какво е TOD system?
  • какво е TOD system?
    знам, че според всички фронтераджийски канони маслото в раздатката е двигателно, но вижте какво пише в моя workshop за раздатките с TOD system:
    Transfer case (W/TOD system) - DEXRON II or DEXRON III Automatic transmision fluid!
    та какво е това TOD, имаме ли го и т.нт...?
    От: какво е TOD system?
    да помогна:
    TOD system means the full time 4WD system and the
    registered trade mark of Borg Warner. TOD is an
    abbreviation of Torque On Demand.
    TOD control unit automatically tailors torque distribution
    t o r o a d , o f f e r i n g f u l l t ime f o u r wh e e l d r i v e . TOD
    distributes electronically-controlled power into front and
    rear wheels whose ratio change from 0 : 100 to 50 : 50
    complying with wheel speed differences.
    Also TOD control unit analyzes data from wheel speed
    sensor and engine output then changes pressure of
    electromagnetic clutch. This pressure controls front
    propeller shaft and power to front wheel. Power to front
    wheel depends on degree of pressure corresponding
    clutch slip.
    TOD is designed to distribute the power to front and
    rear axle by operation of 4H/4L switch and shift motor.
    Shifting 4WD high (4H) to 4WD low (4L) is performed
    t o w a r d s r e d u c i n g h i g h - l o w c o l l a r b y m e a n s f o r
    connection high-low shift fork with output shaft in order
    to join with planetary gear. Torque transmits input shaft
    then sun gear rotating front planetary gear. Front
    planetary gear joins with output shaft and drives at
    low position.
    The TOD system has 2 selectable mode, 4H and 4L.
    4H is the normal operating mode when drive of which
    gear ratio is 1:1 and 4L mode distributes power to
    front and rear wheels 50 : 50 of which gear ratio is
    2.48:1.
    Three witches watch three Swatch watches.
    Which witch watch which Swatch watch?
      Първоначално публикуван от sergej Преглед на мнение
      да помогна:
      clutch slip.
      low position.
      2.48:1.
      Страхотна помощ!!!А тези който не знаят В БЪЛГАРИЯ.......Англ.??????????
      Казвам го без лош замисъл и оценявам това че някой иска да помогне
      но нямаше ли да е по добре леко да се попреведе???
      Range Rover P38 4,6 автомат 99г. (на въоръжение в момента),Опел Фронтера А КБ. 2.0 94г.(нов проект за гората.
      LZ1NES
        Ето ти превод на най-същественото:
        Torque On Demand - въртящ момент при поискване.
        Т.е. става дума за градския (паркетен) тип перманентно 4х4 с някаква електроника като например АБС+накладки.
          Аз лично не мога да га преведа, мой Български не е на този ниво, обаче в Google има толко много преводачи да кой се интересува, ще се оправи и сам, найлесно е, всичко на готово
            Първоначално публикуван от Alexfield Преглед на мнение
            не бъди толкова категоричен, че е градски (паркетен) тип, защото това е вид раздатка, която се монтира и в някои модели Фронтера!
            Тук важния момент е, как да се разбере дали някойя фронтера е с такъв тип раздатка, защото ако е така, то тогава трябва да използва DEXRON III, а не двигателно масло!!!
            довечера ще се поразрова по-дълбоко в менюъла в опити да разбера как се различават двата типа раздатки. предполагам, че тази с TOD, няма да има копче за предното на таблото, но не е задължително....
              bushiDO, няма смисъл да се палиш толкова от това, че някой може да е нарекъл дадена Фронтера паркетник.
              Според това описание:
              When TOD is activated and the transfer case is in the High range position and TOD is turned on, the TOD control unit receives signals sent from the 12 input sensors, including front and rear axle speed sensors, ABS brake switch and the throttle position sensor. Isuzu's proprietary 3-D mapping software uses that input to determine the amount of force that's applied to the clutch pack.
              Източник
              Става дума именно за отворен среден диференциал и прехвърляне на въртящ момент към предния мост, като се задействат спирачките на задния мост. А такова 4х4 решение поне аз наричам "паркетник". При продължителна работа в тежки условия на 4H ще се запалят спирачките.
              Ако не съм прав, ще се радвам някой да ме обори с цитат и линк (както аз съм направил).
                Дишай спокойно! Няма Фронтера с такава "убавиня" в раздатката. Нашите са си от простия, дървен тип без верига и глезотии. Е, твоята е малко електрифицирана, ама се преживява ....
                Неизвестен мъдрец
                  Пиша от чужд комп, че и без очила и ми е тегавко .....на "Експлорър"-ите има такива раздатки (он дименд). На таблото е с ключе х2, 4х4ауто, 4х4лоу .
                  При ОД раздатката датчици следят скоростите на изходящите напред и назад валове, ако стане голяма разликата подават сигнал към муфата в раздатката да приплъзва по-малко и става чист парттайм.
                  Има ОД раздатки и на "Джип" макар и на друг принцип, и там е с АТФ, по спомени и на стария ми Трупър (чист механичен парттайм) беше с АТФ
                  Последно редактирано от дядо владо; 14-02-12, 11:22.
                    Адаш , то че има on demand монтиран на един куп коли е ясно . Но все пак тука говорим конкретно за Опел Фронтера.
                    И както спомена и Куздов :
                    "....Няма Фронтера с такава "у(бав)иня" в раздатката. "
                    Аз също нито съм намирал в манюалите , нито съм срещал по баирите , ма знае ли човек ?!
                      Масло АТФ вероятно автомаат,ама нататък си е фронтера,и чудесата "он деманд"май са за модела АНТАРА.
                      Румен Николов
                      0888 358 572
                        абе не знамм - може ли да няма фронтера с такава раздатка, а в сървиз менюъла да я има?
                        това па за пакетниците не го разбрах - кой се пали, кой гасне, ама каква е разликата м/у масовата раздатка и тази с TOD? и двете зацепват 100% само дето тази с TOD има и автоматичен режим....
                        п.п. а чували ли сте за фронтера с активно окачване?
                          Разликата е че на фронтерата е твърда и приплъзването става в гумите а не в раздатката.Затова и на асфалт не се препоръчва да се кара с включено двойно.Още нещо - няма начин специално на фронтерата - щом корпуса е общ на СК и раздатката втората да е ТОД.Според мен твърдата раздатка е по-здрава,но това си е мое лично мнение.
                          Пример за ТОД - фолксваген синхро.В голфаджийските среди - халдекс съединител.
                          BMW X6
                            Ако скоростите са 4L30E раздатката е като на Исузо.
                            Grand 3.1TD
                            0898 620 306 Стоян
                              Ми колега като нямаш доверие на хората от форума послушай си менюала ( който не е за твоята фронтера ) и си хакни Dextron III да видим как работи тази раздатка ( която със сигурност никога не е слагана на фронтера ).
                              Раздатката на всички видове фронтери от 1990-а до 2004-а са абсолютно един и същи тип. Единственото което се различава е вкючването, до 1998-а е изцяло механична след това е с вакумно управляема вилка.
                              Последно редактирано от fanatic; 15-02-12, 22:13.
                              no signature no problems
