TatraT138
  • TatraT138
    The Tatra T138 was a truck produced in Czechoslovakia by the Tatra company. The immediate successor to the legendary Tatra T111, the model introduced a number of new features while continuing the evolution of Tatra concept. The truck was produced from 1959 to 1971.
    T 138
    Tatra 138 S1
    Manufacturer Tatra
    Predecessor Tatra T111
    Successor Tatra T148
    Class Heavy Truck
    Body style(s)Conventional
    Engine(s)V8 diesel
    Electric range24 V 500 W generator, 24 V 4.4 kW starter motor
    History
    The decision to replace the Tatra T111 was made in 1952 as part of a central state planning economy, where Tatra Kopřivnice was to produce 7-10 ton utility trucks. In 1956 at II. Czechoslovak Machinery Expo in Brno, Tatra exhibited 2 new models, the T137 and T138. Both vehicles had up to 70% of parts in common across the range. New design features were introduced, such as improvement in driver environment and usability e.g. hydraulic power steering, a compressed air assisted clutch and electro-pneumatic auxiliary gearbox gear selection.
    Design and Technology
    The design was of central backbone tube construction with modular power train concept in 4x4 and 6x6 configuration. The main advantages of central load carrying backbone tube are in its high torsion and bend strength protecting truck body against load stresses. The secondary advantage is that it houses all important parts of the drive train. In addition, it enables a concept of modular construction where designers and customers can specify 4, 6, wheel drive and various length and wheelbase combinations.
    Engine
    The engine was located ahead of the front axle. It featured an Aircooled V8 with dry sump design and a new featured thermostat controlled cooling fan by engine oil temperature via hydraulic clutch drive to reduce noise and fuel consumption. The engine was also used in the OT-64 APC.
    T 928
    Engine T138
    Manufacturer Tatra
    Type:V8
    Bore:120 mm (4.7 in)
    Stroke:130 mm (5.1 in)
    Displacement:11,762 cc
    Dry weight:595 kg (1,312 lb)
    Block alloy:Cast iron
    Head alloy:Aluminium alloy
    Valvetrain:OHV
    Fuel system: Direct injection
    Fuel type: Diesel
    Cooling system:Aircooled
    Power output:132.5 kW @ 2000 rpm
    Torque output:720 N·m (530 ft·lbf) @ 1200 rpm
    Compression ratio:16.5:1
    Fuel consumption:36 L/100 km (7.8 mpg imp/6.5 mpg US)
    Chassis
    Central backbone tube, front and rear axles with independent swing half axles. The front suspension by torque arms (torsion bars) and hydraulic shock absorbers. The rear suspension by longitudinal half elliptic leaf springs. Front axle drive selectable on demand, differential locks electro-pneumatically controlled via dash switches.
    • Front track = 1,930 mm (76.0 in)
    • Rear track = 1,752 mm (69.0 in)
    • Wheelbase = model specific
    • Tatra T138 6x6 PP2, P3, PP6 = 4,260 mm (167.7 in)+1,320 mm (52.0 in)
    • Tatra T138 6x6 PR14, PPR S3, PR S1, P19 = 3,690 mm (145.3 in)+1,320 mm (52.0 in)
    • Tatra T138 4x4 = 4,550 mm (179.1 in)
    • Ground clearance = 290 mm (11.4 in)
    T 138 chassis
    Transmision
    Main gearbox - 5+1 (2-5 gear synchronized)
    Auxiliary gearbox - 2 speed (half split electro-pneumatic control)
    Step down transfer case
    Clutch - 2x plate dry
    Brakes
    Main wheel brakes ----> dual circuit full air drum brakes
    Park brake ----> mechanical via output shaft at the back of the gearbox
    Supplementary brake ----> exhaust brake electro-pneumatically controlled
    Bodywork
    All steel cab construction with various body builder equipment such as tippers, flatbeds, concrete mixers, tankers, cranes, excavators and firefighting. The vehicle had a top speed of 72 km/h, capable of water crossing depth 800 mm (31 in), with maximum payload of 12,000 kg (26,500 lb) and could tow trailers up to 15,000 kg (33,100 lb) GCM.
    Production
    Total production exceeded 45,900. The Tatra T138 was exported to theUSSR, Bulgaria, Romania, Poland, France, Austria and the Netherlands
    Primary variants:
    T138 S1 - one-way tipper
    T138 S3 - three-way tipper
    T138 V,VN - civilian and military flatbed
    T138 P1V - military special
    T138 CAS - firefighting unit
    T138 PP6V - excavator
    T138 PP5, PP4V, PP7 - tanker
    T138 P3, P11, P18, PP2, PP5, PP6, PP7, PP8V - crane
    T138 PP7 - concrete mixer
    T138 VVN
    T138 CAS fire
