TOYOTA code engine
  • TOYOTA code engine
    Това са кодовете на двигатели Тойота .ХарактеристикиB29774ID8056360018722008OHV9510521:012B31684ID93623600?20122008OHV9810521:013B34314ID9066350021622008OHV10210520:013B-II34314ID9672350021622008OHV10210520:0113B-T34314TDD12091340028020008OHV10210517.6:114B36614DD96-3400-22008OHV10211218.0:115B-FT41044TDD155-3200-180016OHV10811217.8:1F (-60)38786CG105773200265200012OHV901026.8:1F (60-)38786CG125923600284200012OHV901027.5:12F42306CG135993600294180012OHV941027.8:13F39556CG1551014000275300012OHV94953F-E39556EFIG1551144200298220012OHV94958.1:11FZ-F44776CG1901404400363280024DOHC100959.0:11FZ-FE44776EFIG2121584600373300024DOHC100959.0:1H35766ID90663600205220012OHV889821.0:1H35766ID953600-220012OHV889819.5:12H39806ID103763500241200012OHV9110220.7:112H-T39806TDD1351003500315200012OHV9110218.6:11HD-T41636TDD1651233600360200012SOHC9410018.6:11HD-FT41636TDD1681253600380250024SOHC9410018.6:11HD-FTE41636TDD2051523400431250024SOHC9410018.8:11PZ34695ID115854000238260010SOHC9410022.7:11HZ41636ID135964000280220012SOHC9410022.7:11KZ-T29824TID12592360029520008SOHC9610321.2:11KZ-TE29824TEID13096360028920008SOHC9610321.2:11KZ-FTV29824TCRD1303600-20008SOHC9610321.2:12L24464ID7253400015522008SOHC929222.3:12L-T24464TID8663400018824008SOHC929220.0:12L-T-II24464TID9066400021524008SOHC929221.0:13L27794ID9167400018824008SOHC969622,2:122R23674CG10577480018428008SOHC92899.0:122R-E23674EFIG11484460019234008SOHC92899.0:13RZ-FE26934EFIG150-480023540008SOHC95959.5:12UZ-FE46638EFIG2281704800421340032QOHC94849.6:15VZ-FE33786EFIG185-4800294360032DOHC94829.6:11KD-FTV29824DD1701253400352180016DOHC9610318,4:12KD-FTV24944DD88653800192120032DOHC9293,818.5:1
    FJ40 07 1984 VIVA TEL 0877 454448
    BJ42 04 1982
    FJ62 11 1983 skipe blago4x4
    LZ 2 BHB
    До: TOYOTA code engine
    Имам таблицата , но не се качва както изглежда при мен
    BJ42 04 1982
    LZ 2 BHB
      Ами прати я на мейл на мен или на някой друг да я качи, така не се разбира нищо.
        И аз нищо не разбрах, а ми е интересно за какво става въпрос.
          дали не е това?
          Subaru OUTBACK 2,5
          Hyundai TUCSON 2.0
