само за деца!!
  • само за деца!!
    направо тока ми се спря като го видях това клипче http://www.youtube.com/watch?v=P5NqT...eature=related
    някой има ли информацийка срещу колко се предлага това удоволстиве
    Не всичко, което има две бузи е лице!
    От: само за деца!!
    Това е за бащи, не е за деца....
    Нали знаеш за играчките на бащите и децата
    иначе, яко е
    Technical Data:
    Standard Version:
    Type: Chrysler Jeep CJ7/Wrangler
    Body: Aluminum
    Chassis: welded ladder frame made of high quality aluminum (6082); powder
    Length: 2270mm
    Width: 1200mm
    Wheelbase: 1560mm
    Empty weight: 295 kg
    Payload: 310 kg
    Tank: 16LTR. VA
    Wheels / Tires: 23x8-12"
    Engine: Subaru OHC single cylinder air-cooled, 4-stroke gasoline
    Displacement: 400cc
    Head: 13.5 hp at 3600rpm.
    Starter: electric, battery 12V 36Ah
    Drive: hydrostatic automated driving on rear axle
    Transmission: fully automatic
    Steering: Hydraulic Power Steering
    Brakes: Hydraulic 2-circuit brake system f / r 200mm disc brakes
    Axles: axles made of steel with hydraulic wheel motors
    Suspension: Coil springs with 100mm travel
    Gusts: adjustable 3,7-18,6 mph (6-30km / h)
    Climbing ability: 100%
    Options:
    Paint: Metallic if desired
    Wheels: Alloy wheels 7jx12"
    Tires: 25x12-12" offroad or road
    Motors: Subaru
    1. air-cooled V-twin 650cc / 18-22 hp
    2. air-cooled V-twin 720cc / 25 hp
    3. air-cooled V-twin 720cc injection / 28 HP
    Drive:
    1. permanent all-wheel drive
    2. switchable four-wheel drive
    3. engageable differential locks: in the middle, rear, front
    Suspension: air suspension with level control, 120mm travel
    Air bellows, tanks, air compressor, 12V,
    Working Hydraulics: pumps, valves and connections / 2 circles to operate from mowers, brooms, spreaders, lifting, tilting
    Lighting: to rule the country
    Radio / CD player, tachometer, speedometer, fuel gauge, bumper / rollover bar / rear in VA polished, 1500kg winch, auxiliary lights, trailer socket
      От: само за деца!!
      Млада майка заминава в едноседмична командировка и пита малкия си син:
      "Кажи миличко какво ще правиш докато мама я няма?
      Амии ще си играя.
      С какво ще си играеш?
      Амии или с влакчето или с бавачката. Зависи какво ще избере тати"
        От: само за деца!!
        май ще се трансформира някое атв малко да поотпорасне малкия.....
        Вени, виж хулигана каква идея ми даде......пусти бюджет.... http://www.youtube.com/watch?v=OQrbI...&tracker=False
          От: само за деца!!
          Ами то идеята е добра - комбинацията от двете - още по-добра...
          Какво по-хубаво от Мерседес и джип?
          Ама бюджета се крашва напълно...
          Като се сетя навремето как гледах децата, чиито родители се бяха върнали от гурбет в СССР, и им бяха донесли ламаринени москвич 407 с педалчета...
          Страшно исках такова..
          Нямах...
            От: само за деца!!
            и аз нямах....и аз гледах така.....но за сметка на това в момента точно се пазаря за един такъв
              От: само за деца!!
              Първоначално публикуван от borchev Преглед на мнение
              Е, аз имах, ама докът го карах/ учих/, баба ми не можеше да отгледа нито пипер, нито домати...
                От: само за деца!!
                Твоето ще да е било някакво с повишена проходимост 4х4+2 /твоите два крака/, щом си успявал да го караш и из лехите в градината на баба ти.
                Поздрави!
                  От: само за деца!!
                  Първоначално публикуван от Алекс Маринов Преглед на мнение
                  Поздрави!
                  ахахха то на тоз човек вяра не може да се има кой знае колко точилки е изял по време на обучението през лехите
                    От: само за деца!!
                    Абе то у Берковица , е много стръмно и той се пускал надолу през лехите 2х4
                    Grand Cherokee ZJ 96 5.9 Limited + 4'' Rubicon Express Coils. 4'' Rough Country 2.2 shocks, MAxxis Mudder 33/12.5/15
                    тел. 0897818449
                      От: само за деца!!
                      Поздрави!
                      Карах там, само когато не успявах да карам по пътеката между лехите...
                      Не съм казвал, че споменът е безболезнен...
                      Първоначално публикуван от joro_cska Преглед на мнение
                      Баба ми (Бог да я прости) живееше на по-равнинен терен в Дунавската равнина!
                        От: само за деца!!
                        Това не е ли маскирано UTV (Utility Task Vehicle) ? Гледам на много места и у нас започнаха да предлагат забавления с такива - "Конзата" до Трън, по морето, Рибарица, около Банско...
