Загубен софтуер на GPS Guider PMP Player
  • Загубен софтуер на GPS Guider PMP Player
    Колеги може ли някой да ми помогне да подкарам това чудо - пробвах доста неща но се свършиха познанията ми...!
    Благодаря на всеки който се отзове.
    Марка и модел предполагам Китай - GPS Guider PMP Player
    Feature Specification
    4.3"TFT 65K real color touch screen, with speaker.
    Win CE 5.0 for OS. SD slot.
    USB 1.1 Full.
    Internal Flash ROM 64MB, Activesync.
    Supporting Audio(MP3, WMA, WAV) and Video(Avi, WMV, MPG, MP4, 3gp) playback function.
    Can also be use as Photo Viewer and book reader(TXT, CHM, PDF).
    1200mAH bulid-in Li-Polymer battery.
    Feature:
    Touchscreen
    No awkward buttons, you can learn how to operate it easily within 5 minutes.
    Turn-by-turn voice and visual guidance- Clear & accurate, provide detailed information of each turning point, make your driving safe.
    Multi Way-Point.
    You can configure up to nine? Top over? Points between start and final destination.
    Schematic Map of Inter-Crossing.
    Clear schematic illustration of each inter-crossing guarantees you to view it in advance, and keeps you on the right track to your destination.
    Track Logging.
    The logged information can be replayed or re-used for the subsequent trip.
    Multi-Functions.
    Besides navigation, it can also used as Video and Audio Player or Ebook Reader&Reciter, make you journey colorful.
    Recommend Categories
    Stadium Cups Printed Advertising Balloons Non Adhesive post its Cartoon Radio Swimwear GBA SP Accessories Light Up Drinking Glass Foil balloons Beveled Notepads Football Radio Greeting Cards Surfboard Flasks Bookmarks Posters Shower Radio STRAP WALLET Floor Clock Swimming goggles TV GAME Disposable Cups Bookmark Outdoor Fun Beach Lamp With Clock Radio Leather Crafts Rubber Frisbee Surfing Sword Gun Toys Plastic Mugs Cloisonne Book Mark Adhesive Post its Familiar Radio Balls Shot Glass Reading Lights Keychains & Keytags
    GPS Guider PMP Player Supplier, GPS Guider PMP Player Factory, GPS Guider PMP Player Distributor, GPS Guider PMP Player Exporter, GPS Guider PMP Player Manufacturer, wholesale GPS Guider PMP Player, GPS Guider PMP Player china, Custom-made GPS Guider PMP Player wholesale, Accept mixed orders of customized products, Provide OEM & ODM service.
    От: Загубен софтуер на GPS Guider PMP Player
    Дефинирай "подкарам". Не работи, искаш да го отключиш, да намериш карта за неговия софтуер ...
      SD картата беше блокирана не (работи), и немога да разбера с каква софт.навигация е у-то,то самото иначе си работи. Хубаво ше е да отключа Windowsa за да мога да си кача какъвто софт. искам Igo Primo , Garmin и тн.
        Оригинално трябва да е IGO2006+. Стара програма без подръжка вече. Най-добре ще върви IGO8. Програмата се стартира или с описване на пътя във файл shell.ini или със специфична директория. Трябва да се експериментира , аз лично не знам как е при този модел. Иначе има firmware за него ,ако се скапе:
          Лошото е че нито с актив синг нито с експлорер или CE командер мога да вляза в него. Незнам какъв път да напиша до exe-то.
            Разгледай първо добре менюто някъде в настройки дали не се задава коя програма да се стартира. Нещо от рода на NavPath.
            В прикрепения файл са най-често срещаните начини за стартиране на програмата. Копирай съдържанието на SD карта и натисни бутона Navigation (или както е при теб). Трябва да се стартира TotalComander. Отсяваш последователно докато разбереш кое е твойто.
            Код:
            # Папка Mobilenavigator, а в нея файл Mobilenavigator.exe
            # файл autorun.inf
            # файл GPSRUNFILE.txt
            # файл nav.ini
            # файл shell.ini
            # файл HBS.txt
            Последно редактирано от milstan; 15-12-10, 18:47.
              Mерси колега но не се получава.
              Направих всичко но не разпознава навиг. софт.
              Исписва Cannot find navigation software in SD Card.
              От настройки за навиг. има бутон само с отметка от SD ли да стартира или от Internal Flash.
                Пробвай с директория IGO > igopna.exe на SD картата.
                П.П. Предполагам , че горните файлове не си ги сложил в обща папка на SD kartata? Трябва да са директно на SD картата.
                П.П.П. Има вероятност SD картата да не се вижда от уреда с име SDMMC. Пробвай във всеки .ini файл промени редовете на \Windows\explorer.exe
                П.П. Като има избор на SD карта , чукни на нея и трябва да видиш директориите в нея. За целта естествено SD картата трябва да е в уреда.
                Последно редактирано от milstan; 16-12-10, 18:48.
                  Отново нищо.
                  Не съм чак без никакви познания към GPS sis-те но тоя просто....... ме разби.
                    Здрасти, Хобос!
                    Имам абсолютно същия проблем. Ако си намерил решение вече, би и го споделил? Вече ми иде да захвърля всичко
                      здравейте,
                      изчезна ми картата, не се вижда .Някой има ли идея?Някой може ли да помогне с firmware?
                        Първоначално публикуван от milstan Преглед на мнение
                        http://4pda.ru/forum/index.php?showt...0#entry2613432
                        Линка не работи.ърсих навсякаде, където се сетих, но уви, нищо не намерих._Има ли вариант да се намери firmware?
                        Последно редактирано от Pacific; 14-06-11, 15:46.
                          Линка работи , иска регистрация на сайта.
                            Регистрирах се но пак, ми дава "ошибка".якаква идея?_Какъв модел се води това чудо на техниката?
                            Последно редактирано от Pacific; 14-06-11, 15:44.
                              Моля за съдествие!!!
