Оръжията през обектива...
  • От: Оръжията през обектива...
    Големите металните по принцип са си фарадееви клетки.
    По-малките не-метални си имали медна плоча някъде под ватерлинията. Ето ти част от щатския правилник за малките. Всъщност май не е правилник а съветник :
    LIGHTNING PROTECTION CODE
    The National Fire Protection Association, Lightning Protection Code, suggests a number of ways in which the boater can protect his boat and minimize damage if the boat is struck or is in the vicinity of a lightning strike. These suggestions are summarized below:
    • A lightning protective mast will generally divert a direct lightning strike within a cone-shaped radius two times the height of the mast. Therefore, the mast must be of sufficient height to place all parts of the boat within this cone-shaped zone of protection (see Figure 6).
    • The path from the top of the mast to the "water" ground should be essentially straight. Any bends in the conductor should have a minimum radius of eight inches (see Figure 7).
    • To provide adequate protection, the entire circuit from the top of the mast to the "water" ground should have a minimum conductivity equivalent to a No. 8 AWG copper conductor. If a copper cable is used, the individual strands should be no less than No. 17 AWG. Copper metal or strips should be a minimum of No. 20 AWG.
    • Major metal components aboard the boat, within six feet of the lightning conductor, should be interconnected with the lightning protective system with a conductor at least equal to No. 8 AWG copper. It is preferable to ground the engine directly to the ground plate rather than to an intermediate point in the lightning protection system.
    • If the boat's mast is not of a lightning protective design, the associated lightning or grounding connector should be essentially straight, securely fastened to the mast, extended at least 6 inches above the mast and terminate in a sharp receiving point.
    • The radio antenna may serve as a lightning protective mast, provided it and all the grounding conductors have a conductivity equivalent to No. 8 AWG copper and is equipped with lightning arrestors, lightning protective gaps, or means for grounding during electrical storms. Most antennas do not meet these requirements. The height of the antenna must be sufficient to provide the cone-shaped zone of protection.
    • Antennas with loading coils are considered to end at a point immediately below the loading coil unless this coil is provided with a protective device for by-passing the lightning current. Nonconducting antenna masts with spirally wrapped conductors are not suitable for lightning protection purposes. Never tie down a whip-type antenna during a storm if it is a part of the lightning protection system. However, antennas and other protruding devices, not part of the lightning protection system, should be tied down or removed during a storm.
    • All materials used in a lightning protective system should be corrosion-resistant. Copper, either compact-stranded, concentric-lay-stranded or ribbon, is resistant to corrosion.
    • The "water" ground connection may be any submerged metal surface with an area of at least one square foot. Metallic propellers, rudders or hull will be adequate.
    • On sailboats, all masts, shrouds, stays, preventors, sail tracks and continuous metallic tracks on the mast or boom should be interconnected (bonded) and grounded.
    • Small boats can be protected with a portable lightning protection system. This would consist of a mast of sufficient height to provide the cone of protection connected by a flexible copper cable to a submerged ground plate of at least one square foot. When lightning conditions are observed in the distance, the mast is mounted near the bow and the ground plate dropped overboard. The connecting copper cable should be fully extended and as straight as possible. The boaters should stay low in the middle or aft portion of the boat.
    Издъних се на Тюринг теста
      Първоначално публикуван от Павлин Андреев Преглед на мнение
      И възниква един лично за мен като инженер въпрос - какво се случва с корабите, когато има гръмотевична буря?
      Светкавиците обикновено търсят най-високата точка, а това обикновено са мачти, на които има свързочно, сигнално и/или друго оборудване. Какво се случва с електрическо изпразване от няколко милиона волта?
      Мълнията има две основни действия, директно попадение и повишено електромагнитно поле което повдига потенциала на токопроводящи материали. За първите има -гръмоотводи , за вторите разрядници.
      Фарадевата клетка все още е оспорвана от Англия..., като морска страна.
      САЩ, Русия и някои други страни имат производствен стандарт за мълниезащита - Early streamer emission control. Става въпрос за един цилиндър приблизително равен на 200 мл чаша за вода, която привлича и разрежда концентриращото се магнитно поле преди още да се е образувала "светкавица". Токуда болница е първата в БГ с такава защита.
      В. Иванов
        Изгаря цялата електроника и всички кабели и електромотори ако има добра защита,ако не ти прави дупка на дъното.На ветроходни обикновенно им стопява и горната част на мачтата,имах снимки някъде,нищо интересно.
        TOYOTA SEQUOIA ‘11
        W140 S420 '99
          Благодаря и на трима ви.
            В начале 1930-х годов в конструкторском бюро Калинина был спроектирован многоцелевой самолет-гигант К-7.
            Пассажирский вариант предусматривал перевозку 128 пассажиров на расстояние до 5000 км. Другой вариант — «люкс» — предполагал установку в крыле восьми двухъярусных пассажирских кабин по 8 человек в каждой.
            Военный вариант самолета представлял собой настоящую «летающую крепость». Бомбардировщик К-7 мог взять на борт до 16 тонн бомб
              Нещо занимателно за учения с участието на френска подводница - http://theaviationist.com/2015/03/05...-sunk-by-subs/
              Всеки трети е шести
                0878 79 20 61 Борис
                  Голем дзвер е.
                  Винаги ми е приличал на нещо немско от втората световна.
                  Всеки трети е шести
                    0878 79 20 61 Борис
                      0878 79 20 61 Борис
                        0878 79 20 61 Борис
                          Какво правят тези бе. Може би изграждат риф или кей!
                          Когато човек говори истината - не се налага да лъже!
                            Първоначално публикуван от Sasho74 Преглед на мнение
                            Изграждат риф, но да ли е за защита или за гмуркачи не знам.
                            0878 79 20 61 Борис
                              0878 79 20 61 Борис
                                Всеки трети е шести
                                Тук са 11 потребители онлайн. 0 потребители и 11 гости.
