Tatra T813
  • Tatra T813
    History
    The first prototype already built in 1960 utilized existing Tatra T138 assemblies in 4x4 full time all wheel drive, which was also another first for Tatra. After the initial trials however the designers decided to develop and expand the concepts onto 8x8 all wheel drive all terain vehicle. The basis of the design thus became modular chassis of T813.
    Design and Technology
    The tubular backbone construction was once again selected. The main advantages of central load carrying backbone tube are in its high torsion and bend strength protecting truck body against load stresses. The advantage is also that it houses all important parts of the drive train as well as it enables a concept of modular construction where designers and customers can specify 4,6,8, wheel drive and various length wheelbase combinations. The new cab of COE design was implemented as were the wide profile super single tyres and central tyre inflation /deflation system.
    Engine
    The "monstrous" naturally aspirated V12 T-930 was created by adding extra four cylinders to the existing T-928 75 degree V8 engine used in TatraT138. The crankshaft consisted of six individual journals bolted together with front and rear pins all running on the main roller bearings and located on axial friction thrust washers. The military version was once again multi-fuel capable, running on mixtures of diesel fuel, petrol and aviation kerosine fuel.
    T 930-xx E
    Engine T813
    Manifacturer Tatra
    Also called:T 930 E
    Type:V12 diesel
    Bore:120 mm (4.7 in)
    Displacement:17,640 cc
    Dry weight:1,035 kg (2,282 lb)
    Block alloy:Cast iron
    Head alloy:Aluminium alloy
    Valvetrain:OHV
    Fuel system: Direct injection
    Fuel type: Diesel fuel
    Cooling system:Aircooled
    Power output:198.6 kW (266 hp) @ 2000 rpm
    Torque output:990 N·m (730 ft·lbf) @ 1300 rpm
    Compression ratio:16.5:1
    Fuel consumption:44 L/100 km (6.4 mpg imp/5.3 mpg US)
    Chassis
    Full length backbone tube with independent swing half axles in 4x4, 6x6 and 8x8. On 4x4 models front axle suspension via adjustable torsion bars , 6x6 and 8x8 models front and rear axles suspended by longitudinal semi-elliptic leaf springs. For 4x4 configuration rear axle was suspended via the airbags suspension. Full time all wheel drive front twin steer (6x6, 8x 8 drive via homo-kinetic drive shafts, drive with the differential locks ,inter-axle differentials with locks and planetary hub reductions on all models.
    • Front track
      2050 mm (KOLOS)
      1990 mm (6x6 Hauler, S1, 8x8 Chassis)
      2300 mm (NT, NTH Prime movers)
    • Rear track
      2000 mm (8x8 KOLOS)
      1950 mm (6x6 Hauler, 8x8 Chassis, S 1)
      1990 mm (NT, NTH Prime movers)
    • Wheelbase
      T813 KOLOS - 1650+2200+1450 mm
      6x6 Hauler - 1650+2700 mm
      8x8 Chassis - 1650+3200+1450 mm
      S1 8x8 - 1650+2800+1450 mm
      NT, NTH 4x4 - 3700 mm
    • Ground clearance
      380 mm (KOLOS, 6x6 Hauler)
      330 mm (8x8 Chassis, S1 8x 8
      300 mm (NT, NTH Prime Movers)
    Transmission
    The main gearbox was located behind the cabin and connected to an engine clutch housing via short cardan shaft( this design enables a so called flat floor cabin) was bolted together with an auxiliary gearbox to a transfer case and then to a backbone tube and formed main part of a chassis structure. Options for the rear power take off and or a winch drive were available. Main and auxiliary gears were fully synchronized except the first and reverse gear. The new feature was unique 2 speed planetary overdrive system bolted between front and rear axles. The overdrive could only be selected manually whilst stationary. Auxiliary gearbox had a neutral position which allowed a winch and a power take off to use main gearbox gearing for variable speed operation. The final drives used Tatra gear differentials with locks, offset drive shafts and planetary hub reductions.
    • Main gearbox - 5+1 (2-5 gear synchronized) (KOLOS 8x8 & Hauler 6x6)
      gear ratios - (1)9.97, (2)4.96, (3)2.83, (4)1.68, (5)1.0, (R)8.58
    • Main gearbox - 5+1 (2-5 gear synchronized) with splitter direct and overdrive (S1 8x8, Chassis 8x8,NT & NTH 4x4)
      splitter ratios - 1.0 (Direct) , 0.75 (Overdrive) (electro-pneumatic control via switch on the gear lever and clutch pedal activated )
    • Auxiliary gearbox - 2 speed (electro-pneumatic control via switch on the gear lever and clutch pedal activated )
      gear ratios - 2.2, 1.62 (KOLOS & Hauler 6x6)
    • Step down transfer case - single
      gear ratio - 1.68 (S1 8x8, Chassis 8x8, NT & NTH 4x4 only)
    • Planetary overdrive
      ratios - 1.0 , 0.62 (KOLOS 8x8 & Hauler 6x6 only)
    • Clutch - 3x plate dry (clutch pedal hydraulic and air power assisted) - 2x plate dry (clutch pedal hydraulic and air power assisted) (NT & NTH 4x4 only)
    • Differentials
      2x front and 2x rear (8x8 models)
      2x front and 1x rear (6x6 models)
      1x front and 1x rear (4x4 models)
      final drive
      ratios - 2.71
    • Planetary hub reductions
      ratios- 2.14 (KOLOS 8x 8, 2,12 (Hauler 6x6 & S1 8x 8
    Brakes
    Full triple circuit air "S" cam drum brakes acting on all wheels drums via slack adjuster, all brake cylinders were remotely vented. First brake circuit acts on front wheels , the second on rear wheels and the third controls trailer service brakes. Unique design feature was remotely mounted brake valve which was operated via hydraulic master and slave cylinder principle on the Hauler 6x6 or via mechanical linkage on 8x8 models.
    • Main wheel brakes ----> dual circuit drum brakes "S" cam type
    • Park brake ----> mechanical via output shaft at the back of the gearbox
    • Supplementary brake ----> exhaust brake electro-pneumatically controlled
    Bodywork
    Cabin is all steel construction of COE design but not tiltable, the access to the engine was provided via removable engine cowlings inside the cabin compartment. The cab came in two versions, the "short" two seater two door version and in the "long" "crew cab" seven seater four door version. The military specs cabs included the roof hatch or two in the case of the crew cab. All cabs were equipped with self contained diesel cab heater which could also be used in the winter to warm up the engine before starting it. Another military feature was CTI central tyre inflation system controlled from the cab for each wheel independently and an ability to pressurize gearbox and differentials housing during water crossing. The 8x8 models had abilility to cross trenches up to 1.4 metre wide and vertical obstacles up to 0.6 metre high. Water crossing depth (static including the wave) was up to 1.4 metre (KOLOS 8x 8. The vehicle top speed was 92 km/h (NT & NTH), 80 km/h (KOLOS), 70 km/h (hauler), 60 km/h (S1) @ 2000 engine rpm.
    • Vehicles Weights
      Tare - 14,000 kg (KOLOS 8x 8, 21,050 kg (Hauler 6x6), 11,200 kg (Chassis 8x 8, 15,000 kg (S1 8x 8, 7,000 kg (NT & NTH 4x4)
      GVM - 22,200 kg(KOLOS 8x 8, 22,000 kg (Hauler 6x6), 36,000 kg (Chassis 8x 8, 36,000 kg (S1 8x 8,
      Max Trailer Mass - 65,000 kg (KOLOS 8x 8, 100,000 kg (Hauler 6x6), 32,000 kg (NT & NTH 4x4
      GCM - 79,000 kg (KOLOS 8x 8, 121,050 kg (Hauler 6x6), 39,000 kg (NT & NTH 4x4)
    Production
    Production of Tatra T813 began in 1967 and was superseded by Tatra T815 in 1982. Models were available in the 4x4, 6x6, and 8x8 drive configurations for civilian and military use.
    • Primary models
      Tatra T813 "KOLOS" 8x8 - Military heavy haulage
      Tatra T813 Hauler 6x6 - Civilian heavy haulage
      Tatra T813 S1 8x8 - Heavy one way tipper
      Tatra T813 Cab-chassis 8x8 - Bodybuilders chassis for special use
      Tatra T813 NT & NTH 4x4 - Prime movers and special applications
    Crane 4x4
    Aiport tug T813 6x6
    T813 Hauler
    Fire 8x8
    KOLOS 8x8
    T813 Rocket launcher chassis RM70
    RM-70 MRL
    T813 6x6
    До: TatraT813
    Аз се чудя колко може да струва и от каде се купува такова чудо, нещо никаде нищо не намирам освен Т815 в мобиле.бг...
      До: TatraT813
      в mobile.de дори няма татра като опция
      иначе в ebay продават снимка на 813-ка...за 3;50$
      а аз тъй и не мога да забравя чудовищните оранжеви влекачи от едно друго време, дето мъкнеха товари по "намколкоси" тонове...
      ...една забравена легенда
        До: TatraT813
        Tatra T-813 8x8 military prototype testing:
        http://www.youtube.com/watch?v=4EYjV...related&search=
          До: TatraT813
          Ами вчера доста рових, има много и най-различни татри от евро 1 до евро 5, ставащи все по-ниски. Конкретно тази 813-ка е доста кът, а в България се предлагат предимно 815-ки, със 3 и 4 оси. Производителят дава много интересне показател, при примерно 40 тона % на възможностите за катерене и при над 55 тона пак
          Ето спецификации http://www.tatra.cz/en/akt_vyrpr_en.asp
          След евро 3 стават доста по-ниски, това /най-високата/ http://partners.tatra.cz/exter_pr/vp...d=454&jazyk=AN сякаш ми допада най-много.
            До: TatraT813
            Колеги, като си купите Татра можете да се обадите- продавам ризи и бутала за тях.
            Навремето по Евроспорт даваха доста траяли по офф роад и Татрите бяха едни от водещите.Другото което съм запомнил са Уралите.А Татра и досега се кара доста в Чехия, Словакия ,Русия и Китай.Навремето даже там ги произвеждаха.
              До: TatraT813
              Имаше и няколко години на Париж-Дакар, в които се представиха добре.
              Обаче руските пилоти са по откачени, та ги поизместиха. Не помня точно името - имаше тема някъде из форума, с един руснак, всъщност доста известен, който, като го гледах, ми беше трудно да си прибера висящото чене.
              А траялите по EuroSport са си класика. И аз ги гледах с голям интерес и наслада.
                До: TatraT813
                Чехът се казва Лопарис, мисля. А руснакът с КамАЗа Чагин
                Танки грязи не боятся!
                  До: TatraT813
                  Чагин. Точно. Тоя не е човек!
                    До: TatraT813
                    E аз редовно си пускам клипчета с Чагин, има доста в йотуб-а, но ако искаш нещо проходимо, носещо много тонове, татра с 8 търкала, е много по-подходяща от камаз или дори урал с 2 или 3 оси. Има и 3осни татри, но просто 4-те оси са нещо друго, а татрата ако наистина може да носи 42 тона, незнам просото...
                      До: TatraT813
                      Просто КамАЗите и Уралите са друг клас. Когато става дума за многоосни шасита се намесва МАЗ и МЗКТ.
                        До: TatraT813
                        Ето и едно клипче на Татра Т816, което много ми харесва.
                        http://vbox7.com/play:6aeaa480
                        '05 Suzuki RM 250
                          До: TatraT813
                          Тези по ми харесват
                          http://www.youtube.com/watch?v=mq5mMVd3p1E
                          http://www.youtube.com/watch?v=vVuub...eature=related
                          http://www.youtube.com/watch?v=mwYSw...eature=related
                          http://www.youtube.com/watch?v=dVj22...eature=related
                          Случайни хора УАЗ не карат
                            До: TatraT813
                            Има и 3осни татри,
                            Аз имам 4 броя
                            Three witches watch three Swatch watches.
                            Which witch watch which Swatch watch?
                              До: TatraT813
                              Първоначално публикуван от sergej Преглед на мнение
                              Има и 3осни татри,
                              Аз имам 4 броя
                              Кой си ти и верно ли си от Лозен
