BRONKO Explorer Ranger manual
  • BRONKO Explorer Ranger manual
    в архиве два мануала Bronko и Bronko2-Explorer-Ranger
    2003MaverickOwnersGuideRussian.pdf
    Ford_Bronco_elektrika.pdf
    BRONKO_Explorer_Ranger+manual.rar
    Последно редактирано от CHIMIK; 07-09-09, 21:45.
    ... и это пройдет.....
    Chevrolet Express G1500 2000 г. Ford Explorer 1994 г. Opel Kadett 1979 г. Voschod-2 1971 г. UNIMOG 1963 г.
    До: BRONKO Explorer Ranger manual
    DANA_30_35_44_60_manual.rar
    FORD_EXPLORER_1991_1999_manual.rar
      Выдержка из каталога подшипников TIMKEN.
      FORD TRUCK - LT TRUCK & LT SUV - Aerostar, Bronco II, Explorer, Ranger
      FRONT WHEEL
      2 W D
      2005-2002 Explorer
      Hub Assembly .....................................SP470200[2] 4 0
      2005-2001 Explorer Sport / Sport Trac
      Seal (Inner) ................................................91 50S[2]
      Set (Inner) .................................................. . SET5[2]
      Set (Outer) .................................................. SET2[2]
      2005-1995 Ranger
      2001-1995 Explorer
      1997-1990 Aerostar
      Seal (Inner) .................................................. 6815[2]
      Set (Inner) .................................................. . SET6[2]
      1994-1991 Explorer
      1994-1990 Ranger
      4 W D / A W D
      2005-2003 Explorer Sport / Sport Trac
      Hub Assembly .....................................SP450202[2]
      2005-2003 Ranger (4 Whl. ABS)
      Hub Assembly .....................................SP450203[2] 2 5
      2005-2002 Explorer (4 Whl. ABS)
      2005-2000 Ranger (Rr Whl. ABS)(w/o Auto
      Locking Hub)(From 6/22/2000)
      Hub Assembly .........................................515014[2]
      2002-2001 Explorer Sport / Sport Trac
      Hub Assembly .....................................SP450200[2] 4 0
      2002-2000 Ranger (ABS)(w/o Auto Locking
      Hub Assembly .....................................SP450201[2] 4 0
      Sensor Kit ...........................................SK45020 1[2] 1 6
      FRONT WHEEL (cont.)
      4WD/AWD (cont.)
      2001-1995 Explorer (5 Lug Whl.)(ABS)
      2000-1998 Ranger (4 Whl. ABS)(To
      6/21/2000)
      Hub Assembly .........................................515027[2]
      2000-1998 Ranger (Rr Whl. ABS)(To
      6/21/2000)
      Hub Assembly .........................................515026[2]
      1997-1990 Aerostar
      Hub Assembly .........................................515000[2]
      1997-1990 Bronco II, Ranger (Dana/Spicer
      28 Axle)
      Seal (Inner) ................................................83 12S[2]
      Set (Inner) ................................................. SET45[2]
      Set (Outer) ................................................ SET45[2]
      35 Axle)
      Seal (Inner) .................................................. 4250[2]
      Set (Inner) ................................................. SET37[2]
      Set (Outer) ................................................ SET37[2]
      1994-1991 Explorer
      REAR WHEEL
      2005-2002 Explorer (Ind Rr. Sus)
      Hub Assembly .................................. HA590259K[2] 6 8
      2005-2002 Explorer Sport, Sport Trac (w/o
      Ind. Rr. Sus.)
      Seal .................................................. ........8835S[2]
      Cylindrical Bearing .......................................6408[2]
      K it .................................................. TRP1559TV[2] 1 9
      2005-1998 Ranger (Elec.)
      S e t .................................................. ........ SET49[2]
      2005-1990 Ranger (8.8" R.G.)
      2005-1990 Ranger (7.5" R.G.)
      Seal .................................................. ........8660S[2]
      Cylindrical Bearing .......................................5707[2]
      K it ................................................TR P1563TAV[2] 1 9
      REAR WHEEL (cont.)
      2001-1990 Explorer (w/o Ind Rr. Sus)
      1997-1990 Aerostar (8.8" R.G.)
      1997-1990 Aerostar (7.5" R.G.)
      1990 Aerostar (Dana/Spicer 30 Axle)
      Seal .................................................. ..........2146[2]
      S e t .................................................. ..........SET9[2]
      1990 Bronco II
      4WD FRONT AXLE
      Axle Shaft
      2002 (Dana/Spicer 30 axle)
      Seal Viton ............................................... 710429[2]
      2001 Explorer
      Seal Viton (LH) .........................................710429
      Seal Viton (RH) ........................................ 710428
      2001-1995 (Dana/Spicer 35 axle)
      1997-1990 (Dana/Spicer 35IFS axle)
      Seal (LH) ................................................. 710043
      Seal (RH) .................................................4 70672
      Cylindrical Bearing (RH) .................................5707
      1997-1990 (Dana/Spicer 28IFS axle)
      Seal (LH) .................................................. ...3543
      Seal (RH) .................................................7 10065
      Differential Rebuild Kit
      2005-1990 (Dana/Spicer 35 axle)
      K i t .................................................. .......DRK335
      2003-2001 Explorer (Dana/Spicer Super 30
      axle)
      K i t .................................................. .....DRK334B
      1999-1990 (Dana/Spicer 28 axle)
      K i t .................................................. .......DRK333
      D i f f e r e n t i a l
      2005-2001 Ranger
      C o n e / C u p .......................... LM501349-LM501314[2]
      axle)
      2000-1990 (Dana/Spicer 35 axle)
      C o n e / C u p ..............................LM29749-LM29710[2]
      4WD FRONT AXLE
      P i n i o n
      2005-2001 Ranger
      Cone/Cup (Inner) ....................HM88648-HM88610
      Seal Viton ............................................... 714675
      C o n e / C u p .................................M86649-M86610
      axle)
      Cone/Cup (Inner) ....................HM88649-HM88610
      Cone/Cup (Outer) ....................... M86649-M86610
      Seal Viton (Outer) .....................................714675
      Cone/Cup (Inner) ........................ M88048-M88010
      Seal (Outer) .................................................4 244
      Spindle Kit
      Bearing & Seal Kit .......................................SBK4 3 6
      Bearing & Seal Kit .......................................SBK2 3 4
      S p i n d l e
      1997-1993 (Dana/Spicer 28IFS, 35IFS axle)
      Seal (Inner) ..............................................7104 53
      Needle Bearing (Inner) .................................B2110
      Seal (Outer) ............................................. 722108
      Needle Bearing Thrust ............................NTA1625
      Seal (Inner) ..............................................7221 09
      1992-1990 (Dana/Spicer 28IFS axle)
      Seal (Inner) ..............................................3408 35
      Needle Bearing (Inner) ...............................SCE188
      Seal (Outer) ...............................................831 4S
      REAR AXLE
      2005-1990 (7.5" R.G.)
      K i t .................................................. .......DRK315
      2005-1990 (8.8" R.G.)
      K i t .................................................. .......DRK311
      2003-1990 (Dana/Spicer 35 axle)
      2003-1990 (Dana/Spicer 28 axle)
      S e t .................................................. ........ SET36[2]
      REAR AXLE
      P i n i o n
      2005-1990 (7.5", 8.8" R.G.)
      Cone/Cup (Inner) .................... M802048-M802011
      Seal Viton (Outer) ........................................ 3604
      Cone/Cup (Outer) ....................... M88048-M88010
      _______________________________________________________
      КЛАСИФИКАТОР ПОДШИПНИКОВ
      http://www.podshipnik.ru/catalogue/classifier/
      РУССКИЕ ПОДШИПНИКИ
      http://www.rospodshipnik.ru/catalog/11.htm
      http://www.upodsh.ru/index.php/2009-09-16-08-22-44
      Последно редактирано от CHIMIK; 24-03-10, 21:10.
        Ford Pick-Ups & Bronco 1980-1995 Haynes.pdf
        usford 4R55E(4.0L), 5R55E(4.0L).pdf
        Chevy K5 m1009 cucv.pdf
