Колеги ,някой знаели предавателните числа на 3л и 3,5л бензин автоматик ? И можели мост от 3л 150кс. с блокаж да се насади на 3,5 208кс.? Извинявам се ако го има написано някъде ,но не го намерих.
Предавателни числа паджеро 2
От: Предавателни числа паджеро 2
+1Първоначално публикуван от sapporo Преглед на мнениеМисля че няма да стане, 3 литровото 150к.с. е еднакво с 2.5 дизеловото, 3.5 =2.8 дизел, 3 литровото 178 к.с. има с предавателно число и на двете.Yamaha T max 500i/ABS/2007/50hp
Zander 3.80m,Johnson 2T/8hp
Vw passat 6/2.0TDI-CR/DSG6/140hp/2009
Toyota Hilux/2KD-FTV/102hp/Double Cab/2005
Mitsubishi Pajero 3000 V6 3-door automatic
Production/sales period of cars with this particular specs: July 1993 - August 1994 Powertrain Mitsubishi Pajero 3500 V6 DOHC-24 Wide 3-doorEngine manufacturer: Mitsubishi Cyclone-series V6 6G72 Engine type: spark-ignition 4-stroke Fuel type: petrol (gasoline) Fuel system: indirect injection Charge system: naturally aspirated Valves per cylinder: 2 Valves timing: Additional features: Multi-point fuel injection ECI SOHC, V-60deg Emission control: 3-way cat, Lambda-Sensor Emission standard: Cylinders alignment: V 6 Displacement: 2972 cm3 / 181.6 cui Bore: 91.1 mm / 3.59 in Stroke: 76 mm / 2.99 in Compression ratio: 8.9 : 1 Power net: 114 kW / 155 PS / 153 hp (JIS net)/ 5000 Torque:
235 Nm / 173 ft-lb/ 4000
Gearbox: Aisin Warner AW03-72 Transmission type: automatic Number of gears: 4 Gear ratios (overall): I 2.826 (13.7
II 1.493 (7.2
III 1 (4.8
IV 0.689 (3.36) V () VI () VII () VIII () R 2.703 Speed range (max speed on gears, top gear value theor.): (km/h/mph) I: 58 / 36 II: 109 / 68 III: 163 / 101 IV: 236 / 147 V: / VI: / VII: / VIII: / 1000rpm speed: (km/h/mph) I: 10.3 / 6.4 II: 19.5 / 12.1 III: 29.1 / 18.1 IV: 42.2 / 26.2 V: / VI: / VII: / VIII: / Torque converter factor: Final drive ratio std: 4.875
Production/sales period of cars with this particular specs: February 1994 - February 1994
Powertrain За всеки модел и период на производство има различни стойности, затова най-точна е справката по VIN (и то не винаги, особено при наличие на интервенции), но в общи линии е това. Дано съм бил полезен. УспехEngine manufacturer: Mitsubishi Cyclone-series V6 6G74 Engine type: spark-ignition 4-stroke Fuel type: petrol (gasoline) Fuel system: indirect injection Charge system: naturally aspirated Valves per cylinder: 4 Valves timing: Additional features: Multi-point fuel injection ECI DOHC Emission control: 3-way cat, Lambda-Sensor Emission standard: Cylinders alignment: V 6 Displacement: 3497 cm3 / 213.4 cui Bore: 93 mm / 3.66 in Stroke: 85.8 mm / 3.38 in Compression ratio: 10 : 1 Power net: 169 kW / 230 PS / 227 hp (JIS net) / 5500 Torque: 324 Nm / 239 ft-lb / 3000
Gearbox: Aisin Warner Transmission type: automatic Number of gears: 4 Gear ratios (overall): I 2.804 (13) II 1.532 (7.1) III 1 (4.64) IV 0.753 (3.49) V () VI () VII () VIII () R 2.394 Speed range (max speed on gears, top gear value theor.): (km/h/mph) I: 64 / 40 II: 118 / 73 III: 180 / 112 IV: 240 / 149 V: / VI: / VII: / VIII: / 1000rpm speed: (km/h/mph) I: 10.9 / 6.8 II: 20 / 12.4 III: 30.6 / 19 IV: 40.6 / 25.2 V: / VI: / VII: / VIII: / Torque converter factor: Final drive ratio std: 4.636
П.С. ...ако сте се насочил към конкретен модел мога да проверя и за него
HONDA CR-V RD1 126 hp Auto JDM
Mitsubishi Pajero 2.5 intercooler turbo EX
Видя ли какво съм качил в поста преди твоя? Просто от любопитство.Първоначално публикуван от tihony Преглед на мнение...
За всеки модел и период на производство има различни стойности, ...Животът е това, което се случва, докато ние кроим планове....
Най-много потребители онлайн 33,365 в 14:10 на 11-03-26.
