Тракбол, Мишка или Писалка
    От: Тракбол, Мишка или Писалка
    В молива има генератор и антена на нещо, обикновенно единици килохерцове. Дъсчицата е матрица от приемници. Копчетата са съшото, на други честоти. Когато не е натиснато нищо - свети нещо си. Като натиснеш върха, или страничните копчета, излъчването или минава на друга честота, или спира съвсем.
      При тази схема не би ли следвало в молива да има батерийка ?
      Понеже при уакомите нямат гадините. Пасивни са. Или ако имат са някакви вечни, или изчислени да изкарват повече от самата дъсчица.
      А, сега прочетох. Прав си. Електромагнитен резонанс. Ето го в уикито:
      Wacom tablets use a patented electromagnetic resonance technology.[12] Since the tablet provides power to the pen through resonant coupling, no battery or cord is required for the pointing device. As a result, there are no batteries inside the pen (or the accompanying puck), which makes them slimmer and essentially maintenance-free. However, the battery-less technology makes the tablet bigger and heavier than other technologies, and the short life of the pen makes the lack of maintenance a moot point.
      Under the tablet's surface (or LCD in the case of the Cintiq) is a printed circuit board with a grid of multiple send/receive coils and a magnetic reflector attached behind the grid array. In send mode, the tablet generates a close-coupled electromagnetic field (also known as a B-field) at a frequency of 531khz. This close-coupled field stimulates oscillation in the pen's coil/capacitor (LC) circuit when brought into range of the B-field. Any excess resonant electromagnetic energy is reflected back to the tablet. In receive mode, the energy of the resonant circuit’s oscillations in the pen is detected by the tablet's grid. This information is analyzed by the computer to determine the pen's position, by interpolation and Fourier analysis of the signal intensity. In addition, the pen communicates other vital information, such as pen tip pressure, side-switch status, tip vs. eraser orientation, and the ID number of the tool (to differentiate between different pens. mice, etc.). For example, applying more or less pressure to the tip of the pen changes the value of the pen's timing circuit capacitor. This signal change can be communicated in an analog or digital method. An analog implementation would modulate the phase angle of the resonant frequency, and a digital method is communicated to a modulator which distributes the information digitally to the tablet. The tablet forwards this and other relevant tool information in packets, up to 200 times per second, to the computer.
      Но, това явно си е патент на Уаком. Оня ден разопаковах някаква китайска плоча, дойде си с батерийка в моливчето. При това ААА. Не от часовник.
      Е, тия дни ще посъбера брака и ще намеря начин да го засиля.
      Издъних се на Тюринг теста
        Първоначално публикуван от axlastro Преглед на мнение
        ...CAD - ване на разнообразни програми, се замислям за по-ергономичен и прецизен метод за въвеждане. ... какво според вас е най-подходящото устройство......
        ...разните геймърски очила и ръкавици немогат ли да се адаптират
          Край, абонирам се за тази тема. Ще трябва да дадеш и адрес в PayPal.
          Александър
            Ихаааа, Вакоми за без пари. Дайте да д... вземем.
              Ами те най-вероятно къде твое село ще се залетят, зер имам и макови вентилатори за пращане
              Но, но, но, проблем остават писалките. От тях нямам достатъчно. Абе ще измислим нещо.
                Ти пък. Почти сигурно е, че по пътя ще се изпочупят повече от плочите и по-малко от писалките. Мащабен фактор.
                  И ето ме успокоен
                    Преди доста време бях попаднал на едни специализирани мишки точно за работа с 3D CAD програми. Нещо такова от рода:
                    http://www.3dconnexion.com/products/spacepilot-pro.html
                    Изглежда интересно но не знам как би била работата с такава мишка с програми от рода на Аутокад. И на мен ми е интерсна тази тема дали пада с писалка се явява добра алтернатива.
                      Тука вече без майтап.
                      За работа ми е нужен такъв молив. Къде ги има, и колко струват?
                        Ето това ми върна бате Гошоко с търсне на "Wacom" + "Цена" (извинявам се за външния линк). Първият таблет - Bamboo (CTH-661-EN Таблет Bamboo Pen & Touch M ~ 350 лева) съм го ползвал - съквартиранта ми имаше такъв и мога да потвърдя, че работи. Има нива на натиск, което предполагам в първият момент няма да те засяга, но в някой момент ще се замислиш и за това.
                        "Проблема", който по-горе описах - а именно да пишеш на едно място а да гледаш на друго си е проблем за някои хора.
                        EDIT: // Разликата между трите таблета е на практика само диагонала!
                        EDIT2: // По-горният пост на колегата icpart показва една наистина уникална идея. Жалко, че е съвместима само с MCAD неща Иначе е адски привлекателно устройство... направо се замислям дали да не рискувам едно на по-късен етап - например зимата, когато няма да карам
                        Последно редактирано от господин никой; 15-02-11, 07:52. Причина: EDIT, EDIT2
                          Какви 3Д кад бе, не ме вкарвайте в А група. Не съм за там.
                          За просто драскане. Но поне с поносима разделителна способност. И художник не съм.
                            Идеята с нивата на натиск е нещо съвсем друго - не е въпроса в рисуването, а в прецизността при при писане и съответно при разпознаване на почерка.
                              При Wacom, Bamboo е "домашна" плочица. Тук е 79$. Площта и е като пощенска картичка. Работи си идеално.
                              Профи серията е Intuos, която в момента е на версия 4, с използваема площ 8.8 х 5.5 инча, 22 х 14см за Медиум модела. На моите ширини струва плътно 400$ официална цена, 310$ с търсене и късмет.
                              Екивалентна по размер китайска (всъщност малко по-голяма, 16/9 съотношение а не 4/3, но с батерийка в молива) взех за около 140$ преди около месец, все още не се е счупила.
                              Иначе интуос в безмозъчни служебни условия (разбирай - да трошиш чуждо без да ти се държи сметка) изкарва няколко години, изпивайки горе-долу толкова кафе колкото потребителя, в различни приливни вълни. Моливчето - около две години при добър късмет преди да се разпадне козметически, и още две години преди да спре безнадеждно да работи.
                                Не препоръчвам ефтини таблети. Имам доста наблюдения и е по-добре да се изръсите за някой по-голям и по-прецизен, ако работите професионално.
