Това ще ми върши ли работа (PX-777)
  • Това ще ми върши ли работа (PX-777)
    Frequency Range
    PX-777(U)465 ~520MHz
    Channels
    118
    Channel Steps
    5k,10k,6.25k,12.5k,25k
    Power Supply
    7.2V 1200mah LI-ion
    Operating Temperature
    -20°C ~ +60°C
    Communication Range
    3 ~6km
    Dimension (H x W x D)
    100 x 55.5 x 31mm
    Weight
    225g
    Receiver
    Sensitivity
    <0.20μV
    Selectivity
    65dB
    Intermodulation Rejection
    60dB
    AF Output
    500mW
    Standby Current
    35mA
    Transmitter
    Power Output
    (VHF)5W, (UHF)4W
    Modulation Type
    F3E
    Spurious Emission
    < -65dB
    Transmit Current
    1300mA/750mA
    Max. Deviation
    ±5kHz
    Modulation Distortion
    < 5%
    Frequency Stability
    ±2.5ppm
    "Ако не можеш да ги убедиш, объркай ги."
    До: Това ще ми върши ли работа (PX-777)
    а тази
    . DTMFencoding and DTMFdecoding
    . Output power VHF 5W/1W UHF 4W/1W
    . High/Low power can changeable in temporary
    . VOX (Level adjustable)
    . 105 groups D.C.S/50 groups CTCSS
    . Allcall, groupcall and selectcall.
    . ANI (Caller ID)
    . Scrambler available (Optional accessory)
    . 128 memory channels and 1 group emergency channel
    . Channel name edit available
    . Voice guide (Chinese /English)
    . Side key programmable
    . Wide/Narrow bandwidthselection (12.5KHz/25KHz)
    . FMradio function
    . Come with 1300mAh/1700mah Li-ion battery and intelligent charger
    . Frequency/Channel/Frequency+Channel display mode
    . Multi scan mode (TO/CO/SE)
    . Calling ring and ring overtime auto answer
    . Channel steps (5K/6.25K/10K/12.5K/25K)
    . Three color LCD backlight display
    . Multi silent mode (QT/QTADT/QTXDT)
    . Distant urgency
    . Keyboard lock (Auto/Manual)
    . Reverse frequency function
    . Input frequency by using keypad
    . PC software disable frequency input
    . Busy channel lockout
    . Programmable by computer
    . Menu/Channel reset
    .Wireclone function
    Frequency Range
    KG-679(U)400 ~470MHz
    Memory Channels
    128+1
    Channel
    Co-channel or Simplex or Duplex
    Power Supply
    7.4V 1200mah LI-ion
    -30°C ~ +60°C
    Communication Range
    3 ~6km
    106 x 63 x 38mm
    Weight
    250g
    Receiver
    Sensitivity
    <0.20μV
    Selectivity
    65dB
    60dB
    AF Output
    500mW
    Standby Current
    35mA
    Transmitter
    Power Output
    (UHF) 4W (VHF) 5W
    Modulation Type
    F3E
    Spurious Emission
    < -65dB
    Transmit Current
    700mA / 350mA
    Max. Deviation
    ±5kHz
    < 5%
    Frequency Stability
    ±5ppm
    хайде колеги трябва ми за offroad
      По-добре първата.
        Първата не става за PMR446 в тоя и вариант(465-520).
        Търси тия трите:
        1. Puxing PX-888
        2. Weierwei V1000
        3. Wouxun KG-689Plus
        Не че другите не стават, но това, дето съм изброил са топ-моделите. И софтуера им е по-малко бъгава. Иначе всички ще ти свършат работа.
        Търси версията UHF 400-470, или 400-480Mhz. С втория диапазон са ми PX-888-ците.
        Имал съм ги всичкитие. Аз най-си падам по 888-цата. С V1000 разликата е само в пластмасите отвън.
        Имал съм VEV-3288, PX-777, PX-777+, PX-328, V1000, PX-888, KG-689+, KG-689E
        VEV-3288,PX777 и PX-328 са една и съща станция.
        PX-777PLUS e по-добре, но допълнителните екстри едва ли ще ти свършат някаква работа.
        PX-888 и V1000, също са една и съща станция.
        Всичките се правят в един и същ завод от едни и същи хора.
        Wouxun-ите са друга бира. Малко са по-сложни. Каналите са с копчета нагоре-надолу, вместо с врътка. Имат хиляди настройки. Ама се свиква.
        Та, въпрос на вкус.
        Пазарувам от www.409shop.com и www.radiogearpro.com
        Плаща се като в еBay през PayPal. Идват направо в кварталната поща.
        Снабдих и няколко колеги на приятелски начала. Недоволни засега няма, а само напротив.
        Giorgio има KG-689Plus, Zaarin има PX-777+ и VEV-3288s, kro има V1000.
        kolonal има PX-777.
        Питай ги и тях, ако искаш. Но досега съм чул само положителни отзиви.
        Последно редактирано от sparkybg; 04-08-08, 09:26.
          Опа, не обърнах внимание, че започва от 462МХц.
            Първоначално публикуван от Lazar Преглед на мнение
            Абе то си има и правилната версия. Аз за това му го натъртих. Да не вземе за сбърка.
            Пък и те обикновено се "разширяват" с 20-ина Mhz надолу и 10-20 нагоре. Въпроса е че това със сигурност няма да му върши повече работа от 400-470. Няма сми.
            Да не би и ти да си имал нещо от тия пущини?
              Да, имал съм и повече никога няма да си купя...но аз имам други изисквания и затова, иначе вършат работа.
                E, сподели какви са им били кусурите за твойте цели. Ако не е тайна де. Ще е полезно, не само за мен.
                Аз ги ползвам за PMR, и сериозни кусури, освен бъгавия софтуер за програмиране (което при последните вече го няма), не съм намерил.
                В смисъл, не виждам по-добра алтернатива на скъпарските маркови за PMR.
                  Ами като започнеш от елементната база, толерансите на която бяха огромни, минеш през фърмуера(20-тина версии) на процесора и завършиш с схемните решения - цялото е една огромна китайска чалга. Затова е и евтино.
                    Е, вече фърмуера е еднакъв. Има един за PX777/328/VEV3288, един за PX777+, един за PX-888, и един за V1000.
                    При това на PX-888 и V1000 всичко работи, както трябва. В смисъл, всичко, което го има в спецификациите, си работи и софтуера си го програмира. При 777-ите наистина е малко хаос.
                    Иначе за другото сигурно си прав, но пък не съм забелязал нещо да не работи както трябва, а сигурно има.
                      Една и съща станцийка лятото работи перфектно, а зимата й оглушава приемника и започва да забива софтуерно. Друга станцийка мощността на предавателя й варираше с около 0.8 вата при минус 5* до плюс 10*и не, не заради батерията, щото тестовете са правени на външно стабилизирано захранване.. Друга пък стабилността на честотата й варираше с около 3 кХц....
                      И всичко т'ва , щото са наблъскани с евтини елементи с толеранс 30%
                      Не, че не работят напълно, просто параметрите им "шарят" в много големи граници, а за мен това е неприемливо.
                        Нищо от това не ми се с случвало. Иначе съм чувал че преди е имало такива проблеми.
                        Има честотомер и КСВ метър.
                        Мерил съм мойте, почти всичките. PX-888-цата даже доста обстойно. от 20 градуса до около 60 (пареше - бях я забравил в колата на жегите), честотата мърда със 100-ина херца.
                        Ще взема да я сложа във фризера, да видя как ще се представи.
                        Имал съм досег с над 10-ина станции от тия. Не съм забелязал да имат проблемите, посочени от теб.
                          Имат си, имат проблеми, но пак ти казвам - много съм капризен в това отношение, иначе за обикновения потребител са си екстра.
                          П.П.
                          Дори напоследък и Yeasu не ме кефят. Предпочитам Icom.
                            П.П.
                            Въпрос на вкус, аз лично не харесвам Icom.Yaesu не е върхът но върши работа.Всъщност като става дума за VHF или UHF и не става дума за връзки EME или през тропо всичко върши работа.
                            Замен лично всичко започва с Kenwood останалото можем да го редим в какъвто искаме ред.
                            За ало ало, и китайските радиа вършат работа,за работа през репитри също.Ползвал съм ги, не се е налагало да им правя аутопсия или дисекция на софтуера просто си работеха.
                            Eдинственото и достатъчно условие за да повярваш на нечии глупости е ти да си по-тъп от този който ги е казал.
                              Мда. Icom IC-T90A например. Срещу скромната сума от 700 и кусур долара. Просто не бих ги дал, а не намирам друга маркова с 6.25 стъпка.
