Може ли да ми кажете нещо за този мотор
Yamaxa DT200R
До: Yamaxa DT200R
Ето ти малко данни за модела 1990-та
Make Model - Yamaha DT 200R
Year - 1990
Engine - Liquid cooled, two stroke, single-cylinder, oil injected,reed valve
Capacity - 195
Bore x Stroke - 66.8 х 57mm
Compression Ratio - 6.4:1
Induction - Mikuni TM28SS
Ignition / Starting - CDI. / Kick
Max Power - 33hp @ 8500 rpm
Max Torque - 23.5 N-m 17.4lb-ft @ 7500 rpm
Transmission / Drive - 6 Speed / chain
Front Suspension - Telescopic forks, air adjustable, 270mm wheel travel
Rear Suspension - Single shock swingarm, adjustable preload and compression dampening, 270mmwheel travel
Front Brakes - Single disc
Rear Brakes - Single disc
Front Tyre - 3.00-21
Rear Tyre - 4.60-18
Dry-Weight - 108 kg
Fuel Capacity - 10 Litres
Standing ¼ Mile - 14.73 sec / 138.46 kmh
Top Speed - 162 kmhSuzuki TS 200R - 1996, Suzuki Dr 250 SHC - 1991, Suziki RMZ 450 - 2007, Yamaha YZ 450F - 2010...
До: Yamaxa DT200R
А ето и за модела 1988-ма :
Year - 1988
Engine - Liquid cooled, two stroke, single-cylinder.
Capacity - 195
Bore x Stroke - 66 х 57 mm
Ignition / Starting - - / kick
Max Power - 32 hp @ 8500 rpm
Max Torque - 2.7kg-m @ 8500 rpm
Rear Suspension - Monocross
Rear Tyre - 4.60-18
Dry-Weight - 99kg
До: Yamaxa DT200R
Хубав мотор. Много приятен за каране. По едно време щях да си вземам такъв но не намерихме R модел.Първоначално публикуван от ivoto Преглед на мнениеМоже ли да ми кажете нещо за този мотор2010 CRF 250 R
