamp Anti-Theft Indicator Circuit Open
    B1605 Lamp Anti-Theft Indicator Circuit Short To Battery
    B1606 Lamp Anti-Theft Indicator Circuit Short To Ground
    B1607 Illuminated Entry Input Circuit Failure
    B1608 Illuminated Entry Input Open Circuit
    B1609 Illuminated Entry Input Short Circuit To Battery
    B1610 Illuminated Entry Input Short Circuit To Ground
    B1611 Wiper Rear Mode Select Switch Circuit Failure
    B1612 Wiper Rear Mode Select Switch Circuit Open
    B1613 Wiper Rear Mode Select Switch Circuit Short To Battery
    B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
    B1615 Wiper Rear Disable Switch Circuit Failure
    B1616 Wiper Rear Disable Switch Circuit Open
    B1617 Wiper Rear Disable Switch Circuit Short To Battery
    B1618 Wiper Rear Disable Switch Circuit Short To Ground
    B1619 Wiper Rear Low Limit Input Circuit Failure
    B1620 Wiper Rear Low Limit Input Circuit Open
    B1621 Wiper Rear Low Limit Input Circuit Short To Battery
    B1622 Wiper Rear Low Limit Input Circuit Short To Ground
    B1623 Lamp Keypad Output Circuit Failure
    B1624 Lamp Keypad Output Open Circuit
    B1625 Lamp Keypad Output Short Circuit To Battery
    B1626 Lamp Keypad Output Short Circuit To Ground
    B1627 PRNDL Reverse Input Circuit Failure
    B1628 PRNDL Reverse Input Open Circuit
    B1629 PRNDL Reverse Input Short To Battery
    B1630 PRNDL Reverse Input Short Circuit To Ground
    B1631 Mirror Driver Left Circuit Failure
    B1632 Mirror Driver Left Circuit Open
    B1633 Mirror Driver Left Circuit Short To Battery
    B1634 Mirror Driver Left Circuit Short To Ground
    B1635 Mirror Driver Right Circuit Failure
    B1636 Mirror Driver Right Circuit Open
    B1637 Mirror Driver Right Circuit Short To Battery
    B1638 Mirror Driver Right Short To Ground
    B1639 Mirror Passenger Left Circuit Failure
    B1640 Mirror Passenger Left Circuit Open
    B1641 Mirror Passenger Left Circuit Short To Battery
    B1642 Mirror Passenger Left Circuit Short To Ground
    B1643 Mirror Passenger Right Circuit Failure
    B1644 Mirror Passenger Right Circuit Open
    B1645 Mirror Passenger Right Circuit Short To Battery
    B1646 Mirror Passenger Right Circuit Short To Ground
    B1647 Seat Driver Recline Forward Circuit Failure
    B1648 Seat Driver Recline Forward Circuit Open
    B1649 Seat Driver Recline Forward Circuit Short To Battery
    B1650 Seat Driver Recline Forward Circuit Short To Ground
    B1651 Seat Driver Recline Backward Circuit Failure
    B1652 Seat Driver Recline Backward Circuit Open
    B1653 Seat Driver Recline Backward Circuit Short To Battery
    B1654 Seat Driver Recline Backward Circuit Short To Ground
    B1655 Seat Driver Rear Up Circuit Failure
    B1656 Seat Driver Rear Up Circuit Open
    B1657 Seat Driver Rear Up Circuit Short To Battery
    B1658 Seat Driver Rear Up Circuit Short To Ground
    B1659 Seat Driver Front Up Circuit Failure
    B1660 Seat Driver Front Up Circuit Open
    B1661 Seat Driver Front Up Circuit Short To Battery
    B1662 Seat Driver Front Up Circuit Short To Ground
    B1663 Seat Driver Front Up/Down Motor Stalled
    B1664 Seat Driver Rear Up/Down Motor Stalled
    B1665 Seat Driver Forward/Backward Motor Stalled
    B1666 Seat Driver Recline Motor Stalled
    B1667 Mirror Driver Up/Down Motor Stalled
    B1668 Mirror Driver Right/Left Motor Stalled
    B1669 Mirror Passenger Up/Down Motor Stalled
    B1670 Mirror Passenger Right/Left Motor Stalled
    B1671 Battery Module Voltage Out Of Range
    B1672 Seat Driver Occupied Input Circuit Failure
    B1673 Seat Driver Occupied Input Circuit Open
    B1674 Seat Driver Occupied Input Circuit Short To Battery
    B1675 Seat Driver Occupied Input Circuit Short To Ground
    B1676 Battery Pack Voltage Out Of Range
    B1677 Alarm Panic Input Circuit Failure
    B1678 Alarm Panic Input Circuit Open
    B1679 Alarm Panic Input Circuit Short To Battery
    B1680 Alarm Panic Input Circuit Short To Ground
    B1681 PATS Transceiver Module Signal Is Not Received
    B1682 PATS Is Disabled (Check Link Between PATS And Transponder)
    B1683 Mirror Driver/Passenger Switch Circuit Failure
    B1684 Mirror Driver/Passenger Switch Circuit Open
    B1685 Lamp Dome Input Circuit Failure
    B1686 Lamp Dome Input Circuit Open
    B1687 Lamp Dome Input Circuit Short To Battery
    B1688 Lamp Dome Input Circuit Short To Ground
    B1689 Autolamp Delay Circuit Failure
    B1690 Autolamp Delay Circuit Open
    B1691 Autolamp Delay Circuit Short To Battery
    B1692 Autolamp Delay Circuit Short To Ground
    B1693 Autolamp On Circuit Failure
    B1694 Autolamp On Circuit Open
    B1695 Autolamp On Circuit Short To Battery
    B1696 Autolamp On Circuit Short To Ground
    B1697 Mirror Driver/Passenger Switch Circuit Short To Battery
    B1698 Mirror Driver/Passenger Switch Circuit Short To Ground
    B1699 Passenger's Seat Occupied Switch Circuit Short to Ground
    B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
    B1701 Seat Driver Recline Forward Switch Circuit Failure
    B1702 Seat Driver Recline Forward Switch Circuit Open
    B1703 Seat Driver Recline Forward Switch Circuit Short To Battery
    B1704 Seat Driver Recline Forward Switch Circuit Short To Ground
    B1705 Seat Driver Recline Rearward Switch Circuit Failure
    B1706 Seat Driver Recline Rearward Switch Circuit Open
    B1707 Seat Driver Recline Rearward Switch Circuit Short To Battery
    B1708 Seat Driver Recline Rearward Switch Circuit Short To Ground
    B1709 Seat Driver Front Up Switch Circuit Failure
    B1710 Seat Driver Front Up Switch Circuit Open
    B1711 Seat Driver Front Up Switch Circuit Short To Battery
    B1712 Seat Driver Front Up Switch Circuit Short To Ground
    B1713 Seat Driver Front Down Switch Circuit Failure
    B1714 Seat Driver Front Down Switch Circuit Open
    B1715 Seat Driver Front Down Switch Circuit Short To Battery
    B1716 Seat Driver Front Down Switch Circuit Short To Ground
    B1717 Seat Driver Forward Switch Circuit Failure
    B1718 Seat Driver Forward Switch Circuit Open
    B1719 Seat Driver Forward Switch Circuit Short To Battery
    B1720 Seat Driver Forward Switch Circuit Short To Ground
    B1721 Seat Driver Rearward Switch Circuit Failure
    B1722 Seat Driver Rearward Switch Circuit Open
    B1723 Seat Driver Rearward Switch Circuit Short To Battery
    B1724 Seat Driver Rearward Switch Circuit Short To Ground
    B1725 Seat Driver Rear Up Switch Circuit Failure
    B1726 Seat Driver Rear Up Switch Circuit Open
    B1727 Seat Driver Rear Up Switch Circuit Short To Battery
    B1728 Seat Driver Rear Up Switch Circuit Short To Ground
    B1729 Seat Driver Rear Down Switch Circuit Failure
    B1730 Seat Driver Rear Down Switch Circuit Open
    B1731 Seat Driver Rear Down Switch Circuit Short To Battery
    B1732 Seat Driver Rear Down Switch Circuit Short To Ground
    B1733 Mirror Driver Vertical Switch Circuit Failure
    B1734 Mirror Driver Vertical Switch Circuit Open
    B1735 Mirror Driver Vertical Switch Circuit Short To Battery
    B1736 Mirror Driver Vertical Switch Circuit Short To Ground
    B1737 Mirror Driver Horizontal Switch Circuit Failure
    B1738 Mirror Driver Horizontal Switch Circuit Open
    B1739 Mirror Driver Horizontal Switch Circuit Short To Battery
    B1740 Mirror Driver Horizontal Switch Circuit Short To Ground
    B1741 Mirror Passenger Vertical Switch Circuit Failure
    B1742 Mirror Passenger Vertical Switch Circuit Open
    B1743 Mirror Passenger Vertical Switch Circuit Short To Battery
    B1744 Mirror Passenger Vertical Switch Circuit Short To Ground
    B1745 Mirror Passenger Horizontal Switch Circuit Failure
    B1746 Mirror Passenger Horizontal Switch Circuit Open
    B1747 Mirror Passenger Horizontal Switch Circuit Short To Battery
    B1748 Mirror Passenger Horizontal Switch Circuit Short To Ground
    B1749 Park/Neutral Switch Circuit Failure
    B1750 Park/Neutral Switch Circuit Open
    B1751 Park/Neutral Switch Circuit Short To Battery
    B1752 Park/Neutral Switch Circuit Short To Ground
    B1753 Hazard Flash Output Circuit Failure
    B1754 Hazard Flash Output Circuit Open
    B1755 Hazard Flash Output Circuit Short Battery
    B1756 Hazard Flash Output Circuit Short To Ground
    B1757 Seat Driver Rear Down Circuit Failure
    B1758 Seat Driver Rear Down Circuit Open
    B1759 Seat Driver Rear Down Circuit Short To Battery
    B1760 Seat Driver Rear Down Circuit Short To Ground
    B1761 Seat Driver Front Down Circuit Failure
    B1762 Seat Driver Front Down Circuit Open
    B1763 Seat Driver Front Down Circuit Short To Battery
    B1764 Seat Driver Front Down Circuit Short To Ground
    B1765 Seat Driver Forward Circuit Failure
    B1766 Seat Driver Forward Circuit Open
    B1767 Seat Driver Forward Circuit Short To Battery
    B1768 Seat Driver Forward Circuit Short To Ground
    B1769 Seat Driver Backward Circuit Failure
    B1770 Seat Driver Backward Circuit Open
    B1771 Seat Driver Backward Circuit Short To Battery
    B1772 Seat Driver Backward Circuit Short To Ground
    B1773 Mirror Driver Up Circuit Failure
    B1774 Mirror Driver Up Circuit Open
    B1775 Mirror Driver Up Circuit Short To Battery
    B1776 Mirror Driver Up Circuit Short To Ground
    B1777 Driver's Seatbelt Tension Reducer Circuit Short to Ground
    B1778 Mirror Driver Down Circuit Failure
    B1779 Mirror Driver Down Circuit Open
    B1780 Mirror Driver Down Circuit Short To Battery
    B1781 Mirror Driver Down Short To Ground
    B1782 Mirror Passenger Up Circuit Failure
    B1783 Mirror Passenger Up Circuit Open
    B1784 Mirror Passenger Up Circuit Short To Battery
    B1785 Mirror Passenger Up Circuit Short To Ground
    B1786 Mirror Passenger Down Circuit Failure
    B1787 Mirror Passenger Down Circuit Open
    B1788 Mirror Passenger Down Circuit Short To Battery
    B1789 Mirror Passenger Down Circuit Short To Ground
    B1790 Autolamp Sensor Input Circuit Failure
    B1791 Autolamp Sensor Input Circuit Open
    B1792 Autolamp Sensor Input Circuit Short To Battery
    B1793 Autolamp Sensor Input Circuit Short To Ground
    B1794 Lamp Headlamp Low-Beam Circuit Failure
    B1795 Lamp Headlamp Low-Beam Circuit Open
    B1796 Lamp Headlamp Low-Beam Circuit Short To Battery
    B1797 Lamp Headlamp Low-Beam Circuit Short To Ground
    B1798 Lamp Turn Signal Front Output Circuit Failure
    B1799 Lamp Turn Signal Front Output Circuit Open
    B1800 Lamp Turn Signal Front Output Circuit Short To Battery
    B1801 Lamp Turn Signal Front Output Circuit Short To Ground
    B1802 Lamp Turn Signal Rear Output Circuit Failure
    B1803 Lamp Turn Signal Rear Output Circuit Open
    B1804 Lamp Turn Signal Rear Output Circuit Short To Battery
    B1805 Lamp Turn Signal Rear Output Circuit Short To Ground
    B1806 Lamp Tail Output Circuit Failure
    B1807 Lamp Tail Output Circuit Open
    B1808 Lamp Tail Output Circuit Short To Battery
    B1809 Lamp Tail Output Circuit Short To Ground
    B1810 Lamp Backup Switch Input Circuit Failure
    B1811 Lamp Backup Switch Input Circuit Open
    B1812 Lamp Backup Switch Input Circuit Short To Battery
    B1813 Lamp Backup Switch Input Circuit Short To Ground
    B1814 Wiper Rear Motor Down Relay Coil Circuit Failure
    B1815 Wiper Rear Motor Down Relay Coil Circuit Open
    B1816 Wiper Rear Motor Down Relay Coil Circuit Short To Battery
    B1817 Wiper Rear Motor Down Relay Coil Circuit Short To Ground
    B1818 Wiper Rear Motor Up Relay Coil Circuit Failure
    B1819 Wiper Rear Motor Up Relay Coil Circuit Open
    B1820 Wiper Rear Motor Up Relay Coil Circuit Short To Battery
    B1821 Wiper Rear Motor Up Relay Coil Circuit Short To Ground
    B1822 Wiper Rear Park Sense Input Circuit Failure
    B1823 Wiper Rear Park Sense Input Circuit Open
    B1824 Wiper Rear Park Sense Input Circuit Short To Battery
    B1825 Wiper Rear Park Sense Input Circuit Short To Ground
    B1826 Wiper Rear High Limit Input Circuit Failure
    B1827 Wiper Rear High Limit Input Circuit Open
    B1828 Wiper Rear High Limit Input Circuit Short To Battery
    B1829 Wiper Rear High Limit Input Circuit Short To Ground
    B1830 Door Unlock Disarm Switch Circuit Failure
    B1831 Door Unlock Disarm Switch Circuit Open
    B1832 Door Unlock Disarm Switch Circuit Short To Battery
    B1833 Door Unlock Disarm Switch Circuit Short To Ground
    B1834 Door Unlock Disarm Output Circuit Failure
    B1835 Door Unlock Disarm Output Circuit Open
    B1836 Door Unlock Disarm Output Circuit Short To Battery
    B1837 Door Unlock Disarm Output Circuit Short To Ground
    B1838 Battery Saver Power Relay Circuit Failure
    B1839 Wiper Rear Motor Circuit Failure
    B1840 Wiper Front Power Circuit Failure
    B1841 Wiper Front Power Circuit Open
    B1842 Wiper Front Power Circuit Short To Battery
    B1843 Wiper Front Power Circuit Short To Ground
    B1844 Phone Handset Circuit Failure
    B1845 Ignition Tamper Circuit Failure
    B1846 Ignition Tamper Circuit Open
    B1847 Ignition Tamper Circuit Short To Battery
    B1848 Ignition Tamper Circuit Short To Ground
    B1849 Climate Control Temperature Differential Circuit Failure
    B1850 Climate Control Temperature Differential Circuit Open
    B1851 Climate Control Temperature Differential Circuit Short To Battery
    B1852 Climate Control Temperature Differential Circuit Short To Ground
    B1853 Climate Control Air Temperature Internal Sensor Motor Circuit Failure
    B1854 Climate Control Air Temperature Internal Sensor Motor Circuit Open
    B1855 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery
    B1856 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground
    B1857 Climate Control On/Off Switch Circuit Failure
    B1858 Climate Control A/C Pressure Switch Circuit Failure
    B1859 Climate Control A/C Pressure Switch Circuit Open
    B1860 Climate Control A/C Pressure Switch Circuit Short To Battery
    B1861 Climate Control A/C Pressure Switch Circuit Short To Ground
    B1862 Climate Control A/C Lock Sensor Failure
    B1863 Ground ECU Circuit Open
    B1864 Battery Power Supply ECU Circuit Failure
    B1865 Battery Power Supply ECU Circuit Open
    B1866 Battery Power Supply ECU Circuit Short To Battery
    B1867 Battery Power Supply ECU Circuit Short To Ground
    B1868 Lamp Air Bag Warning Indicator Circuit Failure
    B1869 Lamp Air Bag Warning Indicator Circuit Open
    B1870 Lamp Air Bag Warning Indicator Circuit Short To Battery
    B1871 Passenger Air Bag Disable Module Fault
    B1872 Turn Signal / Hazard Power Feed Circuit Short To Battery
    B1873 Turn Signal / Hazard Power Feed Circuit Short To Ground
    B1874 Cellular Phone Handset Not Present
    B1875 Turn Signal / Hazard Switch Signal Circuit Failure
    B1876 Seatbelt Driver Pretensioner Circuit Failure
    B1877 Seatbelt Driver Pretensioner Circuit Open
    B1878 Seatbelt Driver Pretensioner Circuit Short to Battery
    B1879 Seatbelt Driver Pretensioner Circuit Short to Ground
    B1880 Seatbelt Passenger Pretensioner Circuit Failure
    B1881 Seatbelt Passenger Pretensioner Circuit Open
    B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery
    B1883 Seatbelt Passenger Pretensioner Circuit Short to Ground
    B1884 PAD Warning Lamp Inoperative
    B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib
    B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib
    B1887 Air Bag Driver Circuit Resistance Low or Shorted Together
    B1888 Air Bag Passenger Circuit Resistance Low or Shorted Together
    B1889 Passenger Airbag Disable Module Sensor Obstructed
    B1890 PAD Warning Lamp Circuit Short to Battery
    B1891 Air Bag Tone Warning Indicator Circuit Short to Battery
    B1892 Air Bag Tone Warning Indicator Circuit Failure
    B1893 GPS Antenna Open Circuit
    B1894 Wiper Rear Motor Speed Sense Circuit Failure
    B1895 Driver's / Passenger's Door Ajar Output Circuit Failure
    B1896 Driver's / Passenger's Door Ajar Output Circuit Short to Battery
    B1897 Horn Switch Circuit Failure
    B1898 Chime Input #2 Circuit Short to Ground
    B1899 Microphone Input Signal Circuit Open
    B1900 Driver Side Airbag Fault
    B1901 Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground
    B1902 Air Bag Crash Sensor #1 Ground Circuit Failure
    B1903 Air Bag Crash Sensor #1 Ground Circuit Short To Battery
    B1904 Air Bag Crash Sensor #2 Feed/Return Circuit Failure
    B1905 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery
    B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground
    B1907 Air Bag Crash Sensor #2 Ground Circuit Failure
    B1908 Air Bag Crash Sensor #2 Ground Circuit Short To Battery
    B1909 Air Bag Crash Sensor #2 Ground Circuit Short To Ground
    B1910 Air Bag Diagnostic Monitor Ground Circuit Failure
    B1911 Air Bag Diagnostic Monitor Ground Circuit Short To Battery
    B1912 Air Bag Diagnostic Monitor Ground Circuit Short To Ground
    B1913 Air Bag Driver/Passenger Circuit Short To Ground
    B1914 Air Bag Crash Sensors #1 / #2 Circuit Short To Ground
    B1915 Air Bag Driver Circuit Failure
    B1916 Air Bag Driver Circuit Short To Battery
    B1917 Air Bag Memory Clear Circuit Failure
    B1918 Air Bag Memory Clear Circuit Open
    B1919 Air Bag Memory Clear Circuit Short To Battery
    B1920 Air Bag Passenger Circuit Failure
    B1921 Air Bag Diagnostic Monitor Ground Circuit Open
    B1922 Air Bag Safing Sensor Output Circuit Short To Battery
    B1923 Air Bag Memory Clear Circuit Short To Ground
    B1924 Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault
    B1925 Air Bag Passenger Circuit Short To Battery
    B1926 Air Bag Passenger Pressure Switch Circuit Failure
    B1927 Passenger Side Airbag Fault
    B1928 Air Bag Safing Sensor Output Circuit Failure
    B1929 Air Bag Safing Sensor Output Circuit Open
    B1930 Air Bag Safing Sensor Output Circuit Short To Ground
    B1931 Air Bag Crash Sensor #1 Feed/Return Circuit Failure
    B1932 Air Bag Driver Circuit Open
    B1933 Air Bag Passenger Circuit Open
    B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib
    B1935 Air Bag Passenger Inflator Circuit Resistance Low on Squib
    B1936 Air Bag Driver Circuit Short To Ground
    B1937 Air Bag Passenger Pressure Switch Circuit Open
    B1938 Air Bag Passenger Circuit Short To Ground
    B1939 Air Bag Passenger Pressure Switch Circuit Short To Ground
    B1941 Air Bag Crash Sensor #1 Feed/Return Circuit Open
    B1942 Air Bag Crash Sensor #2 Feed/Return Circuit Open
    B1943 Air Bag Crash Sensor #1 Ground Circuit Short To Ground
    B1944 Air Bag Crash Sensor #1 Ground Circuit Open
    B1945 Air Bag Crash Sensor #2 Ground Circuit Open
    B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure
    B1947 Climate Control A/C Post Evaporator Sensor Circuit Short To Ground
    B1948 Climate Control Water Temperature Sensor Circuit Failure
    B1949 Climate Control Water Temperature Sensor Circuit Short To Ground
    B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure
    B1951 Seat Rear Up/Down Potentiometer Feedback Circuit Open
    B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery
    B1953 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground
    B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure
    B1955 Seat Front Up/Down Potentiometer Feedback Circuit Open
    B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery
    B1957 Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground
    B1958 Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure
    B1959 Seat Recline Forward/Backward Potentiometer Feedback Circuit Open
    B1960 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery
    B1961 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground
    B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure
    B1963 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open
    B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery
    B1965 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground
    B1966 A/C Post Heater Sensor Circuit Failure
    B1967 A/C Post Heater Sensor Circuit Short To Ground
    B1968 A/C Water Pump Detection Circuit Failure
    B1969 A/C Clutch Magnetic Control Circuit Failure
    B1970 Passenger Seatback Forward Switch Circuit Short to Ground
    B1971 Passenger Seatback Rearward Switch Circuit Short to Ground
    B1972 Passenger Rear Seat Up Switch Circuit Short to Battery
    B1973 Passenger Rear Seat Down Switch Circuit Short to Battery
    B1974 Passenger's Seat Recline Forward Switch Circuit Short to Battery
    B1975 Passenger's Seat Recline Back Switch Circuit Short to Battery
    B1976 Passenger's Seat Forward Switch Circuit Short to Battery
    B1977 Passenger's Front Seat Up Switch Circuit Short to Battery
    B1978 Passenger's Front Seat Down Switch Circuit Short to Battery
    B1979 Passenger Seat Rearward Switch Circuit Short to Battery
    B1980 Bulb - Outage Condition Detected
    B1981 Memory Off Switch Circuit Short to Battery
    B1982 Driver's Door Unlock Relay Circuit Failure
    B1983 Driver's Door Unlock Relay Circuit Short to Battery
    B1984 Seat Switch Lumbar Inflate Circuit Failure
    B1985 Seat Switch Lumbar Deflate Circuit Failure
    B1986 Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure
    B1987 Pedal Forward / Rearward Motor Stalled
    B1988 Pedal Position Forward Switch Circuit Short to Battery
    B1989 Pedal Position Rearward Switch Circuit Short to Battery
    B1990 Pedal Forward / Rearward Potentiometer Feedback Circuit Failure
    B1991 Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery
    B1992 Driver Side, Side mount Airbag Circuit Short to Vbatt
    B1993 Driver Sid, Side mount Airbag Circuit Short to Ground
    B1994 Driver Sid, Side mount Airbag Circuit Open
    B1995 Driver Sid, Side mount Airbag Low resistance on Squib
    B1996 Passenger Sid, Side mount Airbag Circuit Short to Vbatt
    B1997 Passenger Sid, Side mount Airbag Circuit Short to Ground
    B1998 Passenger Sid, Side mount Airbag Circuit Open
    B1999 Passenger Sid, Side mount Airbag Low resistance on Squib
    B2100 Door Driver Key Cylinder Switch Failure
    B2101 Head Rest Switch Circuit Failure
    B2102 Antenna Circuit Short to Ground
    B2103 Antenna Not Connected
    B2104 Door Passenger Key Cylinder Switch Failure
    B2105 Throttle Position Input Out of Range Low
    B2106 Throttle Position Input Out of Range High
    B2107 Front Wiper Motor Relay Circuit Short to Vbatt
    B2108 Trunk Key Cylinder Switch Failure
    B2109 Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97)
    B2110 Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97)
    B2111 All Door Lock Input Short to Ground
    B2112 Door Driver Set Switch Stuck Failure
    B2113 Heated Windshield Input Short to Ground
    B2114 Front Washer Input Short to Ground
    B2115 Rear Washer Input Short to Ground
    B2116 Door Driver Reset Switch Stuck Failure
    B2117 Driver Side, Side mount Airbag Low capacitance on Squib
    B2118 Passenger Sid, Side mount Airbag Low capacitance on Squib
    B2119 Compressor Failure
    B2120 Door Passenger Set Switch Stuck Failure
    B2122 Driver Side Satellite Communication Circuit Short to Ground
    B2123 Passenger Side Satellite Communication Circuit Short to Ground
    B2124 Door Passenger Reset Switch Stuck Failure
    B2128 Central Lock Motor Failure
    B2129 Central Lock Feedback Failure
    B2130 Double Lock Timeout Failure
    B2131 Double Lock Feedback Failure
    B2132 Dimmer switch Circuit Short to Gnd
    B2133 Brake Motor Warning lamp Circuit Failure
    B2134 Brake Motor Warning lamp Circuit Short to Vbatt
    B2135 Park Brake Applied Warning Lamp Circuit Failure
    B2136 Park Brake Applied Warning Lamp Circuit Short To Battery
    B2139 Data Mismatch (receive data does not match what was expected)
    B2141 NVM Configuration Failure
    B2142 NVM TIC Failure
    B2143 NVM Memory Failure
    B2144 NVM Alarm Data Failure
    B2145 NVM RF HR Failure
    B2146 Seat Recline Motor Position Out of Range
    B2148 PWM Input Circuit Failure
    B2149 Seat Front Vertical Motor Position Out of Range
    B2150 Power Supply #1 Circuit Short to Ground
    B2151 Power Supply #2 Circuit Short to Ground
    B2152 Seat Rear Vertical Motor Position Out of Range
    B2153 Rear Echo Sensor Circuit Failure
    B2154 Front Echo Sensor Circuit Failure
    B2155 Seat Horizontal Motor Position Out of Range
    B2156 Rear Doppler Sensor Circuit Failure
    B2157 Front Doppler Sensor Circuit Failure
    B2158 Seat Recline Motor Memory Position Out of Range
    B2159 Memory #1 output Short to Ground
    B2160 Memory #1 output Short to VBatt
    B2161 Seat Front Vertical Motor Memory Position Out of Range
    B2162 Data Mismatch #2 (receive data does not match what was expected)
    B2163 Clutch Position Fault
    B2164 Seat Rear Vertical Motor Memory Position Out of Range
    B2165 Gear shift position Fault
    B2166 Gear select position Fault
    B2167 Seat Horizontal Motor Memory Position Out of Range
    B2168 Unable to confirm Unlock Condition
    B2169 Unable to confirm lock Condition
    B2170 Steering Column Lock Switch Circuit Failure
    B2172 Inertia Switch input Circuit Open
    B2174 Window Driver Rear Remote Up Switch Short to Battery
    B2175 A/C Request Signal Circuit Short to Ground
    B2176 Overdrive switch circuit short to Vbatt
    B2177 Interior Scanning Sensor Circuit Failure
    B2178 Window Driver Rear Remote Down Switch Short to Battery
    B2179 Front Wiper Select Switch "A" Short to Ground
    B2180 Front Wiper Select Switch "B" Short to Ground
    B2181 Front Wiper Select Switch "C" Short to Ground
    B2182 Window Passenger Front Remote Up Switch Short to Battery
    B2183 Front Wiper Select Switch "H" Short to Ground
    B2184 Front Wiper Select Switch "W" Short to Ground
    B2185 Rear Wiper Select Switch "D" Short to Ground
    B2186 Window Passenger Front Remote Down Switch Short to Battery
    B2187 Rear Wiper Select Switch "B" Short to Ground
    B2188 Rear Wiper Select Switch "E" Short to Ground
    B2190 Window Passenger Rear Remote Up Switch Short to Battery
    B2194 Window Passenger Rear Remote Down Switch Short to Battery
    B2195 Driver Window Up / Down Power Circuit Short to Ground
    B2196 Passenger Window Up / Down Power Circuit Short to Ground
    B2197 TV Module Error
    B2198 TrafficMaster Module Error
    B2199 VICS Module Error
    B2200 No Communication to TV Module (No Fitting of TV)
    B2201 No Communication With Traffic MasterModule
    B2202 No Communication to VICS Module (No Fitting of VICS)
    B2203 CD-ROM Error
    B2204 GPS Antenna Connection Open or Short
    B2205 GPS Receiver Error
    B2206 Gyroscope Error
    B2207 ECU ROM Checksum Error
    B2208 Communication Link to Display and Switch Module Error
    B2209 Interior Lamp Override Switch Open Circuit
    B2210 Interior Lamp Override Switch Short to Ground
    B2211 Low Coolant Lamp Output Circuit Short to Battery
    B2214 Window Passenger Front Up Switch Short to Battery
    B2215 Window Passenger Front Down Switch Short to Battery
    B2219 Window Driver Front Current Feedback Exceeded
    B2220 Window Driver Rear Current Feedback Exceeded
    B2221 Window Passenger Front Current Feedback Exceeded
    B2222 Window Passenger Rear Current Feedback Exceeded
    B2223 Mirror Driver Drive Circuit Failure
    B2224 Mirror Passenger Drive Circuit Failure
    B2225 Front Crash Sensor Mount Fault
    B2226 Front Crash Sensor Internal Fault
    B2227 Front Crash Sensor Driver Communications Fault
    B2228 Air Bag Driver Circuit Short to Ground - Loop #2
    B2229 Air Bag Passenger Circuit Short to Ground - Loop #2
    B2230 Air Bag Driver Circuit Short to Battery - Loop #2
    B2231 Air Bag Passenger Circuit Short to Battery - Loop #2
    B2232 Air Bag Driver Circuit Open - Loop #2
    B2233 Air Bag passenger Circuit Open - Loop #2
    B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2
    B2235 Air Bag Passenger Inflator Circuit
    B2236 Weak or Defected Electric Vehicle Battery Module Fault
    B2237 Vehicle Signal indicating Park While VSS Present
    B2238 Power Cable For Power Sliding Door Broken
    B2239 Rear Cargo Door Set Switch Stuck (Short to Ground)
    B2240 Rear Cargo Door Reset Switch Stuck (Short to Ground)
    B2241 Rear Cargo Door Lock Circuit Short to Ground
    B2242 Rear Cargo Door Unlock Circuit Open
    B2243 Driver Rear Door Ajar Circuit Open
    B2244 Driver Sliding Door Ajar Circuit Short to GND
    B2245 Passenger Rear Door Ajar Circuit Open
    B2246 Passenger Sliding Door Ajar Circuit Short to GND
    B2247 EV Battery Pack Temperature Fault
    B2248 Heated Windshield Relay Coil Circuit Failure
    B2249 Head Lamp Relay Coil Short to Battery
    B2250 All Doors Unlock Relay Circuit Failure
    B2251 Parklamp Output Relay Driver Circuit Failure
    B2252 Parklamp Output Relay Dirver Short to Battery
    B2300 Seat Driver Memory Position Error
    B2301 Seat Passenger Memory Position Error
    B2302 Seat Headrest Feedback Potentiometer Circuit Failure
    B2303 Seat Headrest Feedback Potentiometer Circuit Open
    B2304 Seat Headrest Feedback Potentiometer Circuit Short to Battery
    B2305 Seat Headrest Feedback Potentiometer Circuit Short to Ground
    B2306 Seat Headrest Motor Stalled
    B2310 Mirror Driver Memory Position Error
    B2311 Mirror Passenger Memory Position Error
    B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure
    B2313 Mirror Passenger Horizontal Feedback Potentiometer Circuit Open
    B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery
    B2315 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground
    B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
    B2317 Mirror Passenger Vertical Feedback Potentiometer Circuit Open
    B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery
    B2319 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground
    B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure
    B2321 Mirror Driver Horizontal Feedback Potentiometer Circuit Open
    B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery
    B2323 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground
    B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure
    B2325 Mirror Driver Vertical Feedback Potentiometer Circuit Open
    B2326 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery
    B2327 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground
    B2328 Column Reach Feedback Potentiometer Circuit Failure
    B2329 Column Reach Feedback Potentiometer Circuit Open
    B2330 Column Reach Feedback Potentiometer Circuit Short to Battery
    B2331 Column Reach Feedback Potentiometer Circuit Short to Ground
    B2332 Column Tilt Feedback Potentiometer Circuit Failure
    B2333 Column Tilt Feedback Potentiometer Circuit Open
    B2334 Column Tilt Feedback Potentiometer Circuit Short to Battery
    B2335 Column Tilt Feedback Potentiometer Circuit Short to Ground
    B2336 Mirror Switch Assembly Circuit Failure
    B2337 Mirror Switch Assembly Circuit Open
    B2338 Mirror Switch Assembly Circuit Short to Battery
    B2339 Mirror Switch Assembly Circuit Short to Ground
    B2340 Column Reach Motor Stalled
    B2341 Column Tilt Motor Stalled
    B2342 Seat Switch Reference Voltage Positive Common Open Circuit
    B2343 Seat Switch Reference Voltage Positive Common Supply Low Voltage
    B2344 Seat Switch Reference Voltage Positive Common Supply Voltage Fault
    B2345 Seat Switch Reference Voltage Negative Common Open Circuit
    B2346 Mirror Switch Reference Voltage Positive Common Open Circuit
    B2347 Mirror Switch Reference Voltage Positive Common Supply Low Voltage
    B2348 Mirror Switch Reference Voltage Positive Common Supply Voltage Fault
    B2349 Mirror Switch Reference Voltage Negative Common Open Circuit
    B2350 Steering Column Switch Circuit Short to Battery
    B2351 Steering Column Switch Circuit Failure
    B2352 Driver Memory Power Switch Indicator Circuit Short to Battery
    B2353 Driver Mirror Power Driver Circuit Short Ground
    B2354 Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
    B2355 Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
    B2357 Driver Window Down Current Sense Low Circuit Failure
    B2362 Remote Open/Close signal Circuit Short to Ground
    B2363 Optical Sensor System Failure
    B2364 Fuel Filler Door Circuit Open
    B2365 B-pillar Power Sliding Door Open/Close Switch Input Ckt Short to Gnd
    B2366 IP Power Sliding Door Open/Close switch Ckt Short to Gnd
    B2367 Power Sliding Door Override Switch Input Ckt Short to Gnd
    B2368 Steering Column Switch Circuit Out of Range
    B2369 Chime OUTPUT Request Ckt Short to Ground
    B2373 LED #1 Circuit Short to Battery
    B2374 Power Sliding Detent (Latch) Circuit Failure
    B2380 Heater Coolant Temp sensor circuit Short to GND
    B2381 Heater Coolant Temp sensor circuit Open
    B2384 Audio Reverse Aid Mute Input Ckt Failure
    B2385 Audio Navigation Mute Input Ckt Failure
    B2401 Audio Tape Deck Mechanism Fault
    B2402 Audio CD/DJ Thermal Shutdown Fault
    B2403 Audio CD/DJ Internal Fault
    B2404 Audio Steering Wheel Switch Circuit Fault
    B2405 Audio Single-Disc CD Player Thermal Shutdown Fault
    B2406 Audio Single-Disc CD Player Internal Fault
    B2416 Climate Control Recirculation Actuator Out of Limits
    B2425 Remote Keyless Entry Out of Synchronization
    B2426 Passenger Solar Radiation Sensor Circuit Open
    B2427 Passenger Solar Radiation Sensor Circuit Short to Ground
    B2428 A/C Post Heater Sensor #2 Circuit Failure
    B2429 A/C Post Heater Sensor #2 Circuit Short to Ground
    B2431 Transponder Programming Failed
    B2432 Drivers Seat Belt Buckle Switch Circuit Open
    B2433 Drivers Seat Belt Buckle Switch Circuit Short to Battery
    B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground
    B2435 Drivers Seat Belt Buckle Switch Resistance out of Range
    B2436 Passengers Seat Belt Buckle Switch Circuit Open
    B2437 Passengers Seat Belt Buckle Switch Circuit Short to Battery
    B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground
    B2439 Passengers Seat Belt Buckle Switch Resistance out of Range
    B2440 Passenger Sid, Side crash sensor mount fault
    B2441 Driver Sid, Side crash sensor mount fault
    B2442 Intrusion Sensor Fault
    B2443 Powertrain Performance Mode Switch Circuit failure
    B2444 Driver Side Crash Sensor Internal Fault
    B2445 Passenger Side Crash Sensor Internal Fault
    B2446 RESCU/VEMS Input Circuit Open
    B2447 RESCU/VEMS Input Circuit Short to Battery
    B2448 RESCU/VEMS Input Circuit Short to Ground
    B2449 Aux Heater Glow Plug Circuit Short to Ground
    B2450 Aux Heater Glow Plug Circuit Open
    B2451 Aux Heater Fuel Pump Circuit Short to Ground
    B2452 Aux Heater Fuel Pump Circuit Open
    B2453 Aux Heater Blower Fan Circuit Short to Ground
    B2454 Aux Heater Blower Fan Circuit Open
    B2455 Aux Heater Blower Faulted
    B2456 Aux Heater Coolant Sensor Circuit Short to Ground
    B2457 Aux Heater Coolant Sensor Circuit Open
    B2458 Aux Heater Overheat Sensor Circuit Short to Ground
    B2459 Aux Heater Overheat Sensor Circuit Open
    B2460 Aux Heater Flame Sensor Circuit Short to Ground
    B2461 Aux Heater Flame Sensor Circuit Open
    B2462 Aux Heater Flame Out Fault
    B2463 Aux Heater Overheat Fault
    B2464 Aux Heater Start Time Exceeded
    B2465 Aux Heater Start Counter Overrun/System Locked (same as below ?)
    B2466 Aux Heater Overheat Counter Overrun/System Locked
    B2467 Aux Heater Cool Down Time Exceeded (may be con to a453-5 )
    B2468 Aux Heater Coolant Pump Circuit Short to Ground
    B2469 Aux Heater Coolant Pump Circuit Open
    B2470 Interior Fan Control Circuit Short to Ground
    B2471 Interior Fan Control Circuit Open
    B2472 Fog Lamp Switch Failure
    B2473 Passenger Door Disarm Switch ckt Short to Ground
    B2474 Passenger Door Lock Switch Circuit Shorted to Ground
    B2475 Passenger Door Unlock Switch Circuit Shorted to Ground
    B2476 RADIO PRESENT SWITCH Ckt Failure
    B2477 Module Configuration Failure
    B2478 ANTI THEFT INPUT SIGNAL SHORT TO GROUND
    B2479 BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND
    B2480 LF CORNER LAMP OUTPUT Ckt Short to Battery
    B2481 Convertible Top Up/Down switch Fault
    B2482 RF CORNER LAMP OUTPUT Ckt Short to Battery
    B2483 Enable Signal Open Circuit
    B2484 Disable Signal Short to Ground
    B2485 LF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
    B2487 RF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
    B2489 UNDERHOOD LAMP OUTPUT CIRCUIT Failure
    B2490 UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery
    B2491 RF PARK LAMP OUTPUT CIRCUIT Short to Battery
    B2492 Already Programmed (Test Mode DTC Only !!!)
    B2493 LF PARK LAMP OUTPUT CIRCUIT Short to Battery
    B2494 ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt
    B2495 ANTI THEFT HORN OUTPUT CIRCUIT Failure
    B2496 ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd
    B2499 COURTESY LAMP OUTPUT Failure
    B2500 COURTESY LAMP OUTPUT Ckt Short to Battery
    B2501 LF LAMP LOW BEAM CIRCUIT Failure
    B2502 LF LAMP LOW BEAM CIRCUIT Short to Battery
    B2503 RF LAMP LOW BEAM CIRCUIT Failure
    B2504 RF LAMP LOW BEAM CIRCUIT Short to Battery
    B2505 LF LAMP HIGH BEAM CIRCUIT Failure
    B2506 LF LAMP HIGH BEAM CIRCUIT Short to Battery
    B2507 RF LAMP HIGH BEAM CIRCUIT Failure
    B2508 RF LAMP HIGH BEAM CIRCUIT Short to Battery
    B2509 Rear Fog Lamp Switch Circuit Failure
    B2510 Main Blower Motor Relay Circuit Short to Battery
    B2511 Horn Output Relay Circuit Short to Battery
    B2512 Front Fog Lamp Relay Ckt Short to Battery
    B2513 Blower (Fan) Circuit Failure
    B2514 Blower (Fan) Circuit Short to Vbatt
    B2515 Heater Blower Relay Circuit Failure
    B2516 Blower Control Circuit Failure
    B2517 Emergency Power Off System Faulted
    B2518 Compressor Overtemp Fault
    B2519 High Mount Stop Lamp Circuit Failure
    B2520 High Mount Stop Lamp Circuit Short to Battery
    B2523 License Lamp Circuit Failure
    B2524 License Lamp Circuit Short to Battery
    B2525 Left Rear Backup Lamp Circuit Failure
    B2526 Left Rear Backup Lamp Circuit Short to Battery
    B2527 Left Rear Stop lamp Circuit Failure
    B2528 Left Rear Stop lamp Circuit Short to Battery
    B2529 Left Rear Turn Lamp Circuit Failure
    B2530 Left Rear Turn Lamp Circuit Short to Battery
    B2531 Right Rear Backup Lamp Circuit Failure
    B2532 Right Rear Backup Lamp Circuit Short to Battery
    B2533 Right Rear Stop lamp Circuit Failure
    B2534 Right Rear Stop lamp Circuit Short to Battery
    B2535 Right Rear Turn Lamp Circuit Failure
    B2536 Right Rear Turn Lamp Circuit Short to Battery
    B2539 Aux A/C Mode Position Reference Circuit Short to Ground
    B2540 Aux A/C Mode Position Reference Circuit Short to Battery
    B2543 Aux A/C Control Switch Reference Circuit Short to Ground
    B2544 Aux A/C Control Switch Reference Circuit Short to Battery
    B2545 System Power Relay Circuit Short to Battery
    B2546 System Power Relay Circuit Failure
    B2550 LAMP DOME OUTPUT Circuit Short to Ground
    B2553 Disable Signal Output Circuit Short to Battery
    B2554 LAMP DOME OUTPUT Circuit Failure
    B2555 LAMP DOME OUTPUT Circuit Short to Battery
    B2556 Enable Signal Circuit Short to Battery
    B2557 Left Power Sliding Door Open/Close Output Circuit Short to Battery
    B2558 Right Power Sliding Door Open/Close Output Circuit Short to Battery
    B2559 Aux A/C Blower Motor Relay Circuit Short to Battery
    B2560 Aux A/C Blower Motor Relay Circuit Short to Ground
    B2561 Aux A/C Blower Speed 1 Circuit Failure
    B2562 Aux A/C Blower Speed 1 Circuit Short to Ground
    B2563 Aux A/C Blower Speed 2 Circuit Failure
    B2564 Aux A/C Blower Speed 2 Circuit Short to Ground
    B2565 Right Tail Lamp Circuit Failure
    B2566 Right Tail Lamp Circuit Short to Ground
    B2567 Reverse Mirror Output Circuit Failure
    B2568 Reverse Mirror Output Circuit Short to Ground
    B2569 Liftgate Disarm Switch Circuit Short to Ground
    B2570 Right Lamp Outage Signal Circuit Short to Ground
    B2571 Left Lamp Outage Signal Circuit Short to Ground
    B2580 Aux Blower Sense Switch Circuit Failure
    B2581 Passenger Seat Occupant Detection Circuit Short To Ground
    B2582 Passenger Seat Occupant Detection Circuit Open
    B2583 Child Seat Detection Circuit Short to Ground
    B2584 Child Seat Detection Circuit Open
    B2585 Anti Theft Input Signal Circuit Short To Battery
    B2586 Headlamp Mode Select Circuit Failure
    B2587 Passenger Seat Occupant Detection Circuit Short To Battery
    B2588 Child Seat Detection Circuit Short To Battery
    B2589 Unexpected Door Reversal During Close
    B2590 Vehicle Park/Speed Signal Circuit Failure
    B2591 Detent Signal Missing During Unlatch
    B2592 PSD Not Fully Closed (Module Commanded Successfully)
    B2593 Power Sliding Door Opened During Module Close Command
    B2594 No Movement Detected After an Unlatch During Power Open
    B2595 Anti Theft Input Signal Circuit Failure
    B2596 Headlamp Aim Output Relay Circuit Short To Battery
    B2597 Headlamp Aim Output Relay Circuit Failure
    B2598 Headlamp Relay Circuit Failure
    B2599 Tailgate Release Open Circuit
    B2600 Double Locking Door Motor Frozen
    B2601 No Latch Signal Sensed on Closing and Door Reversed
    B2602 Missing Latch Signal During Power Sliding Door Unlatch
    B2603 PSD Not Fully Closed During Self-Test
    B2604 Power Sliding Door On/Off Switch Open Circuit
    B2605 Disable Signal Open Circuit
    B2606 A/C Temperature Sensor Out of Range
    U1000 SCP (J1850) Invalid or Missing Data for Primary Id
    U1001 SCP (J1850) Invalid or Missing Data for Primary Id
    U1002 SCP (J1850) Invalid or Missing Data for Primary Id
    U1003 SCP (J1850) Invalid or Missing Data for Primary Id
    U1004 SCP (J1850) Invalid or Missing Data for EEC Programming
    U1005 SCP (J1850) Invalid or Missing Data for EEC Programming
    U1006 SCP (J1850) Invalid or Missing Data for Primary Id
    U1007 SCP (J1850) Invalid or Missing Data for Primary Id
    U1008 SCP (J1850) Invalid or Missing Data for Engine Torque
    U1009 SCP (J1850) Invalid or Missing Data for Engine Torque
    U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake
    U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake
    U1012 SCP (J1850) Invalid or Missing Data for Primary Id
    U1013 SCP (J1850) Invalid or Missing Data for Primary Id
    U1014 SCP (J1850) Invalid or Missing Data for Primary Id
    U1015 SCP (J1850) Invalid or Missing Data for Primary Id
    U1016 SCP (J1850) Invalid or Missing Data for Primary Id
    U1017 SCP (J1850) Invalid or Missing Data for Primary Id
    U1018 SCP (J1850) Invalid or Missing Data for Throttle
    U1019 SCP (J1850) Invalid or Missing Data for Throttle
    U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
    U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
    U1022 SCP (J1850) Invalid or Missing Data for Primary Id
    U1023 SCP (J1850) Invalid or Missing Data for Primary Id
    U1024 SCP (J1850) Invalid or Missing Data for Primary Id
    U1025 SCP (J1850) Invalid or Missing Data for Primary Id
    U1026 SCP (J1850) Invalid or Missing Data for Engine RPM
    U1027 SCP (J1850) Invalid or Missing Data for Engine RPM
    U1028 SCP (J1850) Invalid or Missing Data for Primary Id
    U1029 SCP (J1850) Invalid or Missing Data for Primary Id
    U1030 SCP (J1850) Invalid or Missing Data for Experimental #1
    U1031 SCP (J1850) Invalid or Missing Data for Experimental #1
    U1032 SCP (J1850) Invalid or Missing Data for Primary Id
    U1033 SCP (J1850) Invalid or Missing Data for Primary Id
    U1034 SCP (J1850) Invalid or Missing Data for Primary Id
    U1035 SCP (J1850) Invalid or Missing Data for Primary Id
    U1036 SCP (J1850) Invalid or Missing Data for Wheels
    U1037 SCP (J1850) Invalid or Missing Data for Wheels
    U1038 SCP (J1850) Invalid or Missing Data for Primary Id
    U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed
    U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed
    U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed
    U1042 SCP (J1850) Invalid or Missing Data for Traction Control
    U1043 SCP (J1850) Invalid or Missing Data for Traction Control
    U1044 SCP (J1850) Invalid or Missing Data for Traction Motor
    U1045 SCP (J1850) Invalid or Missing Data for Traction Motor
    U1046 SCP (J1850) Invalid or Missing Data for Primary Id
    U1047 SCP (J1850) Invalid or Missing Data for Primary Id
    U1048 SCP (J1850) Invalid or Missing Data for Primary Id
    U1049 SCP (J1850) Invalid or Missing Data for Primary Id
    U1050 SCP (J1850) Invalid or Missing Data for Brakes
    U1051 SCP (J1850) Invalid or Missing Data for Brakes
    U1052 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
    U1053 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
    U1054 SCP (J1850) Invalid or Missing Data for Primary Id
    U1055 SCP (J1850) Invalid or Missing Data for Primary Id
    U1056 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
    U1057 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
    U1058 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
    U1059 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
    U1060 SCP (J1850) Invalid or Missing Data for Primary Id
    U1061 SCP (J1850) Invalid or Missing Data for Primary Id
    U1062 SCP (J1850) Invalid or Missing Data for Primary Id
    U1063 SCP (J1850) Invalid or Missing Data for Primary Id
    U1064 SCP (J1850) Invalid or Missing Data for Primary Id
    U1065 SCP (J1850) Invalid or Missing Data for Primary Id
    U1066 SCP (J1850) Invalid or Missing Data for Primary Id
    U1067 SCP (J1850) Invalid or Missing Data for Primary Id
    U1068 SCP (J1850) Invalid or Missing Data for Primary Id
    U1069 SCP (J1850) Invalid or Missing Data for Primary Id
    U1070 SCP (J1850) Invalid or Missing Data for Engine Sensors
    U1071 SCP (J1850) Invalid or Missing Data for Engine Sensors
    U1072 SCP (J1850) Invalid or Missing Data for Engine Coolant
    U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant
    U1074 SCP (J1850) Invalid or Missing Data for Engine Oil
    U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temp
    U1076 SCP (J1850) Invalid or Missing Data for Primary Id
    U1077 SCP (J1850) Invalid or Missing Data for Primary Id
    U1078 SCP (J1850) Invalid or Missing Data for Primary Id
    U1079 SCP (J1850) Invalid or Missing Data for Primary Id
    U1080 SCP (J1850) Invalid or Missing Data for Primary Id
    U1081 SCP (J1850) Invalid or Missing Data for Primary Id
    U1082 SCP (J1850) Invalid or Missing Data for Engine Systems Other
    U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other
    U1084 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
    U1085 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
    U1086 SCP (J1850) Invalid or Missing Data for Primary Id
    U1087 SCP (J1850) Invalid or Missing Data for Primary Id
    U1088 SCP (J1850) Invalid or Missing Data for Suspension
    U1089 SCP (J1850) Invalid or Missing Data for Suspension
    U1090 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
    U1091 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
    U1092 SCP (J1850) Invalid or Missing Data for Primary Id
    U1093 SCP (J1850) Invalid or Missing Data for Primary Id
    U1094 SCP (J1850) Invalid or Missing Data for Experimental #2
    U1095 SCP (J1850) Invalid or Missing Data for Experimental #2
    U1096 SCP (J1850) Invalid or Missing Data for Primary Id
    U1097 SCP (J1850) Invalid or Missing Data for Primary Id
    U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
    U1099 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
    U1100 SCP (J1850) Invalid or Missing Data for Primary Id
    U1101 SCP (J1850) Invalid or Missing Data for Primary Id
    U1102 SCP (J1850) Invalid or Missing Data for Primary Id
    U1103 SCP (J1850) Invalid or Missing Data for Primary Id
    U1104 SCP (J1850) Invalid or Missing Data for Chassis Status Request
    U1105 SCP (J1850) Invalid or Missing Data for Chassis Status Request
    U1106 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
    U1107 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
    U1108 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
    U1109 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
    U1110 SCP (J1850) Invalid or Missing Data for Primary Id
    U1111 SCP (J1850) Invalid or Missing Data for Primary Id
    U1112 SCP (J1850) Invalid or Missing Data for Primary Id
    U1113 SCP (J1850) Invalid or Missing Data for Primary Id
    U1114 SCP (J1850) Invalid or Missing Data for Charging System
    U1115 SCP (J1850) Invalid or Missing Data for Charging System
    U1116 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
    U1117 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
    U1118 SCP (J1850) Invalid or Missing Data for Primary Id
    U1119 SCP (J1850) Invalid or Missing Data for Primary Id
    U1120 SCP (J1850) Invalid or Missing Data for Primary Id
    U1121 SCP (J1850) Invalid or Missing Data for Primary Id
    U1122 SCP (J1850) Invalid or Missing Data for Odometer
    U1123 SCP (J1850) Invalid or Missing Data for Odometer
    U1124 SCP (J1850) Invalid or Missing Data for Primary Id
    U1125 SCP (J1850) Invalid or Missing Data for Primary Id
    U1126 SCP (J1850) Invalid or Missing Data for Primary Id
    U1127 SCP (J1850) Invalid or Missing Data for Primary Id
    U1128 SCP (J1850) Invalid or Missing Data for Primary Id
    U1129 SCP (J1850) Invalid or Missing Data for Primary Id
    U1130 SCP (J1850) Invalid or Missing Data for Fuel System
    U1131 SCP (J1850) Invalid or Missing Data for Fuel System
    U1132 SCP (J1850) Invalid or Missing Data for Vehicle Motion
    U1133 SCP (J1850) Invalid or Missing Data for Vehicle Motion
    U1134 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
    U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
    U1136 SCP (J1850) Invalid or Missing Data for Telltales
    U1137 SCP (J1850) Invalid or Missing Data for Telltales
    U1138 SCP (J1850) Invalid or Missing Data for Primary Id
    U1139 SCP (J1850) Invalid or Missing Data for Primary Id
    U1140 SCP (J1850) Invalid or Missing Data for Gateway
    U1141 SCP (J1850) Invalid or Missing Data for Gateway
    U1142 SCP (J1850) Invalid or Missing Data for Primary Id
    U1143 SCP (J1850) Invalid or Missing Data for Primary Id
    U1144 SCP (J1850) Invalid or Missing Data for Primary Id
    U1145 SCP (J1850) Invalid or Missing Data for Primary Id
    U1146 SCP (J1850) Invalid or Missing Data for Vehicle Security
    U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security
    U1148 SCP (J1850) Invalid or Missing Data for Audio Control
    U1149 SCP (J1850) Invalid or Missing Data for Audio Control
    U1150 SCP (J1850) Invalid or Missing Data for Audible Warnings
    U1151 SCP (J1850) Invalid or Missing Data for Audible Warnings
    U1152 SCP (J1850) Invalid or Missing Data for Experimental #3
    U1153 SCP (J1850) Invalid or Missing Data for Experimental #3
    U1154 SCP (J1850) Invalid or Missing Data for Compact Disc
    U1155 SCP (J1850) Invalid or Missing Data for Compact Disc
    U1156 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
    U1157 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
    U1158 SCP (J1850) Invalid or Missing Data for Antenna
    U1159 SCP (J1850) Invalid or Missing Data for Antenna
    U1160 SCP (J1850) Invalid or Missing Data for Primary Id
    U1161 SCP (J1850) Invalid or Missing Data for Primary Id
    U1162 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
    U1163 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
    U1164 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
    U1165 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
    U1166 SCP (J1850) Invalid or Missing Data for Cassette Tape
    U1167 SCP (J1850) Invalid or Missing Data for Cassette Tape
    U1168 SCP (J1850) Invalid or Missing Data for Primary Id
    U1169 SCP (J1850) Invalid or Missing Data for Primary Id
    U1170 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
    U1171 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
    U1172 SCP (J1850) Invalid or Missing Data for Remote Button Control
    U1173 SCP (J1850) Invalid or Missing Data for Remote Button Control
    U1174 SCP (J1850) Invalid or Missing Data for Primary Id
    U1175 SCP (J1850) Invalid or Missing Data for Primary Id
    U1176 SCP (J1850) Invalid or Missing Data for Primary Id
    U1177 SCP (J1850) Invalid or Missing Data for Primary Id
    U1178 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
    U1179 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
    U1180 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
    U1181 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
    U1182 SCP (J1850) Invalid or Missing Data for Primary Id
    U1183 SCP (J1850) Invalid or Missing Data for Primary Id
    U1184 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
    U1185 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
    U1186 SCP (J1850) Invalid or Missing Data for Primary Id
    U1187 SCP (J1850) Invalid or Missing Data for Primary Id
    U1188 SCP (J1850) Invalid or Missing Data for Primary Id
    U1189 SCP (J1850) Invalid or Missing Data for Primary Id
    U1190 SCP (J1850) Invalid or Missing Data for Primary Id
    U1191 SCP (J1850) Invalid or Missing Data for Primary Id
    U1192 SCP (J1850) Invalid or Missing Data for Primary Id
    U1193 SCP (J1850) Invalid or Missing Data for Primary Id
    U1194 SCP (J1850) Invalid or Missing Data for Mirrors
    U1195 SCP (J1850) Invalid or Missing Data for Mirrors
    U1196 SCP (J1850) Invalid or Missing Data for Door Locks
    U1197 SCP (J1850) Invalid or Missing Data for Door Locks
    U1198 SCP (J1850) Invalid or Missing Data for External Access (Doors)
    U1199 SCP (J1850) Invalid or Missing Data for External Access (Doors)
    U1200 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
    U1201 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
    U1202 SCP (J1850) Invalid or Missing Data for Windows
    U1203 SCP (J1850) Invalid or Missing Data for Windows
    U1204 SCP (J1850) Invalid or Missing Data for Steering Column
    U1205 SCP (J1850) Invalid or Missing Data for Steering Column
    U1206 SCP (J1850) Invalid or Missing Data for Primary Id
    U1207 SCP (J1850) Invalid or Missing Data for Primary Id
    U1208 SCP (J1850) Invalid or Missing Data for Seat Switches
    U1209 SCP (J1850) Invalid or Missing Data for Seat Switches
    U1210 SCP (J1850) Invalid or Missing Data for Restraints
    U1211 SCP (J1850) Invalid or Missing Data for Restraints
    U1212 SCP (J1850) Invalid or Missing Data for Primary Id
    U1213 SCP (J1850) Invalid or Missing Data for Primary Id
    U1214 SCP (J1850) Invalid or Missing Data for Primary Id
    U1215 SCP (J1850) Invalid or Missing Data for Primary Id
    U1216 SCP (J1850) Invalid or Missing Data for External Lamp Outage
    U1217 SCP (J1850) Invalid or Missing Data for External Lamp Outage
    U1218 SCP (J1850) Invalid or Missing Data for External Lamps
    U1219 SCP (J1850) Invalid or Missing Data for External Lamps
    U1220 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
    U1221 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
    U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps
    U1223 SCP (J1850) Invalid or Missing Data for Interior Lamps
    U1224 SCP (J1850) Invalid or Missing Data for Primary Id
    U1225 SCP (J1850) Invalid or Missing Data for Primary Id
    U1226 SCP (J1850) Invalid or Missing Data for Body Status Request
    U1227 SCP (J1850) Invalid or Missing Data for Body Status Request
    U1228 SCP (J1850) Invalid or Missing Data for Tires
    U1229 SCP (J1850) Invalid or Missing Data for Tires
    U1230 SCP (J1850) Invalid or Missing Data for Electric Defrost
    U1231 SCP (J1850) Invalid or Missing Data for Electric Defrost
    U1232 SCP (J1850) Invalid or Missing Data for Navigation
    U1233 SCP (J1850) Invalid or Missing Data for Navigation
    U1234 SCP (J1850) Invalid or Missing Data for Displays
    U1235 SCP (J1850) Invalid or Missing Data for Displays
    U1236 SCP (J1850) Invalid or Missing Data for Memory Storage
    U1237 SCP (J1850) Invalid or Missing Data for Memory Storage
    U1238 SCP (J1850) Invalid or Missing Data for Experimental #4
    U1239 SCP (J1850) Invalid or Missing Data for Experimental #4
    U1240 SCP (J1850) Invalid or Missing Data for Primary Id
    U1241 SCP (J1850) Invalid or Missing Data for Primary Id
    U1242 SCP (J1850) Invalid or Missing Data for Exterior Environment
    U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment
    U1244 SCP (J1850) Invalid or Missing Data for Interior Environment
    U1245 SCP (J1850) Invalid or Missing Data for Interior Environment
    U1246 SCP (J1850) Invalid or Missing Data for Primary Id
    U1247 SCP (J1850) Invalid or Missing Data for Primary Id
    U1248 SCP (J1850) Invalid or Missing Data for Time / Date
    U1249 SCP (J1850) Invalid or Missing Data for Time / Date
    U1250 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
    U1251 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
    U1252 SCP (J1850) Invalid or Missing Data for Class A Functions
    U1253 SCP (J1850) Invalid or Missing Data for Class A Functions
    U1254 SCP (J1850) Invalid or Missing Data for Network Control
    U1255 SCP (J1850) Invalid or Missing Data for Network Control
    U1260 SCP (J1850) Single Ended (+) Circuit Failure
    U1261 SCP (J1850) Single Ended (-) Circuit Failure
    U1262 SCP (J1850) Communication Bus Fault
    U1308 SCP (J1850) Invalid or Missing Data for Function Read Engine Torque
    U1341 SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed
    U1430 SCP (J1850) Invalid or Missing Data for Function Read Fuel System
    U1451 SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings / Anti-Theft Module, Vehicle Immobilized
    U1612 SCP (J1850) Lack of Acknowledgment for Primary Id
    U1736 SCP (J1850) Lack of Acknowledgment for Telltales
    U1750 SCP (J1850) Lack of Acknowledgment for Audible Warnings
    U1794 SCP (J1850) Lack of Acknowledgment for Mirrors
    U1797 SCP (J1850) Lack of Acknowledgment for Door Locks
    U1798 SCP (J1850) Lack of Acknowledgment for External Access (Doors)
    U1806 SCP (J1850) Lack of Acknowledgment for Primary Id
    U1900 CAN Communication Bus Fault
    U1950 UPB Communication Bus Fault
    U2000 Audio Rear Control Unit is Not Responding
    U2001 Audio Tape Deck Unit is Not Responding
    U2002 Audio Bezel is Not Responding
    U2003 Audio Compact Disk / Disk Jockey Unit is Not Responding
    U2004 Audio Steering Wheel Control Unit is Not Responding
    U2005 Audio Rear Integrated Control Panel Unit is Not Responding
    U2006 Audio Remote Climate Control Unit is Not Responding
    U2007 Audio Navigation Unit is Not Responding
    U2008 Audio Phone is Not Responding
    U2009 Audio Front Control Module (ACM) is Not Responding
    U2010 Module is Not Responding (Non SCP)
    U2011 Module Transmitted Invalid Data (Non SCP)
    U2012 Communication Bus Error (Non SCP)
    U2013 Compass Module is not Responding
    U2014 Audio Subwoofer Unit is Not Responding
    U2015 Signal Link Fault (Non SCP)
    U2016 Signal Link Short to Ground (Non SCP) / From NGV Module
    U2017 Driver Side Crash Sensor Communication Fault (Non SCP)
    U2018 Passenger Side Crash Sensor Communication Fault (Non SCP)
    U2019 Audio Voice Module Not Responding
    U2020 Audio Center Amp is not responding
    U2021 Invalid /fault data received (Non SCP)
    U2150 SCP (J1850) Invalid Data from REM
    U2152 SCP (J1850) Invalid Data from GEM
    U2160 SCP (J1850) Invalid Data from IC
    U2195 SCP (J1850) Invalid Data from SCLM
    U2500 (CAN) Lack of Acknowledgement From Engine Management
    FORD
    P1000Monitor Checks Not Complete-More Driving Required
    P1001KOER Not Able to Complete, KOER Aborted
    P1100Mass Air Flow Sens Circ Interm.
    P1101Mass Air Flow Sens Out Of Self Test Range
    P1102Mass Air Flow Sens in Range / Lower Than Expected
    P1103Mass Air Flow Sens in Range / Higher Than Expected
    P1104Mass Air Flow Sens Circ Ground
    P1105Dual Alternator Upper Fault (Monitor)
    P1106Dual Alternator Lower Fault (Ctrl)
    P1107Dual Alternator Lower Circ Error (Ctrl)
    P1108Dual Alternator BATT Lamp Circ Error
    P1109Intake Air Temp B Circ Interm.
    P1110Intake Air Temp Circ (D/C) Open/Short
    P1111Sys Pass (No DTCs Available)
    P1112Intake Air Temp Circ Interm.
    P1113Intake Air Temp Circ (L/C) Open/Short
    P1114Intake Air Temp B Circ Low Input (S/T Charged Eng)
    P1115Intake Air Temp B Circ High Input (S/T Charged Eng)
    P1116Eng Coolant Temp Sens Out Of Self Test Range
    P1117Eng Coolant Temp Sens Circ Interm.
    P1118Manf Air Temp Sens Low Input
    P1119Manf Air Temp Sens High Input
    P1120Throttle Pos Sens A Out Of Range Low (Ratch low)
    P1121Throttle Pos Sens A Inconsistent With MAF Sens
    P1122Pedal Pos Sens A Circ Low Input
    P1123Pedal Pos Sens A Circ High Input
    P1124Throttle Pos Sens A Out Of Self Test Range
    P1125Throttle Pos Sens A Interm.
    P1126Throttle Pos (Narrow Range) Sens Circ
    P1127Exhaust Not Warm, Downstream O2 Sens Not Tested
    P1128Upstream HO2S Sens Swapped
    P1129Downstream HO2S Sens Swapped
    P1130Lack Of HO2S11 Switch - Fuel Trim At Limit
    P1131Lack Of HO2S11 Switch - Sens Indicates Lean
    P1132Lack Of HO2S11 Switch - Sens Indicates Rich
    P1133bank1 Fuel Ctrl Shifted Lean (FAOSC)
    P1134bank1 Fuel Ctrl Shifted Rich (FAOSC)
    P1135Pedal Position Sens A Circ Interm.
    P1136Ctrl Box Fan Circ
    P1137Lack Of HO2S12 Switch - Sens Indicates Lean
    P1138Lack Of HO2S12 Switch - Sens Indicates Rich
    P1139Water in Fuel Indicator Circ Error
    P1140Water in Fuel Condition
    P1141Fuel Restriction Indicator Circ
    P1142Fuel Restriction Condition
    P1143Air Assisted Injector Ctrl Valve Range/Perf
    P1144Air Assisted Injector Ctrl Valve Circ
    P1150Lack Of HO2S21 Switch - Fuel Trim At Limit
    P1151Lack Of HO2S21 Switch - Sens Indicates Lean
    P1152Lack Of HO2S21 Switch - Sens Indicates Rich
    P1153bank2 Fuel Ctrl Shifted Lean (FAOSC)
    P1154bank2 Fuel Ctrl Shifted Rich (FAOSC)
    P1155Alternative Fuel Ctrl Mod Has Activated the MIL
    P1156Fuel Select Switch Circ
    P1157Lack Of HO2S22 Switch - Sens Indicates Lean
    P1158Lack Of HO2S22 Switch - Sens Indicates Rich
    P1159Fuel Stepper Motor
    P1167Invalid Test - Operator Did Not Actuate Throttle
    P1168Fuel Rail Pres Sens In Range But Low
    P1169Fuel Rail Pres Sens In Range But High
    P1170Eng Shut Off Solenoid
    P1171Rotor Sens
    P1172Rotor Ctrl
    P1173Rotor Calibration
    P1174Cam Sens
    P1175Cam Ctrl
    P1176Cam Calibration
    P1177Synchronization
    P1178Boltup Limits
    P1179Long Term Fuel Trim Too Rich - Banks 1 & 2
    P1180Fuel Delivery System - Low
    P1181Fuel Delivery System - High
    P1182Fuel Shutoff Solenoid Circ
    P1183Eng Oil Temp Sens Circ
    P1184Eng Oil Temp Sens Circ Perf
    P1185Fuel Pump Temp Sens High
    P1186Fuel Pump Temp Sens Low
    P1187Variant Selection
    P1188Calibration Mem
    P1189Pump Speed Signal
    P1190Calibration Resistor Out Of Range
    P1191Key Line Voltage
    P1192V External
    P1193EGR Dvr Over Current
    P1194ECM/PCM A/D Converter
    P1195SCP HBCC Chip Failed to Initialize
    P1196Key Off Voltage High
    P1197Key Off Voltage Low
    P1198Pump Rotor Ctrl Under-fueling
    P1199Fuel Level Input Circ Low
    P1201Cylinder #1 Injector Circ Open/Shorted
    P1202Cylinder #2 Injector Circ Open/Shorted
    P1203Cylinder #3 Injector Circ Open/Shorted
    P1204Cylinder #4 Injector Circ Open/Shorted
    P1205Cylinder #5 Injector Circ Open/Shorted
    P1206Cylinder #6 Injector Circ Open/Shorted
    P1207Cylinder #7 Injector Circ Open/Shorted
    P1208Cylinder #8 Injector Circ Open/Shorted
    P1209Injection Ctrl System Pres Peak Fault
    P1210Injection Ctrl Pres Expected Level
    P1211ICP Not Ctrllable - Pres Above/Desired
    P1212ICP Voltage Not at Expected Level
    P1214Pedal Position Sens B Circ Interm.
    P1215Pedal Position Sens C Circ Low Input
    P1216Pedal Position Sens C Circ High Input
    P1217Pedal Position Sens C Circ Interm.
    P1218CID Stuck High
    P1219CID Stuck Low
    P1220Series Throttle Ctrl System
    P1221Traction Ctrl System
    P1222Pedal Position Sens B Circ Low Input
    P1223Pedal Position Sens B Circ High Input
    P1224Throttle Position Sens B Out Of Self Test Range
    P1225Injector Circ Cylinder 2 Interm.
    P1226Ctrl Sleeve Sens Circ
    P1227Wastegate Failed Closed (Over Pres)
    P1228Wastegate Failed Open (Under Pres)
    P1229Charge Air Cooler Pump Dvr
    P1230Fuel Pump Low Speed Error (VLCM)
    P1231Fuel Pump Sec Circ Low, High Speed (VLCM)
    P1232Fuel Pump Speed Primary Circ(Two speed fuel pump)
    P1233Fuel Pump Dvr Mod Disabled/Off Line
    P1234Fuel Pump Dvr Mod Disabled/Off Line
    P1235Fuel Pump Ctrl out Of Range
    P1236Fuel Pump Ctrl Out Of Range
    P1237Fuel Pump Sec Circ
    P1238Fuel Pump Sec Circ
    P1239Speed Fuel Pump Positive Feed
    P1240Injector Circ Cylinder 7 Interm.
    P1243Injector Circ Cylinder 8 Interm.
    P1244Alternator Load High Input
    P1245Alternator Load Low Input
    P1246Alternator Load Input
    P1247Turbo Boost Pres Low
    P1248Turbo Boost Pres Not Detected
    P1249Wastegate Fail Steady State Test
    P1250Electronic Passive Anti-Theft System
    P1252Pedal Correlation PDS1 and LPDS High
    P1253Pedal Correlation PDS1 and LPDS Low
    P1254Pedal Correlation PDS2 and LPDS High
    P1255Pedal Correlation PDS2 and LPDS Low
    P1256Pedal Correlation PDS1 and HPDS
    P1257Pedal Correlation PDS2 and HPDS
    P1258Pedal Correlation PDS1 and PDS2
    P1260Theft Detected, Vehicle Immobilized
    P1261High to Low Side Short - Cylinder 1
    P1262High to Low Side Short - Cylinder 2
    P1263High to Low Side Short - Cylinder 3
    P1264High to Low Side Short - Cylinder 4
    P1265High to Low Side Short - Cylinder 5
    P1266High to Low Side Short - Cylinder 6
    P1267High to Low Side Short - Cylinder 7
    P1268High to Low Side Short - Cylinder 8
    P1270Eng RPM/Vehicle Speed Limiter Reached
    P1271High to Low Side Open - Cylinder 1
    P1272High to Low Side Open - Cylinder 2
    P1273High to Low Side Open - Cylinder 3
    P1274High to Low Side Open - Cylinder 4
    P1275High to Low Side Open - Cylinder 5
    P1276High to Low Side Open - Cylinder 6
    P1277High to Low Side Open - Cylinder 7
    P1278High to Low Side Open - Cylinder 8
    P1280ICP Circ Out of Range Low
    P1281ICP Circ Out of Range High
    P1282Excessive ICP
    P1283Injector Pres Regulator Circ
    P1284ICP Failure - Aborts KOER/CCT Test
    P1285Cylinder Head Overtemp Condition
    P1286Fuel Pulsewidth in Range But Lower Than Expected
    P1287Fuel Pulsewidth in Range But Higher Than Expected
    P1288Cylinder Head Temp Sens Out Of Self Test Range
    P1289Cylinder Head Temp Sens Circ High Input
    P1290Cylinder Head Temp Sens Circ Low Input
    P1291High Side No. 1 (Right) Short to GND/B+
    P1292High Side No. 2 (Left) Short to GND/B+
    P1293High Side Open Bank No. 1 (Right)
    P1294High Side Open Bank No. 2 (Left)
    P1295Multiple Faults on Bank No. 1 (Right)
    P1296Multiple Faults on Bank No. 2 (Left)
    P1297High Sides Shorted Together
    P1298Injector Dvr Mod Failure
    P1299Cylinder Head Overtemp Protection Active
    P1300Boost Calibration Fault
    P1301Boost Calibration High
    P1302Boost Calibration Low
    P1303Exhaust Gas Recirculation Calibration Fault
    P1304Exhaust Gas Recirculation Calibration High
    P1305Exhaust Gas Recirculation Calibration Low
    P1306Kickdown Relay Pull-in Circ
    P1307Kickdown Relay Hold Circ
    P1309 Misfire Mon Hdwr-CMP Misaligned, CKP/CMP Noise,PCM AICE Chip
    P1310Ionization Misfire Detect Mod Fault
    P1311Ionization Misfire Detect Mod Comm Fault
    P1316Injector Circ/IDM Codes Detected
    P1317Injector Circ/IDM Codes Not Retrieved
    P1336Crankshaft Position System Variation Not Learned
    P1340Camshaft Position Sens B Circ
    P1350Ignition Ctrl System
    P1351Ignition Diag Monitor Input Circ
    P1352Ignition Coil A Primary Circ
    P1353Ignition Coil B Primary Circ
    P1354Ignition Coil C Primary Circ
    P1355Ignition Coil D Primary Circ
    P1356Ignition Diag Monitor Indicates Eng Not Turning
    P1357Ignition Diag Monitor Pulsewidth Not Defined
    P1358Ignition Diag Monitor Signal Out Of Self Test Range
    P1359Spark Output Circ
    P1360Ignition Coil A Sec Circ
    P1361Ignition Coil B Sec Circ
    P1362Ignition Coil C Sec Circ
    P1363Ignition Coil D Sec Circ
    P1364Ignition Coil Primary Circ
    P1365Ignition Coil Sec Circ
    P1366Ignition Spare
    P1367Ignition Spare
    P1368Ignition Spare
    P1369Eng Temp Light Circ
    P1380Camshaft Position Actuator Circ (bank1)
    P1381Camshaft Position Timing Over Advanced (bank1)
    P1383Camshaft Position Timing Over Retarded (bank1)
    P1385Camshaft Position Actuator Circ (bank2)
    P1386Camshaft Position Timing Over Advanced (bank2)
    P1388Camshaft Position Timing Over Retarded (bank2)
    P1389Glow Plug Circ High Side, Low Input
    P1390Octane Adjust Service Pin In Use/Circ Open
    P1391Glow Plug Circ Low Input Bank No. 1(Right)
    P1392Glow Plug Circ High Input (bank1)
    P1393Glow Plug Circ Low Input Bank No. 2 (Left)
    P1394Glow Plug Circ High Input (bank2)
    P1395Glow Plug Monitor Fault Bank No. 1
    P1396Glow Plug Monitor Fault Bank No. 2
    P1397System Voltage Out of Self Test Range
    P1398Wheel Speed Sens2 - G - Sens Circ High Voltage
    P1399Glow Plug Circ High Side, High Input
    P1400Diff Pres Feedback EGR Circ Low Input
    P1401Diff Pres Feedback EGR Circ High Input
    P1402Exhaust Gas Recirculation Metering Orifice Restricted
    P1403Diff Pres Feedback Sens Hoses Reversed
    P1404EGR Temp Sens Circ
    P1405Diff Pres Feedback Sens Upstream Hose Off/Plugged
    P1406Diff Pres Feedback Sens Downstream Hose Off/Plugged
    P1407Exhaust Gas Recirculation No Flow Detected
    P1408Exhaust Gas Recirculation Flow Out Of Self Test Range
    P1409EGR Vacuum Regulator Solenoid Circ
    P1410Auxiliary Air Cleaner Inlet Ctrl Circ
    P1411Sec Air Injection Incorrect Downstream Flow Detected
    P1413Sec Air Injection Monitor Circ Low Input
    P1414Sec Air Injection Monitor Circ High Input
    P1431Misfire Monitor Disabled, unable to learn trig whl profile
    P1442Evap Emission Ctrl System Ctrl Leak Detected
    P1443Evap Emission Ctrl System Ctrl Valve
    P1444Purge Flow Sens Circ Low Input
    P1445Purge Flow Sens Circ High Input
    P1450Unable to Bleed Up Fuel Tank Vacuum
    P1451Evap Emission Ctrl System Vent Ctrl Circ
    P1452Unable to Bleed Up Fuel Tank Vacuum
    P1455Evap Emission Ctrl Sys Ctrl Leak (gross leak/no flow)
    P1456Fuel Tank Temp Sens Circ
    P1457Unable To Pull Fuel Tank Vacuum
    P1460Wide Open Throttle A/C Cutout Circ
    P1461A/C Pres Sens Circ High Input
    P1462A/C Pres Sens Circ Low Input
    P1463A/C Pres Sens Insuff Pres Change
    P1464A/C On During KOER/CCT Test
    P1465A/C Relay Circ
    P1466A/C Refrigerant Temp Sens Circ
    P1469Rapid A/C Cycling
    P1473Fan Circ Open (VLCM
    P1474Fan Ctrl Primary Circ
    P1479High Fan Ctrl Primary Circ
    P1480Fan Sec Low with Low Fan On
    P1481Fan Sec Low with High Fan On
    P1482SCP
    P1483Fan Circ Shorted To Ground (VLCM)
    P1484Fan Dvr Circ Open To Power Ground (VLCM)
    P1485Brake Pedal Input Short To Battery
    P1500Vehicle Speed Sens
    P1501Vehicle Speed Sens Out Of Self Test Range
    P1502VSS Interm./Invalid Self Test - APCM Functioning
    P1504Idle Air Ctrl Circ
    P1505Idle Air Ctrl System At Adaptive Clip
    P1506Idle Air Ctrl Overspeed Error
    P1507Idle Air Ctrl Underspeed Error
    P1512Intake Manf Runner Ctrl Stuck Closed (bank1)
    P1513Intake Manf Runner Ctrl Stuck Closed (bank2)
    P1516Intake Manf Runner Ctrl Input Error (bank1)
    P1517Intake Manf Runner Ctrl Input Error (bank2)
    P1518Intake Manf Runner Ctrl Stuck Open (bank1)
    P1519Intake Manf Runner Ctrl Stuck Closed (bank2)
    P1520Intake Manf Runner Ctrl Circ
    P1530A/C Clutch Circ Open (VLCM)
    P1531Invalid Test -Accelerator Pedal Movement
    P1532Intake Manf Comm Ctrl Circ (bank2)P1533
    P1534Restraint Deployment Indicator Circ
    P1536Parking Brake Applied Failure
    P1537Intake Manf Runner Ctrl Stuck Open (bank1)
    P1538Intake Manf Runner Ctrl Stuck Open (bank2)
    P1539A/C Clutch Circ Overcurrent/Short (VLCM)
    P1542Primary PCM ID Circ (dual PCM application)
    P1543Eng Coolant heater A Ctrl Circ
    P1544Eng Coolant heater B Ctrl Circ
    P1549Intake Manf Comm Ctrl Circ (bank1)
    P1550Power Steering Pres Sens Out Of Self Test Range
    P1565Speed Ctrl Command Switch Out of Range High
    P1566Speed Ctrl Command Switch Out of Range Low
    P1567Speed Ctrl Output Circ
    P1568Speed Ctrl Unable to Hold Speed
    P1572Brake Pedal Switch Circ
    P1573Throttle Position Not Available
    P1574Throttle Position Sens Outputs Disagree
    P1575Pedal Position Out Of Self Test Range
    P1576Pedal Position Not Available
    P1577Pedal Position Sens Outputs Disagree
    P1578ETC Power Less Than Demand
    P1579ETC In Power Limiting Mode
    P1580Electronic Throttle Monitor PCM Override
    P1581Electronic Throttle Monitor Error
    P1582Electronic Throttle Monitor Data Available
    P1583Electronic Throttle Monitor Cruise Disablement
    P1584Throttle Ctrl Detected ETB Error
    P1585Throttle Ctrl Error
    P1586Electronic Throttle to PCM Comm Error
    P1587Throttle Ctrl Modulated Command Error
    P1588Throttle Ctrl Detected Loss Of Return Spring
    P1589Throttle Ctrl Unable To Ctrl To Desired Throttle Angle
    P1600Loss Of KAM Power, Circ Open
    P1605Keep Alive Memory Test Failure
    P1610SBDS Interactive Codes
    P1611SBDS Interactive Codes
    P1612SBDS Interactive Codes
    P1613SBDS Interactive Codes
    P1614SBDS Interactive Codes
    P1615SBDS Interactive Codes
    P1616SBDS Interactive Codes
    P1617SBDS Interactive Codes
    P1618SBDS Interactive Codes
    P1619SBDS Interactive Codes
    P1620SBDS Interactive Codes
    P1625Fan Dvr Circ Open to Power B+ (VLCM)
    P1626A/C Circ Open to Power B+ (VLCM)
    P1633Keep Alive Power Voltage Too Low
    P1634Data Output Link Circ
    P1635Tire/Axle Out of Acceptable Range
    P1636Inductive Signature Chip Comm Error
    P1639Vehicle ID Block Corrupted, Not Programmed
    P1640Powertrain DTCs Available In Another Ctrl Mod
    P1641Fuel Pump Primary Circ
    P1642CAN Link Circ
    P1643CAN Link Eng Ctrl Mod/Tran Ctrl Mod Circ/Network
    P1644Fuel Pump Speed Ctrl Circ
    P1650Power Steering Pres Switch Out Of Self Test Range
    P1651Power Steering Pres Switch Input
    P1656CAN Link PCM/PCM Circ/Network
    P1657CAN Link Chip Error
    P1660Output Circ Check Circ High Input
    P1661Output Circ Check Circ Low Input
    P1662EDU_EN Output Circ
    P1663Fuel Demand Command Signal Output Circ Failure
    P1667Cylinder ID Circ Failure
    P1668PCM/IDM Diagnostic Comm Error
    P1670EF Feedback Signal Not Detected
    P1690Wastegate Ctrl Valve Error
    P1700Tran Indeterminate Failure (Failed to Neutral)
    P1701Reverse Engagement Error
    P1702Tran Range Sens Interm. Circ Error
    P1703Brake Switch Out Of Self Test Range
    P1704Tran Range Sens Failed to Transition State or Tran Range Sens out of Self Test Range
    P1705Tran Range Circ Not Indicating P/N in Self test
    P1706High Vehicle Speed Observed in Park
    P1707Transfer Case Neutral Indicator Hard Fault Present
    P1709Park Neutral Position Switch Out Of Self Test Range
    P1711Tran Fluid Temp Sens Out Of Self Test Range
    P1712Tran Torque Reduction Request Signal
    P1713Tran Fluid Temp Sens In Range Failure(< 50 F)
    P1714Shift Solenoid A Inductive Signature
    P1715Shift Solenoid B Inductive Signature Error
    P1716Shift Solenoid C Inductive Signature
    P1717Shift Solenoid D Inductive Signature
    P1718TFT Stuck in Range High-25OF
    P1725Insuff Eng Speed Increase During Self Test
    P1726Insuff Eng Speed Decrease During Self Test
    P1727Coast Clutch Solenoid Inductive Signature
    P1728Tran Slip Error
    P17294x4L Switch Error
    P17311-2 Shift Error
    P17322-3 Shift Error
    P17333-4 Shift Error
    P1740Torque Converter Clutch Solenoid Inductive Signal
    P1741Torque Converter Clutch Solenoid Ctrl Error
    P1742Torque Converter Clutch Solenoid Circ Failed On
    P1743Torque Converter Clutch Solenoid Circ Failed On*
    P1744Torque Converter Clutch System Perf
    P1746EPC Solenoid Open Circ
    P1747EPC Solenoid Short Circ
    P1748Pres Ctrl Solenoid A
    P1749Pres Ctrl Solenoid A Failed Low
    P1751Shift Solenoid A Perf
    P1754Coast Clutch Solenoid Circ Error
    P1756Shift Solenoid B Perf
    P1760EPC Solenoid Short Interm.
    P1761Shift Solenoid C Perf
    P1762Overdrive Band Failed Off
    P1766Shift Solenoid D Perf
    P1767Torque Converter Clutch Circ
    P1768Perf/Normal/Winter Mode Input
    P1770Clutch Solenoid Circ
    P1779TCIL Circ
    P1780TCS Circ Out of self Test Range
    P17814x4L Circ Out of Self Test Range
    P1782Perf/Economy Switch Circ Out Of Self Test Range
    P1783Tran Overtemp Condition
    P1784Tran Mechanical Failure - 1st And Reverse
    P1785Tran Mechanical Failure - 1st And 2nd
    P17863-2 Downshift Error
    P17872-1 Downshift Error
    P1788Pres Ctrl Solenoid B Open Circ
    P1789Pres Ctrl Solenoid B Short Circ
    P1795Inconsistent CAN Level
    P18044WD High Indicator Circ Open/Shorted To Ground
    P18064WD High Indicator Short To Battery
    P18084WD Low Indicator Circ Open/Short To Ground
    P18104WD Low Indicator Short To Battery
    P18124WD Mode Select Switch Circ Open
    P18154WD Mode Select Switch Circ Short To Ground
    P1819Neutral Safety Switch Input Short To Ground
    P1820Transfer Case LO/HI Shift Relay Circ Open/Short To Gnd
    P1822Transfer Case LO/HI Shift Relay Coil Short To Battery
    P18244WD Electric Clutch Relay Open/Short To Ground
    P18264WD Electric Clutch Relay Short To Battery
    P1828Transfer Case HI/LO Shift Relay Coil Circ Open/Short to Gnd
    P1830Transfer Case HI/LO Shift Relay Coil Circ Short To Battery
    P1832Transfer Case 4WD Solenoid Circ Open/Short To Gnd
    P1834Transfer Case 4WD Solenoid Circ Short To Battery
    P1838No Shift Motor Movement Detected
    P1846Transfer Case Contact Plate 'A' Circ Open
    P1850Transfer Case Contact Plate 'B' Circ Open
    P1854Transfer Case Contact Plate 'C' Circ Open
    P1858Transfer Case Contact Plate 'D' Circ Open
    P1865Transfer Case Contact Plate Power Short to Ground
    P1866Transfer Case Cannot Be Shifted
    P1867Transfer Case Contact Plate General Circ Failure
    P1876Transfer Case 2WD Solenoid Circ Open/Short To Gnd
    P1877Transfer Case 2WD Solenoid Circ Short To Battery
    P1881Eng Coolant Level Switch Circ
    P1882Eng Coolant Level Switch Circ Short To Ground
    P1883Eng Coolant Level Switch Circ
    P1884Eng Coolant Level Lamp Circ Short To Ground
    P1891Transfer Case Contact Plate Gnd Return Open Circ
    P1900Output Shaft Speed Sens Circ Interm.
    P1901Turbine Shaft Speed Sens Circ Interm.
    P1902Kickdown Solenoid Relay Ctrl Circ (Allison)
    P1903Kickdown Solenoid Circ Low Voltage
    P1904Kickdown Solenoid Circ High Voltage
    U1058J1850 SCP Trans Fluid Temp Invalid ЁC Instr Clstr
    U1059J1850 SCP Trans/Transaxle PRNDL invalid-Instr Clstr
    U1073J1850 SCP Engine Coolent Invalid ЁC Instr Clstr
    U1262J1850 SCP Comm Bus Fault ЁC Instr Clstr
    U1950UBP Comm Bus Fault - DSM,or UBP Comm Bus Fault - VSM,or UBP Comm Bus Fault ЁC Instr Clstr
    Geo
    P1250Early fuel evaporation heater circuit fault
    P1300Ignition Coil 1 Primary Feedback Circuit
    P1305Ignition Coil 2 Primary Feedback Circuit
    P1310Ignition Coil 3 Primary Feedback Circuit
    P1315Ignition Coil 4 Primary Feedback Circuit
    P1335Crankshaft position sensor circuit
    P1346Intake Camshaft Position System Performance
    P1349Intake Camshaft Position System
    P1408MAP Sensor Circuit
    P1410Fuel tank pressure system fault
    P1450Barometric pressure sensor circuit fault
    P1451Barometric pressure sensor performance
    P1460Cooling fan control system fault
    P1500Starter signal circuit fault
    P1510Backup power supply fault
    P1520Stop Lamp Switch Circuit
    P1530Ignition timing adjustment switch circuit
    P1600PCM battery circuit fault
    P1656Intake CMP Actuator Solenoid Control Circuit
    GM
    P1031Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
    P1032Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
    P1101Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
    P1105Secondary Vacuum Sensor Circuit
    P1106Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
    P1107Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
    P1108BARO to MAP Sensor Comparison Too High
    P1109Secondary Port Throttle System
    P1111Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    P1112Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
    P1113Intake Resonance Switchover Solenoid Control Circuit
    P1114Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
    P1115Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
    P1116ECT Signal Unstable or Intermittent
    P1117Engine Coolant Temp. Signal Out-Of-Range Low
    P1118Engine Coolant Temp. Signal Out-Of-Range High
    P1119ECT Signal Out-Of-Range With TFT Sensor
    P1120Throttle Position (TP) Sensor 1 Circuit
    P1121Throttle Position (TP) Sensor Circuit Intermittent High Voltage
    P1122Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    P1125Accelerator Pedal Position (APP) System
    P1130Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
    P1131Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
    P1132Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
    P1133Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
    P1134Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
    P1135Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
    P1136Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
    P1137Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
    P1138Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
    P1139Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
    P1140Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
    P1141Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
    P1143Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
    P1144Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
    P1145Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
    P1153Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
    P1154Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
    P1155Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
    P1156Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
    P1157Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
    P1158Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
    P1159Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
    P1161Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2
    P1163Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage
    P1164Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage
    P1165Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3
    P1170Bank to Bank Fuel Trim Offset
    P1171Fuel System Lean During Acceleration
    P1172Fuel Transfer Pump Flow Insufficient
    P1185Engine Oil Temperature Circuit
    P1186EOT Circuit Performance
    P1187EOT Sensor Circuit Low Voltage
    P1188EOT Sensor Circuit High Voltage
    P1189Engine Oil Pressure (EOP) Switch Circuit
    P1190Engine Vacuum Leak
    P1191Intake Air Duct Air Leak
    P1200Injector Control Circuit
    P1201(Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
    P1202(Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
    P1203(Alt. Fuel) Gas Mass Sensor Circuit High Frequency
    P1211Mass Air Flow Circuit Intermittent High
    P1212Mass Air Flow Circuit Intermittent Low
    P1214Injection Pump Timing Offset
    P1215Ground Fault Detection Indicated
    P1216Fuel Solenoid Response Time Too Short
    P1217Fuel Solenoid Response Time Too Long
    P1218Injection Pump Calibration Circuit
    P1219Throttle Position Sensor Reference Voltage
    P1220Throttle Position (TP) Sensor 2 Circuit
    P1221Fuel Pump Secondary Circuit Low
    P1222Injector Control Circuit Intermittent
    P1225Injector Circuit Cylinder 2 Intermittent
    P1228Injector Circuit Cylinder 3 Intermittent
    P1231Injector Circuit Cylinder 4 Intermittent
    P1234Injector Circuit Cylinder 5 Intermittent
    P1237Injector Circuit Cylinder 6 Intermittent
    P1240Injector Circuit Cylinder 7 Intermittent
    P1243Injector Circuit Cylinder 8 Intermittent
    P1245Intake Plenum Switchover Valve
    P1250Early Fuel Evaporation Heater Circuit
    P1257Supercharger System Overboost
    P1258Engine Coolant Overtemperature - above 268ЎгF - Protection Mode Active
    P1260Last Test Failed Failed SCC ENTER:More Info.
    P1270Accelerator Pedal Position Sensor A/D Converter Error
    P1271Accelerator Pedal Position (APP) Sensor 1-2 Correlation
    P1272Accelerator Pedal Position Sensor 2
    P1273"Accelerator Pedal Position Sensor 1
    P1274Injectors Wired Incorrectly
    P1275Accelerator Pedal Position (APP) Sensor 1 Circuit
    P1276Accelerator Pedal Position Sensor 1 Circuit Performance
    P1277Accelerator Pedal Position Sensor 1 Circuit Low Voltage
    P1278Accelerator Pedal Position Sensor 1 Circuit High Voltage
    P1280Accelerator Pedal Position (APP) Sensor 2 Circuit
    P1281Accelerator Pedal Position Sensor 2 Circuit Performance
    P1282Accelerator Pedal Position Sensor 2 Circuit Low Voltage
    P1283Accelerator Pedal Position Sensor 2 Circuit High Voltage
    P1285Accelerator Pedal Position Sensor 3 Circuit
    P1286Accelerator Pedal Position Sensor 3 Circuit Performance
    P1287Accelerator Pedal Position Sensor 3 Circuit Low Voltage
    P1288Accelerator Pedal Position Sensor 3 Circuit High Voltage
    P1300Ignitor Circuit
    P1320IC 4X Reference Circuit Intermittent
    P1321Electronic Ignition System Fault Line
    P1322EI System or Ignition Control Extra or Missing
    P1323IC 24X Reference Circuit Low Frequency
    P1324Crank RPM Too Low
    P1335CKP Circuit
    P1336Crankshaft Position (CKP) System Variation Not Learned
    P1345Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
    P1346Intake Camshaft Position [CMP] Sensor System Performance
    P1350Ignition Control System
    P1351Ignition Coil Control Circuit High Voltage
    P1352IC Output High/Pulse Detected when GND_Cyl. 2
    P1353IC Output High/Pulse Detected when GND_Cyl. 3
    P1354IC Output High/Pulse Detected when GND_Cyl. 4
    P1355IC Output High/Pulse Detected when GND_Cyl. 5
    P1356IC Output High/Pulse Detected when GND_Cyl. 6
    P1357IC Output High/Pulse Detected when GND_Cyl. 7
    P1358IC Output High/Pulse Detected when GND_Cyl. 8
    P1359Ignition Coil Group 1 Control Circuit
    P1360Ignition Coil Group 2 Control Circuit
    P1361Ignition Coil Control Circuit Low Voltage
    P1362IC Cylinder 2 Not Toggling After Enable
    P1363IC Cylinder 3 Not Toggling After Enable
    P1364IC Cylinder 4 Not Toggling After Enable
    P1365IC Cylinder 5 Not Toggling After Enable
    P1366IC Cylinder 6 Not Toggling After Enable
    P1367IC Cylinder 7 Not Toggling After Enable
    P1368IC Cylinder 8 Not Toggling After Enable
    P1370IC 4X Reference Circuit Too Many Pulses
    P1371IC 4X Reference Circuit Too Few Pulses
    P1372Crankshaft Position (CKP) Sensor A-B Correlation
    P13743X Reference Circuit
    P1375IC 24X Reference Circuit High Voltage
    P1376Ignition Ground Circuit
    P1377IC Cam Pulse To 4X Reference Pulse
    P1380Misfire Detected - Rough Road Data Not Available
    P1381Misfire Detected - No Communication with Brake Control Module
    P1390Wheel Speed Sensor 1 - G - Sensor Circuit
    P1391Wheel Speed Sensor 1 - G - Sensor Circuit Performance
    P1392Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
    P1393Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
    P1394Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
    P1395Wheel Speed Sensor 2 - G - Sensor Circuit
    P1396Wheel Speed Sensor 2 - G - Sensor Circuit Performance
    P1397Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
    P1398Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
    P1399Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
    P1401Exhaust Gas Recirculation (EGR) flow test fault
    P1403Exhaust Gas Recirculation System Valve 1
    P1404Exhaust Gas Recirculation (EGR) Closed Position Performance
    P1405Exhaust Gas Recirculation System Valve 3
    P1406EGR Valve Pintle Position Circuit
    P1407EGR Air Intrusion in Exhaust Supply to EGR Valve
    P1408Intake Manifold Pressure Sensor Circuit
    P1409EGR Vacuum System Leak
    P1410Fuel Tank Pressure System
    P1415Secondary Air Injection (AIR) System Bank 1
    P1416Secondary Air Injection (AIR) System Bank 2
    P1418Secondary Air Injection System Relay A Control Circuit High
    P1420Intake Air Low Pressure Switch Circuit Low Voltage
    P1421Intake Air Low Pressure Switch Circuit High Voltage
    P1423Intake Air High Pressure Switch Circuit High Voltage
    P1431Fuel Level Sensor 2 Circuit Performance
    P1432Fuel Level Sensor 2 Circuit Low Voltage
    P1433Fuel Level Sensor 2 Circuit High Voltage
    P1441Evaporative Emission (EVAP) System Flow During Non-Purge
    P1442EVAP Vacuum Sw. High Voltage During Ign. On
    P1450Barometric Pressure Sensor Circuit
    P1451Barometric Press. Sensor Performance
    P1460Cooling Fan Control System
    P1480Cooling Fan 1 Control Circuit High
    P1481Cooling Fan Speed Sensor Circuit
    P1482Cooling Fan Speed Output Circuit
    P1483Engine Cooling System Performance
    P1484Cooling Fan System Performance
    P1500Starter Signal Circuit
    P1501Theft Deterrent System
    P1501Vehicle Speed Sensor Circuit Intermittent
    P1502Theft Deterrent Fuel Enable Signal Not Received
    P1503Theft Deterrent Fuel Enable Signal Not Correct
    P1504Vehicle Speed Output Circuit
    P1508Idle Speed Low - Idle Air Control (IAC) System Not Responding
    P1509Idle Speed High - Idle Air Control (IAC) System Not Responding
    P1510Throttle Control System Performance - Throttle Limitation Active
    P1511Throttle Control System - Backup System Performance
    P1514Airflow to TP Sensor Correlation High
    P1515Electronic Throttle System Throttle Position
    P1516Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
    P1517Electronic Throttle Module
    P1518Electronic Throttle Module to PCM Communication
    P1519Throttle Actuator Control (TAC) Module Internal Circuit
    P1520Transmission Range Switch Circuit
    P1521Transmission Engaged at High Throttle Angle
    P1522Park/Neutral to Drive/Reverse at High RPM
    P1523Throttle Closed Position Performance
    P1524Throttle Closed Position Performance
    P1525Throttle Body ServiceRequired
    P1526Minimum Throttle Position Not Learned
    P1527Transmission Range to Pressure Switch Correlation
    P1528Governor
    P1529Heated Windshield Request Problem
    P1530Throttle Actuator Control (TAC) Module Internal Circuit
    P1531A/C Low Side Temperature Sensor Fault
    P1532A/C Evaporator Temp. Sens. Circuit Low Voltage
    P1533A/C Evaporator Temp. Sens. Circuit High Voltage
    P1534A/C High Side Temp. Sensor Low Voltage
    P1535A/C High Side Temperature Sensor Circuit
    P1536Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
    P1537A/C Request Circuit Low Voltage
    P1538A/C Request Circuit High Voltage
    P1539A/C Clutch Status Circuit High Voltage
    P1540Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
    P1541A/C High Side Over Temperature
    P1542A/C System High Pressure High Temperature
    P1543A/C System Performance
    P1544A/C Refrigerant Condition Very Low
    P1545Air Conditioning (A/C) Clutch Relay Control Circuit
    P1546A/C Clutch Status Circuit Low Voltage
    P1547A/C System Performance Degraded
    P1548A/C Recirculation Circuit
    P1551Throttle Valve Rest Position Not Reached During Learn
    P1554Cruise Control Feedback Circuit
    P1555Electronic Variable Orifice Output
    P1558Cruise Control Servo Indicates Low
    P1559Cruise Control Power Management Mode
    P1560Transaxle Not in Drive - Cruise Control Disabled
    P1561Cruise Vent Solenoid
    P1562Cruise Vacuum Solenoid
    P1563Cruise Vehicle Speed/Set Speed Difference Too High
    P1564Vehicle Acceleration Too High - Cruise Control Disabled
    P1565Cruise Servo Position Sensor
    P1566Engine RPM Too High - Cruise Control Disabled
    P1567Active Banking Control Active - Cruise Control Disabled
    P1568Cruise Servo Stroke Greater than Commanded in Cruise
    P1569Cruise Servo Stroke High While not in Cruise
    P1570Traction Control Active - Cruise Control Disabled
    P1571Traction Control Torque Request Circuit
    P1572ASR Active Circuit Low Too Long
    P1573PCM/EBTCM Serial Data Circuit
    P1574Stoplamp Switch Circuit
    P1575Extended Travel Brake Switch Circuit
    P1576BBV Sensor Circuit High Voltage
    P1577BBV Sensor Circuit Low Voltage
    P1578BBV Sensor Circuit Low Vacuum
    P1579P/N to D/R at High Throttle Angle - Power Reduction Mode Active
    P1580Cruise Move Circuit Low Voltage
    P1581Cruise Move Circuit High Voltage
    P1582Cruise Direction Circuit Low Voltage
    P1583Cruise Direction CircuitHigh Voltage
    P1584Cruise Control Disabled
    P1585Cruise Control Inhibit Output Circuit
    P1586Cruise Control Brake Switch 2 Circuit
    P1587Cruise Control Clutch Control Circuit Low
    P1588Cruise Control Clutch Control Circuit High
    P1599Engine Stall or Near Stall Detected
    P1600TCM Internal Watchdog Operation
    P1601Serial Comm. Problem With Device 1
    P1602Knock Sensor (KS) Module Performance
    P1603Loss of SDM Serial Data
    P1604Loss of IPC Serial Data
    P1605Loss of HVAC Serial Data
    P1606Serial Communication Problem With Device 6
    P1607Serial Communication Problem With Device 7
    P1608Serial Communication Problem With Device 8
    P1609Loss Of TCS Serial Data
    P1610Loss Of PZM Serial Data
    P1611Loss Of CVRTD Serial Data
    P1612Loss Of IPM Serial Data
    P1613Loss Of DIM Serial Data
    P1614Loss Of RIM Serial Data
    P1615Loss Of VTD Serial Data
    P1617Engine Oil Level Switch Circuit
    P1619Engine Oil Life Monitor Reset Circuit
    P1620Low Coolant Circuit
    P1621Control Module Long Term Memory Performance
    P1622Cylinder Select
    P1623Transmission Temp Pull-Up Resistor
    P1624Customer Snapshot Requested - Data Available
    P1625TCM System Reset
    P1626Theft Deterrent Fuel Enable Signal Not Received
    P1627A/D Performance
    P1628ECT Pull-Up Resistor
    P1629Theft Deterrent System - Cranking Signal
    P1630Theft Deterrent Learn Mode Active
    P1631Theft Deterrent Start Enable Signal Not Correct
    P1632Theft Deterrent Fuel Disable Signal Received
    P1633Ignition 0 Switch Circuit
    P1634Ignition 1 Switch Circuit
    P16355 Volt Reference Circuit
    P1636PCM Stack Overrun
    P1637Generator L-Terminal Circuit
    P1638Generator F-Terminal Circuit
    P16395 Volt Reference 2 Circuit
    P1640Driver-1-Input High Voltage
    P1641Malfunction Indicator Lamp (MIL) Control Circuit
    P1642Vehicle Speed Output Circuit
    P1643Engine Speed Output Circuit
    P1644Traction Control Delivered Torque Output Circuit
    P1645Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
    P1646Evaporative Emission (EVAP) Vent Solenoid Control Circuit
    P1647Driver 1 Line 7
    P1650Control Module Output B Circuit
    P1651Fan 1 Relay Control Circuit
    P1652Powertrain Induced Chassis Pitch Output Circuit
    P1653Oil Level Lamp Control Circuit
    P1654Cruise Control Inhibit Output Circuit
    P1655EVAP Purge Solenoid Control Circuit
    P1656Driver 2 Line 6
    P16571-4 Upshift Solenoid Control Circuit
    P1658Starter Enable Relay Control Circuit
    P1660Cooling Fan Control Circuits
    P1661MIL Control Circuit
    P1662Cruise Lamp Control Circuit
    P1663Oil Life Lamp Control Circuit
    P16641-4 Upshift Lamp Control Circuit
    P1665Driver 3 Line 5
    P1666Driver 3 Line 6
    P1667Reverse Inhibit Solenoid Control Circuit
    P1669ABS Unit Expected
    P1670Driver 4
    P1671Driver 4 Line 1
    P1672Low Engine Oil Level Lamp Control Circuit
    P1673Engine Hot Lamp Control Circuit
    P1674Tachometer Control Circuit
    P1675EVAP Vent Solenoid Control Circuit
    P1676Driver 4 Line 6
    P1677Driver 4 Line 7
    P1680Driver 5 (ECU Malfunction)
    P1681Driver 5 Line 1
    P1682Driver 5 Line 2
    P1683Driver 5 Line 3
    P1684Driver 5 Line 4
    P1685Driver 5 Line 5
    P1686Driver 5 Line 6
    P1687Driver 5 Line 7
    P1689Delivered Torque Circuit Fault
    P1690ECM Loop Overrun
    P1691Coolant Gage Circuit Low Voltage
    P1692Coolant Gage Circuit High Voltage
    P1693Tachometer Circuit Low Voltage
    P1694Tachometer Circuit High Voltage
    P1695Remote Keyless Entry Circuit Low
    P1696Remote Keyless Entry Voltage High
    P1700Transmission Control Module (TCM) Requested MIL Illumination
    P1701Trans. MIL Request Circuit
    P1705P/N Signal Output Circuit
    P1719Incorrect Shifting Detected (TCM)
    P1740Torque Reduction Signal Circuit
    P1743TP Signal from ECM
    P1760TCM Supply Voltage Interrupted
    P1779Engine Torque Delivered to TCM Signal
    P1780Park/Neutral Position [PNP] Switch Circuit
    P1781Engine Torque Signal Circuit
    P1790Transmission Control Module Checksum
    P1791Transmission Control Module Loop
    P1791Throttle/Pedal Position Signal (2000+)
    P1792Transmission Control Module Reprogrammable Memory
    P1792ECM to TCM Engine Coolant Signal
    P1793Transmission Control Module Stack Overrun
    P1793Wheel Speed Signal (2000+)
    P1795CAN Bus - Throttle Body Position
    P1800TCM Power Relay Control Circuit
    P1801Performance Selector Switch Failure
    P1804Ground Control Relay
    P1810TFP Valve Position Switch Circuit
    P1811Maximum Adapt and Long Shift
    P1812Transmission Over Temperature Condition
    P1813Torque Control
    P1814Torque Converter Overstressed
    P1815Transmission Range Switch - Start In Wrong Range
    P1816TFP Valve Position Sw. - Park/Neu. With Drive Ratio
    P1817TFP Valve Position Sw. - Reverse With Drive Ratio
    P1818TFP Valve Position Sw. - Drive Without Drive Ratio
    P1819Internal Mode Switch - No Start\Wrong Range
    P1820Internal Mode Switch Circuit A Low
    P1822Internal Mode Switch Circuit B High
    P1823Internal Mode Switch Circuit P Low
    P1825Internal Mode Switch - Invalid Range
    P1826Internal Mode Switch Circuit C - High
    P1831Pressure Control (PC) Solenoid Power Circuit - Low Voltage
    P1832Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
    P1833A/T Solenoids Power Circuit - Low Voltage
    P1834Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
    P1835Kick-Down Switch Circuit
    P1836Kick-Down Switch Failed Open
    P1837Kick-Down Switch Failed Short
    P18421-2 Shift Solenoid Circuit Low Voltage
    P18431-2 Shift Solenoid Circuit High Voltage
    P1844Torque Reduction Signal Circuit Desired By TCM
    P18452-3 Shift Solenoid Circuit Low Voltage
    P18472-3 Shift Solenoid Circuit High Voltage
    P1850Brake Band Apply Solenoid Circuit
    P1851Brake Band Apply Solenoid Performance
    P1852Brake Band Apply SolenoidLow Voltage
    P1853Brake Band Apply Solenoid High Voltage
    P1860TCC PWM Solenoid Circuit Electrical
    P1864Torque Converter Clutch Circuit
    P18654-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
    P1866Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
    P1867Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
    P1868Transmission Fluid Life
    P1870Transmission Component Slipping
    P1871Undefined Gear Ratio
    P1873TCC Stator Temp. Switch Circuit Low
    P1874TCC Stator Temp. Switch Circuit High
    P18754WD Low Switch Circuit Electrical
    P1884TCC Enable/Shift Light Circuit
    P1886Shift Timing Solenoid
    P1887TCC Release Switch Circuit
    P1890ECM Data Input Circuit, or - Throttle Position Signal Input
    P1891Throttle Position Sensor PWM Signal Low
    P1892Throttle Position Sensor PWM Signal High
    P1893Engine Torque Signal Low Voltage
    P1894Engine Torque Signal High Voltage
    P1895TCM to ECM Torque Reduction Circuit
    U1000Class 2 Communication Malfunction
    U1001Loss of serial communications for class 2 devices
    U1002Loss of serial communications for class 2 devices
    U1003Loss of serial communications for class 2 devices
    U1004Loss of serial communications for class 2 devices
    U1005Loss of serial communications for class 2 devices
    U1006Loss of serial communications for class 2 devices
    U1007Loss of serial communications for class 2 devices
    U1008Loss of serial communications for class 2 devices
    U1009Loss of serial communications for class 2 devices
    U1010Loss of serial communications for class 2 devices
    U1011Loss of serial communications for class 2 devices
    U1012Loss of serial communications for class 2 devices
    U1013Loss of serial communications for class 2 devices
    U1014Loss of serial communications for class 2 devices
    U1015Loss of serial communications for class 2 devices
    U1016Loss of Class 2 Communication with VCM
    U1016Loss of Communications with PCM
    U1017Loss of serial communications for class 2 devices
    U1018Loss of serial communications for class 2 devices
    U1019Loss of serial communications for class 2 devices
    U1020Loss of serial communications for class 2 devices
    U1021Loss of serial communications for class 2 devices
    U1022Loss of serial communications for class 2 devices
    U1023Loss of serial communications for class 2 devices
    U1024Loss of serial communications for class 2 devices
    U1025Loss of serial communications for class 2 devices
    U1026Loss of ATC Class 2 Communication
    U1027Loss of Serial Communications for Class 2 Devices
    U1028Loss of Serial Communications for Class 2 Devices
    U1029Loss of Serial Communications for Class 2 Devices
    U1030Loss of Serial Communications for Class 2 Devices
    U1031Loss of Serial Communications for Class 2 Devices
    U1032Loss of Serial Communications for Class 2 Devices
    U1033Loss of Serial Communications for Class 2 Devices
    U1034Loss of Serial Communications for Class 2 Devices
    U1035Loss of Serial Communications for Class 2 Devices
    U1036Loss of Serial Communications for Class 2 Devices
    U1037Loss of Serial Communications for Class 2 Devices
    U1038Loss of Serial Communications for Class 2 Devices
    U1039Loss of Serial Communications for Class 2 Devices
    U1040Loss of Class 2 Communications with ABS
    U1041Loss of EBCM Communication
    U1042Lost Communications with Brake/Traction Control System
    U1043Loss of Serial Communications for Class 2 Devices
    U1044Loss of Serial Communications for Class 2 Devices
    U1045Loss of Serial Communications for Class 2 Devices
    U1046Loss of Serial Communications for Class 2 Devices
    U1047Loss of Serial Communications for Class 2 Devices
    U1048Loss of Serial Communications for Class 2 Devices
    U1049Loss of Serial Communications for Class 2 Devices
    U1050Loss of Serial Communications for Class 2 Devices
    U1051Loss of Serial Communications for Class 2 Devices
    U1052Loss of Serial Communications for Class 2 Devices
    U1053Loss of Serial Communications for Class 2 Devices
    U1054Loss of Serial Communications for Class 2 Devices
    U1055Loss of Serial Communications for Class 2 Devices
    U1056Loss of Communications with RSS
    U1057Loss of Serial Communications for Class 2 Devices
    U1058Loss of Serial Communications for Class 2 Devices
    U1059Loss of Serial Communications for Class 2 Devices
    U1060Loss of Serial Communications for Class 2 Devices
    U1062Loss of Serial Communications for Class 2 Devices
    U1064Loss Of Communications With DIM
    U1065Loss of Communications with IPM
    U1066Loss of Communications with RIM
    U1067Loss of Serial Communications for Class 2 Devices
    U1068Loss of Serial Communications for Class 2 Devices
    U1069Loss of Serial Communications for Class 2 Devices
    U1071Loss of Serial Communications for Class 2 Devices
    U1072Loss of Serial Communications for Class 2 Devices
    U1073Loss of Serial Communications for Class 2 Devices
    U1074Loss of Serial Communications for Class 2 Devices
    U1075Loss of Serial Communications for Class 2 Devices
    U1076Loss of Serial Communications for Class 2 Devices
    U1077Loss of Serial Communications for Class 2 Devices
    U1078Loss of Serial Communications for Class 2 Devices
    U1079Loss of Serial Communications for Class 2 Devices
    U1080Loss of Serial Communications for Class 2 Devices
    U1081Loss of Serial Communications for Class 2 Devices
    U1082Loss of Serial Communications for Class 2 Devices
    U1083Loss of Serial Communications for Class 2 Devices
    U1084Loss of Serial Communications for Class 2 Devices
    U1085Loss of Serial Communications for Class 2 Devices
    U1086Loss of Serial Communications for Class 2 Devices
    U1087Loss of Serial Communications for Class 2 Devices
    U1088Loss of Communications with SDM
    U1089Loss of Serial Communications for Class 2 Devices
    U1090Loss of Serial Communications for Class 2 Devices
    U1091Loss of Serial Communications for Class 2 Devices
    U1092Loss of Serial Communications for Class 2 Devices
    U1093Loss of Serial Communications for Class 2 Devices
    U1094Loss of Serial Communications for Class 2 Devices
    U1095Loss of Serial Communications for Class 2 Devices
    U1096Loss of Communications with IPC
    U1097Loss of serial communications for class 2 devices
    U1098Loss of serial communications for class 2 devices
    U1099Loss of serial communications for class 2 devices
    U1100Loss of serial communications for class 2 devices
    U1101Loss of serial communications for class 2 devices
    U1102Loss of serial communications for class 2 devices
    U1103Loss of serial communications for class 2 devices
    U1104Loss of serial communications for class 2 devices
    U1105Loss of serial communications for class 2 devices
    U1106Loss of serial communications for class 2 devices
    U1107Loss of serial communications for class 2 devices
    U1108Loss of serial communications for class 2 devices
    U1109Loss of serial communications for class 2 devices
    U1110Loss of serial communications for class 2 devices
    U1111Loss of serial communications for class 2 devices
    U1112Loss of serial communications for class 2 devices
    U1113Loss of serial communications for class 2 devices
    U1114Loss of serial communications for class 2 devices
    U1115Loss of serial communications for class 2 devices
    U1116Loss of serial communications for class 2 devices
    U1117Loss of serial communications for class 2 devices
    U1118Loss of serial communications for class 2 devices
    U1119Loss of serial communications for class 2 devices
    U1120Loss of serial communications for class 2 devices
    U1121Loss of serial communications for class 2 devices
    U1122Loss of serial communications for class 2 devices
    U1123Loss of serial communications for class 2 devices
    U1124Loss of serial communications for class 2 devices
    U1125Loss of serial communications for class 2 devices
    U1126Loss of serial communications for class 2 devices
    U1127Loss of serial communications for class 2 devices
    U1128Loss of Communications with IRC
    U1129Loss of Communications with AMP
    U1130Loss of serial communications for class 2 devices
    U1131Loss of serial communications for class 2 devices
    U1132Loss of serial communications for class 2 devices
    U1133Loss of serial communications for class 2 devices
    U1134Loss of serial communications for class 2 devices
    U1135Loss of serial communications for class 2 devices
    U1136Loss of serial communications for class 2 devices
    U1137Loss of serial communications for class 2 devices
    U1138Loss of serial communications for class 2 devices
    U1139Loss of serial communications for class 2 devices
    U1140Loss of serial communications for class 2 devices
    U1141Loss of serial communications for class 2 devices
    U1142Loss of serial communications for class 2 devices
    U1143Loss of serial communications for class 2 devices
    U1144Loss of Communications with PHN
    U1145Loss Of NAV Communications
    U1146Loss Of Onstar Communiction
    U1147Loss of serial communications for class 2 devices
    U1148Loss of serial communications for class 2 devices
    U1149Loss of serial communications for class 2 devices
    U1150Loss of serial communications for class 2 devices
    U1151Loss of serial communications for class 2 devices
    U1152Loss Of ACM Serial Data Communication
    U1152Loss of Data HCM
    U1153Loss of Communications with CCP
    U1154Loss of serial communications for class 2 devices
    U1155Loss of serial communications for class 2 devices
    U1156Loss of serial communications for class 2 devices
    U1157Loss of serial communications for class 2 devices
    U1158Loss of serial communications for class 2 devices
    U1159Loss of serial communications for class 2 devices
    U1160Loss of Communications with DDM
    U1161Loss of PDM Serial Data
    U1161Loss of PASS Door Module SBI
    U1162Loss of Rear Driver Door Module SBI
    U1163Loss of Rear PASS Door Module SBI
    U1163Loss of RRDM Serial Data
    U1164Loss Of DIM Serial Data Communication
    U1165Loss of serial communications for class 2 devices
    U1166Loss of Communications with SCM
    U1167Loss of serial communications for class 2 devices
    U1168Loss Of TTM Communications
    U1169Loss of Communications with MMM
    U1170Loss of Driver Door Switch Asm Serial Data
    U1170Loss of Driver Door Switch SBI
    U1171Loss of serial communications for class 2 devices
    U1172Loss of serial communications for class 2 devices
    U1173Loss of serial communications for class 2 devices
    U1174Loss of serial communications for class 2 devices
    U1175Loss of serial communications for class 2 devices
    U1176Loss Of RFA Communications
    U1177Loss of serial communications for class 2 devices
    U1178Loss of serial communications for class 2 devices
    U1179Loss of serial communications for class 2 devices
    U1180Loss of serial communications for class 2 devices
    U1181Loss of serial communications for class 2 devices
    U1182Loss of serial communications for class 2 devices
    U1183Loss of serial communications for class 2 devices
    U1184Loss of serial communications for class 2 devices
    U1185Loss of serial communications for class 2 devices
    U1186Loss of serial communications for class 2 devices
    U1187Loss of serial communications for class 2 devices
    U1188Loss of serial communications for class 2 devices
    U1189Loss of serial communications for class 2 devices
    U1190Loss of serial communications for class 2 devices
    U1191Loss of serial communications for class 2 devices
    U1192Loss of VTD Class 2 Serial Data Com
    U1193Loss of VIM Class 2 Communication
    U1194Loss of serial communications for class 2 devices
    U1195Loss of serial communications for class 2 devices
    U1196Loss of serial communications for class 2 devices
    U1197Loss of serial communications for class 2 devices
    U1198Loss of serial communications for class 2 devices
    U1199Loss of serial communications for class 2 devices
    U1200Loss of serial communications for class 2 devices
    U1201Loss of serial communications for class 2 devices
    U1202Loss of serial communications for class 2 devices
    U1203Loss of serial communications for class 2 devices
    U1204Loss of serial communications for class 2 devices
    U1205Loss of serial communications for class 2 devices
    U1206Loss of serial communications for class 2 devices
    U1207Loss of serial communications for class 2 devices
    U1208Loss of serial communications for class 2 devices
    U1209Loss of serial communications for class 2 devices
    U1210Loss of serial communications for class 2 devices
    U1211Loss of serial communications for class 2 devices
    U1212Loss of serial communications for class 2 devices
    U1213Loss of serial communications for class 2 devices
    U1214Loss of serial communications for class 2 devices
    U1215Loss of serial communications for class 2 devices
    U1216Loss of serial communications for class 2 devices
    U1217Loss of serial communications for class 2 devices
    U1218Loss of serial communications for class 2 devices
    U1219Loss of serial communications for class 2 devices
    U1220Loss of serial communications for class 2 devices
    U1221Loss of serial communications for class 2 devices
    U1222Loss of serial communications for class 2 devices
    U1223Loss of serial communications for class 2 devices
    U1224Loss of serial communications for class 2 devices
    U1225Loss of serial communications for class 2 devices
    U1226Loss of serial communications for class 2 devices
    U1227Loss of serial communications for class 2 devices
    U1228Loss of serial communications for class 2 devices
    U1229Loss of serial communications for class 2 devices
    U1230Loss of serial communications for class 2 devices
    U1231Loss of serial communications for class 2 devices
    U1232Loss of serial communications for class 2 devices
    U1233Loss of serial communications for class 2 devices
    U1234Loss of serial communications for class 2 devices
    U1235Loss of serial communications for class 2 devices
    U1236Loss of serial communications for class 2 devices
    U1237Loss of serial communications for class 2 devices
    U1238Loss of serial communications for class 2 devices
    U1239Loss of serial communications for class 2 devices
    U1240Loss of serial communications for class 2 devices
    U1241Loss of serial communications for class 2 devices
    U1242Loss of serial communications for class 2 devices
    U1243Loss of serial communications for class 2 devices
    U1244Loss of serial communications for class 2 devices
    U1245Loss of serial communications for class 2 devices
    U1246Loss of serial communications for class 2 devices
    U1247Loss of serial communications for class 2 devices
    U1248Loss of serial communications for class 2 devices
    U1249Loss of serial communications for class 2 devices
    U1250Loss of serial communications for class 2 devices
    U1251Loss of serial communications for class 2 devices
    U1252Loss of serial communications for class 2 devices
    U1253Loss of serial communications for class 2 devices
    U1254Loss of serial communications for class 2 devices
    U1255Class 2 Communication Malfunction (Serial Data Line Malfunction)
    U1300Class 2 Short to Ground
    U1301Class 2 Short to Battery
    U1304Loss Of UART Communications
    U1305Class 2 Data Link Low or High
    U1500Inter-Device Dedicated Bus Malfunction
    U1713Loss Of Front Door Module to Window Motor High Speed Comm.
    U1714Loss Of Front Door Module to Window Motor Normal Speed Comm.
    U1715Loss Of Front Door Module to Window Motor High Speed Comm.
    U1716Loss Of Front Door Module to Window Motor Normal Speed Comm.
    U1800Controller Area Network (CAN) Bus Communication
    HONDА
    P1020Valve Pause System Stuck Off
    P1021Valve Pause System Stuck On
    P1025Valve Pause System Sticking Off
    P1026Valve Pause System Sticking On
    P1077Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)
    P1078Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)
    P1106Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
    P1107Barometric Pressure (BARO) Sensor Circuit Low Voltage
    P1108Barometric Pressure (BARO) Sensor Circuit High Voltage
    P1121Throttle Position (TP) Sensor Lower Than Expected
    P1122Throttle Position (TP) Sensor Higher Than Expected
    P1128Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than Expected
    P1129Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected
    P1130Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)(Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)
    P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor 03-020 6 of 10,or Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean Range A/F sensor
    P1157Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High Voltage,or Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High Voltage,or Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1158Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
    P1159Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low Voltage
    P1162Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor
    P1163Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor,or Air/Fuel Ratio Sensor (Sensor 1) Slow Response A/F sensor
    P1164Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor,or Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/Performance A/F sensor
    P1165Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor,or Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/Performance A/F sensor
    P1166Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical Problem A/F sensor heater,or Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction (HO2S)
    P1167Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction A/F sensor heater,or Heated Oxygen Sensor Sensor1 (Primary LAF HO2S) Heater System Malfunction A/F sensor heater
    P1168Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low Voltage
    P1169Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL High Voltage
    P1182Fuel Temperature Sensor Circuit Low Voltage
    P1183Fuel Temperature Sensor Circuit High Voltage
    P1253VTEC System Circuit Fault
    P1259VTEC System Circuit Fault(Bank 1)
    P1297Electric Load Detector (ELD) Circuit Low Voltage
    P1298Electric Load Detector (ELD) Circuit High Voltage
    P1300Random Misfire Misfire
    P1324Knock Sensor Power Source Circuit Low Voltage
    P1336Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
    P1337Engine Speed (RPM) Fluctuation Sensor No Signal
    P1355Front Ignition Coil Power Circuit Malfunction
    P1359Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit Malfunction
    P1361Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption,or Top Dead Center (TDC) Sensor Intermittent Interruption
    P1362Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal,or Top Dead Center (TDC) Sensor No Signal
    P1366Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption,or Top Dead Center (TDC) Sensor 2 Intermittent Interruption
    P1367Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal,or Top Dear Center (TDC) Sensor 2 No Signal
    P1381Cylinder Position (CYP) Sensor Intermittent Interruption
    P1382Cylinder Position (CYP) Sensor No Signal
    P1410Air Pump Malfunction(Air system)
    P1415Air Pump Electric Current Sensor Circuit Low Voltage (Air system)
    P1416Air Pump Electric Current Sensor Circuit High Voltage (Air system)
    P1420Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter
    P1438Motor Drive Module (MDM) Overheating Signal Circuit,or Motor Drive Module (MDM) Overheating
    P1439Motor Drive Module (MDM) Short Circuit Sensor Problem,or Motor Drive Module (MDM) Short Circuit
    P1440IMA System Problem
    P1445Bypass Control Problem
    P1448Battery Module Overheating
    P1449Battery Module Overheating, or Battery Cell Overheating,or Battery Module Individual Voltage Input Deviation,or Battery Module Deterioration,or Battery Module Deviation
    P1454Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
    P1456Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System) EVAP
    P1457Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System) EVAP
    P1459Evaporative Emission (EVAP) Purge Flow Switch Malfunction
    P1486Cooling System Malfunction (Thermostat)
    P1491Exhaust Gas Recirculation (EGR) Valve Insufficient Lift EGR
    P1491Exhaust Gas Recirculation (EGR) Valve Insufficient Lift (EGR)
    P1498Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
    P1505Positive Crankcase Ventilation (PCV) Air Leakage
    P1508Idle Air Control Valve (IACV) Circuit Malfunction
    P1509Idle Air Control Valve (IACV) Circuit Failure
    P1519Idle Air Control Valve (IACV) Circuit Malfunction
    P1522Brake Booster Pressure Sensor Circuit Low Voltage
    P1523Brake Booster Pressure Sensor Circuit High Voltage
    P1524Brake Booster Pressure Sensor Range/Performance Problem
    P1541Climate Control Unit Signal Circuit Low Voltage
    P1542Climate Control Unit Signal Circuit High Voltage
    P1565Motor Commutation Signal Problem
    P1568Battery Module Individual Voltage Input Problem,or Battery Module Temperature Signal Circuit Problem,or Battery Cell Temperature Signal Circuit Problem
    P1572Motor Drive Module (MDM) Temperature Signal Circuit Low Input,or Motor Drive Module (MDM) Temperature Signal Circuit High Input
    P1576Motor Drive Module (MDM) Voltge Signal Circuit Low Input
    P1577High Voltage Detection Signal Circuit Problem
    P1580Battery Current Circuit Problem
    P1581Motor Power Inverter (MPI) Module Current Signal Circuit Low Input,or Motor Power Inverter (MPI) Module Current Signal Circuit High Input,or Motor Power Inverter (MPI) Module Current Signal Circuit Problem
    P1582Motor Current U Phase Signal Circuit Low Input,or Motor Current U Phase Signal Circuit High Input
    P1583Motor Current V Phase Signal Circuit Low Input,or Motor Current V Phase Signal Circuit High Input
    P1584Motor Current W Phase Signal Circuit Low Input,or Motor Current W Phase Signal Circuit High Input
    P1585Motor Current Signal Circuit Problem
    P1586Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit Problem
    P1607Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit Malfunction
    P1630Transmission Control Module
    P1635Battery Condition Monitor (BCM) Module Proble
    P1639MOTB Signal Circuit Malfunction
    P1640ACTTRQ Motor Torque Signal Circuit Low Input
    P1641ACTTRQ Motor Torque Signal Circuit High Input
    P1642QBATT Battery Signal Circuit Low Input
    P1643QBATT Battery Signal Circuit High Input
    P1644MOTFSA Signal Malfunction
    P1645MOTFSB Signal Malfunction
    P1646MOTSTB Signal Malfunction
    P1647Power Command Signal Circuit Low Input,or Power Command Signal Circuit High Input,or Engine Torque Signal Circuit Low Input,or Engine Torque Signal Circuit High Input,or Mode Signal Circuit 1 Low Input
    P1648Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem,or Motor Control Module (MCM) Communication Signal Circuit Problem
    P1655CVT-FI TMA/TMB Signal Line Failure
    P1656Problem in PCM-toVTM-4 Control Unit Communications Circuit
    P1660A/T-FI Data Line Failure/TCM - ECM Halt
    P1676FPTDR Signal Line Failure
    P1678FPTDR Signal Line Failure
    P1679RSCD Signal Circuit Malfunction
    P1681A/T FI Signal A Cicuit Low Voltage
    P1682A/T FI Signal A Circuit High Voltage
    P1683Throttle Valve Default Position Spring Performance Problem
    P1684Throttle Valve Return Spring Performance Problem
    P1686A/T FI Signal B Circuit Low Voltage
    P1687A/T FI Signal B Circuit High Voltage
    P1705Short in Transmission Range Switch Circuit (More than one range position is on at the same time)
    P1706Open in Transmission Range Switch Circuit
    P1709Problem Transmission Gear Selection Switch Circuit DTC Detection Item Associated Monitor
    P1730Problem in Shift Control System:Shift Solenoid Valve A and D Stuck OFF ,or Shift Solenoid Valve B Stuck ON,or Shift Valves A, B, and D Stuck
    P1731Problem in Shift Control System:Shift Solenoid Valve E Stuck ON,or Shift Valve E Stuck,or A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
    P1732Problem in Shift Control System:Shift Solenoid Valve B and C Stuck ON,or Shift Valves B and C Stuck
    P1733Problem in Shift Control System:Shift Solenoid Valve D Stuck ON,or Shift Valve D Stuck,or A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
    P1734Problem in Shift Control System:Shift Solenoid Valves B and C Stuck ON, or Shift Valves B and C Stuck
    P1738Problem in 2nd Clutch Pressure Switch Circuit
    P1739Problem in 3rd Clutch Pressure Switch Circuit
    P1740Problem in 4th Clutch Pressure Switch Circuit
    P1750Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve Assemblies A and B, or Problem in the Hydraulic Control System
    P1751Problem in Torque Converter Clutch Solenoid Valve B Circuit
    P1751Mechanical Problem in Hydraulic Control System of Shift Solenoid Valve B and A/T Clutch Pressure Control Solenoid Valves A and B, or Problem in the Hydraulic Control System
    P1753Problem in Torque Converter Clutch Solenoid Valve Circuit
    P1768Problem in Torque Converter Clutch Solenoid Valve B Circuit
    P1773Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P1790Throttle Position (TP) Sensor Circuit Malfunction
    P1791Vehicle Speed Sensor (VSS) Range/Performance Problem
    P1792Problem in Engine Coolant Temperature (ECT) Sensor Circuit
    P1793Manifold Absolute Pressure Sensor Circuit
    P1870Problem in CVT Speed Change Control Valve Assembly Circuit
    P1873Problem in CVT Pulley Pressure Control Valve Assembly Circuit
    P1879Problem in CVT Start Clutch Pressure Control Valve Assembly Circuit
    P1882Problem in Inhibitor Solenoid Circuit
    P1884Secondary Gear Speed Sensor 2 Circuit Malfunction
    P1885CVT Drive Pulley Speed Sensor Circuit
    P1886CVT Driven Pulley Speed Sensor Circuit
    P1888CVT Speed Sensor
    P1889Problem in CVT Speed Sensor 2 Circuit
    P1890Shift Control System
    P1891Problem in Start Clutch System
    P1894CVT Speed Change Control Valve Circuit
    P1895CVT Pulley Pressure Control Valve Circuit
    JAGH
    P1000OBD Systems Readiness Test Not Complete
    P1104Mass Air Flow Sensor Circuit Ground
    P1111System Pass
    P1121Pedal Position Sensor A Circuit Range / Performance
    P1122Pedal Position Sensor A Circuit Low input
    P1123Pedal Position Sensor A Circuit High Input
    P1136Control Box Fan Circuit
    P1137Lack Of HO2S12 Switches -Sensor Indicates Lean
    P1138Lack Of HO2S12 Switches -Sensor Indicates Rich
    P1143Air Assisted Injector Control Valve Range/ Performance
    P1144Air Assisted Injector Control Valve Circuit
    P1157Lack Of HO2S22 Switches -Sensor Indicates Lean
    P1158Lack Of HO2S22 Switches -Sensor Indicates Rich
    P1171System Too Lean -Banks 1 and 2 (Lean Fuel Fault)
    P1172System Too Rich -Banks 1 and 2 (Rich Fuel Fault)
    P1174System Too Lean -Banks 1 and 2 (Suspect HO2S)
    P1175System Too Rich -Banks 1 and 2 (Suspect HO2S)
    P1176Long Term Fuel Trim Too Lean - Banks 1 and 2 (FMFR)
    P1177Long Term Fuel Trim Too Rich - Banks 1 and 2 (FMFR)
    P1178Long Term Fuel Trim Too Lean - Banks 1 and 2 (AMFR)
    P1179Long Term Fuel Trim Too Rich - Banks 1 and 2 (AMFR)
    P118502 Sensor Heater Circuit Open - Hardware Fault
    P118602 Sensor Heater Circuit Shorted - Hardware Fault
    P118702 Sensor Heater Circuit Open - Inferred Fault
    P118802 Sensor Heater Circuit Resistance
    P118902 Sensor Heater Circuit Low Resistance Fault 1
    P119002 Sensor Heater Circuit Low Resistance Fault 2
    P119102 Sensor Heater Circuit Open -Hardware Fault
    P119202 Sensor Heater Circuit Shorted
    P119302 Sensor Heater Circuit Open - Inferred Fault
    P119402 Sensor Heater Circuit Resistance Fault
    P119502 Sensor Heater Circuit Low Resistance Fault 1
    P119602 Sensor Heater Circuit Low Resistance Fault 2
    P1198Fuel Level Input Circuit High
    P1199Fuel Level Input Circuit Low
    P1201Cylinder # 1 Injector Circuit Open / Shorted
    P1202Cylinder # 2 Injector Circuit Open / Shorted
    P1203Cylinder # 3 Injector Circuit Open / Shorted
    P1204Cylinder # 4 Injector Circuit Open / Shorted
    P1205Cylinder # 5 Injector Circuit Open / Shorted
    P1206Cylinder # 6 Injector Circuit Open / Shorted
    P1207Cylinder # 7 Injector Circuit Open / Shorted
    P1208Cylinder # 8 Injector Circuit Open / Shorted
    P1221Pedal Demand Sensor B Circuit Range / Performance
    P1224Electronic Throttle Control Position Error
    P1226Mechanical Guard Circuit Range / Performance
    P1227Mechanical Guard Circuit Low Input
    P1228Mechanical Guard Circuit High Input
    P1229Electronic Throttle Control Circuit
    P1230Fuel Pump Relay
    P1235VSV 1/2/3 Circuit Range / Performance
    P1236VSV 1 Circuit
    P1237VSV 2 Circuit
    P1238VSV 3 Circuit
    P1240Sensor Power Supply
    P1241Sensor Power Supply Low Input
    P1242Sensor Power Supply High Input
    P1243Analog Ground
    P1245Crank Signal Low Input
    P1246Crank Signal High Input
    P1250Throttle Valve Spring
    P1251Throttle Position
    P1252VSV stuck on VA/VV
    P1253VSV Stuck on VR
    P1313Misfire Rate Catalyst Damage Fault - Bank 1
    P1314Misfire Rate Catalyst Damage Fault - Bank 2
    P1315Persistent Misfire
    P1316Misfire Rate Exceeds Emissions
    P1336Crankshaft / Camshaft Sensor Range / Performance
    P1340Camshaft Position Sensor B Circuit
    P1341Camshaft Position Sensor B Circuit Range / Performance
    P1361Ignition Coil, Cylinder #1, No Activation
    P1362Ignition Coil, Cylinder #2, No Activation
    P1363Ignition Coil, Cylinder #3, No Activation
    P1364Ignition Coil, Cylinder #4, No Activation
    P1365Ignition Coil, Cylinder #5, No Activation
    P1366Ignition Coil, Cylinder #6, No Activation
    P1367Ignition System Failure Group 1
    P1368Ignition System Failure Group 2
    P1370Insufficient RPM Increase During Spark Test
    P1371Ignition Coil - Cylinder 1 - Early Activation Fault
    P1372Ignition Coil - Cylinder 2 - Early Activation Fault
    P1373Ignition Coil - Cylinder 3 - Early Activation Fault
    P1374Ignition Coil - Cylinder 4 - Early Activation Fault
    P1375Ignition Coil - Cylinder 5 - Early Activation Fault
    P1376Ignition Coil - Cylinder 6 - Early Activation Fault
    P1384Variable Valve Timing Solenoid A Circuit
    P1392Variable Valve Timing Solenoid A Circuit Low Input
    P1393Variable Valve Timing Solenoid A Circuit High Input
    P1396Variable Valve Timing Solenoid B Circuit
    P1397Variable Valve Timing Solenoid B Circuit Low Input
    P1398Variable Valve Timing Solenoid B Circuit High Input
    P1400Exhaust Gas Recirculation Valve Position Control
    P1401Exhaust Gas Recirculation Valve Position Circuit
    P1408Exhaust Gas Recirculation Thermister
    P1409Exhaust Gas Recirculation Valve Circuit
    P1440Purge Valve Stuck Open
    P1441ELC System 1
    P1447ELC System Closure Valve Flow
    P1448ELC System System 2
    P1453Fuel Tank Pressure Relief Valve Malfunction
    P1454Evaporative Emission Control System Vacuum Test
    P1475Fan Relay (Low) Circuit
    P1476Fan Relay (High) Circuit
    P1508Idle Air Control Circuit Open
    P1509Idle Air Control Circuit Shorted
    P1514High Load Neutral / Drive Fault
    P1516Gear Change Neutral / Drive Fault
    P1517Cranking Neutral / Drive Fault
    P1534Restraint Deployment Indicator Circuit
    P1565Speed Control Command Switch Out Of Range High
    P1566Speed Control Command Switch Out Of Range Low
    P1567Speed Control Output Circuit
    P1568Speed Control Unable to Hold Speed
    P1571Brake Switch
    P1600Loss Of KAM Power, Cricuit Open
    P1603EEPROM Malfunction
    P1606ECM Control Relay Output Circuit
    P1607MIL Output Circuit
    P1608Watchdog Malfunction
    P1609Internal Control Module CPU to CPU Communication Failure
    P1611Throttle Target Malfunction 1
    P1612Throttle Offset Malfunction
    P1637CAN Link ECM/ABS Control Module Circuit / Network
    P1638CAN Link ECM / INSTM Circuit / Network
    P1641Fuel Pump Primary Circuit
    P1642CAN Link Circuit
    P1643CAN Link Engine Control Module / Transmission Control Module Circuit / Network
    P1646Linear 02 Sensor Control Chip (Bank 1)
    P1647Linear 02 Sensor Control Chip (Bank 2)
    P1648Knock Sensor Input Chip
    P1696CAN Link Engine Control Module /Cruise Control Module Circuit / Network
    P1697Cruise Control Distance - Control Input Circuit
    P1700Transmission Indeterminate Failure (Failed to Neutral)
    P1720Vehicle Speed (Meter ) Circuit
    P1722Stall Speed
    P1726Engine Overspeed
    P1730Gear Control Malfunction 2,3,5
    P1731Inconsistent Gear Ratio
    P1734Gear Control Malfuntion
    P1745Pressure Regulator 1
    P1746Pressure Regulator 2
    P1747Pressure Regulator 3
    P1748Pressure Regulator 5
    P1758Pressure Solenoid Control System Incorrect Current
    P1775Transmission System MIL Fault
    P1776Ignition Retard Request Duration
    P1777Ignition Retard Request Circuit
    P1778Transmission Reverse I / P Circuit
    P1779Load Control
    P1789Ignition Supply Malfunction
    P1790Ignition Supply Malfunction
    P1791Ignition Supply Malfunction
    P1792Ignition Supply Malfunction
    P1793Ignition Supply Malfunction
    P1794Battery Voltage Circuit
    P1796CAN Controller Circuit (Bus off)
    P1797CAN TCM / ECM Circuit Malfunction
    P1798CAN TCM / INST Circuit Malfunction
    P1799CAN TCM / ABS Circuit Malfunction
    P1882Engine Coolant Level Switch Circuit Short To Ground
    KIA
    P1102HO2S - 11 heater circuit high voltage
    P1105HO2S - 12 heater circuit high voltage
    P1115HO2S - 11 heater circuit low voltage
    P1117HO2S - 12 heater circuit low voltage
    P1123Long term trim adaptive air system low
    P1124Long term fuel trim adaptive air system high
    P1127Long term fuel trim multiplicative air system low
    P1128Long term fuel trim multiplicative air system high
    P1140Load calculation cross check
    P1170HO2S - 11 circuit voltage stuck at Mid - range
    P1195EGR Boost or pressure sensor circuit fault
    P1196Ignition switch start circuit fault
    P1213Fuel injector 1 circuit high voltage
    P1214Fuel injector 2 circuit high voltage
    P1215Fuel injector 3 circuit high voltage
    P1216Fuel injector 4 circuit high voltage
    P1225Fuel injector 1 circuit low voltage
    P1226Fuel injector 2 circuit low voltage
    P1227Fuel injector 3 circuit low voltage
    P1228Fuel injector 4 circuit low voltage
    P1250Pressure regulator control solenoid circuit fault
    P1345No SGC (CMP) signal to PCM
    P1386Knock sensor control zero test
    P1401EGR control solenoid circuit signal low
    P1402EGR control solenoid circuit signal high
    P1402EGR valve position sensor circuit fault
    P1410EVAP purge control solenoid circuit high voltage
    P1412EGR differential pressure sensor signal low
    P1413EGR differential pressure sensor signal high
    P1425EVAP purge control solenoid circuit low voltage
    P1449Canister drain cut valve solenoid circuit fault
    P1455Fuel tank sending unit circuit fault
    P1458Air conditioning compressor clutch signal fault
    P1485EGR Vent control solenoid circuit fault
    P1486EGR vacuum control solenoid circuit fault
    P1487EGR boost sensor solenoid circuit fault
    P1510Idle air control valve closing coil high voltage
    P1513Idle air control valve closing coil low voltage
    P1515A / T to M / T codification
    P1523VICS solenoid valve circuit fault
    P1552Idle air control valve opening coil low voltage
    P1553Idle air control valve opening coil high voltage
    P1606Chassis accelerator sensor signal circuit fault
    P1608PCM internal fault
    P1611MIL request circuit low voltage
    P1614MIL request circuit high voltage
    P1616Chassis accelerator sensor signal low voltage
    P1617Chassis accelerator sensor signal high voltage
    P1624TCM to PCM MIL request signal circuit fault
    P1655Unused power stage 'B'
    P1660Power stage group 'B'
    P1665Power stage group 'A'
    P1743Torque converter clutch solenoid circuit fault
    P1794Battery or circuit fault
    P1797Clutch pedal switch (MT) -or- P/N switch circuit fault
    MAZDA
    P1001Activate self test SCP error
    P1100Mass Air Flow Sensor Circuit Intermittent
    P1101Mass Air Flow Sensor Out Of Self Test Range
    P1102Mass Air Flow Sensor In Range But Lower Than Expected
    P1103Mass Air Flow Sensor In Range But Higher Than Expected
    P1110Intake Air Temperature Circuit (dynamic chamber) Open/Short
    P1112Intake Air Temperature Circuit Intermittent
    P1113Intake Air Temperature Circuit (dynamic chamber) Open/Short
    P1116Engine Coolant Temperature Sensor Out Of Self Test Range
    P1117Engine Coolant Temperature Sensor Circuit Intermittent
    P1120TP sensor out of range low
    P1121Tp sensor signal not consistent with MAF signal
    P1122Throttle Position Sensor A In Range But Lower Than Expected
    P1123Throttle Position Sensor A In Range But Higher Than Expected
    P1124TP sensor signal out of self test range
    P1125TP sensor signal intermittent
    P1126Throttle Position(Narrow Range)Sensor Circuit
    P1127H02S-12 heater not ON during KOER self test
    P1128Upstream H02S Sensors Swapped
    P1129Downstream H02S Sensors Swapped
    P1130H02S-11 not switching (fuel control limit reached)
    P1131H02S-11 signal above 0.45v(A/F ratio too lean)
    P1132H02S-11 signal below 0.45v(A/F ratio too rich)
    P1133Bank 1 Fuel Control Shifted Lean (FAOSC)
    P1134Bank 1 Fuel Control Shifted Rich (FAOSC)
    P1135H02S11 Heater Circuit Low
    P1136H02S11 Hester Circuit High
    P1137H02S-11 signal above 0.45v(A/F ratio too rich)
    P1138Lack Of HO2S12 Switches - Sensor Indicates Rich
    P1141H02S12 Heater Circuit Low
    P1142H02S12 Hester Circuit High
    P1143Lack Of HO2S Switches,H02S13 Indicates Lean
    P1144Lack Of HO2S Switches,H02S13 Indicates Rich
    P1150HO2S-21 not switching (fuel control limit reached)
    P1151H02S-21 signal below 0.45v (A/F ratio too rich)
    P1152H02S-21 signal above 0.45v (A/F ratio too rich)
    P1153Bank 2 Fuel Control Shifted Lean (FAOSC)
    P1154Bank 2 Fuel Control Shifted Rich (FAOSC)
    P1169Feedback A/F Mixture Control (HO2S12)
    P1170HO2S-11 circuit too high or low (bank 1 sensor 1)
    P1173Feedback A/F Mixture Control (HO2S21)
    P1182Fuel Shut Off Solenoid Circuit
    P1189Pump Speed Signal
    P1190Calibration Resistor Out Of Range
    P1191TP (controlled) circuit
    P1194ECM/PCM A/D Converter
    P1195EGR boost sensor circuit fault
    P1197Mileage Switch Circuit
    P1213Start Injector Circuit
    P1221Traction Control System
    P1222Traction Control Output Circuit
    P1226Control Sleeve Sensor Circuit
    P1235Fuel pump control out range
    P1236Fuel pump control out range
    P1248Turbo Boost Pressure Not Detected
    P1250Fuel Pressure Regulator Control Solenoid
    P1251Air Mixture Solenoid Circuit
    P1252Pressure regulator control solenoid '2'circuit fault
    P1260Anti-theft system signal detected, engine disabled
    P1270Engine RPM or vehicle speed limit reached
    P1279Control Sleeve Sensor Circuit Range / Performance
    P1298Injector Driver Module Failure
    P1312Injection Pump Timing Actuator Circuit
    P1318Injection Timing Piston Position Sensor Circuit
    P1319Injection Timing Piston Position Sensor Circuit Range / Performance
    P1345CMP or SGC sensor circuit fault
    P1351IDM signal lost to PCM or out of range
    P1352Ignition coil 'A' primary circuit fault
    P1353Ignition coil 'B' primary circuit fault
    P1354Ignition coil 'C' primary circuit fault
    P1358IDM signal out of self test range
    P1359SPOUT signal lost to PCM or out of range
    P1360Ignition coil 'A' secondary circuit fault
    P1361Ignition coil 'B' secondary circuit fault
    P1362Ignition coil 'C' secondary circuit fault
    P1364Ignition coil primary circuit fault
    P1365Ignition coil secondary circuit fault
    P1382Camshaft Position Timing Solenoid #1 Circuit
    P1387Camshaft Position Timing Solenoid #2 Circuit
    P1390Octane adjust shorting bar out or circuit open
    P1400DPFE sensor signal below self test minimum
    P1401DPFE sensor signal above self test maximum
    P1405DPFE sensor upstream hose off or plugged
    P1406DPFE sensor downstream hose off or plugged
    P1407No EGR flow detected
    P1408EGR system flow out of KOER self test range
    P1409EGR vacuum regulator solenoid circuit fault
    P1412Exhaust Gas Recirculation Valve Frozen
    P1415Air Pump Circuit
    P1416Port Air Circuit
    P1417Port Air Relief Circuit
    P1418Split Air #1 Circuit
    P1419Split Air #2 Circuit
    P1439Floor Temp Switch Circuit
    P1443EVAP system purge flow fault
    P1444EVAP purge flow sensor circuit low voltage
    P1445EVAP purge flow sensor circuit high voltage
    P1446Evaporative Vacuum Solenoid Circuit
    P1449Evaporative Check Solenoid Circuit
    P1450Unable to Bleed Up Fuel Tank Vacuum
    P1451Evaporative Emission Control System Vent Control Circuit
    P1455Fuel tank level sensor circuit fault
    P1456Fuel Tank Temperature Sensor Circuit
    P1457Purge Solenoid Control System
    P1460Wide open throttle A/C cut-off relay circiut fault
    P1464Air conditioning control signal circuit fault
    P1465A/C Relay Circuit
    P1473Fan Circuit Open (VLCM)
    P1474Fan control system fault
    P1477Additional Fan Relay Circuit
    P1479High Fan Control Primary Circuit
    P1480Fan Secondary Low With Low Fan On
    P1481Fan Secondary Low With High Fan On
    P1485EGR vacuum solenoid circuit fault
    P1486EGR vent solenoid circuit fault
    P1487Exhaust Gas Recirculation Check Solenoid Circuit
    P1490Secondary Air Relief Solenoid Circuit
    P1491Secondary Switch Solenoid Circuit
    P1492APLSOL Solenoid Circuit
    P1493RCNT Solenoid Circuit
    P1494SPCUT Solenoid Circuit
    P1495TCSPL Solenoid Circuit
    P1496EGR Stepper Motor 1 Control Circuit Low/High
    P1497EGR Stepper Motor 2 Control Circuit Low/High
    P1498EGR Stepper Motor 3 Control Circuit Low/High
    P1499EGR Stepper Motor 4 Control Circuit Low/High
    P1500Vehicle speed sensor intermittent signals
    P1501Vehicle speed sensor out of self test range
    P1504Idle air control solenoid circuit intermittent fault
    P1505Idle air control system at adaptive clip
    P1506IAC system overspeed detected during self test
    P1507IAC system underspeed detected during self test
    P1508Bypass air solenoid '1' circuit fault
    P1509Bypass air solenoid '2' circuit fault
    P1510Idle Signal Circuit
    P1511Idle Switch (Electric Control Throttle) Circuit
    P1512Intake Manifold Runner Control Stuck Closed (Bank 1)
    P1515Electric Current Circuit
    P1521Variable Resonance Induction System Solenoid #1 Circuit
    P1522Variable Resonance Induction System Solenoid #2 Circuit
    P1523VICS solenoid circuit fault
    P1524Variable Intake Solenoid Circuit
    P1525ABV vacuum solenoid circuit fault
    P1526ABV vent solenoid circuit fault
    P1527Bypass Air Solenoid (Accelerate Warmup) Circuit
    P1528Subsidiary Throttle Valve Solenoid Circuit
    P1529L/C atmospheric balance air control valve fault
    P1540Air Bypass Valve Circuit
    P1562PCM B+ Voltage Low (KAM power)
    P1566TCM B+ Voltage Low
    P1569Intake Manifold Runner Control Control Circuit Low
    P1570Intake Manifold Runner Control Control Circuit High
    P1600Loss Of KAM Power, Circuit Open
    P1601ECM / TCM Serial Communication Error
    P1602Immobilizer / ECM Communication Error
    P1603ID Number Unregistered
    P1604Code Word Unregistered
    P1605PCM keep active memory test error
    P1608PCM Internal Circuit
    P1609PCM (ECM CPU) knock sensor fault
    P1621Immobilizer Code Words Do Not Match
    P1622Immobilizer ID Does Not Match
    P1623Immobilizer Code Word / ID Number Write Failure
    P1624Anti-theft System
    P1627PCM (ECM / TCS) line communication error
    P1628PCM (ECM / TCS) ABV line communication error
    P1630Alternator Regulator #1 Control Circuit
    P1631Alternator Regulator #2 Control Circuit
    P1633Generator Control System - over charge
    P1634Generator Control System - no charge
    P1645Fuel Pump Resistor Switch Circuit
    P1649Fuel Injection Pump Module
    P1650Power steering pressure switch out of range fault
    P1651Power steering pressure switch circuit fault
    P1652Idle Air Control Monitor Disabled By PSPS Failed On
    P1680Metering Oil Pump Failure
    P1681Metering Oil Pump Failure
    P1682Metering Oil Pump Failure
    P1683Metering Oil Pump Temperature Sensor Circuit
    P1684Metering Oil Pump Position Sensor Circuit
    P1685Metering Oil Pump Stepping Motor Cont.Circuit
    P1686Metering Oil Pump Stepping Motor Cont.Circuit
    P1687Metering Oil Pump Stepping Motor Cont.Circuit
    P1688Metering Oil Pump Stepping Motor Cont.Circuit
    P1689Oil Pressure Control Solenoid Circuit
    P1690Wastegate Solenoid Circuit
    P1691Turbo Pressure Control Solenoid Circuit
    P1692Turbo Control Solenoid Circuit
    P1693Turbo Charge Control Circuit
    P1694Turbo Charge Relief Circuit
    P1701A / T TR sensor reverse engagement error
    P1703Brake on / off switch out of self test range
    P1705Transmission Range Circuit Not Indicating Park / Neutral During Self Test
    P1706HighVehicle Speed Observed in Park
    P1708Clutch Switch Circuit
    P1709Clutch Pedal (or Park / Neutral Position) Switch Out Of Self Test Range
    P1710Transmission Control Module Solenoid / Internal Ground Circuit
    P1711A/T TFT sensor out of self test range
    P1713Transmission Fluid Temperature Sensor In Range Failure
    P1719Engine Torque Signal
    P1720Vehicle speed sensor '2' signal error
    P1721Gear 1 Incorrect Ratio
    P1722Gear 2 Incorrect Ratio
    P1723Gear 3 Incorrect Ratio
    P1724Gear 4 Incorrect Ratio
    P1729Transmission 4ЎБ4 low switch error during self test
    P1735First Gear Switch Circuit Failure
    P1736Second Gear Switch Circuit Failure
    P1737Lockup Solenoid
    P1738Shift Time Error
    P1739Slip Solenoid
    P1741Torque converter clutch control error
    P1742Torque converter clutch failed on, MIL is on
    P1743Torque converter clutch failed on, TCIL is on
    P1744Torque converter clutch Solenoid Circuit
    P1745Line Pressure Solenoid
    P1746Electronic pressure control solenoid circuit open
    P1747Electronic pressure control solenoid circuit short
    P1748Pressure Control Solenoid A
    P1749Electronic pressure control solenoid circuit low
    P1751Shift Solenoid A Circuit Open
    P1752Shift Solenoid A Circuit Short
    P1754Transmission coast clutch solenoid electrical fault
    P1756Shift Solenoid B Circuit Open
    P1757Shift Solenoid B Circuit Short
    P17592-4 Brake Failsafe Valve Malfunction
    P1761Transmission shift solenoid '3' performance
    P1763Low and Reverse Brake Pressure Switch Circuit
    P1764Low and Reverse Brake Failsafe Valve Malfunction
    P1765Timing Solenoid Circuit
    P1770Clutch Solenoid Circuit
    P1771Throttle Position Sensor Circuit High Input
    P1772Throttle Position Sensor Circuit Low Input
    P1775Torque Down Signal #1 Circuit
    P1776Torque Down Signal #2 Circuit
    P1777Torque Down Response Signal Circuit
    P1780Transmission control switch electrical fault
    P1781Transmission 4ЎБ4 low switch out of range fault
    P1783Transmission fluid temperature too high
    P1788Pressure Control Solenoid B Open Circuit
    P1789Pressure Control Solenoid B Short Circuit
    P1790TP (Mechanical ) Circuit
    P1791TP (Electric) Circuit
    P1792Barometer Pressure Circuit
    P1793Intake Air Volume Circuit
    P1795Idle Switch Circuit
    P1796Kick Down Switch Circuit
    P1797Clutch Pedal (or Park / Neutral ) Position Switch Circuit
    P1798Coolant Temperature Circuit
    P1799Hold Switch Circuit
    MERCEDES (diesel)
    P1105Atmospheric pressure sensor in control module
    P1220Fuel quantity actuator (Y23/1)
    P1221CAN communication, ETC or ETS interrupted
    P1222IFI accelerator pedal position sensor (R25/2)
    P1223Fuel rack position sensor (Y23/1/1)
    P1335CKP sensor (IFI)
    P1350Injection sensor solenoid
    P1351Injection sensor circuit
    P1352Needle Lift Sensor
    P1401EGR lifting sender (B28/3)
    P1404EGR control
    P1465EPW power
    P1470Pressure control flap vacuum transducer (Y31/2)
    P1475Resonance intake line switchover valve (Y22/7)
    P1476Resonance intake manifold switchover valve (Y22/6)
    P1480Preglow control
    P1481Glow plug failure
    P1482Preglow control module (N14/2)
    P1520Cruise control switch (S40)
    P1610Voltage supply missing -or- relay module (K40)
    P1611IFI Control module (N3/7)
    P1612IFI Control module (N3/7) voltage, circuit 15
    P1613IFI Control module (N3/7)
    P1614IFI Control module (N3/7) voltage -or-Fuel metering actuator(Y23/1k1) -or-Fuel rack position sensor(Y23/1/1)
    P1615IFI Control module (N3/7) supply voltage
    P1617Control module fault -or- Control module not coded
    P1622Electrohydraulic shut-off actutor (Y1/1)
    P1625Check Engine MIL
    P1630Drive authorization signal
    P1705Starter lock-out/backup lamp switch(S16/1)
    P1780Modulating pressure switchover valve(AT/CC)(Y3/4) -or-Upshift delay switchover valve(AT/CC)(Y3/5)
    P1781Upshift delay switchover valve (AT/CC)(Y3/5)
    MERCEDES benzin
    P1146Left hot film MGF sensor (B2/6)
    P1147Left ECT sensor (B11/9)
    P1148Left IAT sensor (B17/5)
    P1149Left Manifold pressure sensor (B28/1)
    P1162Left EA/CC/ISC actuator actual value potentiometer (M16/4r1,M16/4r2)
    P1163Oil level switch (S43)
    P1176Oil pressure sensor
    P1177Oil sensor, level-temperature implausible
    P1179Oil quality implausible
    P1180High oil temperature
    P1181Engine electric cooling fan, faulty
    P1182Start relay output stage, faulty
    P1183Output stage cylinder fadeout, valve1
    P1184Output stage cylinder fadeout valve2
    P1185Water in oil
    P1186Satety fuel shutoff detected
    P1225Variable intake manifold switchover valve (Y22/6)
    P1233Throttle valve jamming
    P1300Left CKP sensor (L5/4)
    P1355Cylinder shut-off valve, right bank (Y80) does not close at cylinder cutoff
    P1356Cylinder shut-off valve, left bank(Y81) does not close at cylinder cutoff
    P1357Cylinder cutoff,inlet valve of a cylinder continuous to be operated at cylinder cutoff
    P1358Cylinder 5 exhaust valve is not operating at cylinder cutoff
    P1359Cylinder 2 exhaust valve is not operating at cylinder cutoff
    P1360Cylinder 3 exhaust valve is not operating at cylinder cutoff
    P1361Cylinder 8 exhaust valve is not operating at cylinder cutoff
    P1366Exhaust flap switchover valve (Y93)
    P1380Inlet valve of a cylinder is not operated at cylinder cutoff
    P1384Left knock sensor 1 (A29g1)
    P1385Left knock sensor 2 (A29g2)
    P1386Knock sensor regulation from right ECM (N3/12) hardware failure
    P1397Left camshaft Hall-effect sensor (B6/2)
    P1400EGR switchover valve output stage (Y31-1)
    P1420AIR pump switchover valve (Y32)
    P1437Exhaust gas temperature sensor 1
    P1443Purge valve
    P1444Exhaust gas temperature sensor 2
    P1453AIR relay module (K17)
    P1463Left AIR system malfunction
    P1490Left purge control valve (Y58/2)
    P1491A/C refrigerant pressure too high
    P1519Right adjustable camshaft timing solenoid (Y49/2)(logic chain)
    P1522Left adjustable camshaft timing solenoid (Y49/1)(logic chain)
    P1525Right adjustable camshaft timing solenoid (Y49/2)
    P1533Left adjustable camshaft timing solenoid (Y49/1)
    P1542Pedal value sensor (B37)
    P1550AC compressor torque implausible
    P1570Start enable of DAS not sent
    P1580Throttle valve actuator (M16/6)
    P1581Left EA/CC/ISC actuator M16/4)
    P1584Stop lamp switch (S9/1)
    P1587Left ECM (N3/11) voltage supply
    P1588CAN signal from RCL control module (N54) to left ECM (N3/11) interrupted
    P1589Knock sensor regulation from left ECM (N3/11) hardware failure
    P1603No or incorrect CAN message from control unit EIS
    P1605Rough road detected by signal from comparing wheel speeds
    P1632Left engine control module (N3/11)
    P1642ECU incorrectly coded
    P1643ECU incorrectly coded -or- CAN from transmission
    P1644Transmission version can't be checked due to low voltage at transmission ECU
    P1681Crash Sensor, signal implausible or frontal crash or short to power
    P1747CAN signal from ETC (N15/3) interrupted
    MITSUBISHI
    P1100Induction control motor position sensor fault
    P1101Traction control vacuum solenoid circuit fault
    P1102Traction control ventilation solenoid circuit fault
    P1103Turbocharger waste gate actuator circuit fault
    P1104Turbocharger waster Gate solenoid circuit fault
    P1105Fuel pressure solenoid circuit fault
    P1294Target Idle speed not reached
    P1295No 5-volt supply to TP sensor
    P1296No 5-volt supply to MAP sensor
    P1297No charge in MAP from start to run
    P1300Ignition timing adjustment circuit fault
    P1390Timing belt skipped one tooth or more
    P1391Intermittent loss of CMP or CKP sensor signals
    P1400Manifold differential pressure sensor fault
    P1443EVAP purge control solenoid '2' circuit fault
    P1486EVAP leak monitor pinched hose detected
    P1487High speed radiator fan control relay circuit fault
    P1489High speed condenser fan control relay fault
    P1490Low speed fan control relay fault
    P1492Battery temperature sensor high voltage
    P1494EVAP ventilation switch or mechanical fault
    P1495EVAP ventilation solenoid circuit fault
    P14965 Volt supply output too low
    P1500Generator FR terminal circuit fault
    P1600PCM / TCM serial communication link circuit fault
    P1696PCM failure- EEPROM write denied
    P1698NO CCD messages from TCM
    P1715TCM pulse generator circuit fault
    P1750Pressure control,shift control,TCC solenoid fault
    P1791PCM ECT level signal to TCM circuit fault
    P1899P / N position / transaxle range switch circuit fault
    NISSAN
    P1031Air/Fuel Ratio Sensor Meter
    P1032Air/Fuel Ratio Sensor Meter
    P1065ECM Power Supply Heater
    P1102Mass Air Flow Sensor Function Heater
    P1103MAP Sensor Heater
    P1104MAP Sensor Heater
    P1105MAP/BARO Switch SOL/V
    P1108MAP Sensor Heater
    P1110Intake Valve Timing Control, LH Bank
    P1111Intake Valve Timing Control Solenoid Valve
    P1119Radiator Temperature Sensor Circuit
    P1120TP Sensor 2
    P1121Electronic Throttle Control Actuator
    P1122Electronic Throttle Control Actuator
    P1124Throttle Control Motor Relay
    P1125Tandem TP Sensor
    P1126Throttle Control Motor Relay
    P1128Throttle Control Motor
    P1130Swirl Control Valve Control Solenoid Valve
    P1131Swirl Control Solenoid Valve
    P1132Swirl Control Valve
    P1135Intake Valve Timing Control, RH Bank 2
    P1136Intake Valve Timing Control Solenoid Valve
    P1137Swirl Control Valve Position Sensor
    P1138Swirl Control Valve
    P1140Intake Valve Timing Control Position Sensor, LH Bank 1
    P1143Heated O2 Sensor 1
    P1144Heated O2 Sensor 1
    P1145Intake Valve Timing Control Position Sensor, RH Bank 2
    P1146Heated O2 Sensor 2
    P1147Heated O2 Sensor 2
    P1148Closed Loop, Bank 1
    P1163Heated O2 Sensor 1
    P1164Heated O2 Sensor 1
    P1165Swirl Control Valve Control Vacuum Check Switch
    P1166Heated O2 Sensor 2
    P1167Heated O2 Sensor 2
    P1168Closed Loop, Bank 2
    P1169Heated O2 Sensor 3
    P1170Heated O2 Sensor 3
    P1210Traction Control Signal Circuit
    P1211ABS/TCS Control Unit
    P1212ABS/TCS Communication Line
    P1217Engine Coolant Temperature
    P1220FPCM
    P1221Throttle Actuator Circuit
    P1222Temperature Sensor Circuit
    P1223Throttle Position Sensor 2
    P1224Throttle Position Sensor 2
    P1225Closed Throttle Position Learning
    P1226Closed Throttle Position Learning
    P1227Accelerator Pedal Position Sensor 2
    P1228Accelerator Pedal Position Sensor 2
    P1229Sensor Power Supply
    P1271Air/Fuel Ratio Sensor 1
    P1272Air/Fuel Ratio Sensor 1
    P1273Air/Fuel Ratio Sensor 1
    P1274Air/Fuel Ratio Sensor 1
    P1276Air/Fuel Ratio Sensor 1
    P1278Air/Fuel Ratio Sensor 1
    P1279Air/Fuel Ratio Sensor 1
    P1320Ignition Signal, Primary
    P1335CKP Sensor (Ref)
    P1336CKP Sensor (POS) Cog
    P1400EGRC Solenoid/V
    P1401EGR Temp Sensor
    P1402EGR System
    P1440EVAP Small Leak
    P1441VC/V Bypass/V
    P1443Canister Control Vacuum Check Switch
    P1444Purge Volume Control/V
    P1445Purge Volume Control/V
    P1446Vent Control Valve
    P1447EVAP Purge Flow
    P1448Vent Control Valve
    P1456EVAP Control System
    P1464Fuel Level Sensor Circuit Ground Signal
    P1480Fan Control Solenoid Valve Circuit
    P1490VC/V Bypass/V
    P1491VC Cut/V Bypass/V
    P1492Purge Control/V S/V
    P1493Purge Control/V & S/V
    P1564ASCD Steering Switch
    P1568ICC (Intelligent Cruise Control)
    P1572ASCD (Automatic Sped Control Device) Brake Switch
    P1574ASCD Vehicle Speed Sensor
    P1605A/T Diag Comm Line
    P1610NATS Malfunction
    P1611NATS Malfunction
    P1612NATS Malfunction
    P1613NATS Malfunction
    P1614NATS Malfunction
    P1615NATS Malfunction
    P1705TP Sensor A/T
    P1706PNP Switch
    P1720Vehicle Speed Sensor- A/T Output
    P1760Overrun Clutch S/V
    P1775Torque Converter Clutch Solenoid Valve
    P1776Torque Converter Clutch Solenoid Valve
    P1780Shift Change Signal
    P1800VIAS Control Solenoid Valve
    P1805Brake switch
    P1900Cooling Fan
    SUBARU
    P1086Tumble generator valve #2 (LH) position sensor circuit low input
    P1087Tumble generator valve #2 (LH) position sensor circuit high input
    P1088Tumble generator valve #1 (RH) position sensor circuit low input
    P1089Tumble generator valve #1 (RH) position sensor circuit high input
    P1090Tumble generator valve #1 (RH) malfunction (stuck open)
    P1091Tumble generator valve #1 (RH) malfunction (stuck close)
    P1092Tumble generator valve #2 (LH) malfunction (stuck open)
    P1093Tumble generator valve #2 (LH) malfunction (stuck close)
    P1094Tumble generator valve circuit #1 (open circuit)
    P1095Tumble generator valve circuit #1 (over current)
    P1096Tumble generator valve circuit #2 (open circuit)
    P1097Tumble generator valve circuit #2 (over current)
    P1100Starter Switch Circuit Malfunction
    P1101Neutral Position Switch Circuit High Input (A/T), or Neutral Position Switch Circuit Malfunction (M/T)
    P1102Pressure Sources Solenoid Valve Circuit Malfunction
    P1103Pressure Sources Switching Solenoid Valve Circuit
    P1104Engine Torque Control Signal Circuit Malfunction
    P1106Engine Torque Control Signal 2 Circuit Malfunction
    P1110Atmospheric pressure sensor low input
    P1111Atmospheric pressure sensor high input
    P1112Atmospheric pressure sensor range/performance problem
    P1115Engine Torque Control Cut Signal Circuit High Input
    P1116Engine Torque Control Cut Signal Circuit Low Input
    P1120Starter Switch High Input
    P1121Neutral Position Switch Circuit High Input [MT Vehicles], or Neutral Position Switch Circuit Low Input [AT Vehicles]
    P1122Pressure Sources Switching Valve Circuit High Input
    P1124TCS Signal Circuit High Input
    P1130Front oxygen sensor circuit malfunction (open circuit)
    P1131Front oxygen sensor circuit malfunction (short circuit)
    P1134Front oxygen (A/F) sensor microcomputer problem
    P1137Front oxygen (A/F) sensor circuit range/performance problem
    P1139Front oxygen (A/F) sensor #1 heater circuit performance/range problem
    P1141Mass Air Flow Sensor Circuit High Input
    P1142Mass Air Flow Sensor Circuit Low Input
    P1143Pressure Sensor Circuit Low Input
    P1144Pressure Sensor Circuit High Input
    P1146Pressure sensor circuit range/performance problem (high input)
    P1150Front Oxygen Sensor Heater Circuit High Input
    P1151Rear Oxygen Sensor Heater Circuit High Input
    P1230Fuel pump control unit malfunction
    P1244Wastegate control solenoid valve malfunction (low input)
    P1245Wastegate control solenoid valve malfunction (fail-safe)
    P1301Fire due to increased exhaust temperature
    P1312Exhaust temperature sensor malfunction
    P1325Knock Sensor Circuit Low Input
    P1400Fuel Tank Pressure Control Solenoid Low Input
    P1420Fuel Tank Pressure Control Solenoid High Input
    P1421Exhaust Gas Recirculation Circuit High Input
    P1422EVAP Purge Control Valve Circuit High Input
    P1423EVAP Vent Control High Input
    P1440Fuel Tank Pressure Control System Low Input
    P1441Fuel Tank Pressure Control System High Input
    P1442Fuel Level Sensor Circuit Range/Perf
    P1443EVAP Control System Vent Control Function Problem
    P1480Cooling fan relay 1 circuit high input
    P1500Radiator Fan Relay 1 Circuit Malfunction
    P1501Idle Control System Malfunction (Fail Safe)
    P1502Radiator Fan Function Problem
    P1507Idle Control System Malfunction (Fail Safe)
    P1510Idle Air Control Solenoid Signal 1 Circuit Low Input
    P1511Idle Air Control Solenoid Signal 1 Circuit High Input
    P1512Idle Air Control Solenoid Signal 2 Circuit Low Input
    P1513Idle Air Control Solenoid Signal 2 Circuit High Input
    P1514Idle Air Control Solenoid Signal 3 Circuit Low Input
    P1515Idle Air Control Solenoid Signal 3 Circuit High Input
    P1516Idle Air Control Solenoid Signal 4 Circuit Low Input
    P1517Idle Air Control Solenoid Signal 4 Circuit High Input
    P1518Starter switch circuit low input
    P1520Radiator Fan Relay 1 Circuit High Input
    P1540Vehicle Speed Sensor Malfunction 2
    P1544High exhaust temperature detected
    P1560Back-Up Voltage Circuit Malfunction
    P1590Neutral position switch circuit high input
    P1591Neutral position switch circuit low input
    P1592Neutral position switch circuit (MT model)
    P1594Automatic transmission diagnosis input signal circuit malfunction
    P1595Automatic transmission diagnosis input signal circuit low input
    P1596Automatic transmission diagnosis input signal circuit high input
    P1698Engine torque control cut signal circuit low input
    P1699Engine torque control cut signal circuit high input
    P1700Throttle Position Sensor Circuit Malfunction (A/T)
    P1701Cruise Control Set Signal Circuit Malfunction (A/T)
    P1702Auto Trans Diagnosis Input Signal Circuit
    P1703Low clutch timing control solenoid valve circuit malfunction
    P17042-4 Brake Timing Solenoid Valve Circuit Malfunction
    P17052-4 Brake Pressure Solenoid Valve (Solenoid D) Circuit
    P1711Engine torque control signal 1 circuit malfunction
    P1712Engine torque control signal 2 circuit malfunction
    P1722Auto Trans Diagnosis Input Signal High Input
    P1742Auto Trans Diagnosis Input Signal Malfunction
    SUZUKI
    P1250EFE heater circuit fault
    P1408Manifold differential pressure sensor circuit fault
    P1410Fuel tank pressure control solenoid circuit fault
    P1450Barometric pressure sensor too low or too high
    P1451Barometric pressure sensor performance
    P1460Radiator fan control system fault
    P1500Engine starter signal circuit fault
    P1510PCM backup power supply circuit fault
    P1530Ignition timing adjustment switch circuit fault
    P1600PCM / TCM serial communication circuit fault
    P1700TCM throttle position sensor circuit fault
    P1705TCM ECT sensor circuit fault
    P1710Back-Up Signal For Speed Sensor Circuit Malfunction
    P1715PNP switch circuit fault
    P1717AT Drive range signal circuit fault
    P18754WD Low Switch Circuit Malfunction
    P1895TCM To ECM Torque Reduction Circuit Malfunction
    TOYOTA
    P1100BARO Sensor Circuit malfunction
    P1120Accelerator Pedal Position Sensor Circuit Malfunction
    P1121Accelerator Pedal Position Sensor Range/Performance Problem
    P1125Throttle Control Motor Circuit Malfunction
    P1126Magnetic Clutch Circuit Malfunction
    P1127ETCS Actuator Power Source Circuit Malfunction
    P1128Throttle Control Motor Lock Malfunction
    P1129Electric Throttle Control System Malfunction
    P1130AirЁCFuel Sensor Circuit Range/Performance
    P1133AirЁCFuel Sensor Circuit Response Malfunction
    P1135AirЁCFuel Sensor Heater Circuit Response Malfunction
    P1150A./F Sensor Circuit Range/Performance Malfunction
    P1153A./F Sensor Circuit Response Malfunction
    P1155A./F Sensor Heater Circuit Malfunction
    P1200Fuel Pump Relay Circuit Malfunction
    P1300Igniter Circuit Malfunction No. 1
    P1305Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1310Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celica & Tundra), or Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1315Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
    P1320Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra)
    P1325Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra)
    P1330Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra)
    P1335No CKP Sensor Signal Engine Running
    P1340Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra)
    P1345VVT Sensor/Camshaft Position Sensor Circuit Malfunction Bank 1
    P1346VVT Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1)
    P1349VVT System Malfunction Bank 1
    P1350VVT Sensor/Camshaft Position Sensor Circuit Malfunction Bank 2
    P1351VVT Sensor/Camshaft Position Sensor Circuit Range/Performance Problem Bank 2
    P1354VVT System Malfunction Bank 2
    P1400Sub-Throttle Position Sensor Malfunction
    P1401Sub-Throttle Position Sensor Range/Performance Problem
    P1405Turbo Pressure Sensor Circuit Malfunction
    P1406Turbo Pressure Sensor Range/Performance Problem
    P1410EGR Valve Position Sensor Circuit Malfunction
    P1411EGR Valve Position Sensor Circuit Range/Performance
    P1500Starter Signal Circuit Malfunction
    P1510Boost Pressure Control Circuit Malfunction
    P1511Boost Pressure Low Malfunction
    P1512Boost Pressure High Malfunction
    P1520Stop Lamp Switch Signal Malfunction
    P1565Cruise Control Main Switch Circuit Malfunction
    P1600ECM BATT Malfunction
    P1605Knock Control CPU Malfunction
    P1630Traction Control System Malfunction
    P1633ECM Malfunction ECTS Circuit
    P1645Body ECU Malfunction
    P1652IACV Control Circuit Malfunction
    P1656OCV Circuit Malfunction Bank 1
    P1658Waste Gate Valve Control Circuit Malfunction
    P1661EGR Circuit Malfunction
    P1662EGR By-Pass Valve Control Circuit Malfunction
    P1663OCV Circuit Malfunction Bank 2
    P1690OCV Circuit Malfunction
    P1692OCV Open Malfunction
    P1693OCV Closed Malfunction
    P1780PNP Switch Malfunction
    VW_NEW
    P1101O2 Sensor Circ., Bank1-Sensor1 Voltage too Low/Air Leak
    P1102O2 Sensor Heating Circ., Bank1-Sensor1 Short to B+
    P1103O2 Sensor Heating Circ., Bank1-Sensor1 Output too Low
    P1104Bank1-Sensor2 Voltage too Low/Air Leak
    P1105O2 Sensor Heating Circ., Bank1-Sensor2 Short to B+
    P1106O2 Sensor Circ., Bank2-Sensor1 Voltage too Low/Air Leak
    P1107O2 Sensor Heating Circ., Bank2-Sensor1 Short to B+
    P1108O2 Sensor Heating Circ., Bank2-Sensor1 Output too Low
    P1109O2 Sensor Circ., Bank2-Sensor2 Voltage too Low/Air Leak
    P1110O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
    P1111O2 Control (Bank 1) System too lean
    P1112O2 Control (Bank 1) System too rich
    P1113Bank1-Sensor1 Internal Resistance too High
    P1114Bank1-Sensor2 Internal Resistant too High
    P1115O2 Sensor Heater Circ., Bank1-Sensor1 Short to Ground
    P1116O2 Sensor Heater Circ., Bank1-Sensor1 Open
    P1117O2 Sensor Heater Circ., Bank1-Sensor2 Short to Ground
    P1118O2 Sensor Heater Circ., Bank1-Sensor2 Open
    P1119O2 Sensor Heater Circ., Bank2-Sensor1 Short to Ground
    P1120O2 Sensor Heater Circ., Bank2-Sensor1 Open
    P1121O2 Sensor Heater Circ., Bank2-Sensor2 Short to Ground
    P1122O2 Sensor Heater Circ., Bank2-Sensor2 Open
    P1123Long Term Fuel Trim Add.Air., Bank1 System too Rich
    P1124Long Term Fuel Trim Add.Air., Bank1 System too Lean
    P1125Long Term Fuel Trim Add.Air., Bank2 System too Rich
    P1126Long Term Fuel Trim Add.Air., Bank2 System too Lean
    P1127Long Term Fuel Trim mult., Bank1 System too Rich
    P1128Long Term Fuel Trim mult., Bank1 System too Lean
    P1129Long Term Fuel Trim mult., Bank2 System too Rich
    P1130Long Term Fuel Trim mult., Bank2 System too Lean
    P1131Bank2-Sensor1 Internal Rsistance too High
    P1132O2 Sensor Heating Circ., Bank1+2-Sensor1 Short to B+
    P1133O2 Sensor Heating Circ., Bank1+2-Sensor1 Electrical Malfunction
    P1134O2 Sensor Heating Circ., Bank1+2-Sensor2 Short to B+
    P1135O2 Sensor Heating Circ., Bank1+2-Sensor2 Electrical Malfunction
    P1136Long Term Fuel Trim Add.Fuel, Bank1 System too Lean
    P1137Long Term Fuel Trim Add.Fuel, Bank1 System too Rich
    P1138Long Term Fuel Trim Add.Fuel, Bank2 System too Lean
    P1139Long Term Fuel Trim Add.Fuel, Bank2 System too Rich
    P1140Bank2-Sensor2 Internal Resistance too High
    P1141Load Calculation Cross Check Range/Performance
    P1142Load Calculation Cross Check Lower Limit Exceeded
    P1143Load Calculation Cross Check Upper Limit Exceeded
    P1144Mass or Volume Air Flow Circ Open/Short to Ground
    P1145Mass or Volume Air Flow Circ Short to B+
    P1146Mass or Volume Air Flow Circ Supply Malfunction
    P1147O2 Control (Bank 2) System too lean
    P1148O2 Control (Bank 2) System too rich
    P1149O2 Control (Bank 1) Out of range
    P1150O2 Control (Bank 2) Out of range
    P1151Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
    P1152Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
    P1154Manifold Switch Over Malfunction
    P1155Manifold Abs.Pressure Sensor Circ. Short to B+
    P1156Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
    P1157Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
    P1158Manifold Abs.Pressure Sensor Circ. Range/Performance
    P1160Manifold Temp.Sensor Circ. Short to Ground
    P1161Manifold Temp.Sensor Circ. Open/Short to B+
    P1162Fuel Temp.Sensor Circ. Short to Ground
    P1163Fuel Temp.Sensor Circ. Open/Short to B+
    P1164Fuel Temperature Sensor Range/ Performance/ Incorrect Signal
    P1165Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
    P1166Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
    P1171Throttle Actuation Potentiometer Sign.2 Range/Performance
    P1172Throttle Actuation Potentiometer Sign.2 Signal too Low
    P1173Throttle Actuation Potentiometer Sign.2 Signal too High
    P1174Fuel Trim, Bank 1 Different injection times
    P1176O2 Correction Behind Catalyst,B1 Limit Attained
    P1177O2 Correction Behind Catalyst,B2 Limit Attained
    P1178Linear 02 Sensor/ Pump Current Open Circuit
    P1179Linear 02 Sensor/ Pump Current Short to ground
    P1180Linear 02 Sensor/ Pump Current Short to B+
    P1181Linear 02 Sensor/ Reference Voltage Open Circuit
    P1182Linear 02 Sensor/ Reference Voltage Short to ground
    P1183Linear 02 Sensor/ Reference Voltage Short to B+
    P1184Linear 02 Sensor/ Common Ground Wire Open Circuit
    P1185Linear 02 Sensor/ Common Ground Wire Short to ground
    P1186Linear 02 Sensor/ Common Ground Wire Short to B+
    P1187Linear 02 Sensor/ Compens. Resistor Open Circuit
    P1188Linear 02 Sensor/ Compens. Resistor Short to ground
    P1189Linear 02 Sensor/ Compens. Resistor Short to B+
    P1190Linear 02 Sensor/ Reference Voltage Incorrect Signal
    P1196O2 Sensor Heater Circ., Bank1-Sensor1 Electrical Malfunction
    P1197O2 Sensor Heater Circ., Bank2-Sensor1 Electrical Malfunction
    P1198O2 Sensor Heater Circ., Bank1-Sensor2 Electrical Malfunction
    P1199O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
    P1201Cyl.1-Fuel Inj.Circ. Electrical Malfunction
    P1202Cyl.2-Fuel Inj.Circ. Electrical Malfunction
    P1203Cyl.3-Fuel Inj.Circ. Electrical Malfunction
    P1204Cyl.4-Fuel Inj.Circ. Electrical Malfunction
    P1205Cyl.5-Fuel Inj.Circ. Electrical Malfunction
    P1206Cyl.6-Fuel Inj.Circ. Electrical Malfunction
    P1207Cyl.7-Fuel Inj.Circ. Electrical Malfunction
    P1208Cyl.8-Fuel Inj.Circ. Electrical Malfunction
    P1209Intake valves for cylinder shut-off Short circuit to ground
    P1210Intake valves for cylinder shut-off Short to B+
    P1211Intake valves for cylinder shut-off Open circuit
    P1213Cyl.1-Fuel Inj.Circ. Short to B+
    P1214Cyl.2-Fuel Inj.Circ. Short to B+
    P1215Cyl.3-Fuel Inj.Circ. Short to B+
    P1216Cyl.4-Fuel Inj.Circ. Short to B+
    P1217Cyl.5-Fuel Inj.Circ. Short to B+
    P1218Cyl.6-Fuel Inj.Circ. Short to B+
    P1219Cyl.7-Fuel Inj.Circ. Short to B+
    P1220Cyl.8-Fuel Inj.Circ. Short to B+
    P1221Cylinder shut-off exhaust valves Short circuit to ground
    P1222Cylinder shut-off exhaust valves Short to B+
    P1223Cylinder shut-off exhaust valves Open circuit
    P1225Cyl.1-Fuel Inj.Circ. Short to Ground
    P1226Cyl.2-Fuel Inj.Circ. Short to Ground
    P1227Cyl.3-Fuel Inj.Circ. Short to Ground
    P1228Cyl.4-Fuel Inj.Circ. Short to Ground
    P1229Cyl.5-Fuel Inj.Circ. Short to Ground
    P1230Cyl.6-Fuel Inj.Circ. Short to Ground
    P1231Cyl.7-Fuel Inj.Circ. Short to Ground
    P1232Cyl.8-Fuel Inj.Circ. Short to Ground
    P1237Cyl.1-Fuel Inj.Circ. Open Circ.
    P1238Cyl.2-Fuel Inj.Circ. Open Circ.
    P1239Cyl.3-Fuel Inj.Circ. Open Circ.
    P1240Cyl.4-Fuel Inj.Circ. Open Circ.
    P1241Cyl.5-Fuel Inj.Circ. Open Circ.
    P1242Cyl.6-Fuel Inj.Circ. Open Circ.
    P1243Cyl.7-Fuel Inj.Circ. Open Circ.
    P1244Cyl.8-Fuel Inj.Circ. Open Circ.
    P1245Needle Lift Sensor Circ. Short to Ground
    P1246Needle Lift Sensor Circ. Range/Performance
    P1247Needle Lift Sensor Circ. Open/Short to B+
    P1248Injection Start Control Deviation
    P1249Fuel consumption signal Electrical Fault in Circuit
    P1250Fuel Level Too Low
    P1251Start of Injection Solenoid Circ Short to B+
    P1252Start of Injection Solenoid Circ Open/Short to Ground
    P1253Fuel consumption signal Short to ground
    P1254Fuel consumption signal Short to B+
    P1255Engine Coolant Temp.Circ Short to Ground
    P1256Engine Coolant Temp.Circ Open/Short to B+
    P1257Engine Coolant System Valve Open
    P1258Engine Coolant System Valve Short to B+
    P1259Engine Coolant System Valve Short to Ground
    P1280Fuel Inj.Air Contr.Valve Circ. Flow too Low
    P1283Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
    P1284Fuel Inj.Air Contr.Valve Circ. Open
    P1285Fuel Inj.Air Contr.Valve Circ. Short to Ground
    P1286Fuel Inj.Air Contr.Valve Circ. Short to B+
    P1287Turbocharger bypass valve open
    P1288Turbocharger bypass valve short to B+
    P1289Turbocharger bypass valve short to ground
    P1296Cooling system malfunction
    P1297Connection turbocharger - throttle valve pressure hose
    P1300Misfire detected Reason: Fuel level too low
    P1319Knock Sensor 1 Circ. Short to Ground
    P1320Knock Sensor 2 Circ. Short to Ground
    P1321Knock Sensor 3 Circ. Low Input
    P1322Knock Sensor 3 Circ. High Input
    P1323Knock Sensor 4 Circ. Low Input
    P1324Knock Sensor 4 Circ. High Input
    P1325Cyl.1-Knock Contr. Limit Attained
    P1326Cyl.2-Knock Contr. Limit Attained
    P1327Cyl.3-Knock Contr. Limit Attained
    P1328Cyl.4-Knock Contr. Limit Attained
    P1329Cyl.5-Knock Contr. Limit Attained
    P1330Cyl.6-Knock Contr. Limit Attained
    P1331Cyl.7-Knock Contr. Limit Attained
    P1332Cyl.8-Knock Contr. Limit Attained
    P1335Engine Torque Monitoring 2 Control Limint Exceeded
    P1336Engine Torque Monitoring Adaptation at limit
    P1337Camshaft Pos.Sensor, Bank1 Short to Ground
    P1338Camshaft Pos.Sensor, Bank1 Open Circ./Short to B+
    P1339Crankshaft Pos./Engine Speed Sensor Cross Connected
    P1340Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
    P1341Ignition Coil Power Output Stage 1 Short to Ground
    P1342Ignition Coil Power Output Stage 1 Short to B+
    P1343Ignition Coil Power Output Stage 2 Short to Ground
    P1344Ignition Coil Power Output Stage 2 Short to B+
    P1345Ignition Coil Power Output Stage 3 Short to Ground
    P1346Ignition Coil Power Output Stage 3 Short to B+
    P1347Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
    P1348Ignition Coil Power Output Stage 1 Open Circuit
    P1349Ignition Coil Power Output Stage 2 Open Circuit
    P1350Ignition Coil Power Output Stage 3 Open Circuit
    P1354Modulation Piston Displ.Sensor Circ. Malfunction
    P1355Cyl. 1, ignition circuit Open Circuit
    P1356Cyl. 1, ignition circuit Short to B+
    P1357Cyl. 1, ignition circuit Short to ground
    P1358Cyl. 2, ignition circuit Open Circuit
    P1359Cyl. 2, ignition circuit Short Circuit to B+
    P1360Cyl. 2, ignition circuit Short Circuit to Ground
    P1361Cyl. 3, ignition circuit Open Circuit
    P1362Cyl. 3, ignition circuit Short Circuit to B+
    P1363Cyl. 3, ignition circuit Short Circuit to ground
    P1364Cyl. 4, ignition circuit Open Circuit
    P1365Cyl. 4, ignition circuit Short circuit to B+
    P1366Cyl. 4, ignition circuit Short circuit to ground
    P1367Cyl. 5, ignition circuit Open Circuit
    P1368Cyl. 5, ignition circuit Short Circuit to B+
    P1369Cyl. 5, ignition circuit short to ground
    P1370Cyl. 6, ignition circuit Open Circuit
    P1371Cyl. 6, ignition circuit Short Circuit to B+
    P1372Cyl. 6, ignition circuit short to ground
    P1373Cyl. 7, ignition circuit Open Circuit
    P1374Cyl. 7, ignition circuit Short Circuit to B+
    P1375Cyl. 7, ignition circuit short to ground
    P1376Cyl. 8, ignition circuit Open Circuit
    P1377Cyl. 8, ignition circuit Short Circuit to B+
    P1378Cyl. 8, ignition circuit short to ground
    P1386Internal Control Module Knock Control Circ.Error
    P1387Internal Contr. Module altitude sensor error
    P1388Internal Contr. Module drive by wire error
    P1391Camshaft Pos.Sensor,Bank2 Short to Ground
    P1392Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
    P1393Ignition Coil Power Output Stage 1 Electrical Malfunction
    P1394Ignition Coil Power Output Stage 2 Electrical Malfunction
    P1395Ignition Coil Power Output Stage 3 Electrical Malfunction
    P1396Engine Speed Sensor Missing Tooth
    P1397Engine speed wheel Adaptation limit reached
    P1398Engine RPM signal, TD Short to ground
    P1399Engine RPM signal, TD Short Circuit to B+
    P1400EGR Valve Circ Electrical Malfunction
    P1401EGR Valve Circ Short to Ground
    P1402EGR Valve Circ Short to B+
    P1403EGR Flow Deviation
    P1404EGR Flow Basic Setting not carried out
    P1406EGR Temp.Sensor Range/Performance
    P1407EGR Temp.Sensor Signal too Low
    P1408EGR Temp.Sensor Signal too High
    P1409Tank Ventilation Valve Circ. Electrical Malfunction
    P1410Tank Ventilation Valve Circ. Short to B+
    P1411Sec.Air Inj.Sys.,Bank2 Flow too Flow
    P1412EGR Different.Pressure Sensor Signal too Low
    P1413EGR Different.Pressure Sensor Signal too High
    P1414Sec.Air Inj.Sys.,Bank2 Leak Detected
    P1417Fuel Level Sensor Circ Signal too Low
    P1418Fuel Level Sensor Circ Signal too High
    P1420Sec.Air Inj.Valve Circ Electrical Malfunction
    P1421Sec.Air Inj.Valve Circ Short to Ground
    P1422Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
    P1423Sec.Air Inj.Sys.,Bank1 Flow too Low
    P1424Sec.Air Inj.Sys.,Bank1 Leak Detected
    P1425Tank Vent.Valve Short to Ground
    P1426Tank Vent.Valve Open
    P1432Sec.Air Inj.Valve Open
    P1433Sec.Air Inj.Sys.Pump Relay Circ. open
    P1434Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
    P1435Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
    P1436Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
    P1439EGR Potentiometer Error in Basic Seting
    P1440EGR Valve Power Stage Open
    P1441EGR Valve Circ Open/Short to Ground
    P1442EGR Valve Position Sensor Signal too high
    P1443EGR Valve Position Sensor Signal too low
    P1444EGR Valve Position Sensor range/performance
    P1445Catalyst Temp.Sensor 2 Circ. Range/Performance
    P1446Catalyst Temp.Circ Short to Ground
    P1447Catalyst Temp.Circ Open/Short to B+
    P1448Catalyst Temp.Sensor 2 Circ. Short to Ground
    P1449Catalyst Temp.Sensor 2 Circ. Open/Short to B+
    P1450Sec.Air Inj.Sys.Circ Short to B+
    P1451Sec.Air Inj.Sys.Circ Short to Ground
    P1452Sec.Air Inj.Sys. Open Circ.
    P1453Exhaust gas temperature sensor 1 open/short to B+
    P1454Exhaust gas temperature sensor short 1 to ground
    P1455Exhaust gas temperature sensor 1 range/performance
    P1456Exhaust gas temperature control bank 1 limit attained
    P1457Exhaust gas temperature sensor 2 open/short to B+
    P1458Exhaust gas temperature sensor 2 short to ground
    P1459Exhaust gas temperature sensor 2 range/performance
    P1460Exhaust gas temperature control bank 2 limit attained
    P1461Exhaust gas temperature control bank 1 Range/Performance
    P1462Exhaust gas temperature control bank 2 Range/Performance
    P1465Additive Pump Short Circuit to B+
    P1466Additive Pump Open/Short to Ground
    P1467EVAP Canister Purge Solenoid Valve Short Circuit to B+
    P1468EVAP Canister Purge Solenoid Valve Short Circuit to Ground
    P1469EVAP Canister Purge Solenoid Valve Open Circuit
    P1470EVAP Emission Contr.LDP Circ Electrical Malfunction
    P1471EVAP Emission Contr.LDP Circ Short to B+
    P1472EVAP Emission Contr.LDP Circ Short to Ground
    P1473EVAP Emission Contr.LDP Circ Open Circ.
    P1474EVAP Canister Purge Solenoid Valve electrical malfunction
    P1475EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
    P1476EVAP Emission Contr.LDP Circ Malfunction/ Insufficient Vacuum
    P1477EVAP Emission Contr.LDP Circ Malfunction
    P1478EVAP Emission Contr.LDP Circ Clamped Tube Detected
    P1500Fuel Pump Relay Circ. Electrical Malfunction
    P1501Fuel Pump Relay Circ. Short to Ground
    P1502Fuel Pump Relay Circ. Short to B+
    P1503Load signal from Alternator Term. DF Range/ performance/ Incorrect Signal
    P1504Intake Air Sys.Bypass Leak Detected
    P1505Closed Throttle Pos. Does Not Close/Open Circ
    P1506Closed Throttle Pos.Switch Does Not Open/Short to Ground
    P1507Idle Sys.Learned Value Lower Limit Attained
    P1508Idle Sys.Learned Value Upper Limit Attained
    P1509Idle Air Control Circ. Electrical Malfunction
    P1510Idle Air Control Circ. Short to B+
    P1511Intake Manifold Changeover Valve circuit electrical malfunction
    P1512Intake Manifold Changeover Valve circuit Short to B+
    P1513Intake Manifold Changeover Valve2 circuit Short to B+
    P1514Intake Manifold Changeover Valve2 circuit Short to ground
    P1515Intake Manifold Changeover Valve circuit Short to Ground
    P1516Intake Manifold Changeover Valve circuit Open
    P1517Main Relay Circ. Electrical Malfunction
    P1518Main Relay Circ. Short to B+
    P1519Intake Camshaft Contr.,Bank1 Malfunction
    P1520Intake Manifold Changeover Valve2 circuit Open
    P1521Intake Manifold Changeover Valve2 circuit electrical malfunction
    P1522Intake Camshaft Contr.,Bank2 Malfunction
    P1523Crash Signal from Airbag Control Unit range/performance
    P1525Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction
    P1526Intake Camshaft Contr.Circ.,Bank1 Short to B+
    P1527Intake Camshaft Contr.Circ.,Bank1 Short to Ground
    P1528Intake Camshaft Contr.Circ.,Bank1 Open
    P1529Camshaft Control Circuit Short to B+
    P1530Camshaft Control Circuit Short to ground
    P1531Camshaft Control Circuit open
    P1533Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction
    P1534Intake Camshaft Contr.Circ.,Bank2 Short to B+
    P1535Intake Camshaft Contr.Circ.,Bank2 Short to Ground
    P1536Intake Camshaft Contr.Circ.,Bank2 Open
    P1537Engine Shutoff Solenoid Malfunction
    P1538Engine Shutoff Solenoid Open/Short to Ground
    P1539Clutch Vacuum Vent Valve Switch Incorrect signal
    P1540Vehicle Speed Sensor High Input
    P1541Fuel Pump Relay Circ Open
    P1542Throttle Actuation Potentiometer Range/Performance
    P1543Throttle Actuation Potentiometer Signal too Low
    P1544Throttle Actuation Potentiometer Signal too High
    P1545Throttle Pos.Contr Malfunction
    P1546Boost Pressure Contr.Valve Short to B+
    P1547Boost Pressure Contr.Valve Short to Ground
    P1548Boost Pressure Contr.Valve Open
    P1549Boost Pressure Contr.Valve Short to Ground
    P1550Charge Pressure Deviation
    P1551Barometric Pressure Sensor Circ. Short to B+
    P1552Barometric Pressure Sensor Circ. Open/Short to Ground
    P1553Barometric/manifold pressure signal ratio out of range
    P1554Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
    P1555Charge Pressure Upper Limit exceeded
    P1556Charge Pressure Contr. Negative Deviation
    P1557Charge Pressure Contr. Positive Deviation
    P1558Throttle Actuator Electrical Malfunction
    P1559Idle Speed Contr.Throttle Pos. Adaptation Malfunction
    P1560Maximum Engine Speed Exceeded
    P1561Quantity Adjuster Deviation
    P1562Quantity Adjuster Upper Limit Attained
    P1563Quantity Adjuster Lower Limit Attained
    P1564Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation
    P1565Idle Speed Control Throttle Position lower limit not attained
    P1566Load signal from A/C compressor range/performance
    P1567Load signal from A/C compressor no signal
    P1568Idle Speed Contr.Throttle Pos. mechanical Malfunction
    P1569Cruise control switch Incorrect signal
    P1570Contr.Module Locked
    P1571Left Eng. Mount Solenoid Valve Short to B+
    P1572Left Eng. Mount Solenoid Valve Short to ground
    P1573Left Eng. Mount Solenoid Valve Open circuit
    P1574Left Eng. Mount Solenoid Valve Electrical fault in circuit
    P1575Right Eng. Mount Solenoid Valve Short to B+
    P1576Right Eng. Mount Solenoid Valve Short to ground
    P1577Right Eng. Mount Solenoid Valve Open circuit
    P1578Right Eng. Mount Solenoid Valve Electrical fault in circuit
    P1579Idle Speed Contr.Throttle Pos. Adaptation not started
    P1580Throttle Actuator B1 Malfunction
    P1581Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out
    P1582Idle Adaptation at Limit
    P1583Transmission mount valves Short to B+
    P1584Transmission mount valves Short to ground
    P1585Transmission mount valves Open circuit
    P1586Engine mount solenoid valves Short to B+
    P1587Engine mount solenoid valves Short to ground
    P1588Engine mount solenoid valves Open circuit
    P1600Power Supply (B+) Terminal 15 Low Voltage
    P1602Power Supply (B+) Terminal 30 Low Voltage
    P1603Internal Control Module Malfunction
    P1604Internal Control Module Driver Error
    P1605Rough Road/Acceleration Sensor Electrical Malfunction
    P1606Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
    P1607Vehicle speed signal Error message from instrument cluster
    P1608Steering angle signal Error message from steering angle sensor
    P1609Crash shut-down activated
    P1611MIL Call-up Circ./Transm.Contr.Module Short to Ground
    P1612Electronic Control Module Incorrect Coding
    P1613MIL Call-up Circ Open/Short to B+
    P1614MIL Call-up Circ./Transm.Contr.Module Range/Performance
    P1615Engine Oil Temperature Sensor Circuit range/performance
    P1616Glow Plug/Heater Indicator Circ. Short to B+
    P1617Glow Plug/Heater Indicator Circ. Open/Short to Ground
    P1618Glow Plug/Heater Relay Circ. Short to B+
    P1619Glow Plug/Heater Relay Circ. Open/Short to Ground
    P1620Engine coolant temperature signal open/short to B+
    P1621Engine coolant temperature signal short to ground
    P1622Engine coolant temperature signal range/performance
    P1623Data Bus Powertrain No Communication
    P1624MIL Request Sign.active
    P1625Data-Bus Powertrain Unplausible Message from Transm.Contr.
    P1626Data-Bus Powertrain Missing Message from Transm.Contr.
    P1627Data-Bus Powertrain missing message from fuel injection pump
    P1628Data-Bus Powertrain missing message from steering sensor
    P1629Data-Bus Powertrain missing message from distance control
    P1630Accelera.Pedal Pos.Sensor 1 Signal too Low
    P1631Accelera.Pedal Pos.Sensor 1 Signal too High
    P1632Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction
    P1633Accelera.Pedal Pos.Sensor 2 Signal too Low
    P1634Accelera.Pedal Pos.Sensor 2 Signal too High
    P1635Data Bus Powertrain missing message f.air condition control
    P1636Data Bus Powertrain missing message from Airbag control
    P1637Data Bus Powertrain missing message f.central electr.control
    P1638Data Bus Powertrain missing message from clutch control
    P1639Accelera.Pedal Pos.Sensor 1+2 Range/Performance
    P1640Internal Contr.Module (EEPROM) Error
    P1641Please check DTC Memory of Air Condition ECU
    P1642Please check DTC Memory of Airbag ECU
    P1643Please check DTC Memory of central electric ECU
    P1644Please check DTC Memory of clutch ECU
    P1645Data Bus Powertrain missing message f.all wheel drive contr.
    P1646Please Check DTC Memory of all wheel drive ECU
    P1647Please check coding of ECUs in Data Bus Powertrain
    P1648Data Bus Powertrain Malfunction
    P1649Data Bus Powertrain Missing message from ABS Control Module
    P1650Data Bus Powertrain Missing message fr.instrument panel ECU
    P1651Data Bus Powertrain missing messages
    P1652Please check DTC Memory of transmission ECU
    P1653Please check DTC Memory of ABS Control Module
    P1654Please check DTC Memory of control panel ECU
    P1655Please check DTC Memory of ADR Control Module
    P1656A/C clutch relay circuit short to ground
    P1657A/C clutch relay circuit short to B+
    P1658Data Bus Powertrain Incorrect signal from ADR Control Module
    P1676Drive by Wire-MIL Circ. Electrical Malfunction
    P1677Drive by Wire-MIL Circ. Short to B+
    P1678Drive by Wire-MIL Circ. Short to Ground
    P1679Drive by Wire-MIL Circ. Open
    P1681Contr.Unit Programming, Programming not Finished
    P1684Contr.Unit Programming Communication Error
    P1686Contr.Unit Error Programming Error
    P1690Malfunction Indication Light Malfunction
    P1691Malfunction Indication Light Open
    P1692Malfunction Indication Light Short to Ground
    P1693Malfunction Indication Light Short to B+
    P1694Malfunction Indication Light Open/Short to Ground
    P1704Kick Down Switch Malfunction
    P1705Gear/Ratio Monitoring Adaptation limit reached
    P1711Wheel Speed Signal 1 Range/Performance
    P1716Wheel Speed Signal 2 Range/Performance
    P1721Wheel Speed Signal 3 Range/Performance
    P1723Starter Interlock Circ. Open
    P1724Starter Interlock Circ. Short to Ground
    P1726Wheel Speed Signal 4 Range/Performance
    P1728Different Wheel Speed Signals Range/Performance
    P1729Starter Interlock Circ. Short to B+
    P1733Tiptronic Switch Down Circ. Short to Ground
    P1739Tiptronic Switch up Circ. Short to Ground
    P1740Clutch temperature control
    P1741Clutch pressure adaptation at limit
    P1742Clutch torque adaptation at limit
    P1743Clutch slip control signal too high
    P1744Tiptronic Switch Recognition Circ. Short to Ground
    P1745Transm.Contr.Unit Relay Short to B+
    P1746Transm.Contr.Unit Relay Malfunction
    P1747Transm.Contr.Unit Relay Open/Short to Ground
    P1748Transm.Contr.Unit Self-Check
    P1749Transm.Contr.Unit Incorrect Coded
    P1750Power Supply Voltage Low Voltage
    P1751Power Supply Voltage High Voltage
    P1752Power Supply Malfunction
    P1760Shift Lock Malfunction
    P1761Shift Lock Short to Ground
    P1762Shift Lock Short to B+
    P1763Shift Lock Open
    P1764Transmission temperature control
    P1765Hydraulic Pressure Sensor 2 adaptation at limit
    P1766Throttle Angle Signal Stuck Off
    P1767Throttle Angle Signal Stuck On
    P1768Hydraulic Pressure Sensor 2 Too High
    P1769Hydraulic Pressure Sensor 2 Too Low
    P1770Load Signal Range/Performance
    P1771Load Signal Stuck Off
    P1772Load Signal Stuck On
    P1773Hydraulic Pressure Sensor 1 Too High
    P1774Hydraulic Pressure Sensor 1 Too Low
    P1775Hydraulic Pressure Sensor 1 adaptation at limit
    P1776Hydraulic Pressure Sensor 1 range/performance
    P1777Hydraulic Pressure Sensor 2 range/performance
    P1778Solenoid EV7 Electrical Malfunction
    P1780Engine Intervention Unreadable. Also check for loose ECM power relay.
    P1781Engine Torque Reduction Open/Short to Ground
    P1782Engine Torque Reduction Short to B+
    P1784Shift up/down Wire Open/Short to Ground
    P1785Shift up/down Wire Short to B+
    P1786Reversing Light Circ. Open
    P1787Reversing Light Circ. Short to Ground
    P1788Reversing Light Circ. Short to B+
    P1789Idle Speed Intervention Circ. Error Message from Engine Contr.
    P1790Transmission Range Display Circ. Open
    P1791Transmission Range Display Circ. Short to Ground
    P1792Transmission Range Display Circ. Short to B+
    P1793Output Speed Sensor 2 Circ. No Signal
    P1795Vehicle Speed Signal Circ. Open
    P1796Vehicle Speed Signal Circ. Short to Ground
    P1797Vehicle Speed Signal Circ. Short to B+
    P1798Output Speed Sensor 2 Circ. Range/Performance
    P1799Output Speed Sensor 2 Circ. Rpm too High
    P1813Pressure Contr.Solenoid 1 Electrical
    P1814Pressure Contr.Solenoid 1 Open/Short to Ground
    P1815Pressure Contr.Solenoid 1 Short to B+
    P1818Pressure Contr.Solenoid 2 Electrical
    P1819Pressure Contr.Solenoid 2 Open/Short to Ground
    P1820Pressure Contr.Solenoid 2 Short to B+
    P1823Pressure Contr.Solenoid 3 Electrical
    P1824Pressure Contr.Solenoid 3 Open/Short to Ground
    P1825Pressure Contr.Solenoid 3 Short to B+
    P1828Pressure Contr.Solenoid 4 Electrical
    P1829Pressure Contr.Solenoid 4 Open/Short to Ground
    P1830Pressure Contr.Solenoid 4 Short to B+
    P1834Pressure Contr.Solenoid 5 Open/Short to Ground
    P1835Pressure Contr.Solenoid 5 Short to B+
    P1841Engine/Transmission Control Modules Versions do not match
    P1842Please check DTC Memory of instrument panel ECU
    P1843Please check DTC Memory of ADR Control Module
    P1844Please check DTC Memory of central electric control ECU
    P1847Please check DTC Memory of brake system ECU
    P1848Please check DTC Memory of engine ECU
    P1849Please check DTC Memory of transmission ECU
    P1850Data-Bus Powertrain Missing Message from Engine Contr.
    P1851Data-Bus Powertrain Missing Message from Brake Contr.
    P1852Data-Bus Powertrain Unplausible Message from Engine Contr.
    P1853Data-Bus Powertrain Unplausible Message from Brake Contr.
    P1854Data-Bus Powertrain Hardware Defective
    P1855Data-Bus Powertrain Software version Contr.
    P1856Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
    P1857Load Signal Error Message from Engine Contr.
    P1858Engine Speed Input Circ. Error Message from Engine Contr.
    P1859Brake Switch Circ. Error Message from Engine Contr.
    P1860Kick Down Switch Error Message from Engine Contr.
    P1861Throttle Position (TP) sensor Error Message from ECM
    P1862Data Bus Powertrain Missing message from instr. panel ECU
    P1863Data Bus Powertrain Missing Message from St. Angle Sensor
    P1864Data Bus Powertrain Missing message from ADR control module
    P1865Data Bus Powertrain Missing message from central electronics
    P1866Data Bus Powertrain Missing messages
    Последно редактирано от Beco; 04-11-09, 11:41.
