Фонтан и пожар на сондажна платформа до Луизиана
  • Фонтан и пожар на сондажна платформа до Луизиана
    Неприятна история, добре е че поне няма пострадали:
    The chain of events began when a blowout and a loss of well control occurred Tuesday while work was being done for well A-3 in 154 feet of water off the coast of Louisiana. Forty-four personnel were safely evacuated from the Hercules 265 jackup, and there were no injuries
    A portion of the Hercules 265 (250’ MC) jackup has collapsed after catching fire
    Tuesday night, the Bureau of Safety and Environmental Enforcement (BSEE) said Wednesday.
    “Two firefighting vessels were in the area and re-located a safe distance from the fire.
    A third vessel equipped with fire-fighting capability and improved monitoring system is enroute and expected to arrive late morning.
    The 87-foot Coast Guard Cutter Pomano is standing by to assess the situation and enforce the security zone.
    The Coast Guard Cutter Cypress is enroute and will arrive at approximately noon,” the BSEE said in a press statement.
    The fire started around 10:50 p.m. Tuesday evening, when natural gas leaking from the A-3 natural gas well at South Timbalier Block 220 ignited off the coast of Louisiana. The fire then spread to the Hercules jackup.
    As the fire continued to burn, the beams supporting the derrick and the rig floor folded and collapsed over the rig structure.
    BSEE said that under its direction, Walter Oil & Gas, owner of the well, has begun moving a jackup to the location if adecision is made to drill a relief well.
    От: Фонтан и пожар на сондажна платформа до Луизиана
    Пожар е избухнал на платформа за добив на газ в Мексиканския залив на 55 мили (85 км) край бреговете на Луизиана, предаде Би Би Си, цитирайки американски служители. Взрив във вторник сутринта принуди евакуацията на 44 работници от платформата. Бреговата охрана на САЩ и федералните власти все още се опитват да се оценят потенциалната опасност, съобщава novini.bg. Районът е близо до мястото на инцидента с платформата Deepwater Horizon, при който, през 2010 г., изтекоха милиони литри петрол. Новият взрив не е с такива мащаби, казаха длъжностни лица пред Асошиейтед прес. Портативната сондажна машина, която работи в плитките води на 47 метра, е собственост на Hercules, изпълнител на проекти на Walter Oil & Gas Corporation. "Огънят продължава да гори, но структурата на платформата е все още непокътната", заяви говорителят на бреговата охрана Карлос Вега. Не е ясно каква е причината за експлозията.
    Прочети повече на: http://profit.bg/news/Pozhar-e-izbuh...id-110013.html
    LZ1ZAH
