колеги интересувате дали стават джанти от аро на уаз без да се престъргват
ако има някакъв проблем казваи ште я махна
... The letter that typically sits between the rim width and diameter figures stamped on the wheel, and indicates the physical shape of the wheel where the tire bead meets it. In the cross-section on the left you can see the area highlighted in red.
From the tables present in this manual, the difference in dimensions between "J" and "B" rims is mainly due to the shape of the rim flange. This is the part in the above diagram defined by the R radius and B and Pmin parameters. Hence my somewhat simpler description : tire bead profiles.
сега си мислех да обърна едни волгови джанти
някой знае/ли каЪде и за колко обръштЩат
