Търся лично-служебен джип
    От: Търся лично-служебен джип
    Първоначално публикуван от Вещер Преглед на мнение
    Нямам думи щом от 112 сте стигнали до там...
    "Пловдив 112" е доброволна организация и няма нищо общо с националният 112.
      Първоначално публикуван от kkarakashev Преглед на мнение
      ...фриилендър...
      Казаха ти вече за това. По-добре го задраскай от списъка си въобще.
      Ако поназнайваш ингилизки, чети:
      I have a 2003 Land Rover FREELANDER with currently 38,000 miles. I has been a total nightmare. Besides broken coolant reservoir, (3)changes of brake pads and discs, window water leaks, headlining damaged from manufacturing, sunroof motor and sliding replaced, jet washer defective, computer reconfigured, AC heater assy replaced and cooling system bled due to coolant leakeage on heater, front speaker replaced, codes P1472, p2070 intake chamber replaced, bad brake rotors replaced, fuel pump replaced, defective ignition coil #4 replaced and adjusted gaps in plugs, tail light replaced, ignition coil #2 codes p0302,p1392, replaced defective brake pedal switch code 1221, c1222, another tail light replaced, a Tech Bulletin 80/01/03 NAS were they modified the drivers lower heater duct and housing assy, faulty Plenum Chamber with VIS motors replaced, faulty brake booster switch - removed and replaced brake vaccum switch, deglazed and adjustment of rear brakes, glass door regulator assy replaced, tweeter grille replaced, lamp assy replaced due to humidity leak, deformed spacer of the power steering line -pressure hose R&R spacer of the high pressure hose power steering bleeding to system performed all due to power steering leakage, due to excesive coolant consumption they foud a leak in the R&R housing thermostat and hose R&R intake manifold gasket both sides AND my vehicle is in the shop as we speak and has been in there since june 25, 2007 for what it seems is the alternator. MY WARRANTY EXPIRES JULY 4, 2007.
      HELP!!!!!
        Гледам сега във Варна продават един дизелов УАЗ Хънтър точно за 3000, с гуми и т.н. за нормална употреба. Сигурно ще има и неща за правене както всяка УАЗ-ка, но и това е вариант.
        Иначе Кия ,Витара и Галопер може да се намери що годе здраво.
          Не знам каква е тая Фронтера дето ще харчи 16-17/100 нафта градско. Вероятно някоя тотално издухана 2,3 дизел. По-скоро ще се намери някоя 2,4 бензин без климатик, с разход 16-18/100 газ градско.
          Моята 2,3 ТДИ, реколта '93 я продадох на 320 000 (по километраж ) без да и е отварян мотора (даже и капака на клапаните) и с 80% оригинални от завода тампони по окачването. Зиме на - 25, лете на + 35 палеше по един и същи начин, само дето на - 25 искаше по 2-3 подгрева за да запали от първото завъртане на ключа. На градско при какви да е условия не е качвала над 11-12/100, а на извънградско ако не си състезателен тип, разхода е около 7,2-8/100. Ако попадна на добър екземпляр, отново бих си купил такава, вЕрвай ми ....
          П.П. Тая Фронтера я карах 8 години, като това досега е абсолютен рекорд за мене. Имал съм общо към 40 автомобила откак имам книжка и не е като да нямам база за сравнение ...
          Последно редактирано от kuzdov; 29-09-15, 09:32.
          Неизвестен мъдрец
            ауди 100 авант куатро,
            като изключим плуването на 50 см. мисля че покрива всички изисквания.
            Поздрави
              Виж ква джипка продавам,даже е червена на цвят тамън кат за ваща организация
              http://www.offroad-bulgaria.com/showthread.php?t=198723
              Pathfinder 4.0L
                Тъп въпрос - очевидния отговор на въпроса не е ли Lada Niva?
                РенеГАД
                VW Golf V Variant 1.9 TDI
                Honda HR-V 1.6i 4WD
                "Of all the things I've lost I miss my mind the most."
                  Уж гледах като купувах, не вие нищо, мотора часовник, дребни неща за оправяне и обслужване. За тези пари си е бонус. Та нещо такова да гледа ми е мисълта.
                  Ладата определено е грешен избор... за работа му трябва на човека.
                    Имам лимит от около 3000лв. да харесам високо проходим автомобил.
                    Да харесаш ще ти стигнат...
                      Здравей колега, ако не държиш на джип погледни в субару форума в раздел продава има едно червено легаси 94та за малко над твоите пари! има си и бавни, 4х4 е и изгледжа доста запазено! колата не я познавам!
                      Real Recognize Real
                        За 50 сантиметра вода и малко кал всяка стокова витара с мааалко по-сериозни гумета ще върши прекрасна работа. Моята, докато беше още витара си беше много здрава, ама аз съм магаре, та я чупех. Покрай всичките ремонти които съм правил разбрах, че това е добре измислена и добре изпълнена машина, която ако се кара по начин за който е предназначена(а случая на колегата е точно такъв) е доста здрава и не даваща ядове.
                        С оглед на това, че ще има и багаж-дълга база, така става по-обемиста от доста комбита. Може би най-икономичния "джип", конкуренти са само самураите и ферозите.
                        Само трябва да се внимава с ръждите, че те са основната болест.
                          Аз бих се метнал на Черока на колегата без да му мисля.
                          Успех...
                          VITARA, SAMURAI
                          FIAT PANDA 4x4 CABRIO
                          RENAULT ESPACE QUADRA
                          ...и едно сивикче за града...
                            Понеже ще се товари обемист багаж, поне според мен, джип с газова бутилка в купето не е най-удачното решение. Такова е решението в моето Чероки и на моменти ме хващат лудите, защото не ми достигат няколко сантиметра височина, за да вкарам нещо по обемисто в колата.
                            Из "Златния телец"
                              Ако не се кара тежък офф - спокойно бутилката се мести отдолу - доста черокита са така.
                              Поздрави!
                              VITARA, SAMURAI
                                А как е подръжката им на тези Черокита?
                                После ще се иска подръжка, едва ли ще му се работи на човека само за да е здрав и работещ джипа.
                                Потресен съм от проходимоста на Нивата във водата. Явно предразсъдъците против тази марка с повечко.
                                Последно редактирано от velinsl; 01-10-15, 17:45.
