Замяна на вентилатор на ДВГ с електрически
  • Замяна на вентилатор на ДВГ с електрически
    Здравейте Колеги,
    Замислям се дали да си сменям виско муфата с нова или направо да заменя оригиналното охлаждане (вентилатора с виско муфата задвижвано от ремъка) с електрически модул. В Падок се предлага такъв кит и цената му е приемлива (£108.9. Ето какво казват производителите на кита:
    Part No. 14HPBS
    Kenlowe are the premium manufacturer of aftermarket electric fans for Land Rover. To see why you should kit a Kenlowe fan visit www.kenlowe.com. You will notice that we often list two different fans per model - one standard and one heavy duty. For regular use of your Land Rover it is only necessary to fit the standard model. The heavy duty option is only applicable to vehicles under extreme weather conditions and those being reguarly driven under a lot of weight.
    4x4 vehicle manufacturers fit a larger than average belt driven engine fan just in case you are the one in a million who tow two ton across the Sahara! However, as most owners spend the majority of their time on the road you suffer the noise of a large continuously driven viscous fixed fan, moving a lot of air to over cool your engine and to waste around 8.5% of fuel or performance. Replacing the belt driven engine fan with a Kenlowe thermo-electric fan makes any 4x4 drive more like a car, much quieter and less tiring on a run combined with around 8.5% fuel saving or 8.5% extra performance. In addition the engine and therefore the heater, warm up quicker to a more efficient operating temperature without cold air being blown over a cold engine! The engine also becomes more flexible and free revving which is invaluable when overtaking, you even need fewer gear changes which can be a relief on long journeys. Removal of the engine fan overcomes the risk of drowned electric's from water spray when fording.
    Някой от Вас правил ли е подобно нещо?
    Toyota Hilux 3.0 D4D 2008
    Discovery 2.5 TD5 2000 EX
    Land Rover Discovery 2.5 TDI 1996 EX
    До: Замяна на вентилатор на ДВГ с електрически
    Изглежда много добро решение.
      а защо искаш да я сменяш? според мен тя е най-доброто охлаждане измислено изобщо и толкова пари ще ти струва и да я подновиш.
      [SIGPIC][/SIGPIC]Нека да не бъркаме "хубавите" пътища в България със самолетни писти. Колеги карайте бавно нека се виждаме по-често.:cool::D
        И аз се бях засилил натам преди време. Обсъждахме го доста с англетата. Тяхното мнение е, че ако няма да се състезаваш - не ти трябва.
          Карам Диско 300tdi от неотдавна и съм впечатлен от температурния му режим на работа.Последният месец ми е малко студено - бавно загрява, но като се сетя за няколкото автомобила, които не можех да им смъкна температурата/ дакараш на парно при тропически жеги/...
          може би не бих сменял виското за електро.Но може и да има плюсове, какво пък...
          Последно редактирано от сто; 16-01-09, 21:46.
            Първоначално публикуван от Lazar Преглед на мнение
            +1 Но ако все пак го направиш сподели впечатленията си
            [SIGPIC][/SIGPIC]
              Дългия Ровър е с ел. перка от МБ климатик. Късия Ровър е с ел. перка от BMW климатик. ГАЗ69- 2,3 Опел Дизел 2 перки от ............нещо.Всички са тънки с преден монтаж. Сега като регистрирам Дифендъра, ще отскубна и неговата.
                Аз на РР п38 си закупих от падок kenlowe перка електрическа 17 инчова дават я за офроуд. бих казал че съм доволен няма го това виене на високите обороти. Престига със пълно опътване, кабели,скоби,миши опашки даже и ще ти останат работи
                  Първоначално публикуван от ALTIDEAD Преглед на мнение
                  И аз на kenlowe съм харесал вентилатора.
                    Виж в сайта на kenlowe колко е консумацията на вентилаторите.
                    Ще трябва да си предвидиш ел. инсталацията/акумулатора, алтернатора/ за него. 16-инчовия лочи към 20 ампера.
                      А така,там е истината еле ако ги намираш на нормални цени вора рька частите.На някои модели перките са 2,има датчик за температура които да включват тия перки на различни градуси като отделно ги льжем поне 8-10 градуса по-ниско да включват.
                      Датчика е 10% от цената на виско сьединитяля,ел.перката е на половин цена от виското.Като ги измамя да включват десетина градуса по-ниско и на виското не му чувам гласеца,не му вдигам температурата,че да се включи.
                      Части втора рька колкото искаш,оригинал части,лесно и евтино за монтаж,а да ги изльжем е лесно та лесно.
                      Перка от 124 модела,датчик за включване на перката и преден монтаж.30 градуса вьншна температура с климатик на 6 и температурата не мьрда над 95 градуса при положение,че оригинал на 96 трябва да ми отвори напьлно термостата.
                      TOYOTA SEQUOIA ‘11
                      W140 S420 '99
                        При положение че я дават за точно определен модел (примерно като при мен П38 не е ли смятана за да я сложат за продан? Аз не съм правил никакви промени просто я сложих, или трябва да правя промени? Има си и реле като на боилерите и си я правиш да се включва на колкото ти душа сака
                          В случай, че си с по-слабичко акумулаторче от стандарното, ще му дойде в повече. Фарове, парно, музика и изведнъж - я дай още 20-тина ампера...
                              Е кажи какво е положението, де Работи, не работи? Доволен, недоволен?
