Официален Safety Recall за Опел Фронтера
Това е залепена тема.
  • Официален Safety Recall за Опел Фронтера
    Породено от тема за Jeep потърсих официалните Safety Recall за нашите Опели. Очудващо малко са на фона на останалите марки
    сигурно защото са прекалено прости от към електроника но все пак, може би ще е полезно за някой:
    12/10/1992 R/1992/052 VAUXHALL Frontera Estate - Sport lack of weld penetration of roadwheel seam welds NV500001 - NV523984 01/08/1991 01/06/1992
    03/02/1995 R/1994/091 VAUXHALL Frontera bonnet may fly open inadvertently NV500400 - RV628664 01/08/1991 28/02/1994
    12/02/1996 R/1996/012 VAUXHALL Frontera Estate and Sport variant models fuel tank protection NV500001 to TV825158 01/04/1996
    13/10/1999 R/1999/081 VAUXHALL Estate/Sport 3.2, 2.2 Petrol and 2.2 Diesel steering coupling bolt security concern XV600000 to YV603805 01/07/1998 31/10/1999
    Reference : R/1992/052
    Manufacturer Ref :
    Make: VAUXHALL
    Model : Frontera Estate - Sport
    Launch Date : 12/10/1992
    Numbers Involved : 1059
    Build Start Date : 01/08/1991
    Build End Date : 01/06/1992
    Recall Details
    Concern : LACK OF WELD PENETRATION OF ROADWHEEL SEAM WELDS
    Description : The seam weld joining the wheel disc to the wheel rim may lack penetration resulting in failure of the weld and eventual detachment of the road wheel.
    Remedial Action : Recall the affected vehicles and replace the road wheels with quality assured examples.
    Vehicle Id : NV500001 - NV523984
    Reference : R/1994/091
    Manufacturer Ref :
    Make: VAUXHALL
    Model : Frontera
    Launch Date : 03/02/1995
    Numbers Involved : 18499
    Build End Date : 28/02/1994
    Recall Details
    Concern : BONNET MAY FLY OPEN INADVERTENTLY
    Description : The bonnet safety catch can stick in the open position due to the formation of white corrosion on the pivot pin. If this occurs and the vehicle is in motion wind force can lift the bonnet, obstructing the driver's forward vision.
    Remedial Action : Recall all potentially affected vehicles and by lubrication, ensure that the bonnet safety catch moves freely. At the same time the original return spring will be replaced with a revised spring of higher load capacity.
    Vehicle Id : NV500400 - RV628664
    Reference : R/1996/012
    Manufacturer Ref :
    Make: VAUXHALL
    Model : Frontera Estate and Sport variant models
    Launch Date : 12/02/1996
    Numbers Involved : 40042
    Build Start Date : 01/04/1996
    Build End Date :
    Recall Details
    Concern : FUEL TANK PROTECTION
    Description : In the event of an exhaust tail pipe fracture an unacceptably high level of heat radiation may occur in the area surrounding the fuel tank.
    Remedial Action : Recall the affected vehicles for the installation of a protective shield over the fuel tank.
    Vehicle Id : NV500001 to TV825158
    Reference : R/1999/081
    Manufacturer Ref : 99-C-29
    Make: VAUXHALL
    Model : Estate/Sport 3.2, 2.2 Petrol and 2.2 Diesel
    Launch Date : 13/10/1999
    Numbers Involved : 7478
    Build Start Date : 01/07/1998
    Build End Date : 31/10/1999
    Recall Details
    Concern : STEERING COUPLING BOLT SECURITY CONCERN
    Description : Possible misalignment of the coupling between the transfer box and steering rack may result in loosening of the coupling securing bolt.
    Remedial Action : Recall affected vehicles, check the alignment between the transfer box and steering rack and realign if necessary. Fit new coupling bolts in all cases.
    Vehicle Id : XV600000 to YV603805
    no signature no problems
