До: Селек-Трак II с раздатка NV256
Тук има мнения на собственици (на руски): http://jeep.avtograd.ru/Liberty/Liberty2008/opinion.htm
Тук са оборудване и някои спецификации: http://www.media.chrysler.com/dcxms/...cations_WN.pdf
Jeep Liberty
Long story short: The Liberty was the only truck no one picked for the drive home-it was assigned. While this all-new Liberty is much more refined than the first generation of econoboxes, it's still an underpowered mini SUV that's not much use off-road due to the lack of ground clearance and the highest crawl ratio of the group. You can hope this new Liberty will be redeemed by the addition of a diesel engine under the hood, once again, but don't hold your breath if you live in the U.S.
Engine Displacement: 225.8 ci (3,700 cc)Type: V-6 SOHC 12-valveTorque: 235 lb-ft at 4,000 rpmEPA (city/highway): 17 mpg
4WD SystemType: Full-time/part-time 4WDFront axle: OpenRear axle: Limited-slipTransfer case: NV256 electronicAxle ratios: 3.73:1Low-range ratio: 2.72:1Crawl ratio: 28.8:1
Jeep Liberty
