За почитатели и фенове на БПЛА се предлага тази статия на The Washington Post
When drones fall from the sky.
От: When drones fall from the sky.
Един от коментарите по статията...This article does an okay job explaining some of the issues that the UAV community has. Having said that I will complete the picture a bit. One of things to point out that it is not fair to compare these aircraft to ones that will be used in the civil airspace in the future. I flew MQ-1’s for 4 years including a launch tour. First off, these airplanes were originally designed just to be an “Eye in the Sky.” At some point 2004 we figured out that we could put some rockets on them, or more accurately the Hellfire missile on them. One thing to point out these airplanes have flown in some real demanding environments from mountains in Afghanistan to some of the densest airspace of Iraq.
Because these were unmanned, we did push them right on the edge envelope. They fly 2 to 3 times longer than their manned counterparts. We did operate them in weather that generally we would not put a manned plane in. There were many times when I thought, I was going to lose one in some bad weather but I lucky and got it out okay. Some of my counterparts were not so lucky. Like any system mishaps occur either due to mechanical failures, lack of training or complacency. At the end of the day a commercial operation will not require aircraft like these to fly under the stringent conditions and that is something important to point out. For commercial operations systems training and emergency procedures will be cornerstone over any other function of the aircraft. I think there is no better time than now to bring in a commercial arena, because of what we learned in over a decade of flying these in some of the most challenging environments you could put them through their paces. We now have a large cadre of competent pilots that have been doing this for a long time.
Толкова много перки направо си проси да го замериш с нещо. На прима виста се сещам за много едра мрежа (20х20 см...) от леко влакно и тежести по крайщата. Трябва да се подбере дизайна така, че да се отваря правилно във въздуха, а също и метода на изстрелване-от ръка, с прашка, сгъстен въздух, нещо огнестрелно (има самоделки за изстрелване на картофи в ю-тубата...).Toyota Land Cruiser BJ70 1985
Lexus LS430
Няма как да слагаме под общ знаменател всички дрони. Има съвсем обикновенни, има и такива с наченки на Изкуствен Интелект. Например X-47 при един от полетите си от палубата на самолетоносач, реши сам, че е твърде опасно да кацне и взе свое решение да се приземи на най-близката база ... времето на терминаторът идва
Но принципно навлизат все повече и повече, и за в бъдеще ще видим доста от това на какво са способни.
Иначе на мен този ми харесва:
Много евтин, може да се произведе в неограничени количества и ще спаси стотици, ако не хиляди живота на пехотинците.
Примерно в градски боеве, като Чечня (Грозни), Сирия или срещу партизански и паравоенни формирования. Може да надникне по етажите и покривите за хора с РПГ, снайпери, да огледа за засади и т.н докато операторът е скрит зад ъгъла или в бронираната машина.
Кое ти харесва повече? Компютърната анимация или пироефектите..?!!Първоначално публикуван от nitro Преглед на мнение
Харесват ми Възможностите...
Човека се е постарал, защо да не подпали малко за по-голяма показност ?
Иначе кое ти се струва нереално за прилагане в действителност ? Автоматът ли, или фърчилото, или камерата на него, или джойстика за управление ? Или кое ?
Автомата е най-нереалната част, има откат пустият.
Не е евтино, никак даже - сложна и капризна механика и електроника, особено ако ти трябва за военни цели.
Уязвимо е за всякакво огнестрелно оръжие (че и за прашка даже).
Върши работа само за неподвижни , неоказващи съпротива цели, на 3-5м разстояние, в добри метео условия, и то ако наоколо има няколко камери които да ти показват добре цялата обстановка.
По отношение на неограничената бройка - към всяко трябва да прикрепиш и по един пилот и механик, а те са краен брой.
Да не забравяме и че докато някой го управлява поне двама ще трябва да го пазят.
Я да си представим как това нещо ще се представи в реална обстановка. Когато звукът му ще указва къде е и боец с автомат за $100 ще го сваля от 50-100м. Ако добавим и радиосмущения, дим и т.н.
За сега единствената полза от тези хвърчила е за наблюдение от разстояние на обстановката.
За такива цели се използват масово и в момента. Най-много да изстрелят някоя и друга самонасочваща се ракетка.
Иначе и сега можеш да си купиш такова в България (без автомат) http://aerocam.bg/shop/index.php?rou...&product_id=50. Е не е милитари оцветено.Fear is the path to the dark side. Fear leads to anger. Anger leads to hate. Hate leads to suffering.
Е, няма перфектно оръжие - всички си имат по някой недостатък.
За откатът не мисля, че е неразрешим проблема - хората са разрешили къде по-големи. Иначе възможността да разузнаеш обстановката, без да даваш жертви е много добро начало за развитие на подобно оръжие. Разбира се има някой държави и военни школи, които не определят собствените си жертви като фактор, подтикващ към иновации и създаване на нови системи.
Иначе подобно хвърчило-автомат, във военен вариант не мисля, че ще надхвърли 5-10 хиляди долара бройката със всичките му спец системи, което го прави много евтино. Това е прашинка от гледна точка милиардите хвърлени за война и негативизма на общественото мнение спрямо собствените жертви в белите демократични държави.
Значи безпилотните апарати понякога падат и-и изобщо аварират. Верно ли баси, това е епохално прозрение, равностойно на колелото...
А как седи въпросът с количеството загинали пилоти при тези аварии, или пък катапултиралите се и попаднали в плен, или проведени операции за евакуация на екипажи, при които се поставят в риск и евентуално загиват и други хора? А въпросът откъм чисто материалната страна - колко струва едно такова хвърчило, сравнено с пилотиран самолет?
Самият факт, че след най-боеспособната армия, на най-богатата и развита държава в света - в такава посока почват да работят ред други, вече е достатъчно показателен.
Самите хвърчилки, от просто пособие за наблюдение, успешно се справят и като оръжейни платформи.
Ма някому (от когото и нищо не зависи) не му харесвали - ми негова си работа.Прави каквото трябва, пък да става каквото ще!
Безпилотните апарати засега, а вероятно и завинаги, са важен и съществен елемент, само когато противниците са на порядъци технологично назад... При еднакво или близко ниво на технологичност... всякакви безпилотни и прочие автоматизирани системи нуждаещи се от изчислителна техника и връзка от какъвто и да е порядък и вид, са само разход без приход... Който му трябва знае защо...
Не само на който му трябва, а и огромно множество средно технически грамотни хора - знаят защо. И какво следва от това - че те не са стратегическо оръжие, адекватно срещу стратегически противник. Поне на този етап (10-15 години от началото на практическото им приложение) категорично
Ми то и това би било едно прозрение, нареждащо се до горните...Прави каквото трябва, пък да става каквото ще!
Ама изключително важен пост по темата:
А иначе, сега тоя пич от видеото, дето стреля по тикви, ли намерихте да давате за пример за изобретател?!Първоначално публикуван от nitro Преглед на мнениеЕ, няма перфектно оръжие - всички си имат по някой недостатък.
Иначе подобно хвърчило-автомат, във военен вариант не мисля, че ще надхвърли 5-10 хиляди долара бройката със всичките му спец системи, което го прави много евтино. Това е прашинка от гледна точка милиардите хвърлени за война и негативизма на общественото мнение спрямо собствените жертви в белите демократични държави.Всеки трети е шести
Това от оппит ли го казваш? Доста от дроновете по време на операции се управляват от друг континент. Тези в Афганиста се управляват от оператори, които не са там. Та освен да си пазят кафето да не изстине, не виждам какво друго има за пазене. Вярно, има доста дронове по инженерните машини, които се управляват от един член на екипажа. Има кой да го "пази", но така или иначе машината излезе ли навън, вся някой трябва да я пази. И не на последно място е реално обстановка се представят отлично и са не заменими. Относно свалянето им с автомат. Във видео игрите става. В реалния живот няма много смисъл да си разкриеш позицията пред многочислен враг, особено когато ползваш елемента на изненадата. А дронове има много. Радиосмущенията не им пречат. Дори и джамърите не им оказват влияние. За дим е бесмислено да коментираме. Може би съветския вариант е чувствителен към дим и алкохолнии пари.По отношение на неограничената бройка - към всяко трябва да прикрепиш и по един пилот и механик, а те са краен брой.
Пряко съм наблюдавал работата на няколко вида летящи дрони (витлови и с реактивен двигател) и няколко вида пълзящи (веришни и колесни, от най-малките до най-големите), така че впечатленията ми са от личен опит. Дроните са незаменим помощник.
П.П. А относно пускането на темата и покриването на автора и, което е от рода "вижте как падат американските дрони, щото са американски" мога да му пусна линк свързан с ядрените електроцентрали от рода "в Чернобил имат безплатни фоерверки и светят в тъмното".If you can't stand behind our troops feel free to stand in front of them!
Ти още ли си с представа че войната ще се води само срещу единственно по-слабо развит технологичен противник? Тези папуаските войни са пред свършване, ако не и са се свършили вече. Този факт вече и отвъд океан са си вече разбрали, и според мен затова и излязла тази статия. Това ли искаш от мен да чуеш, или за съветските дронове?
