Първи стъпки след покупка на Гранд WJ 4.7 V8
    От: Първи стъпки след покупка на Гранд WJ 4.7 V8
    Какъвто и електриков цвят да му сложиш няма да сбъркаш.Червен,зелен,лилав....и др.
      Как се мери нивото на маслото в автоматичната скоростна кутия?
        от http://www.wjjeeps.com/service/transmission.htm
        CHECKING THE TRANSMISSION FLUID LEVEL:
        All WJ transmissions have a dipstick to check oil level. It is located on the right side of the engine (passenger side). The dipstick cap and fill tube should be wiped clean before checking fluid level. Dirt, grease and other foreign material on the cap and tube could fall into the tube if not removed beforehand. Take the time to wipe the cap and tube clean before withdrawing the dipstick.
        MODEL 45RFE or 545RFE: (used with V8 engines only)
        1. Transmission fluid must be at normal operating temperature for accurate fluid level check. Drive vehicle if necessary to bring fluid temperature up to normal hot operating temperature of 82°C (180°F). The torque converter fills in both the P (PARK) and N (NEUTRAL) positions.
        2. The engine should be running at idle speed for at least one minute, with the vehicle on level ground.
        3. Apply parking brakes.
        4. Place the selector lever in P (PARK) to be sure that the fluid level check is accurate.
        5. Clean top of filler tube and dipstick to keep dirt from entering tube.
        6. Remove dipstick and check fluid level as follows:
        (a) Correct acceptable level is in crosshatch area or area between "COLD" and "HOT".
        (b) Correct maximum level is to "HOT" arrow mark.
        (c) Incorrect level is at or below "COLD" line. The fluid level will be approximately at the upper COLD hole of the dipstick at 70° F fluid temperature.
        (d) If fluid is low, add only enough Mopar ATF +4 Automatic Transmission fluid to restore correct level. Do not overfill.
        WG 2.7 CRD
          Как мога да се сдобия с това масло - MANNOL Synpower 4x4 75W-140 API GL 5
            М-комплект.....по спомени
              Масла и други консумативи за джип-ове с ниски надценки на www.charkove.com
                АвтоХелп/АутоХелп един от двата. Аз карам с този тип масла и нямам проблеми засега....20 000+км вносител
                в общия случай, питащия, приема за точен и коректен,само отговора който е очаквал.....
                Land Rover Discovery 4 & VW Touareg 3.0TDI
