Систематизирана информация
Това е залепена тема.
    От: Систематизирана информация
    Официален он лаин магазин на Хонда .Всичко е безплатно и е съвсем истинско.Заедно с номерана часта има и чертеж макар че по скоро е скица но се разбира кое закъде е.
    Все пак не зная дали обслужва колите извън северна Америка но някои може да се пробва и да каже - има търсене на части по ВИН.
    http://estore.honda.com/
      Здравейте,
      Това малко информация за одобрените от Honda вазелиноподобни мазила и течности. (А откъде може да си купи човек, не-знам)
      Honda Recommended Grease and Lubricants
      "A recommended Grease and Lubricant material is selected by Honda engineers only after its effectiveness has been evaluated under the conditions in which it will be used. This Service Bulletin describes most of the recommended materials commonly referenced in Honda service and training publications. You can purchase these materials through local suppliers; many are also available through American Honda.
      GREASES AND LUBRICANTS:
      Material USA Part # Canada Part # Description and/or Usage
      3M Brake Lube 3M #08945 N/A High-temperature anti-seize lubricant and corrosion protection for tight-fitting or dissimilar metal parts. It’s good for minimizing exhaust system buzz.
      Heavy Duty Brake Fluid DOT 3 08798-9008 4423802 The only brake fluid specifically formulated for use in Honda vehicles. It helps to reduce the corrosive effects of moisture in the fluid and is compatible with synthetic and rubber materials.
      Anti-Freeze/Coolant - Type 2 OL999-9011 6512636 Extended life coolant. Do not add water as it comes premixed.
      Brembo Brake Grease 08798-9027 7773278 The only recommended grease to be used on Brembo brake pads.
      CV Joint Grease-Inner (yellow) 08798-9003 4011748 Extreme-pressure, high-temperature grease for inner CV joint lubrication.
      CV Joint Grease-Outer (black) 08798-9007 4414405 Extreme-pressure grease for lubricating outer CV joints.
      DC 111 Silicone Paste Call Dow Corning: (800) 248-2481 High-viscosity lubricant for rubber-to-metal and plastic-to-metal contact. Also used for suspension bushings and brake system seals.
      Honda Caliper Grease 08C30-B0224M 4853958 High-temperature, silicone-based grease used to lubricate caliper slide pins.
      Shin-Etsu Silicone Grease 08798-9013 4642294 Used to reduce rubber-to-rubber noises and to lubricate roof seals.
      Silicone Grease 08C30-B0234M 6110928 Used to reduce rubber-to-rubber noises and to lubricate roof seals.
      Lithium Dielectric Grease 08798-9001 3720976 White grease used to pack electrical connectors for moisture and corrosion protection.
      Moly 60 Paste 08734-0001 2963866 60% moly-grease formula that is recommended for gears, bearings, and other high pressure/high temperature applications.
      Molykote 44MA Call Dow Corning: (800) 248-2481 Moly grease used between the brake shoes and backing plate and on the ends of the shoes.
      Molykote MH62 08798-9012 4562187 Moly grease used to lubricate plastic-to-plastic contact.
      Molykote M77 (75-gram jar) 08798-9010 4503793 A high-molybdenum-content paste that polishes more than it lubricates. Use it on the back of brake pads and on brake shims.
      Power Steering Grease 08C35-B0534L 6009583 The only recommended power steering grease because of cold weather properties. Use only on steering racks.
      Super High Temp Urea Grease 08798-9002 3720984 Medium-viscosity grease used to lubricate parts with metal-to-metal and metal-to-plastic contact. It’s good for mainshaft splines and clutch pivot points.
      Continuously Variable Transmission (CVT) Fluid 08200-9006 5030119 The only CVT fluid specifically formulated for use in Honda CVTs.
      Automatic Transmission Fluid - Z1 08200-9001 6512628 The only ATF specifically formulated for use in Honda A/Ts. Don’t use any other ATF.
      Manual Transmission Fluid 08798-9031 4928271 The only MTF specifically formulated for use in Honda M/Ts. Don’t use any other MTF.
      Dual Pump Fluid 08200-9002 6512644 Use in the CR-V dual pump rear differential. The fluid helps reduce noise and wear.
      VTM-4 Differential Fluid 08200-9003 6512651 Use in vehicles equipped with an active torque rear differential. The fluid helps to reduce noise and wear.
      PAG Oil ND-8 38897-P0A-A01AH 4172474 Refrigerant oil used in A/C systems with Nippon Denso (ND) compressors.
      PAG Oil S10-X 38897-PR7-A01AH 4419347 Refrigerant oil used in A/C systems with Hadsys compressors.
      PAG Oil 38897-P13-A01AH 4172466 Refrigerant oil used in A/C systems with Sanden compressors.
      PAG Oil (Passport V6) 2-90188-301-0 4435996 Refrigerant oil used in Passport V6 A/C systems.
      PAG Oil (Passport L4) 2-90188-300-0 4435996 Refrigerant oil used in Passport L4 A/C systems.
      Sanden SE-10Y 38899-RCJ-A01 38899-RMC-A01 Refrigerant oil used in Civic and Accord Hybrid vehicles. Do not mix with any other refrigerant oils.
      Power Steering Fluid 08206-9002 4435996 Power steering fluid in all Honda vehicles except Passports.
      Water Pump Lubricant 08798-9005 4212049 When added to the coolant, this lubricant reduces noise caused by water pump bearings and seals.
      Lock Lube 08732-0010 6985634 A grease that’s safe to use in all types of locks: door, ignition, and trunk."
      Honda Service Bulletin 99-030 Feb 2007
      Honda CR-V B20Z 2001
        Надявам се това да е полезно и на други колеги. Аз когато се чудих за Хондата трудно успях да разбера какви са точно условиятa за включване на 4х4 системата на ЦРВ:
        http://www.honda.bg/files/crv%20tech.pdf
          Ето няколко полезни ръководства, за CR-V 2 генерация:
          http://www.crvclub.r...p_5v.htm#158830
          CR-V02 manual K20 K24 all regions zip
          http://japancars.ru/cat/honda/
          / HONDA-CR-V-IIг. -> 2.2 i-ctdi (N22A2) // HONDA-CR-V-IIIг. ->2.2 i-DTEC (N22B3)/
            Ето и още едно доста полезно ръководство:
            http://omanual.ru/Honda/CR-V/2/
              Ето и още едно полезно място за ръководства, за който го интересува:
              http://www.crvclub.ru/honda_crv_manual.htm
