Карти на Garmin за GSM? Може!
  • Карти на Garmin за GSM? Може!
    Става за:
    Nokia: 2610, 2626, 2630, 2760, 2855i, 2865, 2865i, 3155, 3155i, 3230, 3250, 3500, 5070, 5140, 5140i, 5200, 5300, 5310 XpressMusic, 5500, 6020, 6021, 6060, 6060v, 6061, 6070, 6080, 6085, 6086, 6101, 6102, 6102i, 6103, 6111, 6125, 6126, 6131, 6133, 6151, 6155, 6165, 6165i, 6170, 6230, 6230i, 6233, 6234, 6235, 6235i, 6255, 6255i, 6265, 6265i, 6267, 6270, 6275i, 6280, 6288, 6300, 6500c, 6500s, 6555, 6630, 6680, 6681, 6682, 6708, 6822, 7260, 7270, 7360, 7370, 7373, 7390, 7500, 7710, 8600 Luna, 8800 Sirocco, 9300, 9500, E50, E60, E61, E61i, E62, E65, E70, E90, N70, N71, N72, N73, N75, N77, N80-1, N90, N91, N92, N93, N93i, N95
    Sony-Ericsson: D750, D750i, F500i, J300a, J300i, K200i, K300, K300a, K300i, K310, K310a, K310i, K320i, K500i, K508, K508c, K508i, K510a, K510i, K530i, K550i, K600, K600i, K608i, K610, K610i, K618i, K700, K700c, K700i, K750, K750i, K790a, K790i, K800i, K800iv, K810i, K850i, M600i, P1i, P990i, S500i, S700, S700i, S710a, T250i, T650i, V600, V600i, V630i, W200a, W200i, W300, W300i, W550c, W550i, W580i, W600c, W600i, W660i, W700i, W710i, W800i, W810i, W810iv, W830i, W850i, W850iv, W880i, W900i, W910i, W950i, Z1010, Z300i, Z310i, Z310iv, Z500, Z500a, Z520a, Z520i, Z530i, Z550a, Z550i, Z558i, Z610i, Z710i, Z800
    До: Карти на Garmin за GSM? Може!
    Пробвано на 5310 Xpress Music - полуработещо състояние - закача се към блутут GPS ресивъра (HOLUX М1000) и получава координати, не може да показва картата - не му достига памет (когато се пусне фул скрийн казва няма достатъчно памет)
    Това е за варианта с външна карта (БГ ОФРМ) - External Maps installation:
    Create a folder named "mario" in your mobile's root filesystem (JSR75 needed) and copy Garmin IMG files. No previous conversion is needed. Mario Advisor will display map data and labels for roads, Points Of Interest and cities. Search capabilities are under development.
    по късно ще пробвам Internal варианта - Internal Maps installation:
    Maps can also be stored inside the Jar file, to avoid the confirmation request every time a file is accessed. To do so, copy maps in the "maps" folder inside the Jar, and update the file "map_list.txt" with the names of the files included. Check your mobile can intall the new Jar, since midlet size will be bigger.
      за съжаление с 5310 не се получават нещата и с интърнал варианта - когато включа .img файла по описания начин се получава около 8MB .jar - който не може да се инсталира на телефона. Ако някой може да пробва на друг телефон.... ще се опитам утре на nokia 6500.
        Имам Нокия 3110, инсталирах програмката не е в телефона, а в карта. Пробвах без Блутут - работи.
          пробвах на SE K550i - с external карти - работи прилично (като скорост) ... НО, програмката не е sign-ата а всеки път когато се опита та чете от карата, телефона ми иска позволение ... много досадно е и в същност това я прави неизползваема ... ще наблюдавам с интерес и когато се появи 'официална' версия ще я пробвам пак ...
          LR Disco II, Td5
            Опитах да я кача на к810, но .... нещо с отключването на картите май ми се изплъзва ... Може ли малко хелп как да кача и унл файла?
              незнам какво е УНЛ - направих фолдер mario и сложих там няколко IMG файла от BGTopoMaps, после .., в Settings има опция 'external folder' от където избрах change и избрах същия фолдер (изписа ми file://localhost/e:/mario/ като стойност - това е ... но всеки път когато генерира карта и му трябва досъп до img файловете - пита за разрешение - писах на разработ4кита да пусне sign-ата версия на програмката, но ни вест, ни кост от него ...
              LR Disco II, Td5
                на SE к800i ми заявява - приложението изисква повече памет и дотам
                с екстернал варианта
                за интернал - не разбрах какво, как и къде се поставя
                а имам SD card 1 GB , явно не става въпрос за нея, ама как да разчистя оперативна памет????
                  В СЕ к810 работи идеално, чакам нова версия с работеща търсачка))
                    n80- работи идеално мерси
                    LZ1FMD
                      Първоначално публикуван от ficafica Преглед на мнение
                      на n80 ХТ-то не работи ли?
                      Светът на Владо
                        za nokia n 82 stava li
                          Първоначално публикуван от byrbana Преглед на мнение
                          Много ясно
                          Светът на Владо
                            е не мога да го подкарам и това си е ...
                            СЕ к800i
                            Кажете къде бъркам, защото се амбицирах и като не става....
                            от МапСорса си генерирам gmapsupp.img файл на БГТопо Мапс ~ 30 к
                            файла го добавям в папка Мапс на jar архива - точно до файла world.img
                            променям съдържанието на map_list.txt, като добавям и gmapsupp.img в него
                            затварям архива
                            обема му се увеличава съответно - явно всичко е станало
                            стартирам
                            само световната карта....
                            изтрих я.
                            няма карти, беше отговора от апарата
                            преименувах gmapsupp.img на world.img
                            редактирах map_list.txt
                            затварям, стартирам...
                            няма карти...
                            пробвам с gmapsupp.img като външен файл, анонсирам му нахождението в телефона - резултата е същия - картата я няма
                            дали някой няма да ми помогне, като ме насочи къде бъркам?
                            Предварително благодаря
                              Играхме си с един колега със същия телефон - никакъв резултат. Май само по едно време продума нещо от сорта "not enough memory...".
                              Отказахме се .
                              Ако някой е успял с този модел, да се похвали .
                              Животът се мери не с броя вдишвания, а с моментите които спират дъха
                              GARMIN nuviCam LMT, GARMIN nuvi 200
